Old 7th December 2017, 09:16   #2741  |  Link
Vesdaris
Originally Posted by JohnLai View Post
Dont select VBR HQ with the CQ mode setting, otherwise, you will get full 17500kbps or 38400kbps all the way and ended up with huge file size.
CQ mode only work with standard VBR.
I use the settings like on the image I posted above (found it in this thread), only with VBR HQ instead of VBR and so far it's been working fine.No huge files\bitrates.
Vesdaris is offline   Reply With Quote
Old 9th December 2017, 23:34   #2742  |  Link
davidm71
Are your fans spinning?
Using Staxrip and NVenc and it says my Video Engine is at 97% load on my GTX 1060 but my fans aren't spinning on my video card! Is this normal??
Max temps in the low 60's. Also like the last few you asked what are your 2500 bps quality settings? Staxrip doesn't have a 2-pass mode?
davidm71 is offline   Reply With Quote
Old 10th December 2017, 00:51   #2743  |  Link
gonca
Trying to process a 10 bit video with StaxRip and getting an error
I'm sure its just user caused, so if someone can point out my error it would be appreciated.
Error
avs: invalid colorformat.
Failed to open input file.
AVS script
LoadPlugin("C:\Program Files (Portable)\dgdecnv\x64 Binaries\DGDecodeNV.dll")
DGSource("I:\xxxxx.dgi", fieldop=0, fulldepth=true)
CMD line
"C:\Program Files (Portable)\StaxRip\Apps\NVEnc\NVEncC64.exe" --vbrhq 38400 --codec h265 --preset quality --level 5.1 --output-depth 10 --weightp --ref 5 --gop-len 24 --lookahead 32 --qp-init 1 --max-bitrate 38400 --vbr-quality 25 --aq --cuda-schedule auto --colormatrix bt2020nc --colorprim bt2020 --transfer bt2020-10 --mv-precision q-pel --cabac -i -o W:\TEMP\%source_name%_temp\_out.h265
Thank you
Old 10th December 2017, 04:29   #2744  |  Link
craigpro
nvidia drivers 388.13 still have API error with nvencc
craigpro is offline   Reply With Quote
Old 10th December 2017, 05:14   #2745  |  Link
JohnLai
I got a feeling that your Initial QP ain't set to 1.........
=.= Let just say NVENCC two pass isn't what you think it is........
MSI GTX 1060? I read it only start to spin the fan once it reach 62'C. There is one manufacturer who set the fan to spin at 65'C too, but I can't remember which. To be sure, try manually adjust the fan speed to verify if it is fan hardware issue. Can't discount the possibility.
Because nvenc chip (pascal) doesn't support B-Frame, depending on resolution/framerate/scene, 2500kbps might be a bad or good idea.....
2500kbps with DVD resolution is fine.
720p 30fps is still acceptable.
1080p 30fps with 2500kbps? Unless it is animation or the content has a lot of static scene......don't bother.
General rule: Follow https://support.google.com/youtube/answer/1722171?hl=en youtube bitrate recommendation, but with a bit twist. Youtube bitrate recommendation is for H264. Since you are using HEVC, well, divide those values by 2? However, since Nvenc chip doesn't support b-frame, so....better set 60-70% of youtube recommended bitrates/resolution/framerate.
Yup...didn't I type that version in the screenshot? As far as nvidia concerned, it is fixed in their bug report database. I kinda lazy to report/inform the issue still exists. Anyone wanna inform nvidia instead?
JohnLai is offline   Reply With Quote
Old 10th December 2017, 09:47   #2746  |  Link
impei
Two pass nvenc
How is it different than x264 two pass?
impei is offline   Reply With Quote
Old 10th December 2017, 11:13   #2747  |  Link
JohnLai
Copy paste from afterdawn and Nvidia documentation
x265/x264 multi-pass
The video encoder analyzes the video many times from the beginning to the end before the actual encoding process.
Nvenc
In 2-pass rate control modes, NVENC estimates the complexity of the frame to be encoded and determines bit distribution across the frame in the first pass. In the second pass, NVENC actually encodes macroblocks in the frame using the distribution determined in the first pass.
Old 10th December 2017, 13:01   #2748  |  Link
NikosD
The video engine chip inside the GPU, is a very small piece of hardware compared to the whole GPU chip.
So, even after using that chip to 100% for hours, don't expect to push GPU Temps high enough to trigger the spinning of fans, especially in winter and inside a cool case.
The behavior of your card is normal.
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 12th December 2017, 14:57   #2749  |  Link
videoh
Useful n00b
Trying to process a 10 bit video with StaxRip and getting an error I'm sure its just user caused, so if someone can point out my error it would be appreciated.
Error:
NVEncC supports only 8 bit for AVS input. If you must use DGSource then you can use VPY input.
Also, it would be worth asking Rigaya if he can support full depth for AVS input.
Old 12th December 2017, 22:51   #2750  |  Link
gonca
Yes, I must use DGSource
Old 13th December 2017, 07:56   #2751  |  Link
thomy21
I got this error message. Can anyone tell me what the problem is?
------------------ Error Muxing using mkvmerge 17.0.0 ------------------
Muxing using mkvmerge 17.0.0 failed with exit code: 2 (0x2)
The exit code might be a system error code: STATUS_WAIT_2
The exit code might be a system error code: Das System kann die angegebene Datei nicht finden.
The file could not be opened for reading, or there was not enough data to parse its headers.
--------------------- Muxing using mkvmerge 17.0.0 ---------------------
thomy21 is offline   Reply With Quote
Old 13th December 2017, 16:29   #2752  |  Link
Zetti
FFmpeg v3.4.1 is released.
Old 14th December 2017, 19:00   #2753  |  Link
Pulp Catalyst
Hello,
preview not working in latest version, i'm running vapoursynth mode.
"Resize error: Resize error 3074: unrecognized transfer characteristics (1/5/5 => 0/5/5). May need to specify additional colorspace parameters."
without previewing working, can't do manual crop!!
Pulp Catalyst is offline   Reply With Quote
Old 15th December 2017, 10:22   #2754  |  Link
grich99
Hello StaxRip,
Thank you for a wonderful program!0
I found a bug with 1.7.0.0
- For encoding using AMD VCEenc H.265, if I select .MP4 box as the output container, the file generated cannot be played. .MKV container works fine with H.265
Feature request:
Is it possible to stamp onto the encoded file the same Date and Time as the original file? It would save a lot of time for archiving purposes!
grich99 is offline   Reply With Quote
Old 15th December 2017, 15:06   #2755  |  Link
hajj_3
XviD 1.3.5 has been released.
Old 15th December 2017, 20:49   #2756  |  Link
grich99
Yep, and the fun thing is that you can literally encode HEVC files while playing a game and suffer no slow downs for encoding or game playing!
Old 17th December 2017, 07:55   #2757  |  Link
Vesdaris
Ah, but it is set to 1.
Old 21st December 2017, 10:33   #2758  |  Link
Micheal813
Originally Posted by Taurus View Post
This is what I get trying Avisynth+ new "mClean" on any suitable SourceFilter/ or any encoder.
All other new scripts (Finesharp,etc.) are doing fine
I'm having the same issue with the latest stable x64 and test build x64 on Windows 10 64 bit. All other filters work fine. It's when I add mclean (either by itself or with others) that I get the same error message.
Error Video encoding using x264 0.150.2851 8-Bit (1.7.0.0)
Video encoding using x264 0.150.2851 8-Bit failed with exit code: -1073741795 (0xC000001D)
The exit code might be a system error code: {EXCEPTION}
Illegal Instruction
An attempt was made to execute an illegal instruction.
-------------- Video encoding using x264 0.150.2851 8-Bit --------------
F:\Programs\StaxRip-x64-1.7.0.0-stable\Apps\x264\x264.exe --crf 20 --output F:\Capture\Testing_temp\Testing_out.h264 F:\Capture\Testing_temp\Testing.avs
StaxRip.ErrorAbortException: Video encoding using x264 0.150.2851 8-Bit failed with exit code: -1073741795 (0xC000001D)
Illegal Instruction
   at StaxRip.Proc.Start() in D:\Projekte\VS\VB\StaxRip\General\Proc.vb:line 338
   at StaxRip.x264Enc.Encode(String passName, String commandLine, ProcessPriorityClass priority) in D:\Projekte\VS\VB\StaxRip\Encoding\x264Enc.vb:line 69
   at StaxRip.x264Enc.Encode() in D:\Projekte\VS\VB\StaxRip\Encoding\x264Enc.vb:line 41
   at StaxRip.GlobalClass.ProcessVideo() in D:\Projekte\VS\VB\StaxRip\General\GlobalClass.vb:line 225
   at System.Threading.Tasks.Parallel.<>c__DisplayClass4_0.<Invoke>b__0()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at StaxRip.GlobalClass.ProcessJob(String jobPath) in D:\Projekte\VS\VB\StaxRip\General\GlobalClass.vb:line 137
Micheal813 is offline   Reply With Quote
Old 21st December 2017, 15:22   #2759  |  Link
Khun_Doug
I've seen instances where the order of the filters can cause faults. In particular, I had to be mindful of where the cropping filter was, and also any resizing filter. You can try to temporarily disable any cropping or resizing if you are using them, and set a small 1 or 2 minute clip, and then see if the error goes away. If so, then the fix would be as simple as rearranging your filters.
Also, the latest beta build may resolve your problem. I know mClean is currently at revision 2.0 and I am sure that StaxRip 1.7.0.0 is not up to that revision. Since you specifically want to use mClean then going to 1.7.0.4 will be a boost. I'm using 1.7.0.3 but copied in the updated mClean AVSI file to get the latest filter. The filter works great!
Khun_Doug is offline   Reply With Quote
Old 21st December 2017, 20:54   #2760  |  Link
Micheal813
It's not a filter order problem. It happens when mClean is the only filter. I tried 1.7.0.3 and got some other error. I'll do some more testing in a bit.
