10th November 2020, 08:48 | #15041 | Link |
This is a "Frequently Asked Question". One reply here: No worries.
11th November 2020, 12:14 | #15044 | Link |
Tested the latest libFLAC v.1.3.3.git-ce6dd6b5 for win32 (in RareWares) and work fine with eac3to.
28th November 2020, 20:16 | #15045 | Link | |
Hello,
I was struggling today with eac3to errors during conversion. Initially thought the files were corrupt but had no issues when using other tools. Finally I found out it was because of accented characters. Using the last version of eac3to (3.34) in windows 10 CMD. Quote:
Anyone has faced such issues? Last edited by vkostas; 28th November 2020 at 22:18. Reason: amend text in quote box |
29th November 2020, 01:18 | #15046 | Link | |
Work fine here:
15th December 2020, 22:53 | #15048 | Link |
Big Bit Savings Now !
DGDemux is your friend.
17th December 2020, 16:20 | #15049 | Link |
Hi everybody, I need a little help. I try to convert a DTS-HD Master to "simple" DTS so my soundbar could do the job in passthrough.
Actually my source is: Audio Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Bit rate mode : Variable Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossless I try using Megui with "HD Stream extractor" and specify DTS instead DTS_CORE but when I check the generated file it have the same properties of above. I try using "USEac3To GUI", I don't know if I have checked to good option but the generated file have same properties of the source. Is someone can help me to convert DTS-HD Master 5.1 file to "simple" DTS ? Thanks |
4th January 2021, 13:07 | #15052 | Link | |
Force eac3to to Silent Mode
4th January 2021, 18:18 | #15053 | Link |
@user8235
Welcome to Doom9's forum. [EDIT] The answer was in next post: (some other off topic posts deleted)
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 7th January 2021 at 15:51. Reason: moderated |
7th January 2021, 23:22 | #15054 | Link |
I've been looking all over the forum and in the internet. How to use eac3to via powershell? I want to use the qaac codec and using UsEac3to (what I've been using for years) the command line output would be:
"eac3to.exe path" "input mkv path" tracknumber: stdout.wav delayapplied video frame rate frame rate change -progressnumbers -log = "file.mkv_Job_n.log" | "qaac.exe path" -V n --ignorelength --adts --no-delay -o "fileoutput.mkv_0lang.aac" - I've tried to do something like: Code:
$convert_eac3to = -join ($moviefile, " ", $numbertrack, ": stdout.wav ", $frameratechange, " -log = 'logfile path' ", $qaac_path, " -V ", $audioquality, " --ignorelength --adts --no-delay -o ", $audiooutput) How would be the code? I guess @stax76 knows the answer as he looks almost the only one "fighting" for using Powershell. ^^ Thanks EDIT I've tried to understand much better the behavior of the command and I've tried to adapt it to Powershell, but it's not my lucky day. Code:
& $eac3to $moviefile $numbertrack $stdout $timedelay $frameratechange > $qaac_path $audiooutput -v $audioquality --ignorelength --adts --no-delay $moviefile: movie.mkv with path $stdout: stdout.wav with same path as moviefile $timedelay: i.e. +340ms $frameratechange: i.e. -24.000 -changeTo23.976 $qaac_path: qaac.exe with path $audiooutput: i.e. movie.2spa.aac $audioquality i.e. 99 Last edited by Harrenkyym; 8th January 2021 at 03:18. |
8th January 2021, 11:44 | #15055 | Link |
Sometimes it's necessary to call cmd from powershell:
1. using built in cmd functionality like mklink (powershell 5 has New-Item for symlinks) 2. certain kind of pipe I've never researched the reason of the pipe problem, but I know how to call cmd from powershell, have a look at /s /c in the cmd console help: cmd /? If this does not work then you might additionally need a stop parsing command: --% https://docs.microsoft.com/en-us/pow...powershell-5.1 Some of these ideas are originally from qyot27 btw.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 8th January 2021 at 12:22. |
8th January 2021, 23:41 | #15056 | Link |
$eac3toPath = "C:\path\to\eac3to\eac3to.exe" $input = "D:\" $chapterTrackNumber = 1 $videoTrackNumber = 2 $audioTrackNumber = 3 $audioFormat = "flac" & ${eac3toPath} "$input" ${chapterTrackNumber}: "Z:\temp.txt" ${videoTrackNumber}: "Z:\temp.mkv" ${audioTrackNumber}: "Z:\temp.$audioFormat" -log=nul > $null |
9th January 2021, 00:19 | #15057 | Link |
@Snowknight26
That may work for extract, Harrenkyym try to recode to AAC with a pipe ("|" in command line, ">" in powershell syntax) from eac3to.exe to qaac.exe. And seems that don't work.
9th January 2021, 16:01 | #15058 | Link |
Let's say you got a complex command line that does pipe and also has paths with spaces:
ffmpeg -i "D:\aa aa_temp\aa aa.avs" -f yuv4mpegpipe -strict -1 -loglevel fatal -hide_banner - | x265 --crf 18 --frames 4069 --y4m --output "D:\aa aa_temp\aa aa_out.hevc" - If this command line is in a variable or for instance in the clipboard, you can run it in powershell like so: Code:
cmd /c (Get-Clipboard)
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 9th January 2021 at 16:05. |
10th January 2021, 18:24 | #15059 | Link | |
You either have to use C# in Powershell or launch cmd via Powershell which doesn't have the issue. Code:
$eac3toPath = "C:\path\to\eac3to.exe" $ffmpegPath = "C:\path\to\ffmpeg.exe" $input = "C:\path\to\input.ext" $output = "C:\path\to\output.ext" $trackNumber = 2 & cmd @('/c', $eac3toPath, $input, "${trackNumber}:", 'stdout.wav', '|', $ffmpegPath, '-i', 'pipe:', $output) 2> $null |
eac3to |
