6th May 2014, 23:49 | #20221 | Link | ||
Yes, I just noticed the same thing for BD-25, with the same BD. Total output size was approx 13GB. Anyway, for the sake of trying, I encoded to a BD-25, then used that for the BD-5 encode. It worked very well for reaching the desired BD-5 output size, but encoding twice has always been frowned upon. Always "movie only" for BD-5. Verbatim is great media. I use Verbatim DVD+RW for testing, then JVC/Taiyo-Yuden #TYG02 for final. In truth, if the Verbatim DVD+RWs were priced right, I'd use them instead for final. It has that lovely hard coat/silver bottom. The Taiyo-Yuden's are nice as well, but not as silvery on the bottom. I've tried remuxing to MKV, but BD-5 encode from that is exactly the same as from original BD. I've also tried using custom size @ 4469 (instead of BD-5 default), with no impact. I can always try again Still scratching my head in confusion. I may have to face it that some BDs cooperate as planned, and some do not. I won't give up and will continue testing Sigh.. Quote:
Thanks so much for your reply! I love your software There may have been some confusion with settings used, since I did not include an image. For BD-5, all audio boxes checked or unchecked are for the purpose of encoding to AC3 5.1 @ 640 Kbs. With regard to the checkbox for "Do Not Convert DTS to AC3 (Blu-ray Only)", it has never had an effect for my BD-5s. It's my understanding that it only affects BD-25/50--is that correct? For BD-5, whether I keep it checked or unchecked has had no impact on audio. The conversion to AC3 is done correctly. Today I left it unchecked, as requested. Please see the log file below. The total output size is 3.66GB. Code:
---------------------- [05/06/14] BD Rebuilder v0.47.06 (beta) [07:02:38] Source: TRANSFORMERS_00010 - Input BD size: 42.11 GB - Approximate total content: [02:23:27.307] - Target BD size: 4.36 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Resize: 1080p to 720p enabled - Auto Quality: High Quality (Default), Two Pass - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=1 HD=1 Kbs=640 [07:02:49] PHASE ONE, Encoding - [07:02:49] Processing: VID_00010 (1 of 1) - [07:02:49] Extracting A/V streams [VID_00010] - [07:09:37] Reencoding video [VID_00010] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 206,369 frames - Convert: 1280x720, 23.976fps, 206,369 frames - Bitrate: 2,693 Kbs - [07:09:37] Reencoding: VID_00010, Pass 1 of 2 - [07:43:34] Reencoding: VID_00010, Pass 2 of 2 - [08:41:27] Video Encode complete - [08:41:27] Processing audio tracks - Track 4352 (eng): Keeping original core audio [08:41:47]PHASE ONE complete [08:41:47]PHASE TWO - Rebuild Started - [08:41:47] Rebuilding AVCHD file Structure [08:45:25] - Encode and Rebuild complete [08:45:25] JOB: TRANSFORMERS finished. Code:
General ID : 1 (0x1) Complete name : V:\WORKING\TRANSFORMERS\BDMV\STREAM\00000.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 3.66 GiB Duration : 2h 23mn Overall bit rate mode : Variable Overall bit rate : 3 653 Kbps Maximum Overall bit rate : 35.5 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Codec ID : 27 Duration : 2h 23mn Bit rate mode : Variable Bit rate : 2 856 Kbps Maximum bit rate : 15.0 Mbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.129 Stream size : 2.86 GiB (78%) Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 2h 23mn Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 657 MiB (18%) Text #1 ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Text #2 ID : 4609 (0x1201) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 I hope the logs help Thanks again for all the kind responses! -=K=- Last edited by kaminar; 7th May 2014 at 00:01. |
7th May 2014, 07:59 | #20223 | Link |
@kaminar
I am not sure if this really matters for BD5, however I notice that you still have HD=1 (Keep HD Audio ... ). What happens when you unselect it? Maybe BD-RB calculates a larger muxing overhead when HD=1 is set? Just speculating. I didn't try but I always encode with HD=0 for BD5/9. I don't have your discs so I cannot verify. [Edit]: Hmmm....... the video bitrate of your encode would be just about right if you would have kept two AC3 640 audio tracks. But apparently you selected only one (english) audio, and 2 sups...... Last edited by Sharc; 7th May 2014 at 08:25. |
7th May 2014, 11:47 | #20225 | Link | |
Thanks for replying! Like yourself, I keep HD=0 for BD-5. Whether I check or uncheck the "Do Not Convert DTS to AC3 (Blu-ray only)", it has no impact. BD-RB always converts to AC3. In the case of BD-5, HD=1 or HD=0 has the exact same result. Your suggestion re: muxing overhead is interesting..I will try both--one with the box checked (HD=0) and then unchecked (HD=1), to compare. Thank you As for experimenting, I'm trying custom sizes for BD-5 for the BD listed above. So far, output results for custom size are as follows: 1. 4469 (3.66GB output size) 2. 4476 (3.66GB) 3. 5000 (4.70GB) 4. 4750 (3.93GB) 5. 4876 (??) Am trying 4876 now. Will continue to narrow it down by half until the result falls into range. Heck, who knows, it could by my system. It shouldn't be, but impossible to say. The encodes are clean and relatively fast. -=K=- |
7th May 2014, 16:12 | #20226 | Link |
When making BD3D backups, is the AVC stream being reencoded by x264 (with the current setup parameters) while
the MVC stream is done by FrimEncode (using ABR method and similar quality parameters as the current ones for x264)? Can be used CRF method for the AVC stream in a BD3D backup? |
7th May 2014, 19:12 | #20227 | Link | |
No. CRF does not exist in FRIMEncode. |
7th May 2014, 19:35 | #20228 | Link |
Thank you very much for the information. Even by other very expensive MVC encoders CRF is not available either (just CBR and VBR). I was just interested in CRF because I am very satisfied with the results of that method in BD-RB.
7th May 2014, 21:57 | #20229 | Link |
I have a 3D MKV MVC file (Gravity) made using MakeMKV approximately 26/27 GB in size. I'd like to make a 3D ISO file which I can burn to a 25GB disc. What are my best option selections for success? I just tried using the import option "Video File (SBS source)" and the ISO file output size was under 2GB. Should I be using the other import option "Video Files"? What am I doing wrong?
Thanks, G |
8th May 2014, 21:46 | #20233 | Link |
3D iso playback
Recently did 3D BD25 iso movie only backup of "The legend Of Hercules" using FRIMEncode. Used media players PCH-A400 and Micca EP600 and a Panny DMP-BDT210 for playback. BDRB source was a AnyDVD iso. Created BDRB output would not play as 3D for either of the media players. However, a created 3D Disc played as 3D in the Panny. Also, a 3D iso, created by DVDFxx (from the same AnyDVD iso) played as 3D in both media players. Would like to add that FRIMENcode is great. Around 140 fps for AVC and 47 fps for MVC using i5-3570K. Will provide whatever logs, etc necessary upon request.
Thanks Sorry guys, false alarm on the above. After reviewing the logs, I had overlooked that IMGBurn had an error when creating the iso. I reran the job today and both nedia players recognized it as 3D. I'll do my best to scrutinize the logs more closely in the future before posting.......peace dfox990 Last edited by dfox990; 9th May 2014 at 21:12. Reason: Found my mistake |
8th May 2014, 22:31 | #20234 | Link |
Secondary Video being Reencoded with BD-50.
A bug? The secondary video is being reencoded for each movie I process at BD50. Has anyone else noticed that? With FORCE_NOENCODE=1, too.
[05/08/14] BD Rebuilder v0.47.05 (beta) [12:25:43] Source: NIMS_ISLAND - Input BD size: 34.56 GB - Approximate total content: [02:56:28.852] - Target BD size: 46.26 GB - Windows Version: 6.1 [7601] - MOVIE and MENUS mode enabled - Quality: Highest (Very Slow), Two Pass - Decoding/Frame serving: DGDecNV [4-way] - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [12:25:53] PHASE ONE, Encoding - [12:25:53] Blanking: VID_00033 (1 of 45) - [12:25:53] Blanking: VID_00021 (2 of 45) - [12:25:53] Blanking: VID_00059 (3 of 45) - [12:25:53] Blanking: VID_00057 (4 of 45) - [12:25:53] Blanking: VID_00058 (5 of 45) - [12:25:53] Blanking: VID_00020 (6 of 45) - [12:25:53] Blanking: VID_00077 (7 of 45) - [12:25:53] Blanking: VID_00055 (8 of 45) - [12:25:53] Blanking: VID_00056 (9 of 45) - [12:25:53] Blanking: VID_00004 (10 of 45) - [12:25:53] Processing: VID_00087 (11 of 45) - [12:25:53] Extracting A/V streams [VID_00087] - [12:26:00] Reencoding video [VID_00087] - [12:26:00] Keeping original video (no reencode) - [12:26:00] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:26:00] Multiplexing M2TS - [12:26:04] Processing: VID_00108 (12 of 45) - [12:26:04] Extracting A/V streams [VID_00108] - [12:26:08] Reencoding video [VID_00108] - [12:26:08] Keeping original video (no reencode) - [12:26:08] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:26:08] Multiplexing M2TS - [12:26:12] Processing: VID_00104 (13 of 45) - [12:26:12] Extracting A/V streams [VID_00104] - [12:26:17] Reencoding video [VID_00104] - [12:26:17] Keeping original video (no reencode) - [12:26:17] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:26:17] Multiplexing M2TS - [12:26:22] Processing: VID_00097 (14 of 45) - [12:26:22] Extracting A/V streams [VID_00097] - [12:26:27] Reencoding video [VID_00097] - [12:26:27] Keeping original video (no reencode) - [12:26:27] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:26:27] Multiplexing M2TS - [12:26:31] Processing: VID_00089 (15 of 45) - [12:26:31] Extracting A/V streams [VID_00089] - [12:26:36] Reencoding video [VID_00089] - [12:26:36] Keeping original video (no reencode) - [12:26:36] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:26:36] Multiplexing M2TS - [12:26:40] Blanking: VID_00019 (16 of 45) - [12:26:40] Processing: VID_00092 (17 of 45) - [12:26:40] Extracting A/V streams [VID_00092] - [12:26:46] Reencoding video [VID_00092] - [12:26:46] Keeping original video (no reencode) - [12:26:46] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:26:46] Multiplexing M2TS - [12:26:50] Processing: VID_00094 (18 of 45) - [12:26:50] Extracting A/V streams [VID_00094] - [12:26:55] Reencoding video [VID_00094] - [12:26:55] Keeping original video (no reencode) - [12:26:55] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:26:55] Multiplexing M2TS - [12:27:00] Processing: VID_00100 (19 of 45) - [12:27:00] Extracting A/V streams [VID_00100] - [12:27:06] Reencoding video [VID_00100] - [12:27:06] Keeping original video (no reencode) - [12:27:06] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:27:06] Multiplexing M2TS - [12:27:11] Processing: VID_00085 (20 of 45) - [12:27:11] Extracting A/V streams [VID_00085] - [12:27:16] Reencoding video [VID_00085] - [12:27:17] Keeping original video (no reencode) - [12:27:17] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:27:17] Multiplexing M2TS - [12:27:22] Processing: VID_00103 (21 of 45) - [12:27:22] Extracting A/V streams [VID_00103] - [12:27:27] Reencoding video [VID_00103] - [12:27:27] Keeping original video (no reencode) - [12:27:27] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:27:27] Multiplexing M2TS - [12:27:32] Processing: VID_00098 (22 of 45) - [12:27:32] Extracting A/V streams [VID_00098] - [12:27:37] Reencoding video [VID_00098] - [12:27:37] Keeping original video (no reencode) - [12:27:37] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:27:37] Multiplexing M2TS - [12:27:43] Processing: VID_00084 (23 of 45) - [12:27:43] Extracting A/V streams [VID_00084] - [12:27:48] Reencoding video [VID_00084] - [12:27:48] Keeping original video (no reencode) - [12:27:48] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:27:48] Multiplexing M2TS - [12:27:53] Processing: VID_00099 (24 of 45) - [12:27:53] Extracting A/V streams [VID_00099] - [12:27:58] Reencoding video [VID_00099] - [12:27:58] Keeping original video (no reencode) - [12:27:58] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:27:58] Multiplexing M2TS - [12:28:04] Processing: VID_00096 (25 of 45) - [12:28:04] Extracting A/V streams [VID_00096] - [12:28:09] Reencoding video [VID_00096] - [12:28:09] Keeping original video (no reencode) - [12:28:09] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:28:09] Multiplexing M2TS - [12:28:14] Processing: VID_00091 (26 of 45) - [12:28:14] Extracting A/V streams [VID_00091] - [12:28:21] Reencoding video [VID_00091] - [12:28:21] Keeping original video (no reencode) - [12:28:21] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:28:21] Multiplexing M2TS - [12:28:26] Processing: VID_00093 (27 of 45) - [12:28:26] Extracting A/V streams [VID_00093] - [12:28:32] Reencoding video [VID_00093] - [12:28:32] Keeping original video (no reencode) - [12:28:32] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:28:32] Multiplexing M2TS - [12:28:38] Processing: VID_00086 (28 of 45) - [12:28:38] Extracting A/V streams [VID_00086] - [12:28:44] Reencoding video [VID_00086] - [12:28:44] Keeping original video (no reencode) - [12:28:44] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:28:44] Multiplexing M2TS - [12:28:50] Processing: VID_00106 (29 of 45) - [12:28:50] Extracting A/V streams [VID_00106] - [12:28:56] Reencoding video [VID_00106] - [12:28:56] Keeping original video (no reencode) - [12:28:56] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:28:56] Multiplexing M2TS - [12:29:02] Processing: VID_00101 (30 of 45) - [12:29:02] Extracting A/V streams [VID_00101] - [12:29:08] Reencoding video [VID_00101] - [12:29:08] Keeping original video (no reencode) - [12:29:08] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:29:08] Multiplexing M2TS - [12:29:15] Processing: VID_00102 (31 of 45) - [12:29:15] Extracting A/V streams [VID_00102] - [12:29:21] Reencoding video [VID_00102] - [12:29:21] Keeping original video (no reencode) - [12:29:21] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:29:21] Multiplexing M2TS - [12:29:28] Processing: VID_00105 (32 of 45) - [12:29:28] Extracting A/V streams [VID_00105] - [12:29:34] Reencoding video [VID_00105] - [12:29:34] Keeping original video (no reencode) - [12:29:34] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:29:34] Multiplexing M2TS - [12:29:41] Processing: VID_00107 (33 of 45) - [12:29:41] Extracting A/V streams [VID_00107] - [12:29:47] Reencoding video [VID_00107] - [12:29:47] Keeping original video (no reencode) - [12:29:47] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:29:47] Multiplexing M2TS - [12:29:54] Processing: VID_00080 (34 of 45) - [12:29:54] Extracting A/V streams [VID_00080] - [12:30:01] Reencoding video [VID_00080] - [12:30:01] Keeping original video (no reencode) - [12:30:01] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:30:01] Multiplexing M2TS - [12:30:08] Processing: VID_00095 (35 of 45) - [12:30:08] Extracting A/V streams [VID_00095] - [12:30:15] Reencoding video [VID_00095] - [12:30:15] Keeping original video (no reencode) - [12:30:15] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:30:15] Multiplexing M2TS - [12:30:22] Processing: VID_00088 (36 of 45) - [12:30:22] Extracting A/V streams [VID_00088] - [12:30:29] Reencoding video [VID_00088] - [12:30:29] Keeping original video (no reencode) - [12:30:29] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:30:29] Multiplexing M2TS - [12:30:38] Processing: VID_00090 (37 of 45) - [12:30:38] Extracting A/V streams [VID_00090] - [12:30:45] Reencoding video [VID_00090] - [12:30:45] Keeping original video (no reencode) - [12:30:45] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:30:45] Multiplexing M2TS - [12:30:53] Processing: VID_00079 (38 of 45) - [12:30:53] Extracting A/V streams [VID_00079] - [12:31:02] Reencoding video [VID_00079] - [12:31:02] Keeping original video (no reencode) - [12:31:02] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:31:02] Multiplexing M2TS - [12:31:13] Processing: VID_00083 (39 of 45) - [12:31:13] Extracting A/V streams [VID_00083] - [12:31:23] Reencoding video [VID_00083] - [12:31:23] Keeping original video (no reencode) - [12:31:23] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:31:23] Multiplexing M2TS - [12:31:38] Processing: VID_00081 (40 of 45) - [12:31:38] Extracting A/V streams [VID_00081] - [12:31:47] Reencoding video [VID_00081] - [12:31:47] Keeping original video (no reencode) - [12:31:47] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:31:47] Multiplexing M2TS - [12:32:01] Processing: VID_00074 (41 of 45) - [12:32:01] Extracting A/V streams [VID_00074] - [12:32:12] Reencoding video [VID_00074] - [12:32:12] Keeping original video (no reencode) - [12:32:12] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:32:12] Multiplexing M2TS - [12:32:27] Processing: VID_00082 (42 of 45) - [12:32:27] Extracting A/V streams [VID_00082] - [12:32:37] Reencoding video [VID_00082] - [12:32:37] Keeping original video (no reencode) - [12:32:37] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:32:37] Multiplexing M2TS - [12:32:52] Processing: VID_00075 (43 of 45) - [12:32:52] Extracting A/V streams [VID_00075] - [12:33:03] Reencoding video [VID_00075] - [12:33:03] Keeping original video (no reencode) - [12:33:03] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:33:03] Multiplexing M2TS - [12:33:19] Processing: VID_00078 (44 of 45) - [12:33:19] Extracting A/V streams [VID_00078] - [12:33:33] Reencoding video [VID_00078] - [12:33:33] Keeping original video (no reencode) - [12:33:33] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:33:33] Multiplexing M2TS - [12:33:53] Processing: VID_00002 (45 of 45) - [12:33:53] Extracting A/V streams [VID_00002] - [12:40:42] Reencoding video [VID_00002] - [12:40:42] Reencoding secondary video [TRK_02] - [12:46:42] Keeping original video (no reencode) - [12:46:42] Processing audio tracks - Track 4353 (eng): Keeping original audio - Track 4355 (eng): Keeping original audio - Track 4356 (eng): Keeping original audio - Track 6656 (eng): Keeping original audio - [12:46:42] Multiplexing M2TS [13:03:20]PHASE ONE complete [13:03:20]PHASE TWO - Rebuild Started - [13:03:20] Rebuilding BD file Structure [13:03:46] - Encode and Rebuild complete [13:03:46] JOB: NIMS_ISLAND finished.
9th May 2014, 21:35 | #20235 | Link |
MPEG-2 to AVC FRIMEncode failed
[05.09.14] BD Rebuilder v0.47.05 (beta) [22:29:03] Source: THE_CROODS - Input BD size: 5,04 GB - Approximate total content: [01:34:35.479] - Target BD size: 2,27 GB - Windows Version: 6.1 [7601] - Quality: Ultra High Quality (Extremely Slow), ABR - Output folder: E:\adat\Downloads\BD-RB\ - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [22:29:03] PHASE ONE, Encoding - [22:29:03] Processing: VID_00001 (1 of 1) - [22:29:03] Extracting A/V streams [VID_00001] - [22:30:30] Reencoding video [VID_00001] - Source Video: MPEG-2, 720x576 - Rate/Length: 25,000fps, 141*887 frames - Bitrate: 2*263 Kbs - Using FRIMEncoder for AVC encoding - [22:30:30] Reencoding: VID_00001, Pass 1 of 1 [22:30:31] - Failed video encode, aborted The same encode was successfully completed with x264 CRF method. The only difference in the set up was changing to custom target size due to ABR encoding. If someone has an idea, please let me know, it would be much appreciated. Last edited by mparade; 9th May 2014 at 21:38. |
9th May 2014, 22:26 | #20237 | Link |
This is my Croods DVD and would like to accomplish an AVC encoded stream made by FRIM on it's main movie title using the import function of BD-RB. I think the problem may be with the frame-serving, but I haven't checked yet other than DirectShowSource.
9th May 2014, 22:48 | #20239 | Link |
Just to compare the result to the one made by x264 by putting them into a quality measurement tool for testing through avs scripts.
@jdobbs Sorry, I did not want to generate possible bug reports due to my test purposes. |
10th May 2014, 08:37 | #20240 | Link |
Hi. When BD-3D is reencoded or not reencoded too, to the in-mux structure for BD-3D output and then when I open movie playlist in the tsmuxer 2.6.12 something it's not right.
Tsmuxer open that playlist and everything looks ok but when I’m trying to export movie it shows error: "Current playlist file doesn't has MVC track info. Please, remove MVC track from the track list". Tsmuxer is not able to do anything with that playlist. |
