10th February 2012, 11:58 | #14342 | Link | |
I noticed the version of mkvmerge was changed in the recent BD-Rebuilder releases. The older mkvmerge version with v0.39.07 may not have output MKVs with header compression. Its best to have MKV header compression disabled for most compatability - in the GUI version of mkvmerge this can be set as the default. |
10th February 2012, 12:18 | #14343 | Link |
@neuron2
Can't get DGDecNV to work with BDRB? After Extracting A/V Streams nothing happens? Tried to figure out what's going on and doubledchecked license info and that peculiar line feed but nothing worked. Finally found that the machine ID doesn't match? What's that about? Edit: Just found out that if I go online DGDecNV works?!? Is that it? I have to be connected to the web? When I go offline the machine ID changes and DGDecNV/BDRB won't work!? regards Last edited by varekai; 10th February 2012 at 15:55. Reason: more info added |
10th February 2012, 15:15 | #14344 | Link | |
I had to update the MKVMERGE version so I can add .SUP subtitle support. Last edited by jdobbs; 10th February 2012 at 15:18. |
10th February 2012, 16:43 | #14345 | Link | |
The copy made with 0.40.4, then I used those steps, is now playable. |
10th February 2012, 22:41 | #14353 | Link | |
you can have header stripping turned off permanently: 1. file>options 2. under "mmg" tab, make sure "disable header removal compression for audio and video tracks by default" is checked (v5.3.0 but also was an option in 4.8....not sure about earlier versions) Last edited by Farscape1; 10th February 2012 at 22:43. |
10th February 2012, 23:14 | #14355 | Link | |
Elit Amans
/LD |
10th February 2012, 23:27 | #14356 | Link |
I don't think so... it has to be BD-RB's splitting -- but I can't figure what is different in this case. I'd like to figure it out and put in a fix (as well as the issue reported by The_Unknown) before I post another interim release.
10th February 2012, 23:37 | #14357 | Link | |
Elit Amans
//LD Last edited by jdobbs; 11th February 2012 at 00:18. |
11th February 2012, 01:15 | #14358 | Link |
I'm not sure what's up with MULTIPROCESS, as I'm noticing it's not working well with 40.04. I've noticed as LowDead that something isn't functional as it was. I was going to post to please reactive MULTIPROCESS as 0, 1, 2 or 3 aren't working with my machine anymore.
I also noticed something else, I went back to...40.01 for testing, and when I had reported the video glitch (The Matrix - Revolutions), I didn't notice that BD-RB reported it as VC-1 before or not. So I ripped it again, and tried it with 40.01, and this time I saw VC-1 and MULTIPROCESS=1 showed BD-RB was indeed splitting it. Which could be why the glitch was there...as in your website says it shouldn't work with VC-1. Now, with 40.04 even AVC's, here, with MUTLTIPROCESS 0, 1, 2, or 3 set aren't functioning. I am noticing 1st pass starts with HIGH (98) FPS and slowly it drops to 40 something FPS or lower. I haven't let it go to 2nd pass yet. The changes were made using View/Edit Config and NOT exiting the program for the info above. Code:
[19:37:57] BD Rebuilder v0.40.01 (beta) - Source: ASSAULTONPRECINCT13 - Input BD size: 19.03 GB - Approximate total content: [01:30:49.444] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Automatic cropping of borders enabled - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [19:37:58] PHASE ONE, Encoding - [19:37:58] Processing: VID_00020 (1 of 1) - [19:37:58] Extracting A/V streams [VID_00020] - [19:43:04] Reencoding video [VID_00020] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 130,656 frames - Bitrate: 11,261 Kbs - [19:43:04] Reencoding: VID_00020, Pass 1 of 2 [20:00:37]PHASE ONE aborted by user request ----------------------- [20:00:49] BD Rebuilder v0.40.01 (beta) - Source: ASSAULTONPRECINCT13 - Input BD size: 19.03 GB - Approximate total content: [01:30:49.444] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Automatic cropping of borders enabled - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [20:00:52] PHASE ONE, Encoding - [20:00:52] Processing: VID_00020 (1 of 1) - [20:00:52] Extracting A/V streams [VID_00020] - [20:06:02] Reencoding video [VID_00020] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 130,656 frames - Bitrate: 11,261 Kbs - [20:06:02] Reencoding: VID_00020, Pass 1 of 2 - [21:11:05] Reencoding: VID_00020, Pass 2 of 2 - [23:42:52] Video Encode complete - [23:42:52] Processing audio tracks - [23:42:52] Multiplexing M2TS [23:42:52]PHASE ONE complete [23:42:52]PHASE TWO - Rebuild Started - [23:42:52] Rebuilding stream 00020 [1 of 1] - [23:42:52] Building ALTERNATE OUTPUT Structure [23:50:34] - Encode and Rebuild complete [23:50:34] JOB: ASSAULTONPRECINCT13 finished. ---------------------- [02/10/12] BD Rebuilder v0.40.04 (beta) [10:45:42] Source: ASSAULTONPRECINCT13 - Input BD size: 19.03 GB - Approximate total content: [01:30:49.444] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Automatic cropping of borders enabled - Decoding/Frame serving: DirectShow [3-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [10:45:43] PHASE ONE, Encoding - [10:45:43] Processing: VID_00020 (1 of 1) - [10:45:43] Extracting A/V streams [VID_00020] - [10:50:41] Reencoding video [VID_00020] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 130,656 frames - Bitrate: 5,675 Kbs - [10:50:41] Reencoding: VID_00020, Pass 1 of 2 - [11:47:59] Reencoding: VID_00020, Pass 2 of 2 [12:16:07]PHASE ONE aborted by user request ---------------------- [02/10/12] BD Rebuilder v0.40.04 (beta) [12:16:35] Source: ASSAULTONPRECINCT13 - Input BD size: 19.03 GB - Approximate total content: [01:30:49.444] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Automatic cropping of borders enabled - Decoding/Frame serving: DirectShow [3-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [12:16:37] PHASE ONE, Encoding - [12:16:37] Processing: VID_00020 (1 of 1) - [12:16:37] Extracting A/V streams [VID_00020] - [12:21:32] Reencoding video [VID_00020] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 130,656 frames - Bitrate: 5,675 Kbs - [12:21:32] Reencoding: VID_00020, Pass 1 of 2 [12:22:24]PHASE ONE aborted by user request ---------------------- [02/10/12] BD Rebuilder v0.40.04 (beta) [12:22:44] Source: ASSAULTONPRECINCT13 - Input BD size: 19.03 GB - Approximate total content: [01:30:49.444] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Automatic cropping of borders enabled - Decoding/Frame serving: DirectShow [2-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [12:22:46] PHASE ONE, Encoding - [12:22:46] Processing: VID_00020 (1 of 1) - [12:22:46] Extracting A/V streams [VID_00020] - [12:27:48] Reencoding video [VID_00020] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 130,656 frames - Bitrate: 5,675 Kbs - [12:27:48] Reencoding: VID_00020, Pass 1 of 2 [12:28:00]PHASE ONE aborted by user request ---------------------- [02/10/12] BD Rebuilder v0.40.04 (beta) [12:28:13] Source: ASSAULTONPRECINCT13 - Input BD size: 19.03 GB - Approximate total content: [01:30:49.444] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Automatic cropping of borders enabled - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [12:28:14] PHASE ONE, Encoding - [12:28:14] Processing: VID_00020 (1 of 1) - [12:28:14] Extracting A/V streams [VID_00020] - [12:33:18] Reencoding video [VID_00020] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 130,656 frames - Bitrate: 5,675 Kbs - [12:33:18] Reencoding: VID_00020, Pass 1 of 2 [12:35:37]PHASE ONE aborted by user request ---------------------- [02/10/12] BD Rebuilder v0.40.04 (beta) [12:36:16] Source: ASSAULTONPRECINCT13 - Input BD size: 19.03 GB - Approximate total content: [01:30:49.444] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Automatic cropping of borders enabled - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [12:36:19] PHASE ONE, Encoding - [12:36:19] Processing: VID_00020 (1 of 1) - [12:36:19] Extracting A/V streams [VID_00020] - Extracting A/V to M2TS [VID_00020] - Extracting A/V from M2TS [VID_00020] - Error in attempt to extract audio/subs. - - Error in attempt to extract audio/subs. - [12:48:00] - Failed to retrieve audio, aborted Now most recent test logs.. In this instance MP is set to 1. 3-way is set, looks like, and 1st pass atarts at 95 FPS and slowly drops to 40's but before doing so it climbs to 99. x264 is 1 instance and using 1GB of RAM. Code:
[02/10/12] BD Rebuilder v0.40.04 (beta) [13:05:53] Source: ASSAULTONPRECINCT13 - Input BD size: 19.03 GB - Approximate total content: [01:30:49.444] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Automatic cropping of borders enabled - Decoding/Frame serving: DirectShow [3-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [13:05:53] PHASE ONE, Encoding - [13:05:53] Processing: VID_00020 (1 of 1) - [13:05:53] Extracting A/V streams [VID_00020] - [13:10:52] Reencoding video [VID_00020] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 130,656 frames - Bitrate: 5,675 Kbs - [13:10:52] Reencoding: VID_00020, Pass 1 of 2 Code:
[02/10/12] BD Rebuilder v0.40.04 (beta) [13:18:40] Source: ASSAULTONPRECINCT13 - Input BD size: 19.03 GB - Approximate total content: [01:30:49.444] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Automatic cropping of borders enabled - Decoding/Frame serving: DirectShow [2-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [13:18:42] PHASE ONE, Encoding - [13:18:42] Processing: VID_00020 (1 of 1) - [13:18:42] Extracting A/V streams [VID_00020] - [13:23:50] Reencoding video [VID_00020] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 130,656 frames - Bitrate: 5,675 Kbs - [13:23:50] Reencoding: VID_00020, Pass 1 of 2 [13:25:15]PHASE ONE aborted by user request Code:
[02/10/12] BD Rebuilder v0.40.04 (beta) [13:29:05] Source: ASSAULTONPRECINCT13 - Input BD size: 19.03 GB - Approximate total content: [01:30:49.444] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Automatic cropping of borders enabled - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [13:29:07] PHASE ONE, Encoding - [13:29:07] Processing: VID_00020 (1 of 1) - [13:29:07] Extracting A/V streams [VID_00020] - [13:34:07] Reencoding video [VID_00020] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 130,656 frames - Bitrate: 5,675 Kbs - [13:34:07] Reencoding: VID_00020, Pass 1 of 2 [13:37:02]PHASE ONE aborted by user request ---------------------- Code:
[02/10/12] BD Rebuilder v0.40.04 (beta) [13:39:36] Source: ASSAULTONPRECINCT13 - Input BD size: 19.03 GB - Approximate total content: [01:30:49.444] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Automatic cropping of borders enabled - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [13:39:38] PHASE ONE, Encoding - [13:39:38] Processing: VID_00020 (1 of 1) - [13:39:38] Extracting A/V streams [VID_00020] - [13:44:38] Reencoding video [VID_00020] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 130,656 frames - Bitrate: 5,675 Kbs - [13:44:38] Reencoding: VID_00020, Pass 1 of 2 [13:45:55]PHASE ONE aborted by user request 2nd pass started. 3 processes of x264 using about 50MB+/- each for 14 minutes of processing before it shows FPS. Now ranges from 400 to 700MB each. It started at 40.xx FPS and has slowly dropped to 18.xx at 36% done. The process isn't done and I'll Watch the final result tonight. ----------------------- Code:
[13:47:52] BD Rebuilder v0.40.02 (beta) - Source: ASSAULTONPRECINCT13 - Input BD size: 19.03 GB - Approximate total content: [01:30:49.444] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Automatic cropping of borders enabled - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [13:47:53] PHASE ONE, Encoding - [13:47:53] Processing: VID_00020 (1 of 1) - [13:47:53] Extracting A/V streams [VID_00020] - [13:52:52] Reencoding video [VID_00020] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 130,656 frames - Bitrate: 10,185 Kbs - [13:52:52] Reencoding: VID_00020, Pass 1 of 2 - [14:51:14] Reencoding: VID_00020, Pass 2 of 2
11th February 2012, 01:25 | #14359 | Link |
Didn't the x264 version change between BD Rebuilder v0.40.01 thru v0.40.04?
Could that cause the difference in speed and amounts of RAM used by x264, noted above? Last edited by NightHawkGuy; 11th February 2012 at 02:08. |
11th February 2012, 01:58 | #14360 | Link | |
I'm telling you -- except for fixing the 00006 error, which isn't related to that, the code when using DirectshowSource is identical. I'll go back an check -- but I'm pretty sure that's true. Maybe I'm dense, but as for your post... I read it about 5 times and I can't for the life of me figure out what you're trying to say. I also don't get the connection between what you are saying and LowDead's report. He's reporting an straight-forward error... and that doesn't sound anything like what you're posting. Sticking with only the current version... please tell me what it is (or isn't) doing that you think it should (or should not) be doing??? Last edited by jdobbs; 11th February 2012 at 02:35. |
