Old 26th April 2019, 11:21   #6181  |  Link
fzok4234
MPC-BE cannot play nested playlist.
I created the m3u playlist containing another playlist's path like the following.
dir\sub1.m3u
dir\sub2.m3u
dir\sub3.m3u
I tried to play this playlist. But MPC-BE Cannot play media files contained in sub1.m3u, sub2.m3u, sub3.m3u.
OS: Windows 10 Pro x64 1809
MPC-BE: 1.5.3 (build 4456) beta
fzok4234 is offline   Reply With Quote
Old 26th April 2019, 15:33   #6182  |  Link
Aleksoid1978
Aleksoid1978's Avatar
dir\sub1.m3u
dir\sub2.m3u
dir\sub3.m3u
Open only one playlist.
Old 26th April 2019, 17:10   #6183  |  Link
fzok4234
MPC-BE can play each sub m3u playlist individually.
And I just noticed that the root playlist has only one line, it work just as I intended.
root.m3u :
dir\sub1.m3u
I have a lot of such nested playlists and MPC-HC or previous versions MPC-BE (1.5.1) can play them. But after I upadted MPC-BE to 1.5.3 4456, the symptom began to occur.
Last edited by fzok4234; 26th April 2019 at 18:22. Reason: more detail description
Old 26th April 2019, 19:05   #6184  |  Link
steakhutzeee
steakhutzeee's Avatar
Hi
Updated to 1.5.4 (build 4521) beta, i use madvr and lav filters. Every time i'm in full screen and i right click, i see the screen flashing black one time.
How can i avoid this? In madvr settings i have the delay switch to exclusive mode disabled. With a previous version of mpc be i had no issue like this.
Thanks in advance!
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM
steakhutzeee is offline   Reply With Quote
Old 28th April 2019, 09:14   #6185  |  Link
v0lt
Which latest version has no problem?
Old 28th April 2019, 09:16   #6186  |  Link
steakhutzeee
Don't remember, it was 41xx if I'm not wrong.
Old 28th April 2019, 10:41   #6187  |  Link
Klaus1189
You can try first r4100 if it is still fine, perhaps any other change like driver update is the culprit.
Then you try r4300 for searching the possible changed revision and its commit.
If 4100 is fine and 4300 is not fine, the possible change was between 4100 and 4300. Then pick 4200 and check.
If 4100 and 4300 is fine, the possible change was between 4300 and 4521. Then pick 4400 and check.
Then go on. I‘ve done this already in my MPC-HC time before MPC-BE was created.
Old 28th April 2019, 11:55   #6188  |  Link
v0lt
I suggest to check 1.5.3.4373.
Old 28th April 2019, 12:37   #6189  |  Link
Aleksoid1978
In r4382 prevent parse .m3u from .m3u, but working only if .m3u have one entry with other .m3u
Old 28th April 2019, 20:37   #6190  |  Link
peter0815x
hi
and sorry for interrupt
i have a small dvd problem.
mpc be will feeze with some dvds for about 10 sec before playing the movie.
the good news i guess i know what causes the issue.
question how to solve it :-)
the problem happens only with mpc audio render
NOT with directsound system default render.
(i use mpc audio render to use wasapi output to play dvd movies with 48khz frequency)
here the problem :
when i use mpc audio render and i play some dvds and i press "start" in the dvd menu
mpc be will freeze for about 10 sec before playing the movie.
then dvd plays normal without issues.
i tested several dvds.
i guess i found the problem:
mpc be will freeze for about 10 sec ONLY when the dvds have no audio output during intro and menu.
dvds which have sound during intro or dvd menu will not freeze when i press start in the menu.
hope u understand the problem :-)
when i use mpc audio render and i play dvds which will have no audio output during intro and menu
when i play dvds which will have sound during intro or menu
playback of the movie will start immediately when i press start in dvd menu.
when i use direct sound audio render all dvds no matter if they have sound during intro and menu or not will start immediately.
changing wasapi from exclusive to shared and changing buffer default or 50 ms or 100ms had no effect on the problem.
playing other movies like mkv, mp4 etc. with 48khz have no freezing problem with mpc audio render
only dvds when they have no audio during intro or menu will cause the 10 sec freeze.
(a log window like vlc has would be good to see what mpc be is doing during the 10 sec freeze)
peter0815x is offline   Reply With Quote
Old 28th April 2019, 21:54   #6191  |  Link
Aleksoid1978
Upload small DVD and i check.
Old 29th April 2019, 00:50   #6193  |  Link
Aleksoid1978
No-no, it's very bad and slow.
Old 29th April 2019, 00:56   #6194  |  Link
peter0815x
okidoki
which file hoster should i use ?
(in the past i used zippyshare but seems its down)
i ll reupload the dvd
i found another problem :-)
i have a mp4 video which is played in wrong format
instead of 16:9 it looks like 3:9
from over 1000+ files its the only one with that problem
but other players play it correct.
may be u want to take a look at this as well.
Old 29th April 2019, 01:23   #6195  |  Link
Aleksoid1978
dir\sub1.m3u
dir\sub2.m3u
dir\sub3.m3u
Try this build - https://yadi.sk/d/J-eqOd72Clu64g
Old 29th April 2019, 01:24   #6196  |  Link
Aleksoid1978
Originally Posted by peter0815x View Post
okidoki
1 - zippyshare is working. Or you can google drive.
2 - upload problem .mp4 - i look.
Old 29th April 2019, 07:59   #6197  |  Link
Schattenspieler
Na, they're just blocking IP adresses from UK and germany vor now. Using a proxy or VPN it's still accessable. But you should probably still use another OCH.
Schattenspieler is offline   Reply With Quote
Old 29th April 2019, 12:20   #6198  |  Link
fzok4234
Originally Posted by Aleksoid1978 View Post
Thanks. This build worked just as I intended.
Old 29th April 2019, 13:00   #6199  |  Link
fzok4234
By the way I tested another playlist formats.
1: root.asx
<ASX Version = "3.0">
	<Title>Test</Title>
	<Entry><Ref href="sub1.asx"></Ref></Entry>
	<Entry><Ref href="sub2.asx"></Ref></Entry>
	<Entry><Ref href="sub1.m3u"></Ref></Entry>
	<Entry><Ref href="sub2.m3u"></Ref></Entry>
	<Entry><Ref href="sub1.m3u8"></Ref></Entry>
	<Entry><Ref href="sub2.m3u8"></Ref></Entry>
	<Entry><Ref href="sub1.mpcpl"></Ref></Entry>
	<Entry><Ref href="sub2.mpcpl"></Ref></Entry>
	<Entry><Ref href="sub1.pls"></Ref></Entry>
	<Entry><Ref href="sub2.pls"></Ref></Entry>
	<Entry><Ref href="sub1.wpl"></Ref></Entry>
	<Entry><Ref href="sub2.wpl"></Ref></Entry>
	<Entry><Ref href="sub1.xspf"></Ref></Entry>
	<Entry><Ref href="sub2.xspf"></Ref></Entry>
</ASX>
All sub playlists were not played.
2: root.m3u
sub1.asx
sub2.asx
sub1.m3u
sub2.m3u
sub1.m3u8
sub2.m3u8
sub1.mpcpl
sub2.mpcpl
sub1.pls
sub2.pls
sub1.wpl
sub2.wpl
sub1.xspf
sub2.xspf
Only sub1.m3u, sub2.m3u, sub1.m3u8, sub2.m3u8 were played.
3: root.m3u8
sub1.asx
sub2.asx
sub1.m3u
sub2.m3u
sub1.m3u8
sub2.m3u8
sub1.mpcpl
sub2.mpcpl
sub1.pls
sub2.pls
sub1.wpl
sub2.wpl
sub1.xspf
sub2.xspf
4: root.mpcpl
MPCPLAYLIST
1,type,0
1,filename,sub1.asx
2,type,0
2,filename,sub2.asx
3,type,0
3,filename,sub1.m3u
4,type,0
4,filename,sub2.m3u
5,type,0
5,filename,sub1.m3u8
6,type,0
6,filename,sub2.m3u8
7,type,0
7,filename,sub1.mpcpl
8,type,0
8,filename,sub2.mpcpl
9,type,0
9,filename,sub1.pls
10,type,0
10,filename,sub2.pls
11,type,0
11,filename,sub1.wpl
12,type,0
12,filename,sub2.wpl
13,type,0
13,filename,sub1.xspf
14,type,0
14,filename,sub2.xspf
5: root.pls
[playlist]
File0=sub1.asx
File1=sub2.asx
File2=sub1.m3u
File3=sub2.m3u
File4=sub1.m3u8
File5=sub2.m3u8
File6=sub1.mpcpl
File7=sub2.mpcpl
File8=sub1.pls
File9=sub2.pls
File10=sub1.wpl
File11=sub2.wpl
File12=sub1.xspf
File13=sub2.xspf
NumberOfEntries=14
Version=2
6: root.wpl
<?wpl version="1.0"?>
<smil>
	<head>
		<title>Test</title>
	</head>
	<body>
		<seq>
			<media src="sub1.asx"></media>
			<media src="sub2.asx"></media>
			<media src="sub1.m3u"></media>
			<media src="sub2.m3u"></media>
			<media src="sub1.m3u8"></media>
			<media src="sub2.m3u8"></media>
			<media src="sub1.mpcpl"></media>
			<media src="sub2.mpcpl"></media>
			<media src="sub1.pls"></media>
			<media src="sub2.pls"></media>
			<media src="sub1.wpl"></media>
			<media src="sub2.wpl"></media>
			<media src="sub1.xspf"></media>
			<media src="sub2.xspf"></media>
		</seq>
	</body>
</smil>
7: root.xspf
<?xml version="1.0" encoding="UTF-8"?>
<playlist version="1" xmlns="http://xspf.org/ns/0/">
	<title>Root Playlist</title>
	<creator>Test Artist</creator>
	<trackList>
		<track><location>sub1.asx</location></track>
		<track><location>sub2.asx</location></track>
		<track><location>sub1.m3u</location></track>
		<track><location>sub2.m3u</location></track>
		<track><location>sub1.m3u8</location></track>
		<track><location>sub2.m3u8</location></track>
		<track><location>sub1.mpcpl</location></track>
		<track><location>sub2.mpcpl</location></track>
		<track><location>sub1.pls</location></track>
		<track><location>sub2.pls</location></track>
		<track><location>sub1.wpl</location></track>
		<track><location>sub2.wpl</location></track>
		<track><location>sub1.xspf</location></track>
		<track><location>sub2.xspf</location></track>
	</trackList>
</playlist>
In summary, only .m3u/.m3u8 -> .m3u/.m3u8 patterns worked exactly. I want MPC-BE to parse all patterns of playlists.
Old 29th April 2019, 13:18   #6200  |  Link
Aleksoid1978
fzok4234
Why ??
