3rd October 2010, 04:57 | #8563 | Link |
The algorithm used by Dolby has always been more efficient ie same quality using less space.
The difference between HD and conventional audio(1536/640kbps) is minimal, just a blinded test. What marketing and a 4 decibels(DTS) do not cause people's heads ... Sorry for my English ... |
3rd October 2010, 09:03 | #8564 | Link |
Avisynth error
Hi to everybody,
Firstly, I wanted to add my self in the thanks list of this great tool. Atak. Recently I bought the Spider Man trilogy. While with Spider Man I & 3 everything went fine, I got an avisynth error with Spider Man 2 and particularly I followed the next steps: 1) With anydvd HD and tsmuxer I created a blue ray disk on the hard drive. By looking inside the STREAM folder of the blue ray disk there are multiple smaller files and not just a big one to select (inside the initial blue ray disk). 2) After a while I got the following error: Any help would be appreciated. Last edited by mpamphs70; 3rd October 2010 at 09:08. |
3rd October 2010, 09:07 | #8565 | Link |
friends
i am using ripbot software...after a lot of try ripping my avchd video with ac3 (5,1 channl) ripping...whenever i try to play the video on pc it works fine but it doesnt play smooth on BD PLAYER then i tried it on PS3 but no response...i tried MKV format..then i tried MP4 and the same thing happens.. dont know what i am missing and what is the problem.. Please help me out. Thanks |
3rd October 2010, 15:46 | #8566 | Link |
-amitabhbansal
what are the specs on your source and output? FPS / Resolution / options used / etc -soneca we're not discussing DTS vs AC3. And back when TV's and monitors were CRT/standard def you couldn't really tell the difference between xvid rips and dvd....doesn't mean there's not a difference. I'm aware AC3 is more efficient.....I also know DTS always seems to sound better. lastly burning a bluray and dropping HD sound would be stupid. -mpamphs70 a couple users established that was a bug with one of the more recent versions of AnyDVDHD http://forum.doom9.org/showpost.php?...postcount=8470 if that doesn't fix it you can also try changing your VC-1 codec in FFDShow. that's been known to fix it at times as well |
3rd October 2010, 18:51 | #8568 | Link |
pacaveli211
Here are the details you need to know in Ripbot Video Video = filename.m2v Profile = [High 4.0] HD . BluRay . Consoles FPS = 25 Frames = 14171 Mode = CQ CRF = 22 In Audio Audio = filename.ac3 Profile = x.xCopy STREAM Frequency = 48000 Channels = 6 Normalize = OFF Save As = MKV I have not changed anything and started the job...and the rest i told u b4. Thanks |
4th October 2010, 13:41 | #8573 | Link | |
http://www.mediasmartserver.net/wiki....php/RipBot264
Cheers, Damian Blog - http://www.adigitalhomeblog.com MSS.net blog (contributing editor) - http://www.mediasmartserver.net |
4th October 2010, 14:28 | #8574 | Link |
Good manual.
Here's another > http://adubvideo.net/how-to/convert-...ipbot#more-911 |
4th October 2010, 16:14 | #8575 | Link | |
I uninstall everything (avisynth,ffdshow,haali media splitter). I rebooted and installed everything again, also made no difference both with AnyDVDHD v.6660 and v.6710. I changed VC-1 codec from wmv9 to libavodec, still the problem existed. After searching around in this thread I found a previous post by Atak saying that simpler solutions are often the best and particularly by selecting ANY .m2ts from Blu-Ray disc in ripbot264. That was the solution. Using AnyDVDHD v.6710 I selected an m2ts file (anyone) directly from the blue ray disk and the selected streams were demuxed successfully. Now I'm happy encoding. for the help. Last edited by mpamphs70; 4th October 2010 at 16:45. |
4th October 2010, 21:28 | #8578 | Link |
pacaveli211
Brother i dont have BD recorder, i have recorded the video on my sony handycam which is HDR-XR500E...i want to keep those videos without loosing quality in my dvds so that i can see it on TV. |
4th October 2010, 21:59 | #8579 | Link |
First and foremost, I want to thank you from making this program. It's exactly what I had been searching for!
Sorry if this has been asked before, I just don't have the time to read through 429 pages! Is there any plan to add support for ffdshow 64-bit? Currently, I need to install both the 32 and 64 bit versions. It'd be nice not to need the 32-bit version. |
