Old 10th May 2014, 14:09   #20241  |  Link
Originally Posted by polik View Post
Hi. When BD-3D is reencoded or not reencoded too, to the in-mux structure for BD-3D output and then when I open movie playlist in the tsmuxer 2.6.12 something it's not right.
Tsmuxer open that playlist and everything looks ok but when I’m trying to export movie it shows error: "Current playlist file doesn't has MVC track info. Please, remove MVC track from the track list".
Tsmuxer is not able to do anything with that playlist.
Hmmm.... unfortunately my first guess is that this may be an error in TSMUXER. You can open the M2TS fine directly, but you get that error when you try opening the MPLS.
I'll do some testing and see what I can find.
[Edit]
Yes. I can confirm it is a TSMUXER error. I just tried to remux from a commercial disc that uses in-mux MVC (e.g. AVATAR 3D, playlist 00003) and TSMUXER fails there as well. TSMUXER issues are beyond my control.
There is no issue, however, when using BD Rebuilder. BD-RB uses the M2TS directly and it applies all MPLS characteristics (such as chapters) during the rebuild. So, since BD-Rebuilder processes the MPLS itself, the TSMUXER error doesn't affect the its functioning.
If you want to create a movie-only version of an in-mux 3D, just select that playlist from within BD-RB and let it run. No problems.
The bottom line is that while your report is accurate -- it has no impact on, nor is it a bug within BD Rebuilder.
Old 10th May 2014, 15:33   #20242  |  Link
andref4
Hi jdobbs,
I have problems with full 3D backup of the movie Cloudy with a Chance of Meatballs 2 3D. The movie has multi-view/ multi-angle with multiple playlists.
If I mount the iso, rebuilding stops at the end by converting SSIF file references (see log).
If I rip the movie to an HDD folder, rebuilding finish but the movie hangs between 7.30 - 7,50min. and crashes.
Same result with xVxFab. But a movie only rip or 3D SBS full 3D backup works! I try to make a full 3D 25GB backup of this movie since end of February with diffrent programs but no one can handle this movie. At the moment the only thing is to burn the movie to a BD 50GB or make a movie only backup to BD 25GB.
[05.07.14] BD Rebuilder v0.47.06 (beta)
[04:21:27] Source: CLOUDY_2
- Input BD size: 31,57 GB
- Approximate total content: [02:05:56.170]
- Target BD size: 22,95 GB
- Windows Version: 6.1 [7601]
- Quality: Good (Very Fast), ABR
- MVC 3D Output Mode enabled
- Decoding/Frame serving: FRIMDecode
[04:21:27] PHASE ONE, Encoding
- [04:21:27] Processing: VID_00102 (1 of 5)
- [04:21:27] Extracting A/V streams [VID_00102]
- [04:21:42] Reencoding video [VID_00102]
- Rate/Length: 23,976fps, 6.887 frames
- Bitrate: 5.999 Kbs
- [04:21:42] Reencoding: VID_00102, Pass 1 of 1
- [04:23:30] Video Encode complete
- [04:23:30] Processing audio tracks
- [04:23:30] Multiplexing M2TS
- [04:23:41] Processing: VID_00341 (2 of 5)
- [04:23:41] Extracting A/V streams [VID_00341]
- [04:23:55] Reencoding video [VID_00341]
- Rate/Length: 23,976fps, 2.051 frames
- Bitrate: 17.094 Kbs
- Using FRIMEncoder for MVC encoding
- [04:23:55] Reencoding: VID_00341, Pass 1 of 1
- [04:31:26] Video Encode complete
- [04:31:26] Processing audio tracks
- [04:31:26] Multiplexing M2TS
- [04:31:36] Scanning for 3D CLPI info...
- [04:31:40] Processing: VID_00344 (3 of 5)
- [04:31:40] Extracting A/V streams [VID_00344]
- [04:33:42] Reencoding video [VID_00344]
- Rate/Length: 23,976fps, 10.903 frames
- Bitrate: 25.167 Kbs
- [04:33:42] Reencoding: VID_00344, Pass 1 of 1
- [05:13:09] Video Encode complete
- [05:13:09] Processing audio tracks
- Track 4353 (deu): Keeping original audio
- Track 4355 (eng): Keeping original audio
- [05:13:09] Multiplexing M2TS
- [05:15:12] Scanning for 3D CLPI info...
- [05:15:43] Processing: VID_00345 (4 of 5)
- [05:15:43] Extracting A/V streams [VID_00345]
- [05:15:55] Reencoding video [VID_00345]
- Rate/Length: 23,976fps, 425 frames
- Bitrate: 22.232 Kbs
- [05:15:55] Reencoding: VID_00345, Pass 1 of 1
- [05:17:30] Video Encode complete
- [05:17:30] Processing audio tracks
- [05:17:30] Multiplexing M2TS
- [05:17:36] Scanning for 3D CLPI info...
- [05:17:37] Processing: VID_00346 (5 of 5)
- [05:17:37] Extracting A/V streams [VID_00346]
- [05:35:09] Reencoding video [VID_00346]
- Rate/Length: 23,976fps, 125.112 frames
- Bitrate: 24.366 Kbs
- [05:35:09] Reencoding: VID_00346, Pass 1 of 1
- [13:00:18] Video Encode complete
- [13:00:19] Processing audio tracks
- [13:00:19] Multiplexing M2TS
- [13:16:24] Scanning for 3D CLPI info...
[13:22:23]PHASE ONE complete
[13:22:23]PHASE TWO - Rebuild Started
- [13:22:23] Converting SSIF file references
- ERROR: 3D remuxing failed. Aborted.
- Failed to rebuild BD file(s). Aborted.
[13:25:01] Source: CLOUDY_2
- Resuming from previously started job.
[13:25:09] PHASE ONE, Encoding
[13:25:09]PHASE ONE complete
[13:25:09]PHASE TWO - Rebuild Started
- [13:25:09] Converting SSIF file references
andref4 is offline   Reply With Quote
Old 10th May 2014, 16:01   #20243  |  Link
@andref4
I don't have that disc so I ordered it. This will be my first time ordering a used disc through Amazon, so I'm not sure about the delivery date... I just have to try and keep my personal costs down so it is limited to no more than my donation totals -- I just can't justify (to myself) going in the hole financially to maintain freeware.
Old 11th May 2014, 20:00   #20244  |  Link
Patrick
Error opening disc structure: Lord of the rings - Return of the king special edition
I just noticed that BD rebuilder versions starting with 0.47.xx cannot open "Lord of the rings - return of the king extended edition (disc2)"
Error 2501 (20:58:56) SourceCheck() 00055 2501
appears in V00.47.05
All versions prior to 00.47.xx have no problems.
Patrick is offline   Reply With Quote
Old 11th May 2014, 21:26   #20245  |  Link
andref4
@andref4
many thanks jdobbs. I have the EU (german) version of the disc but the international version have the same multiple playlists and multi-view/angle.
Old 13th May 2014, 13:20   #20246  |  Link
Cedvano
When i try to encode FINAL DESTINATION 4 3D, BD Rebuilder want encode only 3D files.
But the 2D bonus are big and need to be reduced.
How BD Rebuilder can word with 2D and 3D files ?
Cedvano is offline   Reply With Quote
Old 13th May 2014, 15:38   #20247  |  Link
Originally Posted by Cedvano View Post
Please post your INI file and log.
Old 13th May 2014, 19:45   #20248  |  Link
scotlandman
Making 3D BD25 of Marvels The Avengers
Hi jdobbs
I would first like to thank you for the fantastic software you have provided us all with it is truly phenomenal thanks.
The reason for my post today is to ask for your feedback on my recent attempt to make a Movie only 3D BD25 of Marvels the Avengers (Avengers Assemble).
The Source for my movie is USA Retail Blu-ray. I used AnyDVD HD 7.4.6.0 for decrypting the movie then set up BD Rebuilder v0.47.06 (beta) as follows.
My INI File and Log along with BDInfo and Media Info for comparison are as follows.
LOG:
[05/08/14] BD Rebuilder v0.47.06 (beta)
[21:16:12] Source:  MARVELS_THE_AVENGERS_3D_00800
  - Input BD size: 40.19 GB
  - Approximate total content: [02:22:54.899]
  - Target BD size: 23.83 GB
  - Windows Version: 6.2 [9200]
  - MOVIE-ONLY mode enabled
  - Quality: Highest (Very Slow), ABR
[21:16:12] PHASE ONE, Encoding
 - [21:16:12] Processing: VID_00800 (1 of 1)
 - [21:16:12] Extracting A/V streams [VID_00800]
 - [21:18:50] Reencoding video [VID_00800]
   - Rate/Length: 23.976fps, 205,592 frames
   - Bitrate: 16,090 Kbs
 - [21:18:50] Reencoding: VID_00800, Pass 1 of 1
 - [07:15:14] Video Encode complete
 - [07:15:14] Processing audio tracks
[07:15:14]PHASE ONE complete
[07:15:14]PHASE TWO - Rebuild Started
 - [07:15:15] Rebuilding BD-3D file Structure
[07:19:54] - Encode and Rebuild complete
[07:19:54] JOB: MARVELS_THE_AVENGERS_3D finished.
INI
[Status]
LABEL=MARVELS_THE_AVENGERS_3D
VERSION=v0.47.06 (beta)
SOURCE_SIZE=43156592640
SOURCE_VIDEO_SIZE=43156592640
TARGET_SIZE=25585254400
REDUCTION=.592846951876505
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=all
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
DGDECIM=0
FRIMSOURCE=0
SSIF_MODE=-1
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00800]
AUDIO=100
PGS=1011111111111000
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=25585254400
RATE=16090
NSIZE=0
FLINK=0
MLINK=0
BDInfo taken once Attempted conversion has finished.
DISC INFO:
Disc Title:     MARVELS_THE_AVENGERS_3D
Disc Size:      24,302,338,296 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 2:22:54.899 (h:m:s.ms)
Total Bitrate:          22.67 Mbps
VIDEO:
Codec                   Bitrate             Description
MPEG-4 AVC Video        8776 kbps           1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Codec                           Language        Bitrate         Description
DTS-HD Master Audio             English         5217 kbps       7.1 / 48 kHz / 5217 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         36.579 kbps
Presentation Graphics           Russian         30.633 kbps
Presentation Graphics           Ukrainian       31.781 kbps
Presentation Graphics           Swedish         25.619 kbps
Presentation Graphics           Norwegian       24.535 kbps
Presentation Graphics           Danish          30.107 kbps
Presentation Graphics           Finnish         26.513 kbps
Presentation Graphics           Greek           32.475 kbps
Presentation Graphics           Bulgarian       31.138 kbps
Presentation Graphics           Latvian         26.197 kbps
Presentation Graphics           Lithuanian      30.866 kbps
Presentation Graphics           Estonian        30.008 kbps
FILES:
Name            Time In         Length          Size            Total Bitrate
00000.M2TS      0:00:00.000     2:22:54.899     24,302,125,056  22,673
First Media Info file shows how this attempt was done:
General
Complete name                  : F:\\BDMV\PLAYLIST\00001.mpls
Format                         : Blu-ray Playlist
File size                      : 714 Bytes
Duration                       : 2h 22mn
Overall bit rate mode          : Variable
Overall bit rate               : 1 bps
Video #1
Menu ID                        : 1 (0x1)
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : High@L4.1
Format settings, CABAC         : Yes
Format settings, ReFrames      : 3 frames
Codec ID                       : 27
Duration                       : 2h 22mn
Bit rate mode                  : Variable
Maximum bit rate               : 19.0 Mbps
Width                          : 1 920 pixels
Height                         : 1 080 pixels
Display aspect ratio           : 16:9
Frame rate                     : 23.976 fps
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
format_identifier              : HDMV
Source                         : 00000.m2ts / 00000.m2ts
Video #2
Menu ID                        : 1 (0x1)
Format                         : AVC
Format profile                 : Stereo High@L4.1
MultiView_Count                : 2
Codec ID                       : 32
Duration                       : 2h 22mn
Maximum bit rate               : 15.9 Mbps
Color space                    : YUV
Bit depth                      : 8 bits
Audio
Menu ID                        : 1 (0x1)
Format                         : DTS
Format/Info                    : Digital Theater Systems
Format profile                 : MA / Core
Mode                           : 16
Format settings, Endianness    : Big
Muxing mode                    : Stream extension
Codec ID                       : 134
Duration                       : 2h 22mn
Bit rate                       : Unknown / 1 509 Kbps
Channel(s)                     : 8 channels / 6 channels
Channel positions              : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate                  : 48.0 KHz
Bit depth                      : 24 bits
Compression mode               : Lossless / Lossy
Language                       : English
Second Media Info shows the Proper file information for some reason BD Rebuilder does not include file 00872.m2ts in the encode.
General
Complete name                  : F:\\BDMV\PLAYLIST\00800.mpls
File size                      : 878 Bytes
Duration                       : 2h 22mn
Video
ID                             : 4114 (0x1012) / 4113 (0x1011)
Menu ID                        : 1 (0x1)
Format                         : AVC
Format profile                 : Stereo High@L4.1 / High@L4.1
Codec ID                       : 27
Duration                       : 2h 22mn
Maximum bit rate               : 35.0 Mbps
Color space                    : YUV
Bit depth                      : 8 bits
Source                         : 00872.m2ts / 00800.m2ts
Audio #1
Menu ID                        : 1 (0x1)
Format                         : DTS
Mode                           : 16
Codec ID                       : 134
Duration                       : 2h 22mn
Bit depth                      : 24 bits
Language                       : English
Source                         : 00800.m2ts
Audio #2
Menu ID                        : 1 (0x1)
Format                         : AC-3
Format/Info                    : Audio Coding 3
Mode extension                 : CM (complete main)
Codec ID                       : 129
Duration                       : 2h 22mn
Bit rate mode                  : Constant
Bit rate                       : 640 Kbps
Channel(s)                     : 6 channels
Channel positions              : Front: L C R, Side: L R, LFE
Bit depth                      : 16 bits
Compression mode               : Lossy
Stream size                    : 654 MiB (2%)
Language                       : Russian
bsid                           : 6
dialnorm                       : -31
dialnorm/String                : -31 dB
compr                          : 3.52
compr/String                   : 3.52 dB
dynrng                         : 3.52
dynrng/String                  : 3.52 dB
acmod                          : 7
lfeon                          : 1
dialnorm_Average               : -31
dialnorm_Average/String        : -31 dB
dialnorm_Minimum               : -31
dialnorm_Minimum/String        : -31 dB
dialnorm_Maximum               : -31
dialnorm_Maximum/String        : -31 dB
dialnorm_Count                 : 560
compr_Average                  : 3.44
compr_Average/String           : 3.44 dB
compr_Minimum                  : -0.28
compr_Minimum/String           : -0.28 dB
compr_Maximum                  : 6.02
compr_Maximum/String           : 6.02 dB
compr_Count                    : 560
dynrng_Average                 : 3.49
dynrng_Average/String          : 3.49 dB
dynrng_Minimum                 : 0.00
dynrng_Minimum/String          : 0.00 dB
dynrng_Maximum                 : 6.02
dynrng_Maximum/String          : 6.02 dB
dynrng_Count                   : 560
format_identifier              : AC-3
Source                         : 00800.m2ts
Audio #3
Menu ID                        : 1 (0x1)
Format                         : AC-3
Codec ID                       : 129
Duration                       : 2h 22mn
Bit rate                       : 640 Kbps
Bit depth                      : 16 bits
Language                       : Ukrainian
bsid                           : 6
dialnorm                       : -31
compr                          : 5.74
compr/String                   : 5.74 dB
dynrng                         : 5.60
dynrng/String                  : 5.60 dB
acmod                          : 7
lfeon                          : 1
compr_Average                  : 3.68
compr_Average/String           : 3.68 dB
compr_Count                    : 560
dynrng_Average                 : 3.74
dynrng_Average/String          : 3.74 dB
dynrng_Count                   : 560
Source                         : 00800.m2ts
Thank you for taking the time to help me I hope that I have not missed any simple steps in the process as I believe I have done everything correctly.
scotlandman is offline   Reply With Quote
Old 13th May 2014, 22:37   #20249  |  Link
Cedvano
Here the INI file :
[Options]
VERSION=0.47.0.6
MODE=0
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=1
TARGET_SIZE=23500
AUDIO_TO_KEEP=eng;fra;fre;frm;fro;
SUBS_TO_KEEP=ang;fra;fre;frm;fro;
SD_CONVERT=0
OPEN_GOP=1
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=0
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=1
REMOVE_WORKFILES=1
MOVIE_ONLY_LOOP=1
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=1
USE_LAVF=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
DGDECNV=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=100
SUPPRESS_FF_WARNING=1
OUTPUT_3D_ISO=0
SHOW_ENCODER=1
QUICK_EXTRAS=1
AUTO_BURN=0
ENABLE_TEST=1
ENABLE_BLANKING=1
ENCODER=0
PRIORITY_CLASS=2
MIN_M2TS_SIZE=1
MIN_PLAYLIST_MINS=1
DGDECIM=0
[Paths]
SOURCE_PATH=R:\
WORKING_PATH=G:\BLU-RAY\
[Status]
LABEL=FINAL_DESTINATION_4_3D
SOURCE_SIZE=28254282843
SOURCE_VIDEO_SIZE=23043440640
TARGET_SIZE=24641536000
REDUCTION=.843220164061403
RESIZE_1080=0
RESIZE_1440=0
KEEP_HD_AUDIO=0
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
DGDECIM=0
FRIMSOURCE=0
SSIF_MODE=-1
QUICK=1
ENCODE_STEP=1
REBUILD_COMPLETE=0
[00058]
AUDIO=
PGS=
[05 13 14] BD Rebuilder v0.47.06 (beta)
[23:35:12] Source: FINAL_DESTINATION_4_3D
- Input BD size: 26,31 GB
- Approximate total content: [02:14:06.742]
- Audio Settings: AC3=1 DTS=1 HD=0 Kbs=448
[23:35:12] PHASE ONE, Encoding
- [23:35:12] Processing: VID_00058 (1 of 3)
- [23:35:12] Extracting A/V streams [VID_00058]
[23:35:18]PHASE ONE aborted by user request
There is 25 bonus in 2D (3,5 GB) and I don't see in "Stream", I see only 3D files (0.05MB, 119.04 MB and 21 856.85MB)
Old 14th May 2014, 01:16   #20250  |  Link
jetli
hi, i have a problem with version 47.04.
i was compressing main movie only of DELIVERY MAN.
RB completed as always, video ok, audio ok, 1 eng sub NOT ok.
playlist 100 is what it selected and it contains 4 min of 6.m2ts and 140 min of 7.m2ts.
after the 1st 4 minutes the subtitles do NOT track, the 1st 4 min is fine.
i've never really had a problem before using your tools.
what i did to solve this is use tsmuxer to extract the subs from playlist 100 in the same source used by RB
and mux out your result and mux in the extracted result.
that works, the subs are fine throughout the movie, but i have 3 extra minutes of NOTHING at the end of the video playtime,
which i then cut and i have a workable disk.
i am just curious as to why this would happen now.
below is my RB system inspection ...
- AVISYNTH Version: 2.5.8.0, not recommended version
- HAALI Splitter: Isn't recommended version
- FFDSHOW: 3882, not recommended version
the above versions have always worked before, no issues.
please respond, thanks or your attention to this matter.
jetli is offline   Reply With Quote
Old 14th May 2014, 01:31   #20251  |  Link
Ch3vr0n
There is only 1 solution to that problem. Use the recommended versions of the helper tools. Jdobbs has repeatedly stated that bug reports will NOT be accepted if you're using unsupported versions. Fix that guest p first, then come back
Verstuurd vanaf mijn Nexus 7 met Tapatalk
Old 14th May 2014, 14:49   #20252  |  Link
@scotlandman
You've given me a lot of information -- but haven't told me what issue you are having??? Does it not play back correctly?
Old 14th May 2014, 15:27   #20253  |  Link
"Second Media Info shows the Proper file information for some reason BD Rebuilder does not include file 00872.m2ts in the encode."
I suppose he expected 00872.m2ts to be included and it was not.
Old 14th May 2014, 15:35   #20254  |  Link
Each of those files are probably smaller than the minimum M2TS size for reencoding. You call them "big", but when you have 25 files that combined add up to only 3.5GB on a 25GB backup -- it certainly isn't what I'd call big.
I'd leave the settings as-is, that's you best course of action. The minimum M2TS size is there to save you unnecessary reencoding time. But if you are determined to reencode 25 additional small files... you can always add a smaller MIN_M2TS_SIZE to your INI file (see HIDDENOPTS.TXT).
Old 14th May 2014, 15:36   #20255  |  Link
Groucho2004
@jdobbs
How do you check in BDRB if Avisynth is installed?
I didn't use the installer but Avisynth is certainly working and the registry entries for the plugin dir are there. Still, I get an error message when I start BDRB that Avisynth is not installed.
Old 14th May 2014, 15:37   #20256  |  Link
Yes, but sometimes (rarely) there are reasons why you don't want to include lead-in M2TS files in order to assure proper playback.
I'd like to know if there are issues in the movie-only playback. If not, then BD-RB made the right decision. I just don't want to waste time chasing something that was supposed to happen.
Old 14th May 2014, 15:44   #20257  |  Link
@jdobbs
I get the version number directly from the DLL to see if it is the proper version. "2.5.8.0" should be an acceptable version -- for some reason the DLL you have (in System32) isn't matching "2.5.8.0" when it returns from the system call. There may be a hidden null character in there somewhere.
At startup BD-RB checks the registry for one of these two keys to see if it is installed:
HKLM\Software\AviSynth
HKLM\Software\Wow6432Node\AviSynth
Old 14th May 2014, 16:21   #20258  |  Link
Groucho2004
Figured it out. Your check expects the DLL to be in the system32 directory.
Old 14th May 2014, 16:26   #20259  |  Link
If is wasn't there already... how did the string "2.5.8.0" get returned?
Old 14th May 2014, 16:41   #20260  |  Link
Groucho2004
This is the error when avisynth.dll is not in the System32 directory:
What's the reason for the restriction to that directory? When I load avisynth I use something like this:
HINSTANCE hDLL = ::LoadLibrary("avisynth");
if (!hDLL)
  sMsg = "Failed to load avisynth.dll";
  return FALSE;
It does not matter where avisynth.dll is as long as the "PATH" variable points to it.
