5th January 2014, 10:55 | #3801 | Link | |||
Do you check other SP? Quote:
5th January 2014, 14:30 | #3803 | Link |
Please try this build:
http://megui.org/test/MeGUI.zip |
5th January 2014, 21:20 | #3804 | Link | ||
6th January 2014, 00:48 | #3806 | Link |
Anime addict
Hi, I imagine that I gonna to say, could be stupid. But I have installed last version of Framework, and megui detects as:
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite |
7th January 2014, 09:27 | #3808 | Link |
@Zathor
When I let Megui ignore some updates (in example xvid_encraw or mp4Box), why MeGUI me offers them often in the coming opening of the program? It seems that it does not remember that I had ignored these items ... |
7th January 2014, 09:44 | #3809 | Link |
I would welcome a list of required tools without which MeGui won't run.
I typically only encode video into x264, and audio into either FLAC or mp3 - and yet I am forced to download all kinds of stuff which MeGui marks as crucial, but what I never used and never will. I'd like to be able to freely decide. Is it too hard to implement it so that you don't have to download any additional components, and get an update popup only when you try to use some functionality dependant on them instead? |
7th January 2014, 21:29 | #3810 | Link |
Which build are you using? I changed it in the last builds that only required or needed components are downloaded. But as this is a new feature as may not work in every scenario as expected. I need your autoupdate.xml and settings.xml files (in the root of MeGUI) to check that.
8th January 2014, 05:26 | #3811 | Link |
i seem to be getting errors using lsmash now.
--[Information] [8/01/2014 5:18:39 p.m.] Generated Avisynth script ---[NoImage] LoadPlugin("D:\MEGUI\tools\lsmash\LSMASHSource.dll") ---[NoImage] LWLibavVideoSource("J:\TMP\1jjua4yb.ext\STATEN_ISLAND_t00.mkv.lwi") ---[NoImage] #deinterlace ---[NoImage] crop(0, 130, 0, -132) ---[NoImage] BicubicResize(1280,546,0,0.5) # Bicubic (Neutral) ---[NoImage] super = MSuper(pel=2, sharp=1) ---[NoImage] backward_vec1 = MAnalyse(super, isb = true, delta = 1, overlap=4) ---[NoImage] forward_vec1 = MAnalyse(super, isb = false, delta = 1, overlap=4) ---[NoImage] MDegrain1(super, backward_vec1, forward_vec1,thSAD=400) --[Error] [8/01/2014 5:18:41 p.m.] An error occurred ---[Error] [8/01/2014 5:18:41 p.m.] Exception message ----[NoImage] The file J:\TMP\1jjua4yb.ext\STATEN_ISLAND_t00.mkv.avs cannot be opened. ----[NoImage] Error message for your reference: [Fatal]: Failed to avformat_open_input. ----[NoImage] (J:\TMP\1jjua4yb.ext\STATEN_ISLAND_t00.mkv.avs, line 2) ---[Error] [8/01/2014 5:18:41 p.m.] Stacktrace ----[NoImage] at MeGUI.JobUtil.GetAllInputProperties(UInt64& nbOfFrames, Double& framerate, Int32& framerate_n, Int32& framerate_d, Int32& hRes, Int32& vRes, Dar& dar, String video) ----[NoImage] at MeGUI.JobUtil.getInputProperties(UInt64& nbOfFrames, Double& framerate, String video) ----[NoImage] at MeGUI.OneClickPostProcessing.StartPostProcessing() ---[Error] [8/01/2014 5:18:41 p.m.] Inner exception ----[Error] [8/01/2014 5:18:41 p.m.] Exception message -----[NoImage] [Fatal]: Failed to avformat_open_input. -----[NoImage] (J:\TMP\1jjua4yb.ext\STATEN_ISLAND_t00.mkv.avs, line 2) ----[Error] [8/01/2014 5:18:41 p.m.] Stacktrace -----[NoImage] at MeGUI.AviSynthClip..ctor(String func, String arg, AviSynthColorspace forceColorspace) -----[NoImage] at MeGUI.AvsFile..ctor(String script, Boolean parse) -----[NoImage] at MeGUI.JobUtil.GetAllInputProperties(UInt64& nbOfFrames, Double& framerate, Int32& framerate_n, Int32& framerate_d, Int32& hRes, Int32& vRes, Dar& dar, String video) ----[Error] [8/01/2014 5:18:41 p.m.] Inner exception: null --[Information] [8/01/2014 5:18:41 p.m.] Job completed STATEN_ISLAND_t00.mkv.avs Code:
LoadPlugin("D:\MEGUI\tools\lsmash\LSMASHSource.dll") LWLibavVideoSource("J:\TMP\1jjua4yb.ext\STATEN_ISLAND_t00.mkv.lwi") #deinterlace crop(0, 130, 0, -132) BicubicResize(1280,546,0,0.5) # Bicubic (Neutral) super = MSuper(pel=2, sharp=1) backward_vec1 = MAnalyse(super, isb = true, delta = 1, overlap=4) forward_vec1 = MAnalyse(super, isb = false, delta = 1, overlap=4) MDegrain1(super, backward_vec1, forward_vec1,thSAD=400)
A Man Eating Duck Last edited by AMED; 8th January 2014 at 05:29. |
8th January 2014, 07:30 | #3812 | Link |
2452 [Audio Encoder] lowered also the priority for the audio decoder [Audio Encoder] default order: NicAudio, BassAudio, FFAudioSource, LWLibavAudioSource, DirectShow "NicAudio, FFAudioSource, DirectShow, BassAudio, LWLibavAudioSource" is the listed order. Last edited by hello_hello; 8th January 2014 at 07:34. |
8th January 2014, 08:15 | #3813 | Link | |
8th January 2014, 09:06 | #3816 | Link | |
I'm using the last build 2457 |
8th January 2014, 11:24 | #3817 | Link |
Updated to 2457 and now the audio encoder is reporting this error:
[Error] Log for job52 (audio, T3_Audio - English.ac3 -> T3_Audio - English_new.ac3) -[Information] [1/8/2014 4:15:45 AM] Started handling job -[Information] [1/8/2014 4:15:45 AM] Preprocessing -[Information] [1/8/2014 4:15:45 AM] MediaInfo --[Information] File: C:\Users\xxxxx\Videos\T3_Audio - English.ac3 --[Information] General ---[Information] Format: AC-3 ---[Information] FormatString: AC-3 ---[Information] FileSize: 229557760 ---[Information] PlayTime: 00:47:49.472 --[Information] Audio ---[Information] ID: ---[Information] StreamOrder: ---[Information] Format: AC-3 ---[Information] FormatProfile: ---[Information] FormatSettingsSBR: ---[Information] FormatSettingsPS: ---[Information] SamplingRate: 48000 ---[Information] SamplingRateString: 48.0 KHz ---[Information] Channels: 6 ---[Information] ChannelsString: 6 channels ---[Information] ChannelPositionsString2: 3/2/0.1 ---[Information] BitRateMode: CBR ---[Information] Delay: ---[Information] Title: ---[Information] Language: ---[Information] LanguageString: ---[Information] Default: ---[Information] DefaultString: ---[Information] Forced: ---[Information] ForcedString: -[Information] [1/8/2014 4:15:45 AM] Trying to open the file with NicAudio -[Information] [1/8/2014 4:15:46 AM] Successfully opened the file with NicAudio -[Information] [1/8/2014 4:15:46 AM] Avisynth script --[NoImage] LoadPlugin("C:\Personal\MeGUI\tools\avisynth_plugin\NicAudio.dll") --[NoImage] NicAc3Source("C:\Users\xxxxxxx\Videos\T3_Audio - English.ac3") --[NoImage] LoadPlugin("C:\Personal\MeGUI\tools\avs\plugins\Shibatch.dll") --[NoImage] SSRC((AudioRate()*1001+480)/960).AssumeSampleRate(AudioRate()).TimeStretch(pitch=Float((AudioRate()*1001+480)/960)*100.0/Float(AudioRate())) --[NoImage] return last -[Information] [1/8/2014 4:15:46 AM] Commandline used: -readtoeof 1 -b 448 - "{0}" -[Information] [1/8/2014 4:15:46 AM] Avisynth script environment opened -[Error] [1/8/2014 4:15:46 AM] An error occurred: Script error: There is no function named 'TimeStretch'. -[Information] [1/8/2014 4:15:46 AM] Job completed |
8th January 2014, 22:59 | #3820 | Link | |
