25th September 2009, 22:35 | #5361 | Link | |
I understand that there is not a re-encoding going on. I was trying to use BD Rebuilder to do a movie only BD-25. I have checked off Stricter AVCHD compliance. The problem is that the BD-25 backup is not working with BD-Rebuilder. The files that it is producing do not create a working blu-ray disk. I can do it the more difficult way with TSMuxer but I am trying to figure out why I can't do a BD-25 with BD-Rebuilder when I have been able to do it in the past.
25th September 2009, 23:12 | #5362 | Link | |
26th September 2009, 01:34 | #5363 | Link |
Hello everyone.
I've been made about 15 bluray and I had no problem except the following: let only the ENGLISH and SPANISH audio and select all the subtitles on Bdrebuilder options But when watching the movie with SPANISH audio on, for more than select subtitles off, subtitles appears... and the truth that is annoying ... any ideas what might be the problem... and what the solution? thanxs! |
26th September 2009, 14:28 | #5364 | Link | |
26th September 2009, 15:56 | #5365 | Link |
thanks for the reply jdoobs...Use the PLAYSTATION 3 as blu-ray player ... I just finished 007 Casino Royale ... I try the original , select SPANISH audio and the captions do not appear ... instead I try the copy and subtitles appears... I believe that it isnt an issue of the PS3 ... There is something in the program that makes the captions go whenever another language is chosen than the English ..what do you think could be the problem?
26th September 2009, 17:04 | #5366 | Link |
Maybe it's not a bug, but I am wondering about the initial value for crf prediction for the same file and same settings and same target size (BD9).
Full backup mode: - [21:07:18] Reencoding: VID_00009 (4 of 95) - [21:07:18] Collecting video information - Video: 1920x1080, 23.976fps, 2'510 frames - [21:07:18] Performing CRF Prediction... - Analyzing 17.91 19.18 18.79 [18.88] Movie only mode: - [12:47:13] Reencoding: VID_00009 (2 of 26) - [12:47:13] Collecting video information - Video: 1920x1080, 23.976fps, 2'510 frames - [12:47:13] Performing CRF Prediction... - Analyzing 58.13 10.00 46.66 37.93 31.49 26.81 23.50 21.16 19.55 18.55 17.92 17.68 17.46 17.24 17.08 17.18 17.14 17.11 [17.10] Why is the initial crf value for "movie only" 58.13, (continuing with large initial swings)? It looks strange to me, because I would have expected it to be lower than for "full backup" mode as there is more space available for movie only (which is eventually confirmed by the final value of 17.10 vs 18.88). I noticed this "oddness" of the initial crf throughout the disc for most of the segments and for other discs as well. On the positive I like to mention that the final target size was nicely met in both cases - which is the most important of course |
26th September 2009, 21:28 | #5367 | Link | |
26th September 2009, 21:37 | #5368 | Link | |
Sorry, but that pretty much just leaves your PS3... whether "you believe" or not. Is this a full backup or a movie-only backup? Last edited by jdobbs; 26th September 2009 at 21:41. |
27th September 2009, 02:25 | #5370 | Link |
Webmaster
Just got an error anyone know what it means
[02:22:06] PHASE ONE, Encoding - [02:22:06] Extracting A/V streams [VID_00000] - Error in attempt to extract audio/subs. - AV frame too large (55814 bytes). Increase AV buffer. [02:22:38] - Failed to retrieve audio, aborted |
27th September 2009, 03:00 | #5371 | Link | |
I can't imagine how it could be a CODEC issue... the subs are an overlay. There is a register in the player that gets set when a graphic overlay (subtitle) is to be displayed. Somehow the register is getting set -- and only a command sequence or the player itself can set it. The command sequences from the original disc aren't touched when a backup is made by BD-RB, they are kept completely intact. Something has to be turning it on in your player (PS-3). Last edited by jdobbs; 27th September 2009 at 03:06. |
27th September 2009, 12:45 | #5373 | Link |
@jdobbs
This may be a silly question: Why is BD Rebuilder muxing the re-encoded .264-file into an .m2ts-file first before making the final muxing (movie-only, mkv_intermediate=0)? Wouldn't it be possible to do the final muxing *directly* with the .264-videofile? Sorry if this has been discussed before.. |
27th September 2009, 14:16 | #5374 | Link |
Thanks for the continued updates for BD Rebuilder, it is a great piece of software and I have backed up many of my blu-ray collection without any problems.
However there is a series called Torchwood here in the UK and the blu-ray's for both series 2 and 3 fail to compress to BD-25. Is it because there is simply too long a duration of video on the original discs? [14:14:00] BD Rebuilder v0.29.05 (beta) - Source: TORCHWOOD_S3_D1 - Input BD size: 41.98 GB - Approximate total content: [03:05:06.386] - Target BD size: 22.46 GB - Windows Version: 6.1 [7127] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [14:14:00] PHASE ONE, Encoding - [14:14:00] Extracting A/V streams [VID_00002] - [14:14:03] Reencoding: VID_00002 (1 of 15) - [14:14:03] Collecting video information - Video: 1920x1080, 23.976fps, 1,434 frames - Bitrate: 4,156 Kbs - [14:14:03] Reencoding: VID_00002, Pass 1 of 2 - [14:14:04] Reencoding: VID_00002, Pass 2 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. [14:17:10] - Failed video encode, aborted [Status] LABEL=TORCHWOOD_S3_D1 VERSION=v0.29.05 (beta) SOURCE_SIZE=45077149274 SOURCE_VIDEO_SIZE=44544909312 TARGET_SIZE=24117248000 REDUCTION=.52946584474573 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all BACKUP_MODE=0 QUICK=0 ENCODE_STEP=2 [00002] AUDIO=1 PGS=1 M2TS_TARGET=35744383 RATE=4156 Last edited by 4444405; 27th September 2009 at 14:22. |
27th September 2009, 15:15 | #5375 | Link | |
27th September 2009, 15:20 | #5376 | Link | |
27th September 2009, 19:54 | #5378 | Link |
I found that the latest BD Rebuilder version generates problems in video coding during the first roughly 30 secs of movies. If there is mainly a black background (for example during the title screens) this black is more a middle gray and additional blocking errors occur. After this initial phase everything appears to be fine. I found this problems on both movies I encoded ("Transformers" and "The boat that rocked", both region B) and checked that this does not show up in the original rip. It appears to me like the video coder needs some time to "sync" to the video stream. I have not observed this in previous versions. Greetings PS: just saw, that this is still happening at the credits (on black background) .... so it only has to do with the fact that most of the picture is black. I am going back to 29.04 and hope for the best ... Last edited by astraub; 27th September 2009 at 21:59. |
27th September 2009, 23:25 | #5379 | Link | |
28th September 2009, 01:24 | #5380 | Link |
Continuing Coraline Problems
This gets more interesting. I did a BD9 backup of Coraline and it works fine. However, if I do a BD25 (don't worry, I am using a BD-RE to experiment), the disc will not play. However, if I run the m2ts file through TSMUXER again (using tsmuxer GUI), I am able to create a working BD25 disc. This leads me to believe that there is some bug in BD-Rebuilder that affects BD25 backups.
