16th March 2010, 00:21 | #4781 | Link |
I'm attempting to use the Join tab to create a single title from 35 .m2ts files from a camcorder. The m2ts files are the only files in the folder. The properties of the resultant camdump file has a duration of 01:11:44.000 which seems about right. However, the video that's displayed in the properties window seems to be one m2ts file duplicated for the entire length. That is, if I move the video timeline slider all the way to the right, I see frames from one file and no frames from the other 34 files. The camdump.txt file has 35 chapter points, but they are all within the first 20 minutes
Is this a bug or have I missed as needed setting? I was expecting a single title from the joined files with the chapter points at the beginning of each joined file. I'm using 4.0.736 |
16th March 2010, 09:18 | #4782 | Link |
Programmer (or just 教务长)
You didn't miss anything... I'll check it, but since I didn't change anything about m2ts-join I guess there is a problem with tsdemux, which handles the join.
If you have the original playlist(s) of these m2ts files you can join/merge the playlists and still have one title (with many m2ts files). |
16th March 2010, 09:19 | #4783 | Link | |
Naming is possible only for INTERNAL subtitle tracks (not for the external). |
16th March 2010, 11:47 | #4784 | Link | |
Naming is possible only for INTERNAL subtitle tracks (not for the external). OK. I'll try to import srt to mkv file. Thanks. |
16th March 2010, 12:54 | #4785 | Link | |
Direct name the "srt file" like as : video.fra.srt "Video" is for the same name of your mkv video file "Fra" is for language code used for naming and reconize by the player. (Fra for french language code is this sample). But check the correct code, something two existing codes are avialable for on language but only one is supported by the player. (sample for French language 2 codes exist "fre" and "fra" but only fra works correctly for european player products). You see codes on this link (original source found on Multiavchd Forums - Hit and Tips section) http://www.loc.gov/standards/iso639-2/php/code_list.php Edit : After check the list, only one is aviable for "Portuguese" language code : por, you use the correct code. Last edited by drelin; 16th March 2010 at 12:58. Reason: additional informations |
16th March 2010, 16:41 | #4786 | Link |
I think it is time to add mkv2avi.exe to multiAVCHD package... It got some nice 'upgrades' like ETA and preview... There is no need to download 20-30MBs when it can be part of the whole package with all of my tools:
Current version will be 2.3 build 104. Dean |
16th March 2010, 17:40 | #4787 | Link | |
One more question: the only subs that appears in setup menu preview mode are the embedded ones. Is it possible to make the external srt appears in preview mode? |
18th March 2010, 03:42 | #4788 | Link | |
mkvmerge -o output.mkv --chapters C:\Temp\chapters.xml --timecodes 0:C:\Temp\20100314130406.track_4113.tmc C:\Temp\20100314130406.track_4113.264 --timecodes 0:C:\Temp\20100314130406.track_4352.tmc C:\Temp\20100314130406.track_4352.ac3 The resultant output.mkv is with the 35 files joined properly and it plays ok. I loaded output.mkv into multiAVCHD and the chapters are where they should be. I created a Blu-ray structure and the chapter thumbnails are present. However, the Blu-ray image play is jerky. Is that a framerate problem? The original .m2ts files are 29.97; output.mkv is 58.824 (original 29.97); and stream 00000.m2ts is 58.824. from one of the original files: Code:
General ID : 0 Complete name : C:\Temp\20100314130406.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 29.0 MiB Duration : 15s 750ms Overall bit rate : 15.4 Mbps Maximum Overall bit rate : 18.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Duration : 14s 881ms Bit rate : 14.4 Mbps Width : 1 440 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.308 Stream size : 25.5 MiB (88%) Code:
General Complete name : C:\Temp\output.mkv Format : Matroska File size : 2.06 GiB Duration : 19mn 11s Overall bit rate : 15.4 Mbps Encoded date : UTC 2010-03-18 01:07:38 Writing application : mkvmerge v3.1.0 ('Happy up here') built on Jan 19 2010 12:09:24 Writing library : libebml v0.7.9 + libmatroska v0.8.1 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Muxing mode : Container profile=Unknown@4.0 Codec ID : V_MPEG4/ISO/AVC Duration : 19mn 7s Bit rate : 14.7 Mbps Width : 1 440 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 58.824 fps Original frame rate : 29.970 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.160 Stream size : 1.96 GiB (95%) Code:
General ID : 1 Complete name : C:\multiAVCHD\AVCHD_bday\BDMV\STREAM\00000.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 2.16 GiB Duration : 19mn 11s Overall bit rate : 16.1 Mbps Maximum Overall bit rate : 35.5 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Duration : 19mn 7s Bit rate : 15.1 Mbps Width : 1 440 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 58.824 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.165 Stream size : 2.01 GiB (93%) Language : English / / Thanks, AJ Last edited by AJ500; 18th March 2010 at 03:57. |
18th March 2010, 07:01 | #4789 | Link |
Without using mkvmerge, can you import .264 in multiAVCHD, then add .ac3 as external audio and .xml as chapters? If needed, [alter detected properties] and set proper framerate.
You can retry the import in multiAVCHD, since it is possible that the 1st time only the preview was wrong, but the final mux could've been okay. |
18th March 2010, 11:29 | #4790 | Link |
Something new, which probably will be available soon:
It allows similar to HD-DVD functionality - one title per disc, hard-burned subtitles (probably soft once I find a way how to). Now this should allow converting blu-ray playlists (branched or non-branched) to dvd. [SD-DVD] produces DVD output, compatible with standard DVD players. Here is a log from a compilation I made few mins ago, importing Ghost Rider Blu-ray disc Code:
[14:18:44] Initialising... [14:18:44] Checking for new version... [14:18:44] New version/build found! [14:18:44] Consistency check finished! [14:18:44] Initialization finished. multiAVCHD is ready! [14:18:44] 1 year and 82 days since multiAVCHD was published. [14:18:44] 261 people supported it with donations [14:18:44] and you are the 1278308 one to launch the program... [14:18:44] Support multiAVCHD to extend its features and keep it going! [14:18:44] multiAVCHD.dat version: [04000733] [14:22:21] *** Scanning playlist (00065.mpls). Please wait... [14:22:22] *** Playlist EXT format: BDMV 1.1 [14:22:22] *** Detected main-path : [ID#000 Dur: 02:03:25.398] [00:00:11.650] [14:22:24] *** Detected media file: [00066.m2ts, 02:03:25.395] (31502 MiB) [14:22:24] *** Playitem size exceeds split point of 4000 MiB (set in Author tab). [14:22:24] *** Playlist marked for full processing mode. (split/join) [14:22:25] *** Detected media file: [00087.m2ts, 00:00:00.000] (9 MiB) [14:22:25] *** Detected sub-path #: [ID#000, IN: 00:00:11.650] [IGS] [14:22:25] *** Detected chapters #: 00:00:00.000;00:09:21.394;00:18:28.690;... [14:22:25] *** Playlist duration : 02:03:25 (31511 MiB) [14:23:28] Checking for available space and drive types (FAT32/NTFS)... [14:23:29] Destination [D:]: NTFS, 12125.18 MiB (11.841 GiB) free space [14:23:29] Temp folder [D:]: NTFS, 12125.18 MiB (11.841 GiB) free space [14:23:29] Log started for multiAVCHD v4.0 (build 736) [14:23:29] Selected output mode: DVD player (DVD R/RW disc) [14:23:29] Processing one title... [14:23:30] Processing PLAYLIST (full mode) (split/join) (I:\GHOST_RIDER\BDMV\PLAYLIST\00065.mpls)... [14:23:30] Generating meta file for tsMuxer... [14:23:30] M2TS stream split set at 4000MiB... [14:23:30] Title is trimmed: 00:00:00 - 00:05:00 [14:23:31] SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net [14:23:31] Detected resolution: 1920x1080 [14:23:31] Detected video: V_MPEG4/ISO/AVC (TID#4113) [14:23:31] Only this video track will be used! [14:23:31] Detected media file: 00066.m2ts [14:23:31] Detected main PI#000: 00066.m2ts, Duration: [02:03:25.398], [PTS: 00:00:11.650 / 02:03:37.048] [14:23:31] Using audio: A_AC3 (ID#4352 / language: eng / delay: 0) [14:23:31] Using audio: A_LPCM (ID#4353 / language: eng / delay: 0) [14:23:31] Using audio: A_AC3 (ID#4354 / language: hun / delay: 0) [14:23:31] Using audio: A_AC3 (ID#4355 / language: pol / delay: 0) [14:23:31] Using audio: A_AC3 (ID#4356 / language: eng / delay: 0) [14:23:31] Using audio: A_AC3 (ID#4357 / language: eng / delay: 0) [14:23:31] Using subtitles: ID#4608:S_HDMV/PGS Language: eng [14:23:31] Using subtitles: ID#4609:S_HDMV/PGS Language: bul [14:23:31] Using subtitles: ID#4610:S_HDMV/PGS Language: hrv [14:23:31] Using subtitles: ID#4611:S_HDMV/PGS Language: hun [14:23:31] Using subtitles: ID#4612:S_HDMV/PGS Language: pol [14:23:31] Using subtitles: ID#4613:S_HDMV/PGS Language: ron [14:23:31] Using subtitles: ID#4614:S_HDMV/PGS Language: slv [14:23:31] Using subtitles: ID#4615:S_HDMV/PGS Language: tur [14:23:31] Creating clip and playlist info (tsMuxeR)... [14:24:15] This title is marked for reencoding / uncropping... [14:24:15] Encoding process may take 10 min to 10 hours, so be patient... [14:24:15] *** Initiating video encoding: [14:24:15] *** Original : 1920x1080 [14:24:15] *** Crop : 0 [14:24:15] *** Resize : 720x480 [14:24:15] *** Uncrop to : 720x480 [14:24:15] *** Sharpen : 0 [14:24:15] *** Bitrate : 4000 kbps [14:24:15] *** Profile : SD-DVD (MPEG-2) [14:24:24] Cannot detect file size: (D:\_TEMP\multiTEMP-20100318\20100318-142331-3893\BDMV\STREAM\00000.[720x480-29.970].m2v) [14:31:20] *** Transcoding successful! [14:31:20] Detected video: ID#0:V_MPEG-2 720x480, fps=29.970 [14:31:20] Display properties: 853x480 (AR:1.78) [14:31:20] Encoding ac3 audio to AC3 (eac3to)... [14:32:50] Adding AC3 encoded audio track (eng)... [14:32:50] Detected subtitles: ID#4608:S_HDMV/PGS Language: eng [14:32:50] Detected subtitles: ID#4609:S_HDMV/PGS Language: bul [14:32:50] Detected subtitles: ID#4610:S_HDMV/PGS Language: hrv [14:32:50] Detected subtitles: ID#4611:S_HDMV/PGS Language: hun [14:32:50] Detected subtitles: ID#4612:S_HDMV/PGS Language: pol [14:32:50] Detected subtitles: ID#4613:S_HDMV/PGS Language: ron [14:32:50] Detected subtitles: ID#4614:S_HDMV/PGS Language: slv [14:32:50] Detected subtitles: ID#4615:S_HDMV/PGS Language: tur [14:32:50] Total of 2 tracks found in this file. [14:32:50] AR of 16:9 will be set for this title. [14:32:50] Title is trimmed: 00:00:00 - 00:05:00 [14:32:50] Copying audio to source folder for re-use... [14:32:50] Creating SD-DVD structure... [14:32:53] SD-DVD muxing completed! [14:32:53] SD-DVD title saved: [14:32:53] D:\multiAVCHD\AVCHD_GR_DVDS\[DVD]\GHOST RIDER [14:32:53] Compilation contains 1 HD-DVD titles and no AVCHD/Blu-ray titles! [14:32:53] Preparing menu pages... [14:32:54] Setting main menu for 0 titles... [14:32:54] Selected TV system: [NTSC] [14:32:57] Done! Compilation summary: Format: DVD player (DVD R/RW disc) (mixed with HD/SD-DVD) Name : multiAVCHD =============================================================================== 1. 1 HD-DVD/SD-DVD titles =============================================================================== Output size : 161 MiB (0.157 GiB) [14:32:57] D:\multiAVCHD\AVCHD_GR_DVDS folder created (AVCHD/Blu-ray output)! [14:32:57] Burn its CONTENTS to DVD R/RW UDF 2.50/2.60 disc! [14:32:57] Compilation contains HD-DVD/SD-DVD titles placed in [HD-DVD]/[DVD] folder. [14:32:57] Burn each HD-DVD/SD-DVD title folder contents (both HVDVD_TS and VIDEO_TS for HD-DVD) to a separate DVD disc. [14:32:59] You may now remove temp folder (D:\_TEMP\multiTEMP-20100318\). [14:32:59] multiAVCHD finished in 569.248 seconds (00:09:29.247)! [14:32:59] End of log. [14:32:59] Cleaning up... [14:32:59] Done! [14:32:59] For technical support, bug reports and questions: [14:32:59] http://multiforum.deanbg.com/ [14:32:59] http://multiAVCHD.deanbg.com/ [14:32:59] http://forum.doom9.org/showthread.php?t=143744 Dean Last edited by deank; 18th March 2010 at 13:36. |
18th March 2010, 17:32 | #4791 | Link | |
The preview is still not correct. However, the resultant Blu-ray image is now correct. Any idea why the proper duration is not detected? Is it because the .264 stream doesn't have fps data? |
18th March 2010, 20:24 | #4793 | Link |
Build 737:
* Full download required if you want to use (SD)DVD basic authoring. Link #1 / Link #2 * Added another output/authoring mode for standard DVD players (SD-DVD). In SD-DVD output mode multiAVCHD will generate [DVD] folder with subfolders for each of the compilation titles, ready to burn to DVD5/DVD9 (VIDEO_TS and AUDIO_TS folders) SD-DVD output mode supports: * Original chapters * 1 audio track (forcefully encoded to AC3) * 1 external subtitle track * 1 hard-burned subtitle track Supported subtitles: * Text based SRT, MicroDVD SUB and Blu-ray SUP subtitles for hard-burned DVD subtitles * Text based SRT and Blu-ray SUP subtitles for soft DVD subtitles. To use subtitles in this mode you need to have them as EXTERNAL tracks. Internal Blu-ray or file-embeded subtitles won't be used. If there is any interest in this feature at all, I'll add more audio/subtitle tracks support. *** Using SD-DVD output mode you can import virtually any format (files, Blu-ray structures, playlists, AVCHD playlists, DVD folders or IFO playlists) and output to standard DVD format. Examples of using this mode: * Camcoder users shoot a lot of HD material. Exporting to DVD is an easy way to share their videos with relatives and family, which don't own Blu-ray players, but have DVD players at home * Back-up your Blu-ray Disc (movie-only) to a DVD and watch it in the other (non bdp equipped) room, or pass it to your children to watch in their room Dean Last edited by deank; 18th March 2010 at 20:43. |
18th March 2010, 22:16 | #4794 | Link |
Thanks Dean - looks like a great update. Sorry if this is a stupid question, when you say it supports virtually any SD file import, does this include xvid files? I get no preview and a warning that xvid transcode not supported?
Edit: with MPEG2 files I get Avisynth open failure. ConvertFPS: requires YUY2 input. Last edited by rendez2k; 18th March 2010 at 22:25. |
19th March 2010, 07:40 | #4797 | Link | |
I have a blu-ray with a lot of audios and subtitles. So I tried to remove some audios to fit movie to BD25.
But I get this error: Quote:
Can maybe someone please help me, what is the problem. |
19th March 2010, 08:27 | #4798 | Link | |
Yes... It has nothing to do with the DVD output. I have preview and transcode working for all media types/codecs. It depends on your configuration/decoders.
Dean |
19th March 2010, 11:22 | #4800 | Link | |
[07:12:03] *** 1. ARMORED [07:12:03] *** Scanning playlist (00001.mpls). Please wait... [07:12:04] *** Playlist EXT format: BDMV 1.1 [07:12:04] *** Detected main-path : [ID#000 Dur: 01:27:53.267] [00:00:11.650] [07:12:09] *** Detected media file: [00011.m2ts, 01:27:53.258] (0 MiB) [07:12:09] *** Detected chapters #: 00:00:00.000;00:05:03.136;00:12:45.514... [07:12:09] *** Playlist duration : 01:27:53 (0 MiB) |
