24th July 2019, 15:29 | #661 | Link |
So I did more tests and it turns out it's the video player. I use PotPlayer to watch and take snapshots and it seems PotPlayer shows 10bit video a little different than 8bit video. Slightly brighter and more yellow.
I used VLC to take snapshots and it seems VLC shows more accurate colors. Snapshots taking with VLC from 8bit and 10bit show the same colors. What other software do you recommend for taking accurate snapshots from videos? |
24th July 2019, 19:22 | #664 | Link |
Next mpv.net to be released this weekend has config editor support for all of mpv's screenshot settings.
https://mpv.io/manual/master/#options-screenshot-format
31st July 2019, 23:18 | #666 | Link |
Anyone built a Ryzen 3xxx machine yet like 3900X? Curious how staxrip performs on intel i9-9900k vs AMD 3900X. All the benchmark guys always use handbrake and I assume the results would be similar for staxrip. Just curious if anyone's built a new ryzen machine and tested or not.
1st August 2019, 00:34 | #667 | Link | |
x265 > Other > Decoder and: x265 > Other > Piping Tool
2nd August 2019, 03:42 | #669 | Link |
Tried the latest version. I've re-extracted a few times, regardless if I run the .exe from the 4.7 or 4.8 I get this same error.
DirectoryNotFoundException (2.0.2.4) Could not find a part of the path 'C:\Encoding Tools\Staxrip.2.0.2.4.x64\v4.8\Apps\Versions.txt'. System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Encoding Tools\Staxrip.2.0.2.4.x64\v4.8\Apps\Versions.txt'. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.StreamReader..ctor(String path, Encoding encoding, Boolean detectEncodingFromByteOrderMarks, Int32 bufferSize, Boolean checkHost) at System.IO.StreamReader..ctor(String path, Encoding encoding) at System.IO.File.InternalReadAllLines(String path, Encoding encoding) at StaxRip.Package..cctor()" EDIT Apparently you just take the contents from 4.8 and bring it into the root folder and it runs perfectly! My apologies. Where can I get the correct FFMS2 version? It's saying the latest version here isn't supported? (https://github.com/FFMS/ffms2) So the program is calling for FFMS2 version 2.3.0 but that doesn't exists? I can't find it on google/github anywhere? The only version I can find is 2.23.1 and it was made a good while ago. What am I missing here? Last edited by jlw_4049; 2nd August 2019 at 16:04. |
2nd August 2019, 08:52 | #670 | Link | |
mpv.net is my new favorite project, using it every day, it's been great fun working on it. Anyway, I'm trying not to code some days and then I think I can write a little code for staxrip and upload an executable, but no tools, Revan does manage that. It would probably be possible to manage this together but it would need some server technique and it's not the kind of stuff I know much about.
3rd August 2019, 01:12 | #671 | Link | |
Noob
i update avs/vs plug-ins, and other integrated tools manually, no problem in that. just sometimes i make mistakes if some x265 options are not in GUI. I'll try to be more careful with that. |
5th August 2019, 11:03 | #673 | Link | |
Useful n00b
EDIT: Poster edited out the torrent file name. Last edited by videoh; 5th August 2019 at 14:14. |
5th August 2019, 15:27 | #674 | Link |
Latest version of StaxRip. I notice that after you index a source (specifically 4K with ffvidesource) it minimizes StaxRip and does something in the background for about 5 to 10 minutes before it comes back up and you are able to make changes with the UI etc.
However, on the last release it didn't seem to do this. Last edited by jlw_4049; 5th August 2019 at 19:53. |
6th August 2019, 02:28 | #675 | Link |
Inspector Gadget
I can do the 9900k part for you. I don't have a 3900 build though.
P.S. To the people wanting new x265 features go to msystem.waw.pl/x265/ and get the latest VS 2019 AVX2 under the stable branch (use the ~15MB exe it contains 8+10+12 bit) and replace the old x265 in [StaxRip Folder]\Apps\Encoders\x265 |
6th August 2019, 09:17 | #676 | Link |
@stax76
Hello Frank. Are there two versions maintained by you and Revan654 or just one and where can someone find it/them ? I can see a numbering of latest official build of 2.0.2.4 here https://github.com/Revan654/staxrip/...es/tag/2.0.2.4 but the same version has also a different number of 2.0.0.30 here https://ci.appveyor.com/project/Reva...taxrip/history The latest build is 2.0.0.33 here https://ci.appveyor.com/project/Reva...0900/artifacts Thanks.
6th August 2019, 12:36 | #677 | Link |
I'd like to know what's the preferred way of rotating a video using StaxRip (2.0.2.4). My sources come from Ipads and Android phones and sometimes are long enough for me to be willing to use GPU encoding so I use StaxRip for that. But sometimes the sources have improper rotation.
No immediately helpful information about this was found in the help, site or this thread. Or maybe I'm just blind... |
6th August 2019, 15:44 | #678 | Link |
@NikosD
You have to ask Revan about his builds, Revan is now project lead.
6th August 2019, 18:42 | #679 | Link | |
6th August 2019, 19:01 | #680 | Link | |
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
