Old 9th February 2012, 16:48   #14321  |  Link
colinhunt
DGDecNV + 4-way multiprocessing
Pass 1: 42-43 fps
VPU load: 71-82%
GPU RAM: 662 of 896 MB in use
CPU load: 30-38% (2 x Xeon E5520, 12GB RAM)
I believe the low fps for pass 1 with 6-way split was caused by the VPU choking. My graphics card is an old GTX 275 and judging by the tests so far, I'd say 5-way multiprocessing is the limit for its VPU.
Old 9th February 2012, 17:06   #14322  |  Link
varekai
varekai's Avatar
It's kinda' like asking for a tryout of a lunch at Burger King.
OK! I hear you all... just made a 15$ donation to Mr. Donald A. Graft and DGDecNV...
I got 2 Asus Nvidia Geforce GTX 560 Ti DCII TOP 1GB in SLI.
Will DGDecNV use both GPU's? I'll try it and hopefully get some speed improvements.
regards
Old 9th February 2012, 18:11   #14323  |  Link
Harlem Carmello
Missing folder CERTIFICATE
good Afternoon
I just do the conversion from a Blu-ray to AVCHD with BD Rebuilder take more than 18 hours in the end did not come all the BDMV folder without the CERTIFICATE folder so I did a test starting this folder create a BDMV ISO did not run as expected does anyone know the solution as a folder is missing!
Thank you!
Harlem Carmello is offline   Reply With Quote
Old 9th February 2012, 18:39   #14324  |  Link
Originally Posted by Harlem Carmello View Post
good Afternoon
Thank you!
A CERTIFICATE folder is a part of the Blu-Ray standard and is not required in AVCHD.
Old 9th February 2012, 19:15   #14325  |  Link
LowDead
Elit Amans
Maybe found a bug.. I licensed and installed DG.. Set it up in BDRB and took it for a spin.. Worked but gave me worse result than with DS, for example ~70fps(DG) against ~100+fps (DS). And this was the same test setup and movie as the last speed test.. And now for the bug. For comparison I went back to DS decoding and when I got to main movie it gave me - Failed video encode, aborted.. below are the logs.
[Options]
VERSION=0.40.0.4
MODE=0
ENCODE_QUALITY=3
ONEPASS_ENCODING=0
AUTO_QUALITY=0
TARGET_SIZE=24400
AUDIO_TO_KEEP=eng;jpn;
SUBS_TO_KEEP=deu;eng;ger;swe;
SD_CONVERT=0
OPEN_GOP=1
RESIZE_1080=0
DEINTERLACE=1
SD_TO_1080=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=1
REMOVE_WORKFILES=0
MOVIE_ONLY_LOOP=1
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=0
IVTC_PULLDOWN=1
ASSUME_DVD_PAL=0
UNMASK_CHAPTER=0
COMPLETION_BEEP=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=8250
DTSX=1
B_PYRAMID=1
QUICK_EXTRAS=0
MULTIPROCESS=5
DGDECNV=0
[Paths]
SOURCE_PATH=E:\TEMP\THE GIRL WHO LEAPT THROUGH TIME\
WORKING_PATH=C:\TEMP\
DGIndexNV=C:\VidSoft\BD_Rebuilder\Tools\DG\DGIndexNV.exe
DGDecNV=C:\VidSoft\BD_Rebuilder\Tools\DG\DGDecodeNV.dll
"C:\VidSoft\BD_Rebuilder\tools\x264.exe" "C:\TEMP\WORKFILES\VID_00014.5.AVS" --preset slow
--bluray-compat --ref 4 --b-adapt 1 --b-pyramid strict --weightp 1 --open-gop --qpmin=0
--bitrate 8002 --level 4.1 --qpfile "C:\TEMP\WORKFILES\VID_00014.5.CHP" --sar 1:1 --aud
--nal-hrd vbr --pic-struct --vbv-bufsize 13000 --keyint 24 --min-keyint 1 --ipratio 1.1
--pbratio 1.1 --vbv-maxrate 15000 --threads auto --slices 4 --thread-input -
-stats "C:\TEMP\WORKFILES\VID_00014.AVS.5.264.stats" --pass 1 --output NUL
[02-09-12] BD Rebuilder v0.40.04 (beta)
[18:09:20] Source:  THE_GIRL_WHO_LEAPT_THROUGH_TIME
  - Input BD size: 21,88 GB
  - Approximate total content: [01:43:33.102]
  - Target BD size: 8,06 GB
  - Windows Version: 6.1 [7601]
  - Quality: Highest (Very Slow), Two Pass
  - Decoding/Frame serving: DirectShow [5-way]
[18:09:20] PHASE ONE, Encoding
 - [18:09:20] Processing: VID_00000 (1 of 4)
 - [18:09:20] Extracting A/V streams [VID_00000]
 - [18:09:24] Reencoding video [VID_00000]
   - Source Video: MPEG-2, 1920x1080
   - Rate/Length: 23,976fps, 720 frames
   - Bitrate: 5*356 Kbs
 - [18:09:24] Reencoding: VID_00000, Pass 1 of 2
 - [18:09:30] Reencoding: VID_00000, Pass 2 of 2
 - [18:09:39] Video Encode complete
 - [18:09:39] Processing audio tracks
 - [18:09:39] Multiplexing M2TS
 - [18:09:43] Processing: VID_00009 (2 of 4)
 - [18:09:43] Extracting A/V streams [VID_00009]
 - [18:09:50] Reencoding video [VID_00009]
   - Rate/Length: 23,976fps, 6*257 frames
   - Bitrate: 2*260 Kbs
 - [18:09:50] Reencoding: VID_00009, Pass 1 of 2
 - [18:12:29] Reencoding: VID_00009, Pass 2 of 2
 - [18:14:56] Video Encode complete
 - [18:14:56] Processing audio tracks
   - Track 4352 (jpn): Keeping original audio
   - Track 4353 (jpn): Keeping original audio
   - Track 4354 (jpn): Keeping original audio
 - [18:14:56] Multiplexing M2TS
 - [18:15:10] Processing: VID_00014 (3 of 4)
 - [18:15:10] Extracting A/V streams [VID_00014]
 - [18:17:07] Reencoding video [VID_00014]
   - Rate/Length: 23,976fps, 141*415 frames
   - Bitrate: 8*002 Kbs
 - [18:17:07] Reencoding: VID_00014, Pass 1 of 2
  - Encode failed.  Aborting.
  - BD-Rebuilder v0.40.04 (beta)
  - HAALI Splitter: 1.11.96.14, Ok
  - FFDSHOW: 3882, Ok
  - WIN7 preferred AVC CODEC:  Ok
  - WIN7 preferred VC-1 CODEC:  Ok
  - WIN7 preferred MPEG2 CODEC:  Ok
  - FFDSHOW MPEG2 set to "libavcodec":  Ok
  - FFDSHOW AVC set to "ffmpeg-mt":  Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
[18:17:07] - Failed video encode, aborted
[Status]
LABEL=THE_GIRL_WHO_LEAPT_THROUGH_TIME
VERSION=v0.40.04 (beta)
SOURCE_SIZE=23488221533
SOURCE_VIDEO_SIZE=23466332160
TARGET_SIZE=8650752000
REDUCTION=.367712455792665
RESIZE_1080=0
KEEP_HD_AUDIO=0
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=5
DGDECNV=0
QUICK=0
ENCODE_STEP=1.5
COMPLETED=2
[00000]
AUDIO=
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=21627564
RATE=5356
NSIZE=10887168
FLINK=0
MLINK=-1
[00009]
AUDIO=111
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=255163686
RATE=2260
NSIZE=259049472
FLINK=0
MLINK=-1
[00014]
AUDIO=0110
PGS=010001
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=8341755754
RATE=8002
/LD
Old 9th February 2012, 20:00   #14326  |  Link
I'm guessing you're working on a system that is counting hyperthreading as if it represents "real" processors. BD-RB takes the Windows environment variable NUMBER_OF_PROCESSORS literally. I can see that you have at least 5 splits going on. That's probably bringing your system to a point of degenerated return. I'd suggest you set MULTIPROCESS=2 as a start and see how that works out.
Not sure about the DS error -- try reinstalling to counter the impact of other software that is tweaking your system, that's the usual cure.
Old 9th February 2012, 21:49   #14327  |  Link
Harlem Carmello
So what should I do want to record and view directly on the PS3 flimes intend to write to DVD-dl 8GB did a test and do not run!
Thank you.
Old 9th February 2012, 21:50   #14328  |  Link
Harlem Carmello
Thank you.
Old 9th February 2012, 23:42   #14329  |  Link
Thank you.
Nothing special. Lots of people are using BD Rebuilder for the PS3 -- I don't own one so I can't say for sure what settings to use. I would guess you should turn "strict AVCHD off".
Old 9th February 2012, 23:45   #14330  |  Link
LowDead
Elit Amans
Haven't installed anything between 4002(which worked flawlessly with the same settings on my test disc) and 4004, so I went looking on other things before trying to reinstall.. First I tested to use the x264 from 4002 to see if there were some problems with the new one.. no luck, but this time I noticed that the error comes when initiating the split. The split information line just blinks and then the error comes.. I have more than enough space on my hdd, so it should not be that...
//LD
Old 9th February 2012, 23:54   #14331  |  Link
//LD
Does it run if you turn MULTIPROCESS off? That would at least tell for sure if it was the split.
Old 10th February 2012, 00:02   #14332  |  Link
LowDead
Elit Amans
Yes, turning it off worked.
/LD
Old 10th February 2012, 00:11   #14333  |  Link
omegaman7
omegaman7's Avatar
Jdobbs. Go have dinner on me Or buy some more blu rays, or whatever you want. A big thank you for all you do.
If I can get the GTX 560 Ti here soon, I'll try some more testing
Old 10th February 2012, 00:15   #14334  |  Link
Originally Posted by colinhunt View Post
edit: It looks like GPU Monitor is a POS. I aborted BD-RB and noticed GPU temperature dropping rapidly from 58C to 53C which hints at GPU being used during re-encoding even though GPU Monitor says it's not.
DGDecNV uses the VP engine, not the graphics (GPU) core.
Old 10th February 2012, 00:38   #14335  |  Link
That misinformation is probably my fault... I though it was the GPU as well.
Old 10th February 2012, 00:45   #14336  |  Link
soneca
@ neuron2
What is the gain of the VP5 in relation to VP4, an approximate value?
Old 10th February 2012, 00:47   #14337  |  Link
soneca
Try turning MULTIPROCESS on... my experience has been good with DGDecNV -- and there's no delay added in because the indexing happens concurrently with the audio demuxing.
The difference was very small by using multiprocess=auto(6) ... I'll try using two instances.
Old 10th February 2012, 03:28   #14338  |  Link
NightHawkGuy
I've observed with several test runs on an AMD 6core CPU (Phenom II x6 1090T @3.6Ghz) and an Nvidia GTX460 GPU (VP4) and 4GB memory with Windows 7x64,
that using DGDecNV is up to 25% slower than ffdshow directshow if encoding with x264 on the superfast setting.
However, with the x264 faster setting or lower, DGDecNV is about 7-10% faster than ffdshow on my system.
On my system I can also run with multiprocess for 2 instances using under 3GB RAM total and with DGDecNV and x264 faster setting and 24fps 1080p AVC video source, get speeds of pass1@2.8x(67fps) and pass2@2.1x(51fps)
In pass1 I get about 65% use of all six CPU cores with ~3GB RAM used, and GPU video engine at 99% with 288MB GPU memory used.
In pass2 I get full 100% use of all six CPU cores with ~2.8GB RAM used, and GPU video engine at 80% with 289MB GPU memory used.
Testing with DGDecNV and x264 faster setting with only 1 pass ABR to a 25GB output from a 1080p AVC source, I found with my system I get essentially the same speed with multiprocess off vs 2 instances since the CPU load on all six cores is 100% either way.
In this case I'm getting a speed of about 1.25x (30fps) with 100% CPU load and 50% GPU load.
Appears that on my system that multiprocess mode only speeds up 2 pass encoding at faster or lower settings, especially with the DGDecNV decoder - good for 4-8GB output builds.
And for 25GB (BD-R) builds where 1pass ABR is good enough, I can just run with multiprocess off for good speed on my system.
I measured GPU video engine load using GPU-Z software.
So with my system setup for superfast/veryfast x264 runs regular ffdshow and no multiprocess is ok/best, but for higher quality with smaller output size with x264 setting of faster or lower then DGDecNV decoding and multiprocess=2 is best.
Not sure if adding more RAM to up it to 8-12GB to run at multiprocess=3 would speed it up much more to be worth the ~$50 cost to buy some 8GB DDR3 1600 RAM?
NightHawkGuy is offline   Reply With Quote
Old 10th February 2012, 07:15   #14339  |  Link
Mark_Venture
Help?
I've been using BD Rebuilder successfully for a while now to convert Blurays to MKV (via alternate movie only, MKV Container/1920x1080/Intact Audio), which I put on a windows share to be accessed/played with my LG BD390 and BD570 bluray players (wired gigabit Ethernet).
With build 0.40.4, the files wont play. It looks like they are going to start, but the LG goes right back to the file list.
To upgrade, all I did was like I've done in the past... downloaded the new version, unzipped it, and copied the files into the existing directory (overwriting the old ones).
Any suggestions?
Hope the following info helps. Let me know if anything else is needed...
Here is info on a recode I did of GROUNDHOG_DAY with v0.39.07 that works..
[Status]
LABEL=GROUNDHOG_DAY
VERSION=v0.39.07 (beta)
SOURCE_SIZE=26590912512
SOURCE_VIDEO_SIZE=26590912512
TARGET_SIZE=24641536000
REDUCTION=.926690123510418
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=11
USE_LAVF=0
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00011]
AUDIO=10010
PGS=110000000000000000000
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=24641536000
NSIZE=0
FLINK=0
MLINK=0
[00:10:33] BD Rebuilder v0.39.07 (beta)
  - Source:  GROUNDHOG_DAY
  - Input BD size: 24.76 GB
  - Approximate total content: [01:41:04.057]
  - Mode: MKV Container, 1920x1080, Intact Audio
[00:10:35] PHASE ONE, Encoding
 - [00:10:35] Processing: VID_00011 (1 of 1)
 - [00:10:35] Extracting A/V streams [VID_00011]
 - [00:17:40] Reencoding video [VID_00011]
   - Rate/Length: 23.976fps, 145,392 frames
   - Bitrate: 10,187 Kbs
 - [00:17:40] Reencoding: VID_00011, Pass 1 of 2
 - [01:21:52] Reencoding: VID_00011, Pass 2 of 2
 - [02:28:22] Video Encode complete
 - [02:28:22] Processing audio tracks
 - [02:28:22] Multiplexing M2TS
[02:28:22]PHASE ONE complete
[02:28:22]PHASE TWO - Rebuild Started
 - [02:28:22] Rebuilding stream 00011 [1 of 1]
 - [02:28:22] Building ALTERNATE OUTPUT Structure
[02:33:30] - Encode and Rebuild complete
[02:33:31]JOB: GROUNDHOG_DAY finished.
and info about the file per MediaInfo
General
Unique ID                                : 243937437596447059580597332619115883905 (0xB784A43D6F1D0AACB07DD7DD3B97ED81)
Complete name                            : J:\[Movies]\GROUNDHOG_DAY\GROUNDHOG_DAY_00.MKV
Format                                   : Matroska
Format version                           : Version 2
File size                                : 7.64 GiB
Duration                                 : 1h 41mn
Overall bit rate mode                    : Variable
Overall bit rate                         : 10.8 Mbps
Encoded date                             : UTC 2012-02-07 07:28:23
Writing application                      : mkvmerge v2.9.7 ('Tenderness') built on Jul  1 2009 18:43:35
Writing library                          : libebml v0.7.7 + libmatroska v0.8.1
Video
Format                                   : AVC
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 2 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 1h 41mn
Bit rate                                 : 10.2 Mbps
Maximum bit rate                         : 15.0 Mbps
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Frame rate                               : 23.976 fps
Bits/(Pixel*Frame)                       : 0.205
Stream size                              : 7.04 GiB (92%)
Writing library                          : x264 core 120 r2120 0c7dab9
Encoding settings                        : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x3 / me=dia / subme=1 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=48 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=0 / rc=2pass / mbtree=0 / bitrate=10187 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=15000 / vbv_bufsize=15000 / nal_hrd=vbr / ip_ratio=1.10 / pb_ratio=1.10 / aq=1:1.00
Audio #1
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Codec ID                                 : A_AC3
Duration                                 : 1h 41mn
Bit rate                                 : 448 Kbps
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Stream size                              : 324 MiB (4%)
Audio #2
Format                                   : AC-3
Format profile                           : Dolby Digital
Codec ID                                 : A_AC3
Duration                                 : 1h 41mn
Bit rate                                 : 192 Kbps
Channel positions                        : Front: L R
Bit depth                                : 16 bits
Stream size                              : 139 MiB (2%)
Default                                  : No
Menu
00:00:00.000                             : en:00:00:00.000
00:07:26.863                             : en:00:07:26.863
00:14:12.935                             : en:00:14:12.935
00:18:17.221                             : en:00:18:17.221
00:24:30.385                             : en:00:24:30.385
00:30:43.341                             : en:00:30:43.341
00:34:32.653                             : en:00:34:32.653
00:41:00.624                             : en:00:41:00.624
00:45:54.501                             : en:00:45:54.501
00:52:39.823                             : en:00:52:39.823
00:59:21.182                             : en:00:59:21.182
01:06:08.047                             : en:01:06:08.047
01:14:55.490                             : en:01:14:55.490
01:19:59.169                             : en:01:19:59.169
01:24:11.087                             : en:01:24:11.087
01:32:13.611                             : en:01:32:13.611
Here is the same, done with 0.40.4...
[Status]
LABEL=GROUNDHOG_DAY
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=11
USE_LAVF=0
INSTANCES=1
DGDECNV=0
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00011]
AUDIO=10010
VIDEO2=0
V2MBRATE=0
NSIZE=0
FLINK=0
MLINK=0
[02/09/12] BD Rebuilder v0.40.04 (beta)
[08:19:25] Source:  GROUNDHOG_DAY
[08:19:27] PHASE ONE, Encoding
 - [08:19:27] Processing: VID_00011 (1 of 1)
 - [08:19:27] Extracting A/V streams [VID_00011]
 - [08:26:32] Reencoding video [VID_00011]
   - Bitrate: 8,075 Kbs
 - [08:26:32] Reencoding: VID_00011, Pass 1 of 2
 - [09:28:59] Reencoding: VID_00011, Pass 2 of 2
 - [10:31:52] Video Encode complete
 - [10:31:52] Processing audio tracks
 - [10:31:52] Multiplexing M2TS
[10:31:52]PHASE ONE complete
[10:31:52]PHASE TWO - Rebuild Started
 - [10:31:52] Rebuilding stream 00011 [1 of 1]
 - [10:31:52] Building ALTERNATE OUTPUT Structure
[10:37:01] - Encode and Rebuild complete
[10:37:01] JOB: GROUNDHOG_DAY finished.
and from media info...
General
Unique ID                                : 199774127402341520045391125516082624458 (0x964B18EFB7B37330A3DAEB23CF4637CA)
Complete name                            : J:\[Movies]\1-TEST\GROUNDHOG_DAY\GROUNDHOG_DAY_00.MKV
Format                                   : Matroska
File size                                : 7.07 GiB
Duration                                 : 1h 41mn
Overall bit rate                         : 10.0 Mbps
Encoded date                             : UTC 2012-02-09 15:31:54
Writing application                      : mkvmerge v5.2.1 ('A Far Off Place') built on Jan  2 2012 23:21:10
Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
Video
Format                                   : AVC
Muxing mode                              : Header stripping
Duration                                 : 1h 41mn
Nominal bit rate                         : 8 075 Kbps
Bits/(Pixel*Frame)                       : 0.162
Writing library                          : x264 core 120 r2164 da19765
Encoding settings                        : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x3 / me=dia / subme=1 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=48 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=0 / rc=2pass / mbtree=0 / bitrate=8075 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=15000 / vbv_bufsize=15000 / nal_hrd=vbr / ip_ratio=1.10 / pb_ratio=1.10 / aq=1:1.00
Audio #1
Format                                   : TrueHD
Codec ID                                 : A_TRUEHD
Duration                                 : 1h 41mn
Maximum bit rate                         : 3 069 Kbps
Compression mode                         : Lossless
Audio #2
Format                                   : AC-3
Codec ID                                 : A_AC3
Duration                                 : 1h 41mn
Bit rate                                 : 192 Kbps
Bit depth                                : 16 bits
Default                                  : No
Menu
I did also try unchecking "keep hd audio" from setup. That file also doesn't play.
Old 10th February 2012, 09:44   #14340  |  Link
KiwiKid
I'm guessing the Header stripping listed under Muxing mode in MediaInfo is the problem. It is a quick fix with MkvMerge.
Instructions at this link
http://www.noblemd.info/index.php?op...d=21&Itemid=24
KiwiKid is offline   Reply With Quote
