#20261 | Link | |
![]() Join Date: Oct 2001
#20263 | Link | |
Thank you for your reply and yes you are correct the file would not play as 3D as somehow the MVC smaller file of the two was not included by BD Rebuilder in the ReEncode. It basically missed the 00872.m2ts file and only encoded the 00800.m2ts file. So would only playback as 2D. I'm sorry if all my information was slightly missleading I just wanted to provide you with as much as possible, to allow you to see for comparison I hope this helps you as I would love to use BD Rebuilder to make 3D BD25 movie only backup copies Kind Regards Scotlandman |
#20264 | Link | |
Could you post your INI file (BDREBUILDER.INI located in the installation folder) -- what you posted is the INF file from that job, and it doesn't show your settings. If the 00872.MPLS is the MVC portion of the playback -- then it wouldn't show up anyway except in the demuxing. But I don't know whether that is what is even what is being reported by MediaInfo. Last edited by jdobbs; 14th May 2014 at 19:41. |
#20265 | Link |
@jdobbs
My videocam produces 1920x1080@25i (true interlaced 50 temporal shifted fields per second), which I IMPORT with BD-RB. I tried Alternate Output, .mkv container 1280x720, wanting to keep it interlaced in order to preserve the temporal resolution of the original. With Video Encoding Option "Resize 1920x1080 to 1280x720" disabled, the interlaced source gets directly resized without field separation, and then encoded as 1280x720@25i (MBAFF) Code:
#Created by BD Rebuilder - v0.47.06 (beta) LoadPlugin("C:\Program Files VIDEO\DGdecNV\DGDecodeNV.dll") DGSource("C:\TEMP\BD REBUILDER\WORKFILES\VID_00000.DGI", fieldop=0) Spline16Resize(1280,720) LoadPlugin("C:\Program Files Video\BD_Rebuilder\tools\autocrop.dll") Autocrop(mode=0) ConvertToYV12().AssumeFPS(25000,1000) I know I can encode using "BD or AVCHD compliant structure" at 1920x1080@25i or 1440x1080@25i (MBAFF, TFF) in order to preserve the temporal resolution, however this seems not to work with Alternate Output 1280x720). Maybe I miss something? |
#20266 | Link |
There's a SYSWOW64 path pointer in the registry for 64 bit systems, I'd have to check what exists for 32 bit.
In reality on a 64 bit system that's where the file physically exists after installation of the 32 bit application -- it is found via the redirector when you try to access it in system32. Why system32 is named "32" and holds 64 bit dlls is something only Microsoft could explain. Last edited by jdobbs; 14th May 2014 at 20:03. |
#20267 | Link | |
[Edit] After further thought, I guess there's really no mandate to prevent output at 720i -- it's just a little odd I guess. I don't think it falls into any broadcast standard. Last edited by jdobbs; 14th May 2014 at 20:18. |
#20268 | Link | |
Thanks for letting me know this I wasn't aware of this information. Here is my BD Rebuilder INI file that I use for each Encode. [Options] VERSION=0.47.0.6 ENCODER=0 MODE=3 ENCODE_QUALITY=3 ONEPASS_ENCODING=0 AUTO_QUALITY=0 TARGET_SIZE=24400 PRIORITY_CLASS=2 BD25_SIZE=24400 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=0 DGDECIM=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 DGDECNV=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=24400 I hope that this is helpful to you I am sorry if my previous attempts to give you information have not been helpful. Kind Regards Scotlandman |
#20270 | Link | ||
#20271 | Link |
Thank you very much for your kind comments.
Just for further information I do not know if it is at all relevant. I am running Windows 8.1 Pro in bootcamp in a new MAC Pro 6core 32GB RAM 1TB Flash memory Dual D700GPU It is pretty awesome for your software as even in 2 pass Very slow completes in 3 hours few minutes I just wandered if OS had any bearing on the result. Thanks |
#20272 | Link | ||
The bonus take +/- 200 MB / file Quote:
#20273 | Link | |
#20274 | Link | ||
#20275 | Link |
Update for Cloud Atlas chapters.. I bought an SSD and...reinstalled Windows 7, and the Chapters are okay now. I still have the SATA drive, so I'll check into it. I thought you might like an update.
#20277 | Link | |
@scotlandman
The job is currently running -- I will post results when it completes (it will likely be several hours). I'm a little worried that while you said you are using the US version of the disc for which you sent me a link -- your encode's log referenced 00800.M2TS as if it were the file associated with MPLS 00800... but in the commercial disc I am encoding the proper M2TS is 00895, there isn't even a 00800.M2TS on the 3D disc (it only exists on the 2D disc that is included in the 4 disc package)... Code:
[05/16/14] BD Rebuilder v0.47.07 (beta) [18:06:32] Source: MARVELS_THE_AVENGERS_3D_00800 - Input BD size: 41.83 GB - Approximate total content: [02:22:54.899] - Target BD size: 23.83 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: Highest (Very Slow), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [18:06:33] PHASE ONE, Encoding - [18:06:33] Processing: VID_00895 (1 of 1) - [18:06:33] Extracting A/V streams [VID_00895] - [18:16:39] Reencoding video [VID_00895] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 205,592 frames - Bitrate: 16,404 Kbs - Using FRIMEncoder for MVC encoding - [18:16:39] Reencoding: VID_00895, Pass 1 of 1 [Edit] The encode just completed. I used the INI settings provided, so the encode used all the settings exactly as reported. This included the "Highest (Very Slow)" setting which extended my encode time to 16 hours. The bottom line is that it completed with no issues, no problems were found when I examined the result, and the movie-only backup plays in 3D exactly as it should. Last edited by jdobbs; 17th May 2014 at 19:08. |
#20278 | Link | |
Did I miss something? Thank you JDobbs for a most excellent program; when I am able, I will definitely send you some funds ![]() |
#20279 | Link | |
The only time you can burn an imported folder to disc without re-encoding is if the source was 100% BD compliant -- and that is very rare. I've done many imports from MKV in testing -- and BD-RB has always correctly for me. Last edited by jdobbs; 17th May 2014 at 21:41. |
#20280 | Link | |
Here was the exchange that SEEMED to say 'Yes' about this: ABADDON: When using the new "Import" feature, and subsequently fully processing, will a video be "uncropped" to restore the compliant resolution (by adding black boarders) if necessary, or simply vertically stretched? __________________ Last edited by abbadon; 1st October 2012 at 18:21. omegaman7's Avatar Quote: Originally Posted by abbadon View Post When using the new "Import" feature, and subsequently fully processing, will a video be "uncropped" to restore the compliant resolution (by adding black boarders) if necessary, or simply vertically stretched? I ran a cropped video recently. Clearly black borders were added in. It came out perfectly __________________ abbadon hmmm, that's what I figured was SUPPOSED to happen, but for some reason I keep getting stretch video instead of borders . It's just import and process, right? No extra/hidden options? I'm sure I'm missing something... That is why I believe I am missing something ![]() Appreciate your time! Last edited by Lathe; 17th May 2014 at 22:02. |
