26th August 2020, 14:22 | #2181 | Link |
I'm having a weird issue with avisynth colourspaces in the preview window in staxrip. I'm not sure if this is intentional behaviour or if I'm just missing something, as I don't fully understand this
if I assign my source clip to a variable, and then return that variable, the preview window stops working as expected, and instead shows "raw" data (I think) which varies depending on the colourspace - so instead of seeing the image as expected, I see multiple squished grey images as well as some glitchy stuff (I think this is each plane of the colourspace side by side, and some other data appearing visually) so this happens if the bottom of my script looks like this Code:
clip1 = last return clip1 however, despite the preview looking weird, the actual output generated when I run the script will be normal and correct - it's only the preview window that's affected this way I can make the preview window look correct if I convert the clip to RGB - but this then produces a flipped output (apparently RGB space is upside-down) so I also need to flip it vertically - then I can preview the output the way I expect to Code:
return clip1.ConverttoRGB().FlipVertical() is there a reason for this to be happening this way, and is there any way I can stop it? other than modifying my script for when I need to preview it, and then correcting it when it's time to generate the output? |
4th September 2020, 15:53 | #2182 | Link |
StaxRip-x64-2.1.4.3-Beta
There is a very inconvenient moment. When the encoding of files ends and the assembly into the container begins, an obstacle to the program may arise, for example, the free disk space has run out, a file in the temp folder is missing, or something else ... a banner flies out and everything that was done is reset . You can only manually continue the build from what was saved in the temp folder by another software. It would be correct if the program stopped and waited for the user to fix the error. Thanks. Last edited by hevron; 4th September 2020 at 16:01. |
4th September 2020, 19:04 | #2183 | Link |
But unfortunately that would not be compatible with the batch logic. If you do so, the whole batch will wait, and you eventually realize that Staxrip didn't process the jobs due to a single error.... Of course that would make sense for insufficient free space, but not for other reasons...
5th September 2020, 09:19 | #2185 | Link |
But it would'nt change much because mainly the problems occur when muxing. If video is already processed, when you reload the job and re-create it (with NEXT), if no modification has been made in the video settings, you'll be asked if you want to use the already encoded video, so you can finish processing quickly, without encoding again.
6th September 2020, 21:12 | #2186 | Link |
I am not able to hardcode subtitles when encoding a 4K HDR source with mostly default settings. I selected the vobsub (.idx) subtitle file that was converted automatically with BDSup2Sub.
Attached is the log file. What am I doing wrong? Edit: got it working. I had to use VapourSynth instead of the default AviSynth. Last edited by creeve4; 6th September 2020 at 22:54. |
7th September 2020, 01:43 | #2187 | Link |
Just in case anyone was waiting for it there is a new beta out that includes working hardware accelerated video decoding with DXVA2 so if you have any large 4K or 8K files they would probably greatly benefit from this acceleration, I know mine did.
7th September 2020, 08:36 | #2188 | Link |
@creeve4 your log file is still pending approval, I can't see it. You could put it on a free external site like pastebin.com and link to it here (instantly and easily) to avoid long waitss like now.
I would guess you're using avisynth. The Avisynth version of hardcoded subs filter (with ctrl+h) does not work with 10bits+ sources. But VapourSynth version does. I hope this replies to your problem. |
7th September 2020, 15:09 | #2189 | Link | |
11th September 2020, 05:10 | #2191 | Link |
I have a question about using the HDR Ingest option. When using this, 2 files are generated one of which has the suffix "_HDR10".
The only difference I notice is that the _HDR10 file has an adjusted value for Mastering display luminance (which is less than the original file) and two additional values: Maximum Content Light Level and Maximum Frame-Average Light Level. Neither of these two additional values are present in video files on my blu-ray disks. Both video files appear to play back identically on my HDR TV. What is the purpose of this _HDR10 version of the video? Last edited by creeve4; 11th September 2020 at 13:46. |
19th September 2020, 23:20 | #2193 | Link | |
22nd September 2020, 22:05 | #2194 | Link |
Has anyone had success with increasing 'chunks' to something more than 1? I've tried changing it to 2 a couple times now but the resulting video is corrupted right around the middle in several spots. Not sure if this is an issue with staxrip or something else.
staxrip 2.1.3.7, Ryzen 3900X CPU. Example: https://imgur.com/a/WF1ZtC7 If I leave chunks at 1 the result has no corruption issues but it takes much longer. My understanding is that 'chunks' basically allows the encoding to be split up into 2 parts and both parts can be encoded simultaneously. If I leave chunks at 1 the time is around 6 hours and with chunks at 2 the result is 4 hours but with corruption in the middle of the video. With chunks at 1 staxrip seems to use about 60% of the CPU. With chunks at 2 staxrip uses about 97% of the CPU. I thought this was a good way to use my CPU and save time but if the result is corrupted obviously this doesn't help. If anyone has thoughts or suggestions that would be great! |
23rd September 2020, 07:35 | #2195 | Link |
MrBrownCow, chunks has been introduced to allow full usage of CPU, especially when using Ryzens with so many logical cores. We made many tests on small files with mkv output, and they worked without corruption. And no one reported such problems until now.
This is very important. We need the log file first (so we can get at least info about staxrip version and what container you are using for output). Paste your log file (that you can still find in the settings folder of staxrip), in pastebin.com, and link to it here. Last edited by 44vince44; 23rd September 2020 at 08:07. |
23rd September 2020, 09:12 | #2196 | Link | |
Maybe its a filter or setting? I'm open to ideas and thankful for any help here. https://pastebin.com/vhpyLkZH |
23rd September 2020, 09:20 | #2197 | Link |
MrBrownCow, thanks for the log file, I will do some testing later today, using filters. Our previous tests did not include filters, and were made with an older version of Staxrip. So maybe it's a matter of filters, or a regression with newer versions. So this this important!. I'll get back tomorrow to confirm.
Edit: the problem is not due to merging the chunks: the garbled frame is at 52:38 while the cutting point is at something like 55:55, so it's gonna hard to find the reason.... Mr BrownCow, can you please check if the output video has corruption around 55m56s Last edited by 44vince44; 23rd September 2020 at 14:02. |
24th September 2020, 22:55 | #2199 | Link | |
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
