5th September 2017, 14:22 | #2683 | Link |
Professional Code Monkey
R39 test4
I miscompiled test3 so that's why it didn't work. That's what happens when you have to reinstall everything on a new computer...
7th September 2017, 10:40 | #2685 | Link |
Hello. You can call me stupid, but I broke my head. I'm pretty good in Avisynth, but in Vapoursynth is a beginner. I have Xubuntu 16.04 x86, Vapoursynth from PPA. I need to connect avisynth TIVTC.dll plugin, because of 2-pass mode=2 and mode=4 (I have a complex video), which is not in VIVTC. And I can not.
import vapoursynth as vs core = vs.get_core() core.avs.LoadPlugin(TIVTC.dll) video = core.ffms2.Source(source=input.mkv) video = core.avs.TDecimate() video.set_output() Code:
vspipe --y4m script.vpy - | ffmpeg -i pipe: output.mkv No attribute with the name avs exists. Did you mistype a plugin namespace Help me, please. |
7th September 2017, 16:00 | #2686 | Link | ||
7th September 2017, 17:34 | #2687 | Link | |
7th September 2017, 19:41 | #2689 | Link | |
I have a dream that one day an avisynth user will suggest doing the right thing and not just another shitty compatibility hack.
7th September 2017, 19:47 | #2691 | Link |
It's called C. With a system compiler. Works everywhere.
7th September 2017, 20:03 | #2692 | Link |
May there be no system dependent function calls. Or references to external libraries (like FFT3D). Do it yourself ... everything ... from scratch. Or from other OpenSource projects. Rely on the community! Closed Source is so ... last millennium.
8th September 2017, 13:56 | #2693 | Link |
Thanks. This should be specified here so as not to mislead people.
What the point of Vapoursynth then? Another fork? Windows has a working learning Avisynth. Linux does not have avs plug-ins, so Avisynth under Wine is the best solution then. |
8th September 2017, 14:02 | #2694 | Link | |
VapourSynth also isn't a fork. The point is code quality, portability and proper multithreading support. And more flexible scripting too. And no, not caving in to your documentation demands. It shall remain unchanged.
8th September 2017, 14:59 | #2695 | Link | |
I'm Siri
that's enough for me to sentence avisynth to death |
10th September 2017, 14:46 | #2698 | Link | |
feeding x265 via Vapoursynth
Can someone help why it is not possible to feed a HDR10 encoded content to x265 to reencode using DGDecNV (latest with HDR10 support) and Vapoursynth?
Error message as follows: Quote:
I am not a programmer, not using Vapoursynth directly but perhaps can provide all the info required to find the reason for the problem. Please help. |
10th September 2017, 15:03 | #2699 | Link |
@mparade
Your VS script would be a start.
10th September 2017, 16:00 | #2700 | Link |
