11th January 2016, 22:32 | #23501 | Link |
Back to forced sub titles...
I just did The Walk.... Other than slight offset time difference (like a few thousandths of a second), the SRT of the forced subs made by BDRB looks the same as the SRT made the manual way (HdBrStreamExtractor/SubTitleEdit) So the forced sub issue on MI5 maybe movie specific. |
11th January 2016, 23:21 | #23503 | Link | |
Could you post your settings? I can't find anything wrong. |
11th January 2016, 23:26 | #23505 | Link | |
11th January 2016, 23:55 | #23508 | Link |
If you want to hang on a little, I've started importing a bunch of my old dvds. If I encounter more of these I'll report them
Possible I might hit upon one you might already have from DVD_RB development days With the PayPal issue there is no point in you spending money if it isn't needed |
12th January 2016, 15:59 | #23509 | Link | |
[Options] VERSION=0.50.0.11 ENABLE_TEST=1 NEW_CRF_PREDICTION=1 #ENCODER_MENU=1 SHOW_ENCODER=1 HC_PROFILE=BEST ALTERNATE_PAL=1 #MIN_M2TS_SIZE=10 #minimum size required for BD-RB processing in MB, default is 100 IMPORT_HEVC_INTACT=1 #FIXED_CRF=20 #10..50 - force CRF encoding to use this CRF value (output size control disappears) QUICK_CRF=22 #Defaults: BD5=30, BD9=24, BD25=20 QUICK_USE_QUALITY=1 SECONDARY_USE_QUALITY=1 #FORCE_ENCODE=1 #FORCE_NOENCODE=1 FORCED_SUB_LANG=ger;deu #FORCE_INMUX_3D=0 #OUTPUT_3D_ISO=1 #applicable for Movie-only Backup only MENU_FORCE_QUICK=1 TWEAK_PASS_ONE=--ipratio 1.4 --pbratio 1.3 --b-adapt 2 --tune film TWEAK_PASS_TWO=--ipratio 1.4 --pbratio 1.3 --b-adapt 2 --tune film TWEAK_ALTERNATE=--ipratio 1.4 --pbratio 1.3 --b-adapt 2 --tune film B_PYRAMID=1 KEEP_MBTREE=1 EXTENDED_GOP=1 #SAMPLE_GROUP=2400 #SAMPLE_SIZE=96 #DEINTERLACER_TYPE=3 #3=smoothdeinterlacer recommended for IVCT sources #DEINTERLACER_TYPE=4 #4 means --fake-interlaced #IVTC_480i=1 #force IVTC on hard telecined 29.97fps sources (i.e. no pulldown flags) #SD_PROGRESSIVE=1 #encodes 480i IVTC material as 480p ENCODER=0 MODE=3 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=0 AUTO_BIAS=3 MOVIEONLY_TYPE=28 ALTCRF=18 ALT_TARGET=1024 ALTMETHOD=0 ALTAUTOCROP=0 TARGET_SIZE=23500 AUDIO_TO_KEEP=deu;eng;ger; SUBS_TO_KEEP=deu;eng;ger; SD_CONVERT=0 OPEN_GOP=1 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=0 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=1 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AUDIO_DRC=0 DECODER=3 AVCHD=0 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=1 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=1 NEROAAC=1 SUPTITLE=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23500 QUICK_EXTRAS=1 MENU_BACKGROUND=C:\Program Files Video\BD_Rebuilder\Misc\wave.jpg IMPORT_THRESHOLD=15 QUICK_PLAY_THRESHOLD=10 MENU_AUTO_BACKGROUND=1 MENU_AUTO_DVDAUDIO=1 MENU_PLAY_SEQUENTIAL=0 MENU_START_WITH_MENU=1 IMPORT_LIMIT_LANG=1 IMPORT_KEEP_PLAYALL=0 VERBOSE_STATUS=1 ENABLE_BLANKING=1 ALT_CRF_TARGET=1024 AVSFilter01=f:r:Sharpen(0.15) AVSFilter02=#f:Grayscale() PGSTOSRT=0 [Paths] WORKING_PATH=C:\TEMP\BD REBUILDER\ DGIndexNV=C:\Program Files Video\DGdecNV\DGIndexNV.exe DGDecNV=C:\Program Files Video\DGdecNV\DGDecodeNV.dll NeroAACPath=C:\Program Files (x86)\Nero-AAC\win32\neroAacEnc.exe SOURCE_PATH=C:\TEMP\BD REBUILDER\IMPORTS\PALE_RIDER\ Code:
[Status] LABEL=PALE_RIDER VERSION=v0.50.11 SOURCE_SIZE=4137713664 SOURCE_VIDEO_SIZE=4137713664 TARGET_SIZE=24641536000 REDUCTION=5.9553507083858 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=deu;eng;ger; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=deu;eng;ger; BACKUP_MODE=1 MOVIEONLY_TYPE=28 USE_LAVF=0 INSTANCES=1 DGDECNV=-1 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [00001] USE_ORIGINAL=1 AUDIO=11 PGS=1111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=24641536000 NSIZE=0 FLINK=0 MLINK=0 |
12th January 2016, 16:21 | #23510 | Link |
@Sharc
I ran the job with your settings file -- and the import/alternate build all went perfectly. I'm not sure what else I can do. Are you running all the recommended versions of the helper software? Any chance you're using a different version of MKVMERGE? |
12th January 2016, 18:21 | #23511 | Link | |
[01.12.16] Checking System Settings - BD-Rebuilder v0.50.11 - Windows Version: 6.2 [9200] - Working Path Free Space: 659.51GB - AVISYNTH Version: 2.6.0.6, Ok - LAVFILTERS: Ok - AnyDVD settings check: Ok. - X264: Wrong version found - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [01.12.16] Systems Settings Check complete I double checked the MKVMERGE and MKVEXTRACT. It's the version which came with BD-RB (maybe you want to include these in the versions check?). Strange. Now you mention versions: I upgraded DGIndexNV recently to version 2051. Let me try with the former one. I'll report back. Edit: No luck. Same problem. I will try now with the latest version of MKVMERGE ..... Edit2: Success! MKVMERGE version 8.8.0.0 solved the problem. Last edited by Sharc; 12th January 2016 at 19:25. |
16th January 2016, 21:13 | #23514 | Link |
Not a bug report, just a question.
Can BD Rebuilder be "fooled" into performing the rebuild phase without needing to extract and encode all of the A/V streams again if you first select No subtitles and then select All subtitles? The job was a full backup of a blu-ray output to 25 GB. Just curious as I notice that all of the .sup files are in the Workfiles folder anyway. Thanks! Corey |
17th January 2016, 01:35 | #23515 | Link | |
17th January 2016, 06:12 | #23516 | Link |
Maybe I am missing something, but when I tried that, it still tells me the working path is not empty, delete all old files?
No aborts the process, yes starts from scratch. I even tried deleting the movie output folder, just the files in the output folder, and get the same message. Any ideas? Thanks again, |
17th January 2016, 15:29 | #23517 | Link |
That message comes up when one of the settings has changed (a difference between the INF and the current settings). If you first select all the subs, and then edit the INF -- the settings should match. Have you changed any other settings? You did edit the INF for that specific job, right? Not the INI?
17th January 2016, 20:36 | #23518 | Link |
Yeah, it was the INF file I fiddled with, while matching the settings, or so I thought. I thought subtitles were the only thing I messed with, so I must have done something wrong. Strange.
So my problem was with Fox Entertainment titles only. Fantastic? Four and the incredibly fantastic The Martian. Subs were on when I played the backups even though the player was set to no subtitles. I ran The Scorch Trials at the same time I did those, and it did not have that issue. Then I checked my version of Rebuilder and saw that it was the second to last release. I installed the newest and tried again. No luck. Subs remained on. I was trying to run it again with or without subs without a complete re-start, but I had no luck with that as well. What did work was just not including any Subs. Thanks for the help. |
18th January 2016, 01:26 | #23519 | Link |
Something is out-of-whack. BD Rebuilder doesn't have the ability to override your player settings (and couldn't even if it wanted to). The only way that could happen is if you hard-coded the subtitles into the picture.
18th January 2016, 02:59 | #23520 | Link |
Trainwreck & Furious 7 Revisited
Although I haven't made any system changes recently (other than updating MPC-HC to the most recent version), I re-ran both of the above mentioned Universal titles I was having problems with after uninstalling and reinstalling BD Rebuilder and related software.
Low and behold re-encoding the DTS-MA to AC3 w/BD9 worked like it's supposed to. Don't know if updating MPC-HC had anything to do with my problem, as it has it's own set LAV Filters built-in which may have caused conflicts. Also don't know why it didn't work with just Universal titles. I opted not to install the LAV Filters w/BD Rebuilder this time and everything seems to be back to normal. I now return you to your regularly scheduled back-ups... ;^) |
