Old 15th August 2010, 04:29   #8361  |  Link
dragon_warrior
@Atak : Thank you
dragon_warrior is offline   Reply With Quote
Old 16th August 2010, 22:01   #8362  |  Link
glen8
Can someone please tell me if the fps on mpeg2 blu-rays is slightly slower than vc1?
Usually I get a constant 30fps, Now and again up to 45 but with mpeg2 it's a solid 25
Just wondering, thanks
Oh, also I stupidly encoded the same movie twice by mistake and the file sizes were very very slightly different. Only a few k but thought it was strange. Any thoughts?
glen8 is offline   Reply With Quote
Old 17th August 2010, 02:09   #8363  |  Link
pacaveli211
it's not going to encode exactly the same every time. being a bit different is 100% normal
all blurays (main movies) are 24fps (excluding a few 25fps things like BBC life and etc)
encoding fps depends on a lot more things than mpeg2 vs vc1 (and don't forget avc/mpeg4).
such as AR, resolution, and then some things in the movie itself. a lot of fast movements / changes will take longer. whereas a slower really dark movie should go faster
pacaveli211 is offline   Reply With Quote
Old 17th August 2010, 03:47   #8364  |  Link
pacaveli211
hey Atak (or anyone else who might know) if I want to encode something over 25000kbps do I need to modify the profile?
I just noticed my last encode missed the target size by about 1.5GB. but I had set the bitrate to 27000 with the default 4.0 profile
it seems I should change the level to at least 4.1 and the max bitrate to 30000 or however high is necessary, is that correct?
should the buffer be changed to coincide with the max bitrate?
and lastly....having these settings as such (4.1 25000) shouldn't have any negative impact on lower bitrate encodes should they?
like if I use the same profile to encode a bd9
Old 17th August 2010, 04:52   #8365  |  Link
prettyboy85712
4.0 is limited to 25000. Anything higher requires you to switch to 4.1.
prettyboy85712 is offline   Reply With Quote
Old 17th August 2010, 05:04   #8366  |  Link
pacaveli211
yup, have answers to any of my other questions there? =)
Old 18th August 2010, 20:34   #8367  |  Link
MaistroX
Hi!
In the Movie Robots from 2005 I try to get the hole movie but cant seem to get the end with the after texts to be included!
I choose the appropriate mpls, in this case 00850.
mpls and choose the first angle. (tried both)
RipBot does what it should but the movie is missing the aftertexts that are aprox. 6min., what do I do ?
In the mpls i use it uses files:
00818.m2ts+00834.m2ts+00835.m2ts
, but the last part (aftertexts) is in 00821.m2ts!
How do I get the hole movie to be demuxed as one so I can encode the complete movie!
PLEASE HELP!
MaistroX is offline   Reply With Quote
Old 18th August 2010, 22:33   #8368  |  Link
Zorro70
Can you add the correct mpls in ts muxer as you would in ripbot, then ADD the extra 00821.m2ts file and see if it will remux into a blu ray so you can ripbot it????
its just a guess, its one film i havent downloaded so cant try it myself
Zorro70 is offline   Reply With Quote
Old 19th August 2010, 02:03   #8369  |  Link
pacaveli211
if you're choosing a playlist that doesn't include the m2ts with the credits you should check the other playlists, you're probably using the wrong one
use BDinfo
or simply add it with tsmuxer as zorro70 suggested
Old 19th August 2010, 02:37   #8370  |  Link
rack04
I get a avs2yuv crash when I try to load DGDecNV avs file ever since it dropped CUVIDServer.
rack04 is offline   Reply With Quote
Old 19th August 2010, 11:18   #8371  |  Link
MaistroX
Originally Posted by MaistroX View Post
Hi!
PLEASE HELP!
Tryed it, and it does not help, the end resoult is with out the endcredits anyway!
use BDinfo
Tryed to find a playlist WITH the credits, but does not exist from what I can see, this is a major mystery for me.
IS there anyway to tro to manually force together the separate files into one movie file, allready tryed all diffrent ways with TSmuxer, and nothing works, either crash at the end (usually with error msg:
"Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: M:\BDMV\STREAM\00818.m2ts"
or ends...without the credits in the final output ? :/
BDinfo dont show me anything that can help me solve this issue.
Old 19th August 2010, 17:06   #8372  |  Link
pacaveli211
zip your playlist folder for me and upload it (to mediafire). I'll see if I can find anything that you may have missed
also does tsmuxer by chance seem to give that error for any certain stream? or just as a general error?
Old 19th August 2010, 17:40   #8373  |  Link
MaistroX
Here´s the link to Robots playlist -> http://www.mediafire.com/?7gkk4t1bfgi2d2k
Only reason that is given is -> "Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: M:\BDMV\STREAM\00818.m2ts"
When I try to join thoose 4 files.
The movie complete should be Aprox. 90 Mins.
Old 19th August 2010, 17:48   #8374  |  Link
pacaveli211
damn, I need the clipinf folder too
Old 19th August 2010, 18:27   #8375  |  Link
MaistroX
Here´s the clipinfo dir -> http://www.mediafire.com/?z917p6p584sy63p
Old 19th August 2010, 18:52   #8376  |  Link
pacaveli211
bdinfo reads problems with 00334.mpls, 00800.mpls and 00850.mpls
you might want to try pulling the playlist folder and Clipinf folder off the bluray again
I dunno if that's the actual issue....but if the main playlist is truly corrupt it might've dumped some of the data out
Old 19th August 2010, 19:07   #8377  |  Link
MaistroX
This is straight from the original BD -> http://www.mediafire.com/?wzbuarek2s7zcdf
Old 19th August 2010, 19:07   #8378  |  Link
stryker412
I have a question that does not pertain to any particular version of RipBot. I'm just curious (in basic terms) how RipBot determines the bitrates for mkv's? I just ripped a few episodes of "Generation Kill" from BD which are 1hr in length. Using CQ18 I ended up with file sizes around 4GB per episode in 720p. I just tried to do "Book of Eli" which is a 2hr movie and I end up with a file size of 2GB (also in 720p). The bitrate for Eli is only 2.5MB while Generation Kill is 5MBs. I'm just trying to understand how this works.
stryker412 is offline   Reply With Quote
Old 19th August 2010, 20:28   #8379  |  Link
Remicade
After i install latest Haali every video (mkv, avi) stuck at "Please wait...Gathering information". Do you encounter such problem ? Should I reinstall Windows ?
Remicade is offline   Reply With Quote
Old 20th August 2010, 04:30   #8380  |  Link
pacaveli211
I still get the same error, so I dunno man.
maybe try dropping some of the audio / subtitle tracks and see if it gets rid of the buffer overflow error or try demuxing them first. also check to make sure the framerates are the same on all the m2ts files
some movies require a higher bitrate to retain the same quality, while other movies can maintain the same quality with a much lower bitrate. lots of things will factor into this. the colors in the movie, how much action there is, etc. animated movies can be dropped A LOT and still look fine due to how the colors are.
lol....maybe try uninstalling and reinstalling a couple times or something (haali and ffdshow)? is that the first thing you do when you have an issue, reformat? lol
