4th June 2013, 20:28 | #3241 | Link |
I don't undesrtand, there are two languages options,, and their function is not that clear. I thought it defined the output language track name for an mkv or mp4 file ? So actually it's meant to select the default language streams to extract?
4th June 2013, 22:34 | #3243 | Link |
Ok, had a quick look and failed... Does somebody know how to retrieve the information programatically (sso wich parameters to use) from MediaInfo in order to check if a file has attachments? I can find this information in the GUI but not in the API.
4th June 2013, 23:22 | #3244 | Link | |
Huba Huba
... currently you end up with tons of temporary files after queuing some jobs before the actual av processing starts: job1 idx done job1 oneclick done job2 idx done job2 oneclick done job1 audio processing job1 video waiting job1 mux waiting job1 cleanup waiting job2 audio waiting job2 video waiting job2 mux waiting job2 cleanup waiting ... but neatly putting the result of idx/oneclick where it would make more sense, at least to me: job1 idx done job1 oneclick done job1 audio done job1 video processing job1 mux waiting job1 cleanup waiting job2 idx waiting job2 oneclick waiting
"The innocent have nothing to fear" :stupid: |
16th June 2013, 15:48 | #3245 | Link |
That will only be possible if there are reliable command line multiplexers for the MOV container, as there is mkvmerge for MKV, or MP4Box for MP4.
You may be able to create MOVs with ffmpeg or mencoder, but who knows how tightly they follow the specifications? As far as I remember, their "filter" workflow (not seeking back in the output file to fix headers, because the output may be streamed through STDOUT) is a reason for already notorious issues with many output containers. Last edited by LigH; 16th June 2013 at 15:52. |
19th June 2013, 10:27 | #3246 | Link | |
21st June 2013, 19:05 | #3248 | Link |
When you may have some more time again, Zathor ... would you consider supporting L-SMASH Source (LWLibavVideoSource, LWLibavAudioSource) too?
24th June 2013, 21:11 | #3249 | Link | |
http://megui.org/test/MeGUI.zip I had to rewrite large parts of the resolution (resize, crop, pad) logic to use the same functions during OneClick and in the AVS Script Creator. So there may be some new bugs. @all: please test it. it will be released in the next days or weeks as normal development build. |
25th June 2013, 22:02 | #3252 | Link | |
26th June 2013, 07:37 | #3253 | Link |
a) improved compatibility (e.g. with PAFF interlaced AVC, or out of Transport Streams);
b) improved decoding speed (in a specific test on a Phenom-II X4, LSS was about 1.5x as fast as FFMS with a FullHD AVC source encoded with x264 --crf 6); c) LSMASHVideoSource has a specific splitter for ISO/MPEG4 related containers (MP4, MOV) I believe VFR maniac can tell you more "advertizing" ... |
26th June 2013, 23:33 | #3256 | Link |
megui 2356
After updating MeGUI with the latest files, MeGUI didnt care about bitrate setting in the coniguration part of encodersettings for xvid if automated 2 pass is enabled and autoencode is selected with "no target size(Use profile settings)"-option. It even dont care about the given bitrate after clicking on autoencode and filling in a specific bitrate.
Files are encoded at a very low bitrate, regardless of the complexity of the movie. I dont know why this happens. It didnt happen before. Is it possible MeGUI dont find or cant open the stats file? Im using Windows 7 Home Premium 64bit. Last edited by Kunda; 26th June 2013 at 23:35. |
27th June 2013, 10:57 | #3257 | Link | |
On a different matter...AutoEncode - I usually load avs and audio file for encode, and then use AutoEncode. I like to tag the language of my audio, which can only be done in this routine if I check "add additional content". Then there's a language dialog. It's fine when there's real content to add, but when it's something rather minor like language tag, I find it would be more useful to be able to add it on previous stages (like the first automatic encoding dialog box). Also the list of available languages is alphabetical, and has dozens of "less common" languages listed before say English/French/Spanish etc. Be nice if it was like mkvtoolnix that offers the more --common-- languages first and --All-- after. Last edited by mini-moose; 27th June 2013 at 11:37. |
27th June 2013, 11:47 | #3258 | Link |
If you don't expect your files to be played on devices with severely limited reading speed (optical drive, slower memory card/stick, network access) or decoding memory, do not restrict the Profile@Level for the encoder.
27th June 2013, 11:52 | #3259 | Link |
That's what I do, but the unrestricted profile has auto guess, so it still warns about vbv. By the way, I do add level in the custom cmd box, I assume it doesn't have the same effect as vbv settings though.
