13th August 2015, 10:50 | #32541 | Link | |
I went through the net-protocol.txt, and the madTPG* source files, but since I'm not c++ programmer, I don't understand anything about it. Can somebody give me a 'curl' bare minimum example with which I can toggle input source level (CRTL+SHIFT+ALT+I)? (IP is known, and I don't care about error handling for now), like this (question is the content-type, and the method, and the params ) : Code:
curl -H 'content-type: application/json' -X POST http://192.168.1.50:37612/ -d '{"command":"toggleInputSourceLevel"}'
13th August 2015, 12:46 | #32542 | Link | |
I use Auto/24p on mine which means it uses Graphics for the desktop and gaming to minimise input lag, but auto switches to Cinema Scene mode if it detects a 24fps input. I'm starting to warm to the Standard motionflow option lately as it eradicates 24fps stutter on fast pans (not 3:2 pulldown judder as my set handles 24hz properly, but the effect of 24fps simply not been a high enough framerate smoothly display fast panning). There's an element of 'soap opera effect' as it's usually referred to, which I despised for a long time. But the more I live with it then the more I'm beginning to actually like what it does and appreciate that a higher framerate (even interpolated) is almost always just simply superior for displaying video. |
13th August 2015, 14:36 | #32543 | Link | |
HFR is definitely the future. We'll see soon as UHD-BR is just around the corner.
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410. |
13th August 2015, 16:37 | #32545 | Link |
I want to ask a question. Is it useful using technologies such as VSR or DSR alongside with madVR? Right now I'm trying 2560x1440 with my FHD TV and I think it looks better if you have the computing power to use it.
Thanks in advance. |
13th August 2015, 17:45 | #32547 | Link | |
Chroma: Jinc AR Image: Jinc AR Down: CR AR LL Doubling: Was using NNEDI 64 before trying VSR and now I'm using Super-XBR 100. My hardware for reference: I5 3570k@4.2Ghz-/-HD7870@1100/1375-/-16 Gb RAM |
13th August 2015, 17:49 | #32548 | Link |
Windows 10 and madrv - problems with switching from FSE to windowed
I sometimes watch content on my TV with the monitor in the other room on. So in this case the pc is running cloned dual monitor setup. In windows 10 I noticed that the screen is black for a few seconds when starting a video file in FSE – and also goes black for a second if switching to windowed mode. After this it doesn’t happen until I open another video file. Then it does it again. Also it seems that video playback is not smooth but choppy until I change from FSE to windowed and back to FSE again. These problems with switching from FSE to windowed mode dint happen in windows 8. It also doesn’t happen when only using one monitor.
I am unsure however if it is windows 10, driver issues, or something that can be fixed in madvr. Does any1 have any solutions?
http://hometheatersettings.com - how to setup htpc and more Last edited by Budtz; 13th August 2015 at 17:56. |
13th August 2015, 18:30 | #32549 | Link |
I've made a new thread for motionflow discussion since it's not really madVR related. http://forum.doom9.org/showthread.ph...23#post1734223
13th August 2015, 18:44 | #32550 | Link | |
but what do you think you will win by upscaling and downscaling again? thsi is made for games that can run in a higher resolution unlike videos. |
13th August 2015, 19:45 | #32553 | Link | |
14th August 2015, 02:41 | #32556 | Link |
If madshi doesn't change something, probably yes.
http://www.forum-3dcenter.org/vbulle...0&postcount=17 (He's Nvidia beta tester and says that nothing will change. Keep in mind he's not an official representative though and so it's not an official statement yet.). I'd still prefer a SM5.0 implementation. |
14th August 2015, 04:32 | #32557 | Link |
beside the 15.7.1 glitches and crashes because of driverbugs...
14th August 2015, 06:25 | #32558 | Link | |
But it's only for Windows 7/8.1. They are still on the process of making a Tweaked Driver for Windows 10. I'm using it on my Windows 8.1 Machine FX-8320@4.3ghz/2X HD7850 and so far performance and stability are superb running MadVR on FSE 10bit. |
14th August 2015, 06:57 | #32559 | Link | |
Intel i5 3470, EVGA GTX 1050Ti SC ACX 2.0, Windows 10 Pro 64 bit, 16 GB 1600 mhz DDR3 RAM |
14th August 2015, 10:04 | #32560 | Link | |
http://www.tweakforce.com/modules.ph...viewforum&f=28 And for Tweaked Nvidia Drivers http://www.tweakforce.com/modules.ph...viewforum&f=36 |
