Old 19th May 2023, 01:36   #781  |  Link
drunksunk
Originally Posted by VoodooFX View Post
There is no magic button to "fix it", there are many ways for many different videos, you need to understand what the arguments do to get desired result.
Without video you are on your own.
HERE is the video.
Honestly I think the upscaled version would have been better but the AVS plugin can't seem to open that (maybe 12GB is too big) and always says it cannot find the find somehow.
I tried to create the mask manually by using the SVG version of the logo, dunno if you can get a better result automatically. https://i.imgur.com/PpdLlG1.png
I think it would be actually cool if there was a function where you can pass an svg logo as an rgument and it looks for the logo within the frame and automatically scale it perfectly to fit and then generates a mask.
drunksunk is offline   Reply With Quote
Old 19th May 2023, 19:59   #782  |  Link
katzenjoghurt
When I was thinking about "Turbo" argument I had idea to dowsample stuff then inpaint, maybe such approach would work here.
I think that would be cool.
I once tried to inpaint a UHD Video with a really big logo.
No way to get a good result with default settings - the noise in the inpainted corner was way too distracting.
But the result was ok when I downsized the video to 480p, and inpainted the logo with Sharpness=1.
It was superblurry of course but also calm so that it didn't distract and still way better than with the original logo.
But there was no way to reproduce the same thing directly in the UHD source.
In the UHD video Sharpness=1 didn't create anyway near the same amount of blur as it did in 480p.
dPP/oPP couldn't compensate for that.
Old 21st May 2023, 03:05   #783  |  Link
drunksunk
So nobody knows how to fix?
Old 27th May 2023, 17:44   #784  |  Link
drunksunk
Anybody still alive?
Old 29th May 2023, 10:17   #785  |  Link
katzenjoghurt
I'll chime in, even if I only have a mediocre solution for you.
1) Get a better version of that video from here:
https://assets14.ign.com/videos/zenc...26343076-w.mp4
(It's a 817MB file with a 5000kbps encoding rather than your 3000kbps clip)
2) It's actually pretty tricky to create a proper mask due to (I guess)
a) encoding artifacts
b) very transparency parts of the logo
c) hard enbedded subtitles overlapping with the logo at times - InpaintDelogo will add them to the mask
So I selected only parts where the subtitles aren't overlapping with the logo.
Trim(0,340) + Trim(1235,3662) + Trim(4152,4684) + Trim(4982,6685) + Trim(7068,8111) + Trim(8344,8878) \
+ Trim(9325,9495) + Trim(10091,10560) + Trim(10815,11348) + Trim(11603,13157) + Trim(13328,14477) \
+ Trim(14605,16117) + Trim(16372,17713) + Trim(17884,18756) + Trim(18927,19991) + Trim(20779,22674) \
+ Trim(22993,25399) + Trim(25591,26293) + Trim(26655,27336) + Trim(27741,30147) + Trim(34852,35022)
InpaintDelogo(mask="V:\Logos\Test\IGN.bmp", Loc="1572, 906, -20, -60", Mode="Deblend", Automask=1, Analyze=3)
But still I had to overpaint some gaps manually afterwards with MS Paint.
Here's the resulting mask:
https://i.ibb.co/RSWVvc0/IGN.png
3)
The deblending analysis I did with these parameters:
InpaintDelogo(mask="V:\Logos\Test\IGN.bmp", Loc="1572, 906, -20, -60", Mode="Deblend", Automask=0, Analyze=-2, Deep=5, Optimize2=2, Interp=0)
Keep the the trims as the overlapping subtitles will also be a problem here.
Due to that overlapping, interpolation would also warp the subtitles in a pretty nasty way. So I disabled it with Interp=0.
But (also) due to that more remains of the logo are visible, especially whenever the background is rather bright.
We can't fight it with more blurring (by going to lover dPP levels) as that would also blur the subtitles.
Check it out for yourself.
Download the mask above, reconvert it to bmp and try these lines:
(edit: trims added)
Hope that helps.
Old 29th May 2023, 16:35   #786  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
@katzenjoghurt Nice result!
I see you used negative Analyze, were results with positive worse?
VoodooFX is offline   Reply With Quote
Old 29th May 2023, 19:00   #787  |  Link
katzenjoghurt
Hey VoodooFX,
I find Analyze=-2 (or -1), Deep=5 still useful in many cases.
Please never remove it.
Here it helps with the IGN icon.
Source:
Analyze=3:
Analyze=2:
Analyze=-2:
Old 30th May 2023, 01:27   #788  |  Link
drunksunk
Thanks for the great work. Is it normal that you still get a sign on the bottom right corner? https://imgur.com/a/pCZfds7
My code looks like this:
LWLibAvVideoSource("D:\Z_DELOGO\IGN.mp4")
InpaintDelogo(mask="D:\Z_DELOGO\IGN.bmp", Loc="1572, 906, -20, -60", Mode="Deblend", Automask=0, Analyze=-2, Deep=5, Optimize2=2, Interp=0)
Also, what's the difference between using a bmp mask vs png?
Old 30th May 2023, 09:14   #789  |  Link
katzenjoghurt
Argh. My bad. I mentioned that you would need to keep the trims for deblend analysis but my "quick guide" at the end neglected it.
I edited it.
The "signs" are the result of InpaintDelogo analyzing frames where the subtitles overlap with the logo. With the Trims these frames will be skipped.
1) Add the Trims
2) delete the old created .ebmp deblend files or add ReAnalyze=1 for one run
3) The "signs" should be gone now.
4) Remove the Trims.
Oh. I just wasn't aware that InpaintDelogo happily accepts pngs.
Old 30th May 2023, 13:14   #790  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Originally Posted by katzenjoghurt View Post
Hey VoodooFX,
Strange, negative Analyze should be useful only in very rare cases like in some very short clips.
Old 30th May 2023, 16:17   #791  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Here are my results on that 480MB zzz.mp4 file.
Getting a basemask with Automask:
LWLibAvVideoSource("D:\zzz.mp4")
InpaintDelogo(mask="D:\mask.bmp", Loc="1570, 904, -28, -58", Analyze=-4, Automask=1, aMix=3)
Getting a deblend mask [no need for trims with Analyze 1/-1] and delogo:
InpaintDelogo(mask="D:\mask.bmp", Loc="1570, 904, -28, -58", Mode="Deblend", Analyze=1, dPP=-5)
1) Original [frame 6554]:
2) Delogo Analyze=1
3) Delogo Analyze=-1, Deep=5:
In #3 there are less artifacts on that circle at the left but rest looks a bit worse than 2.
Actually negative Analyze looks worse than positive, that artifacts reduction comes from deblend iteration aka Deep [which is not implemented for positive Analyze].
Old 30th May 2023, 16:57   #792  |  Link
kedautinh12
Why you don't add deep for positive Analyze??
Old 30th May 2023, 22:15   #793  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
I didn't see it useful anywhere with positive Analyze and in general it's a nonsensical "hack".
EDIT:
Just tested now, AnalyzeTh=45 produced similar reduction on artifacts on that circle without making worse the rest of deblend like Deep:
InpaintDelogo(mask="D:\mask.bmp", Loc="1570, 904, -28, -58", Mode="Deblend", Analyze=1, AnalyzeTh=45, dPP=-5)
Last edited by VoodooFX; 31st May 2023 at 01:09. Reason: Typo: was Analyze instead of AnalyzeTh
Old 4th June 2023, 14:40   #794  |  Link
drunksunk
So, using the higher quality 817MB video, which of all proposed solutions gives the best results?
Old 4th June 2023, 18:36   #795  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
But that's what YOU should tell us.
Old 10th June 2023, 22:21   #796  |  Link
drunksunk
Why do you want to remove logos from some youtube gaming videos?
Yes:
# Here you import your video:
LWLibAvVideoSource("D:\test4k.mp4")
# Here we crop black borders from video:
Crop(0,250,0,-250)
# Here I located logo coords [+20 pixels from logo edges]:
# Crop(3300,0,-240,-1466)
# Here we do delogo [first run with Automask=1 to get a basemask automatically, then set it to 0 to do analyze and delogo]
InpaintDelogo(Loc="3300,0,-240,-1466", mask="D:\mask.bmp", Automask=0, aMix=-2, NoBorderAt="top", AnalyzeTh=30, mode="Deblend", dPP=-5, Interp=3, Optimize2=2)
Before:
After:
I used the same rule you used here, just different coordinates but I get a poor result with this video.
The logo is basically the same, just a bit smaller, so I thought the same rules would work fine.
Old 11th June 2023, 14:32   #797  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Post your full avs script.
Old 12th June 2023, 00:05   #798  |  Link
drunksunk
LWLibAvVideoSource("D:\Z_DELOGO\b\copy.mp4")
#Crop(1650,50,190,180)
InpaintDelogo(Loc="1650,50,190,180", mask="D:\mask.bmp", Automask=1, aMix=-2, NoBorderAt="top", AnalyzeTh=30, mode="Deblend", dPP=-5, Interp=3, Optimize2=2)
Old 12th June 2023, 15:38   #799  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
You don't need NoBorderAt on this video. And you are analyzing frames without logo and frames with logo fade in/out animations, exclude those parts of video with Trim().
On frames with logo animation use mode=Inpaint.
Old 12th June 2023, 22:45   #800  |  Link
drunksunk
You need to duplicate the InpaintDelogo command for some frames with mode=Inpaint? Not sure I understood that well.
delogo, hardsubs, ocr, remove, watermark
