27th October 2014, 11:42 | #341 | Link |
MkvToMp4 author
Fixed iTunes search: https://dl.dropboxusercontent.com/u/..._exe_fixed.zip
27th October 2014, 14:20 | #342 | Link | |
I've this error and the video-audio is out of sync
19th February 2015, 03:05 | #344 | Link |
I'm thinking no way to do this, however is there a way to do a lossless MP4 conversion with mkvtomp4 when it needs to reencode? Since it has vbr/cbr settings hard coded when editing a profile tried adding --qp 0 in the manual settings box but errored and the entry was automatically removed.
25th February 2015, 20:42 | #345 | Link | ||
Oreons, would you be able to look further into the 2 issues above? Much obliged, Visor |
13th April 2015, 21:00 | #347 | Link | |
Also, here's a tip for those of you who found that random episodes won't import into iTunes: when you edit the tags for each episode, try unchecking the "ContentID" and "XID" options. This will clear out these codes (which can confuse iTunes, especially if you're in a different country) and you should hopefully be able to see all the episodes when importing. |
15th April 2015, 06:40 | #348 | Link |
Not sure why but the covers started working again. Another slight problem and I'm not sure how to fix. Why would the audio encoder add 1000 plus ms to a video? The video in question runs fine (mkv) but after I use this program the audio is out of sync. Only happens one one film and to my knowledge it's never happened before. I've double checked the file and there's no errors with it. Thanks for any help |
18th August 2015, 21:53 | #352 | Link | |
All tools have been updated as of 08-18-2015 Code:
https://www.mediafire.com/?29kwnmrpt2r5qfx Last edited by Mr. Monte; 18th August 2015 at 22:58. |
2nd September 2015, 16:16 | #353 | Link |
I believe this to be true. The software's author (Oreons) seems to participate more often on his videohelp.com forum, and in one of his latest responses (from Nov. 2014) he said the following:
"Now I have time only for bug fixes " The latest "bug" that I've observed is that when I upgraded to Windows 10, artwork no longer showed up for any of my searches. I downgraded back to Windows 7 and the artwork returned. This is something that I'll post in the videohelp forum, and hopefully Oreons will be able to find the time to address this. Last edited by Visor; 2nd September 2015 at 16:31. |
15th September 2015, 11:45 | #354 | Link | |
Does the developer still check these forums? Because there are several issues with Windows 10 and with the new HEVC format, which is not supported but videos are starting to pop up using it. |
15th September 2015, 22:13 | #355 | Link |
Unsure, I for one don't "plan" to move to H265 (HEVC) until Western Digital or someone comes out with a good video player that plays movies from a external USB port and supports MKV, ISO formats.
I own 3 WDTV Lives..one of the best...if you ask me |
18th October 2015, 12:07 | #357 | Link |
For me program is obsolete. Probably not live to see a new version.
Convert MP4 to Matroska I understand the use, but Matroska to conteiner MP4 is nonsense. It should be Matroska VP8/VP9/H264/H265/PCM/AC3/AAC to MOV, but that is my opinion. Reflection on the theme covers, pictures, artwork, add-item, attachment, font described at the forum.filmowiec.pl and conversion should be done manually. The reason is simple. Very often the programs are updated, but it doesn't always work correctly. These additives aren't interactive because video players don't support photo formats. Subtitles ASS are still treated as pirated. It doesn't support this Windows 10 or Cyberlink PowerDirector 14. I will probably never be implemented. Last edited by Jamaika; 18th October 2015 at 12:10. |
19th October 2016, 21:15 | #359 | Link | |
Does anyone know how I can take some mkv files I've created and switch them to mp4... while keeping the subtitles?? |
24th January 2017, 02:16 | #360 | Link | |||
Matroska / MKV containers, while much more robust, are open-source, with standards set outside of the MPEG group. Since media companies are not fond of unregulated technology (including lack of DRM), they generally avoid it for these reasons. Since my wife and I own an assortment of iPads and Apple TVs, it makes sense to build an MP4 collection that supplements our MKV collection where needed. P.S. I'm aware that there are apps out there that allow you to remux MKV files on the fly for iPads, iPhones, etc., but they tend to drain the devices' batteries rather quickly, and don't exactly have perfect output (e.g. NPlayer drops a frame once every 10 seconds). Quote:
Regards, Visor Last edited by Visor; 24th January 2017 at 02:21. |
mkv, mkvtomp4, mp4, repack, video |
