Old 22nd September 2024, 18:02   #1441  |  Link
nji
Originally Posted by v0lt View Post
Avidemux and Shotcut support 3DLut.
Both editors are free and open source.
Thanks!
Wouldn't have expected that.
However they don't fit into my workflow with VD2.
Still I could export (huge) lossless results from them, to import into VD2.
Or use the AviSynth with the above script as frame server for VD2.
nji is offline   Reply With Quote
Old 23rd September 2024, 17:11   #1442  |  Link
Originally Posted by Leo 69 View Post
For you personally they may be obsolete, for others they are as relevant as ever.
I don't mean me personally, but rather developers of plugins. The fewer people desperately need something, the lower may be the incentive for a developer to put any efforts in its implementation.
And I absolutely did not mean to point at you. I have similar problems from time to time. Like, I may be the only one who would like to have an audio plugin ported to AviSynth+ 64b, so I may have to learn coding it myself or wait eternally.
Old 25th September 2024, 20:41   #1443  |  Link
rgr
You're not the only one.
rgr is offline   Reply With Quote
Old 1st October 2024, 00:19   #1444  |  Link
isidroco
@isidroco
Try this file - delogo132_x64.zip.
Thanks for the build, is there a possibility to build one which also works with previous VDUB version?
isidroco is offline   Reply With Quote
Old 1st October 2024, 19:24   #1445  |  Link
v0lt
I don't have this problem with filter selection on my computer. I haven't tried using the filter. But I tried compiling the filter a little differently.
delogo132_x64_2024-10-01.zip
Old 2nd October 2024, 04:53   #1446  |  Link
isidroco
Thanks, better, but still doesn't work when tried to use it in my script it gives: Cannot start filters: Filter "DeLogo 1.3.2" is not handling image formats correctly.
I would like to have only oneversion for all, but it's not critical.
Today I captured a NTSC DV. Original VirtualDub2_44282 using any input driver: all OK.
But with VirtualDub2_44282+avlib_vdplugin_0.7.0.123 or VirtualDub2_v2.1.1.609_x64only:
Image is broken using AV Internal input driver. Small sample here: https://www.mediafire.com/file/e0utl...yM60f.avi/file
Using Caching input driver can't see frames after aprox 1 second; seeking gives: error requested frame not found, next valid frame [lastFr]
Using old VDub, directStreamCopied to sample, partial, and full 7gb copy. None of those had problems with caching input. Will try to make a smaller direct sample with original winXP capture machine to upload it .
Unfortunately, new VirtualDub is for now less useful than 44282 which works with all the formats I'm using.
Old 2nd October 2024, 13:13   #1447  |  Link
isidroco
Maybe "Audio/Video interleave input driver", and "Caching input driver" code should be left exactly as it was before, and add a new "FFMPG input driver" to handle newer formats without breaking old ones which could be opened as before...
Old 2nd October 2024, 17:08   #1448  |  Link
v0lt
"Internal DV decoder" does not work correctly due to optimizations in the modern compiler.
Old 3rd October 2024, 04:09   #1449  |  Link
isidroco
Yes, but many of us use vdub to deal with old video formats (recover old footage). So breaking DV support is a deal breaker here... With new caching driver, Sekh enabled ease of use with newer cameras as MOV/MP4, etc, but we could always return to old internal driver for compatible old behaviour . Here that's not working anymore. Maybe using older compiler, or disabling certain optimizations we could restore those lost functions...
Old 3rd October 2024, 16:44   #1450  |  Link
v0lt
Looks like there is a problem with the VisualStudio 2022 compiler.
https://github.com/v0lt/VirtualDub2/...dc41dc6289e1ab
Added:
I wrote to Microsoft about the optimization problem.
Old 5th October 2024, 22:14   #1451  |  Link
isidroco
Thanks for your concern. Maybe it could be compiled with the older working version used for original VDUB2.
More DV tests in old VDUB2: DV audio with caching driver has correct length, but 100ms silence at the beginning which causes slight synchro displacement. With AV interleave internal driver, length is 50ms shorter, but with no silence at the begin, so it's better. Video is the same on both.
Old 6th October 2024, 19:12   #1452  |  Link
v0lt
VirtualDub2_v2.1.2.647 (test build)
Fixed "Internal DV decoder".
(Disabled optimization for VDVideoDecoderDV:: DecompressFrame function. Visual Studio 2022 v17.11.4 was used)
Updated avlib-1.vdplugin to version 0.7.1.154.
FFmpeg 7.1 is now supported.
Updated scripted.vdplugin to version 0.2.0.44.
Fixed a crash when trying to save a read-only file.
Implemented Unicode support. Now script files are read and saved in UTF-8 format.
Old 7th October 2024, 21:08   #1453  |  Link
jay123210599
How do I add the SubText filter from StaxRip to your version of Virtualdub2? How do I cut losslessly at keyframes?
jay123210599 is offline   Reply With Quote
Old 12th October 2024, 09:27   #1454  |  Link
v0lt
VirtualDub supports filters and plugins written for VirtualDub.
VirtualDub can open Avisynth script files, and accordingly you can use Avisynth/Avisynth+ filters.
In general, no way. Because it works with many limitations (especially with modern formats) and the result will not satisfy you (judging by the number and content of your questions).
Old 12th October 2024, 10:28   #1455  |  Link
Another issue: Due to their heavy limitations, not many of these are being developed anymore. And if you find some ancient plugins from other authors, these probably exist in 32-bit code only. But the latest VirtualDub2 only exists in 64-bit code and can't use 32-bit plugins.
You should really learn to use AviSynth or VapourSynth if you seriously want to filter your videos efficiently. VirtualDub2 can serve as a solid host application to feed the results of these scripts to encoders then.
Old 12th October 2024, 22:33   #1456  |  Link
jay123210599
@v0lt @LigH But whenever I use an Avisynth/VapourSynth script, it doesn't use the same codec as the video I put inside it. How do I fix that?
Old 12th October 2024, 22:41   #1457  |  Link
Whenever you want to apply a filter to the video, it needs to be decoded first. And when the video has been filtered, it needs to get encoded again. Nothing can "fix" that. If you want to keep video as compressed as it is, you cannot modify it.
Old 13th October 2024, 00:32   #1458  |  Link
jay123210599
I want to encode the video, but I want to make sure it has the same aspects as the original. For example, I have a YUV444 video, and I want the output to also be a YUV444 video, even though the quality will not be the same due to encoding. My problem is that I insert a script and it doesn't start at the colorspace as my video (e.g. it starts at YUV420 instead).
Old 13th October 2024, 00:48   #1459  |  Link
AviSynth since v2.60 supports the colour format YV24 for chroma subsampling YUV 4:4:4. Most recent plugins for AviSynth+ should support that too. There is no reason to blame VirtualDub2, it can handle that. You will have to learn how you possibly have to force AviSynth source plugins to read your video in a way that it decodes to YV24 if you need YUV 4:4:4, or to convert it to that format in your script. But that's not a matter of this forum thread.
Old 16th October 2024, 03:35   #1460  |  Link
Hushpower
@Volt, FYI, the file in this post:
https://forum.videohelp.com/threads/...on#post2753941
won't open in your Vdub 2.1. It throws an error:
"FFMPEG: Unsupported Channel Layout"
The original VDub2 hosted on VideoHelp will open the file OK. I did some checks and it seems the error is caused by the updated avlib-1.plugin file or associated DLLs, back as far as "avlib_vdplugin_0.7.0.93".
Hushpower is offline   Reply With Quote
