25th November 2015, 07:00 | #23362 | Link | |
Anyway, FULLY agree with our friend above. I personally ALWAYS keep the Workfiles until I am COMPLETELY satisfied that everything went well... |
26th November 2015, 03:14 | #23366 | Link | |
I notice that you're keeping the original audio intact. Just as a test, try unclicking the first two audio options on the SETUP menu. That way it will reencode the audio. It's worth a try. |
26th November 2015, 04:44 | #23367 | Link | |
Thank you very much for your answer, I will try what you suggest and I will post the results as soon as I have them. I know is not cinavia because when I burn the same movie to a 50Gb blu ray it works fine, the problem is after compressing it to fit in a 25gb blu ray. Also I have tried with at least 5 3D movies and all have the same problem. With normal movies I never had any problem like this using Bd Rebuilder, it is just with the 3d movies. Thanks again for the answer |
26th November 2015, 14:57 | #23369 | Link | |
What kind of player are you using? Last edited by jdobbs; 26th November 2015 at 15:02. |
26th November 2015, 23:33 | #23370 | Link |
The first time you play a Cinavia infected movie, it will take ~20 minutes. If you stop playback and wait for a little bit, then it can take as little as 5 seconds. IIRC, if you wait longer than 30 minutes, then it will take the 20 minutes again.
27th November 2015, 02:28 | #23371 | Link |
No it won't take approx 20 minutes. That 20 minutes is an established 'window' in which detection takes place, some find it faster than others. Some take 20min's, others have 5 minutes or less and yes that effect applies to the initial detection!
Verstuurd vanaf mijn Nexus 7 met Tapatalk |
27th November 2015, 04:44 | #23372 | Link | |
I am using Power Dvd and also use a Ps3 to play the movies, I also already tried unclicking the first two audio options on the SETUP menu and I had the same result, no audio after 8 minutes. I will try changing other things in the setup to see if I can make it work and will let you know. Please if you know any other solution let me know. Thanks for the help |
28th November 2015, 16:34 | #23376 | Link | |
I have 4 files with the name you mention in the working folder, but they have another extension: AUD_00098_4352.AVS AUD_00098_4353.AVS AUD_00098_4354.AVS AUD_00098_4356.AVS But these files only weight 1Kb. I do have files with .ac3 extension, but they have the following name: 00098.track_4352.ac3 Size:377MB Duration: 2 hours 17 minutes 00098.track_4353.ac3 SIze:26MB Duration: 8 Minutes 12 Seconds 00098.track_4354.ac3 Size:26MB Duration: 8 Minutes 12 Seconds 00098.track_4356.ac3 Size:26MB Duration: 8 Minutes 12 Seconds I played all the files and the 00098.track_4352.ac3 seems to be the Audio of the main movie in English, this file looks like has the whole movie Audio because it last 2 hours 17 minutes. The 00098.track_4353.ac3 is English with some comentary but only last 8 minutes 12 seconds. The 00098.track_4354.ac3 file is french but only last 8 minutes 12 seconds. And finally the 00098.track_4356.ac3 file is spanish but only last 8 minutes 12 seconds. Please if you need me to ckeck something else let me know. Thanks for the help |
