28th April 2014, 22:34 | #20141 | Link | |
I notice it looks like you've edited the HIDDENOPTS.TXT file. That's just a document -- if you're changing it there it has no effect. You have to edit the file called BDREBUILDER.INI in the BD Rebuilder folder. |
28th April 2014, 22:37 | #20142 | Link | |
That isn't the INI file, that's only a document of available hidden options. Read my last post right above this one.
Here is the first line in the file you posted: Quote:
28th April 2014, 23:31 | #20143 | Link |
I'mmmmm trying to figure it also. Thus far it's the ONLY movie that's doing it. I'll rerip it...possible the first bad rip in a while. I did notice that it does it with either of the 3 Subtitles. I'll also check AnyDVD HD to see if there's a bug fix..?
29th April 2014, 02:15 | #20147 | Link | |
29th April 2014, 03:01 | #20149 | Link |
Since you replied...I'll share this finding. The new BD-RB MKV from AnyDVD HD has the same challenge as I posted before. The other, processed by BD-RB is showing chapters and film time correct. Odd! I don't know enough of what you do, JDobbs, to...explain that. Nice to know I found a work-around for myself..hehe. More testing..
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 29th April 2014 at 07:56. |
29th April 2014, 14:12 | #20150 | Link | |
I did my disc with no issues -- but it doesn't appear to be the same version as yours. Last edited by jdobbs; 29th April 2014 at 14:47. |
29th April 2014, 17:19 | #20151 | Link |
Pacific Rim 3D
Has anyone tried Pacific Rim 3D? I tried encoding it to a BD25 and the picture is excellent. But at the 1:06:16 mark, the picture jumps ahead about 8-10 seconds and the audio stays the same, so the rest of the movie is out of sync. I do not know if this is a BD Rebuilder problem or a FRIM Encoder problem. I was curious if anyone else has tried this movie, and if so, what were your results? I do have the ini and other info I can post if needed. I did re-rip my disc and the problem occurs with the new rip as well. I do not believe my drive is bad, as I ripped other discs before and after this one and they successfully converted.
Any help or insight is greatly appreciated. Thanks. Acerjen |
29th April 2014, 19:06 | #20152 | Link |
@Acerjen
Hi! If you read through this thead, you'll note that specific problem (halted video while audio has continued) has occurred with a fair amount of discs (2D as well as 3D). I'd suggest that you once againg attempt to scrupulously clean your disc. If the problem persists, return it to the place of purchase for a new replacement disc... |
29th April 2014, 19:41 | #20153 | Link | |
See for example the discussion here. |
29th April 2014, 19:42 | #20154 | Link |
me... it should play nice in sync from start to finish ... unless your PR_3D rip is not a region B !! I can't vouch/ be certain for other regions... !! about the A/V playing out of sync, i have re-done all my movies because of that ↑ nuicance by using x264 internal LaVf as frame server .. and .. voila nomore A/V synch problems... that easy.. You might wanna try that too !! P.S: tested many BD-25 (panasonic japan import 4x burned @6x using pioneer BDR-208EBK BDXL) in different stand alones like the ps3, philips BDP-3480 with 0,00% issues Even BD-R brand Mediarange (midcode: LEGBRAS006) 6x certified , capable of writing them @10x with my pioneer do play very VERY NICE succes, Last edited by kabster; 29th April 2014 at 19:51. |
29th April 2014, 20:13 | #20155 | Link | |
If I process the rip with BD-RB, in this case removing the stuff I don't want, to a BD-50 then use that output BD structure to create the MKV the the chapters and film time are as they should be. Why? I don't yet understand. Do you follow now? If not, I'll type the steps? Let me know. Mine comes from Amazon. Combo Pack; Blu-ray, DVD and Ultraviolet.
29th April 2014, 21:18 | #20156 | Link | |
[Edit] I ordered it and should get it Thursday. It wasn't too bad, $18. Last edited by jdobbs; 29th April 2014 at 21:28. |
29th April 2014, 22:14 | #20157 | Link |
I'm trying "Cloud Atlas" from an almost stock INI and direct from rip. Maybe something in the settings is causing it? Testing now..
Edit 1: Hm...still same result. I'm removing ENABLE_TEST=1...as it was the only change I made. Should not affect it but will check. Doing test.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 29th April 2014 at 22:22. |
29th April 2014, 22:14 | #20158 | Link | |
I didn't retry since. It is definitely not a BD-RB problem, it is a stream or decoder pecularity. Last edited by Sharc; 29th April 2014 at 22:33. |
29th April 2014, 22:47 | #20159 | Link | |
