12th January 2009, 09:01 | #661 | Link | ||
AVStoDVD Dev
if I correctly understood, if the AddBorder value is a multiple of 16 then adding the statement at the end of the script is better, else it is convenient to leave resizing at the end? Quote:
And yes, 2.1.3 Alpha 090102 contains all the fixes. Bye |
12th January 2009, 11:29 | #662 | Link | |
Avisynth Developer
12th January 2009, 12:16 | #663 | Link | |
AVStoDVD Dev
Bye |
13th January 2009, 07:26 | #664 | Link |
Question on saving settings
Hi Everyone,
Today I used the new version of AVStoDVD to encode a great DVD movie. However at the start I opened up The Settings menu and clicked on " 2.HCenc OPV 1-pass " . And the clicked on "save settings as default " . But it looked like the 'QuEnc CBR' was doing the video encoding . After the job was finished , the log showed that the " 1.QuEnc CBR 1-pass " selection was used . The previous time I used AVStoDVD , I selected the 3rd choice , " 3.HCenc VBR 2-pass " and custom set the maximum bit rate to 9000. And then AVStoDVD remembered my settings. But if I remember right , I think I clicked on the " Pad Lock " icon before running that job. Is the " Pad Lock " icon needed to save settings for a job? The QuEnc CBR 1-pass setting made a great movie , in fact I couldn't tell the difference in the video quality between the QuEnc CBR 1-pass setting and the twice as long (in encode time) HCenc VBR 2-pass setting. I still would like to try the HCenc OPV 1-pass setting , so I'm wondering why that setting didn't go into play? Unless I'm not saving the settings the correct way ? Thanks.
Your Friend,
Larry |
13th January 2009, 09:00 | #665 | Link |
AVStoDVD Dev
@leoliver
AVStoDVD automatically chooses Video Profile according to video bitrates levels. To fix, in the current project, a Video Profile (i.e. HCenc OPV 1-pass) for all bitrates, you have simply to select it in 'Settings'/'Enconding'/'Setup Video Profiles' and then click on the small icon 'Lock selected Video Profile for all bitrates'. That's all. Press F1 (Help) to get more details about how AVStoDVD works with Video Profiles. Bye |
18th January 2009, 13:34 | #666 | Link |
AVStoDVD Dev
AVStoDVD 2.1.3 is available to download.
Change log (in italic added items from 2.1.3 Alpha) - Some bugs fixed - Added 'KeepDAR' feature (keep thumbnails Display Aspect Ratio) in DVD Menu Editor - Added 'HL Links' feature (display HighLights links/dependencies) in DVD Menu Editor - Added 'Button Generator' section in DVD Menu Editor - Added 'Muxed MPEG2 File' as Output Setup option (muxing is done by ImagoMPEG-Muxer) - Changed AC3 audio encoder: from QuEnc to Aften r762 - Changed MPEG2 video demuxer: from 'ReJig 0.5f' to 'FFmpeg r14277' - Removed ImgBurn from 'NoInstall' package. It is still present in the 'Installer' package as installer itself. - Improved errors logging in AVStoDVD project log file - Improved AVS Script generation function - AviSynth updated to 2.5.8 - MediaInfo updated to 0.7.8 Bye |
18th January 2009, 14:09 | #667 | Link | |
19th January 2009, 13:36 | #668 | Link | |
AVStoDVD Dev
- aspect ratio (4:3 - 16:9) - multi page menu - custom buttons or no buttons (text only menu) - different highlight shapes - template saving please feel free to add request: in a planning step, everything is allowed. Bye |
19th January 2009, 16:13 | #669 | Link |
A question on Avisynth 2.5.8, will that keep existing plugins in the Avisynth folder?
Also, love the "menu wizard" idea. Even with one movie per DVSD I prefer menu, so I drop in DVD and get to pick when playback of the movie starts. |
20th January 2009, 07:03 | #671 | Link |
DVD AUTHORING FINALIZATION errors
Tonight , the AVStoDVD process was aborted due to a DVD authoring error . The error message said to look at the 2 log files I'm attaching with this post.
When I looked in my "Output" folder , I had a Glory_0_Title_01.ac3 (178 MB. ) file , a Glory_0_Title_01.m2v (4.03 GB.) file and a VIDEO_TS folder (4.31 GB.) . The files 5 .vob files , in the VIDEO_TS folder , were playable if I loaded them as individual files in Mplayer . And those files have good audio/video playback , but no DVD menu structure. Please take a look at my log files and let me know what went wrong and how it can be corrected . Thanks.
Your Friend,
Larry |
20th January 2009, 11:26 | #672 | Link | ||
AVStoDVD Dev
Bye |
21st January 2009, 13:54 | #673 | Link | |||
@leoliver
From your BatchMux log file: Quote:
Cheers manolito |
21st January 2009, 17:52 | #674 | Link |
AVStoDVD Dev
@manolito
you are (clearly ) right! In the chapters creation routine, there is a mismatch between time and frames when selected video standard is NTSC (30 fps vs 29.97 fps). I will try to solve this issue, and if I could not, I will use SD's workaround. Thanks for your debug Bye |
21st January 2009, 17:55 | #675 | Link |
"Looks like the chapter creation routine of AVStoDVD could use some bug fixing. I got this error too a couple of times, so it might be a good idea to create the last chapter only if it is at least one minute away from the end of the movie. IIRC Sir Didymus did it like this in his BatchMux plugin for DVD2SVCD..."
Thanks for your reply. I set my chapter creation time mark to 10 mins. , instead of the default 10 mins. . I don't know if that aggravated the chapter creation routine problem. As I said in my post , my AVStoDVD job did create a full folder of .vob files with good audio/video playback but no DVD menu structure. So I loaded the .vob files into Nero Vision 4 . Nero merged all the .vob files into one single .vob file and was able to create chapters with a DVD menu that I burned to a blank DVD. But that added about 2 extra hrs. to the total time of that particular task. So I'll look forward to this bug being fixed.
Your Friend,
Larry |
21st January 2009, 20:11 | #676 | Link | |
AVStoDVD Dev
Remember that the bug happens only when the total time is equal to (a multiple of chapters interval) plus (a bunch of seconds) Bye |
22nd January 2009, 06:23 | #677 | Link |
Is it possible to create custom chapter points? Also can I create motion menu buttons? How do I resize the resolution to like 352x240? If I can do these things avstodvd would be one of the top freeware dvd authoring programs. |
22nd January 2009, 09:37 | #678 | Link | |
Excellent analysis! I completely agree with your findings. I have also to comment on the very strong and useful logging capabilities of AVStoDVD. Well, just a minor detail: in the DVD2SVCD plugin, the actual threshold to prevent the chapter creation before the end of movie is set to 10 seconds... Suggestion to MrC: batchmux actually supports both chapter files in the "Framecount" and in the "Non Drop Time Code" formats. The advantage of the later is that the represented times (strings of the form "hh.mm.ss.ff") are absolute and independent from the TV standard, presence of pulldown, etc... The format is much more general, and it is the same used internally to MuxMan. It's an option to consider... In case of need, please let me aware about: I would be happy of sharing the section of code for the chapter generation used inside the DVD2SVCD plugin... Cheers, SD |
22nd January 2009, 21:13 | #679 | Link |
23.976 to PAL
Shoudn't 'AssumeFPS(25)' be added to the script when converting an m2ts@23.976 fps to a compliant 720x576 PAL DVD? (=PAL speedup)
(The Audio would have to speed up as well, eac3to can do this for example). |
23rd January 2009, 10:50 | #680 | Link | |||||
AVStoDVD Dev
Bye |
