Old 25th May 2014, 02:01   #20341  |  Link
Chuckwagon
Originally Posted by neuron2
@Chuckwagon
Where do you get these MKV files? And did you not see jdobb's statement:
"I'm sorry, but please review the thread and the criteria for bug reporting. I don't accept bug reports on preprocessed sources. Experience has proven that almost ALL reports using preprocessed sources were shown to have issues before being presented to BD-RB for backup."
There are many video files, all of legal content, floating about on the web. Finding samples with which to work is easy.
And as for "preprocessed" sources, this is a discussion of the import feature, which accepts MKV files, so it sort of has to include preprocessed sources in this case, since you can't get an MKV without processing a source to make it. And I wasn't reporting a bug, just trying to find more details about an issue some one else reported, in an effort to clarify the issue.
Originally Posted by Chuckwagon View Post
I grabbed a bunch of MKVs off the net
You can't discuss that stuff here, per rule 6. If you do it again you'll get a strike.
No such discussion was taking place nor intended.
Chuckwagon is offline   Reply With Quote
Old 25th May 2014, 02:12   #20342  |  Link
You cannot discuss downloaded material unless you specifically show for each instance that it is in the public domain. Strikes will follow if you do not abide by this. Is it clear? If not, please follow up in PM to me and not in this thread. Thank you.
Old 26th May 2014, 08:36   #20343  |  Link
Diego
Hi everyone, my name's Diego. I have used bdrebuilder many times, but with the last upgrade, I have some problems....
I have two pc, with Windows 7.
In the first pc, when I try to convert a bluray 50 to 25 gb, after a few minutes the pc shutdow. This appen with a movie of 2002, Rookie from Disney.
In the second pc, when I try to do the same ( rebuild from 50 to 25 ) all goes ok, but at the end, the size is 14 gb, and the movie freeze after 20 minutes.
I've ripped with anydvdhd, and burnt on 50 gb it works...
Any ideas?
P.S. the log show no error ...
Diego is offline   Reply With Quote
Old 26th May 2014, 13:57   #20344  |  Link
Go to the first page of this thread and install exactly as outlined with exactly the links provided. If you follow that sequence BD-RB will work every time.
Old 26th May 2014, 18:02   #20345  |  Link
RobertM
Hi Diego,
First, do what JD suggested above. But keep in mind that it could still be a bad rip. BD players are designed to throw out data errors and keep going. BD-Rebuilder is not. A bad rip can sneak through, without causing an error message during ripping, and then cause unpredictable results later on. So if re-loading the helper apps doesn't solve the problem, then try cleaning the disc and ripping again.
Old 26th May 2014, 22:13   #20346  |  Link
gonca
Maybe time to clean the dust bunnies. Tis the season for overheating.
Old 27th May 2014, 07:44   #20347  |  Link
Diego
Thanks to everyone,I'have reinstalled all, as the first page and the file readme. said, but still the problem remains.
I've made a try with another disk, machete kills.
Made new rip. The original copy burnt on br rewritable works ( it is about 27 gb ) but, the resize made to fit it in br 25, is 17 gb, and the movie freeze in the first 20 minutes....
Here the process :
LABEL=MACHETE_KILLS_BD
VERSION=v0.47.06 (beta)
SOURCE_SIZE=28830789738
SOURCE_VIDEO_SIZE=28796123136
TARGET_SIZE=24641536000
REDUCTION=.8545202172454
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;ita;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
DGDECIM=0
FRIMSOURCE=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=7
REBUILD_COMPLETE=1
[00004]
AUDIO=11
PGS=10
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=19590818113
RATE=22009
SPLITS=1
NSTART=27000000
NEND=318352934
NSIZE=13953964032
FLINK=0
MLINK=0
[00005]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=591473901
RATE=18179
SPLITS=1
NSTART=27000000
NEND=37713202
NSIZE=576651264
FLINK=0
MLINK=0
[00006]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=587714778
RATE=18172
SPLITS=1
NSTART=27000000
NEND=37645635
NSIZE=580958208
FLINK=0
MLINK=0
[00007]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=291746820
RATE=18562
SPLITS=1
NSTART=27000000
NEND=32178298
NSIZE=288024576
FLINK=0
MLINK=0
[00008]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=324339889
RATE=18487
SPLITS=1
NSTART=27000000
NEND=32777021
NSIZE=330252288
FLINK=0
MLINK=0
[00009]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=237764549
RATE=18770
SPLITS=1
NSTART=27000000
NEND=31172293
NSIZE=233533440
FLINK=0
MLINK=0
[00010]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=2983011348
RATE=17912
SPLITS=1
NSTART=27000000
NEND=81872317
NSIZE=2456303616
FLINK=0
MLINK=0
the target was 24 gb , but at end process it is 17....
Old 27th May 2014, 12:48   #20348  |  Link
Ch3vr0n
If it's burnt to a bd-re then it's not an original, that being said if that one works, then why don't you simply use IMGBurn to burn the disc again. Do a straight copy
Old 27th May 2014, 14:36   #20349  |  Link
worknstiff
@ Diego; RE: I've made a try with another disk, machete kills.
You are not showing your BD Rebuilder log and did you run the inspect to see if everything is installed correctly. Plus you don't say what player you're using to play back the final rebuilt BD. It seems like maybe it has something to do with cinavia since this is an infected disk and it's also stopping at 20 min. Just sayin', maybe it's a player problem if you are using a up to date software player or a BD player that's mfg. after Feb 2012.
Old 27th May 2014, 17:44   #20350  |  Link
kabster
kabster's Avatar
chapter + freez !!
possible Bug 101!!
have made an bd50 → bd25 from the movie AvP Extended edition and during playback the movie freezes at every chapter for an few secs and continue's with playback on stand alone player !!
tested in software player (TMT 6) the image freezes and stay's frozen !!
This is happening with the Extended selection .., when selecting Theatral (original) everything play's fine both on stand alone and software player !!
Have tried an Movie only backup, and it seems to play fine BUT!!
The movie only wos the original (cutted) version and not the extedended version !!
Thats another thing i like to know, how to choose the extended version when doing an "movie only" backup !!
Original Rip seems unaffected and play fine !!
BD-rebuilder 0.47.6
Every utility up to date (check)
regards,
kabster is offline   Reply With Quote
Old 27th May 2014, 17:45   #20351  |  Link
Ch3vr0n
bdrb log please
Old 27th May 2014, 17:48   #20352  |  Link
kabster
kabster's Avatar
Here you are ..
[Status]
LABEL=ALIEN_VS_PREDATOR
SOURCE_SIZE=33037341058
SOURCE_VIDEO_SIZE=28601321472
REDUCTION=.706453945975213
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=dum;dut;eng;kor;nld;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
DGDECIM=0
FRIMSOURCE=-1
SSIF_MODE=0
QUICK=1
ENCODE_STEP=0
COMPLETED=28
REBUILD_COMPLETE=1
[00060]
AUDIO=1
PGS=1111
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=186639
SPLITS=1
NSTART=27000000
NEND=27011261
NSIZE=67584
FLINK=0
MLINK=0
[00029]
AUDIO=10000
PGS=1101010000000000000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=52966861
RATE=18955
SPLITS=1
NSTART=27000000
NEND=27724473
NSIZE=49274880
FLINK=-1
MLINK=0
[00017]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=57899569
RATE=17095
SPLITS=1
NSTART=27000000
NEND=27893392
NSIZE=55357440
FLINK=-1
MLINK=0
[00036]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=64814732
RATE=17307
SPLITS=1
NSTART=27000000
NEND=27977852
NSIZE=60936192
FLINK=-1
MLINK=0
[00058]
AUDIO=1
PGS=1111
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=85199591
SPLITS=1
NSTART=27000000
NEND=29451198
NSIZE=74913792
FLINK=0
MLINK=0
[00006]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=91421155
RATE=16448
SPLITS=1
NSTART=27000000
NEND=28383257
NSIZE=85241856
FLINK=-1
MLINK=0
[00011]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=95813223
RATE=17121
SPLITS=1
NSTART=27000000
NEND=28388887
NSIZE=88903680
FLINK=-1
MLINK=0
[00020]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=127341963
RATE=17547
SPLITS=1
NSTART=27000000
NEND=28809307
NSIZE=115402752
FLINK=-1
MLINK=0
[00003]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=142889355
RATE=19556
SPLITS=1
NSTART=27000000
NEND=28989487
NSIZE=137232384
FLINK=-1
MLINK=0
[00032]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=185725102
RATE=17851
SPLITS=1
NSTART=27000000
NEND=29723345
NSIZE=177432576
FLINK=-1
MLINK=0
[00055]
AUDIO=1
PGS=1111
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=212896955
SPLITS=1
NSTART=27000000
NEND=33180549
NSIZE=246773760
FLINK=0
MLINK=0
[00057]
AUDIO=1
PGS=1111
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=238410821
SPLITS=1
NSTART=27000000
NEND=33505248
NSIZE=237656064
FLINK=0
MLINK=0
[00056]
AUDIO=1
PGS=1111
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=254603401
SPLITS=1
NSTART=27000000
NEND=33595338
NSIZE=264554496
FLINK=0
MLINK=0
[00026]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=256013604
RATE=18897
SPLITS=1
NSTART=27000000
NEND=30400897
NSIZE=237441024
FLINK=-1
MLINK=0
[00002]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=342696884
RATE=19257
SPLITS=1
NSTART=27000000
NEND=31579575
NSIZE=312330240
FLINK=-1
MLINK=0
[00023]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=358216958
RATE=18763
SPLITS=1
NSTART=27000000
NEND=32097592
NSIZE=340531200
FLINK=-1
MLINK=0
[00005]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=365493535
RATE=19059
SPLITS=1
NSTART=27000000
NEND=31928673
NSIZE=340525056
FLINK=-1
MLINK=0
[00000]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=376161317
RATE=14330
SPLITS=1
NSTART=27000000
NEND=33394513
NSIZE=345704448
FLINK=-1
MLINK=0
[00016]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=402543757
RATE=18338
SPLITS=1
NSTART=27000000
NEND=32628748
NSIZE=371349504
FLINK=-1
MLINK=0
[00031]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=495354082
RATE=20057
SPLITS=1
NSTART=27000000
NEND=33394513
NSIZE=457402368
FLINK=-1
MLINK=0
[00022]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=498431807
RATE=21213
SPLITS=1
NSTART=27000000
NEND=33129873
NSIZE=462778368
FLINK=-1
MLINK=0
[00013]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=542523943
RATE=19941
SPLITS=1
NSTART=27000000
NEND=34043912
NSIZE=501086208
FLINK=-1
MLINK=0
[00025]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=732986883
RATE=19896
SPLITS=1
NSTART=27000000
NEND=36611477
NSIZE=680939520
FLINK=-1
MLINK=0
[00028]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=943184213
RATE=20582
SPLITS=1
NSTART=27000000
NEND=38944432
NSIZE=883716096
FLINK=-1
MLINK=0
[00019]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=1519098073
RATE=19905
SPLITS=1
NSTART=27000000
NEND=47213943
NSIZE=1419454464
FLINK=-1
MLINK=0
[00034]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=2175867473
RATE=20233
SPLITS=1
NSTART=27000000
NEND=55367088
NSIZE=2037233664
FLINK=-1
MLINK=0
[00008]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=4956041765
RATE=20269
SPLITS=1
NSTART=27000000
NEND=91735295
NSIZE=4638959616
FLINK=-1
MLINK=0
[00038]
AUDIO=10000
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=5582317182
RATE=19410
SPLITS=1
NSTART=27000000
NEND=102756305
NSIZE=5269487616
FLINK=0
MLINK=0
Old 27th May 2014, 20:00   #20353  |  Link
Ch3vr0n
that's the inf file, not the conversion log
Old 27th May 2014, 20:53   #20354  |  Link
kabster
kabster's Avatar
Here i thought the longest/movie log should be the most complete/detailed file and thus the most helpfull log to help you ppl sorting this out ..
i guess i wos wrong!!
↓ this is the rebuilder ini file, now you have both !
Happy hunting..
[05/26/14] BD Rebuilder v0.47.06 (beta)
[23:45:27] Source:  ALIEN_VS_PREDATOR
  - Input BD size: 30,77 GB
  - Approximate total content: [02:06:39.424]
  - Target BD size: 22,95 GB
  - Windows Version: 6.1 [7601]
  - Quality: High Quality (Default), Two Pass
  - SHUTDOWN at completion enabled
  - Decoding/Frame serving: FRIMSource
[23:45:27] PHASE ONE, Encoding
 - [23:45:27] Processing: VID_00060 (1 of 28)
 - [23:45:27] Extracting A/V streams [VID_00060]
 - [23:45:33] Reencoding video [VID_00060]
   - Source Video: MPEG-2, 1920x1080
   - Rate/Length: 23,976fps, 6 frames
 - [23:45:33] Reencoding: VID_00060, Pass 1 of 1
 - [23:45:35] Video Encode complete
 - [23:45:35] Processing audio tracks
 - [23:45:35] Multiplexing M2TS
 - [23:45:38] Processing: VID_00029 (2 of 28)
 - [23:45:38] Extracting A/V streams [VID_00029]
 - [23:45:44] Reencoding video [VID_00029]
   - Rate/Length: 23,976fps, 386 frames
   - Bitrate: 18.955 Kbs
 - [23:45:44] Reencoding: VID_00029, Pass 1 of 2
 - [23:45:49] Reencoding: VID_00029, Pass 2 of 2
 - [23:46:07] Video Encode complete
 - [23:46:07] Processing audio tracks
 - [23:46:07] Multiplexing M2TS
 - [23:46:11] Processing: VID_00017 (3 of 28)
 - [23:46:11] Extracting A/V streams [VID_00017]
 - [23:46:16] Reencoding video [VID_00017]
   - Rate/Length: 23,976fps, 476 frames
   - Bitrate: 17.095 Kbs
 - [23:46:16] Reencoding: VID_00017, Pass 1 of 2
 - [23:46:23] Reencoding: VID_00017, Pass 2 of 2
 - [23:46:44] Video Encode complete
 - [23:46:44] Processing audio tracks
 - [23:46:44] Multiplexing M2TS
 - [23:46:48] Processing: VID_00036 (4 of 28)
 - [23:46:48] Extracting A/V streams [VID_00036]
 - [23:46:53] Reencoding video [VID_00036]
   - Rate/Length: 23,976fps, 521 frames
   - Bitrate: 17.307 Kbs
 - [23:46:53] Reencoding: VID_00036, Pass 1 of 2
 - [23:47:00] Reencoding: VID_00036, Pass 2 of 2
 - [23:47:21] Video Encode complete
 - [23:47:21] Processing audio tracks
 - [23:47:21] Multiplexing M2TS
 - [23:47:26] Processing: VID_00058 (5 of 28)
 - [23:47:26] Extracting A/V streams [VID_00058]
 - [23:47:31] Reencoding video [VID_00058]
   - Rate/Length: 23,976fps, 1.306 frames
 - [23:47:31] Reencoding: VID_00058, Pass 1 of 1
 - [23:47:43] Video Encode complete
 - [23:47:43] Processing audio tracks
 - [23:47:43] Multiplexing M2TS
 - [23:47:50] Processing: VID_00006 (6 of 28)
 - [23:47:50] Extracting A/V streams [VID_00006]
 - [23:47:55] Reencoding video [VID_00006]
   - Rate/Length: 23,976fps, 737 frames
   - Bitrate: 16.448 Kbs
 - [23:47:55] Reencoding: VID_00006, Pass 1 of 2
 - [23:48:06] Reencoding: VID_00006, Pass 2 of 2
 - [23:48:36] Video Encode complete
 - [23:48:36] Processing audio tracks
 - [23:48:36] Multiplexing M2TS
 - [23:48:41] Processing: VID_00011 (7 of 28)
 - [23:48:41] Extracting A/V streams [VID_00011]
 - [23:48:46] Reencoding video [VID_00011]
   - Rate/Length: 23,976fps, 740 frames
   - Bitrate: 17.121 Kbs
 - [23:48:46] Reencoding: VID_00011, Pass 1 of 2
 - [23:48:57] Reencoding: VID_00011, Pass 2 of 2
 - [23:49:30] Video Encode complete
 - [23:49:30] Processing audio tracks
 - [23:49:30] Multiplexing M2TS
 - [23:49:34] Processing: VID_00020 (8 of 28)
 - [23:49:34] Extracting A/V streams [VID_00020]
 - [23:49:40] Reencoding video [VID_00020]
   - Rate/Length: 23,976fps, 964 frames
   - Bitrate: 17.547 Kbs
 - [23:49:40] Reencoding: VID_00020, Pass 1 of 2
 - [23:49:53] Reencoding: VID_00020, Pass 2 of 2
 - [23:50:35] Video Encode complete
 - [23:50:35] Processing audio tracks
 - [23:50:35] Multiplexing M2TS
 - [23:50:40] Processing: VID_00003 (9 of 28)
 - [23:50:40] Extracting A/V streams [VID_00003]
 - [23:50:47] Reencoding video [VID_00003]
   - Rate/Length: 23,976fps, 1.060 frames
   - Bitrate: 19.556 Kbs
 - [23:50:47] Reencoding: VID_00003, Pass 1 of 2
 - [23:51:01] Reencoding: VID_00003, Pass 2 of 2
 - [23:51:45] Video Encode complete
 - [23:51:45] Processing audio tracks
 - [23:51:45] Multiplexing M2TS
 - [23:51:50] Processing: VID_00032 (10 of 28)
 - [23:51:50] Extracting A/V streams [VID_00032]
 - [23:51:57] Reencoding video [VID_00032]
   - Rate/Length: 23,976fps, 1.451 frames
   - Bitrate: 17.851 Kbs
 - [23:51:57] Reencoding: VID_00032, Pass 1 of 2
 - [23:52:16] Reencoding: VID_00032, Pass 2 of 2
 - [23:53:15] Video Encode complete
 - [23:53:15] Processing audio tracks
 - [23:53:15] Multiplexing M2TS
 - [23:53:20] Processing: VID_00055 (11 of 28)
 - [23:53:20] Extracting A/V streams [VID_00055]
 - [23:53:29] Reencoding video [VID_00055]
   - Rate/Length: 23,976fps, 3.293 frames
 - [23:53:29] Reencoding: VID_00055, Pass 1 of 1
 - [23:53:58] Video Encode complete
 - [23:53:58] Processing audio tracks
 - [23:53:58] Multiplexing M2TS
 - [23:54:04] Processing: VID_00057 (12 of 28)
 - [23:54:04] Extracting A/V streams [VID_00057]
 - [23:54:11] Reencoding video [VID_00057]
   - Rate/Length: 23,976fps, 3.466 frames
 - [23:54:12] Reencoding: VID_00057, Pass 1 of 1
 - [23:54:42] Video Encode complete
 - [23:54:42] Processing audio tracks
 - [23:54:42] Multiplexing M2TS
 - [23:54:48] Processing: VID_00056 (13 of 28)
 - [23:54:48] Extracting A/V streams [VID_00056]
 - [23:54:56] Reencoding video [VID_00056]
   - Rate/Length: 23,976fps, 3.514 frames
 - [23:54:56] Reencoding: VID_00056, Pass 1 of 1
 - [23:55:28] Video Encode complete
 - [23:55:28] Processing audio tracks
 - [23:55:28] Multiplexing M2TS
 - [23:55:34] Processing: VID_00026 (14 of 28)
 - [23:55:34] Extracting A/V streams [VID_00026]
 - [23:55:41] Reencoding video [VID_00026]
   - Rate/Length: 23,976fps, 1.812 frames
   - Bitrate: 18.897 Kbs
 - [23:55:41] Reencoding: VID_00026, Pass 1 of 2
 - [23:56:05] Reencoding: VID_00026, Pass 2 of 2
 - [23:57:25] Video Encode complete
 - [23:57:25] Processing audio tracks
 - [23:57:25] Multiplexing M2TS
 - [23:57:31] Processing: VID_00002 (15 of 28)
 - [23:57:31] Extracting A/V streams [VID_00002]
 - [23:57:40] Reencoding video [VID_00002]
   - Rate/Length: 23,976fps, 2.440 frames
   - Bitrate: 19.257 Kbs
 - [23:57:40] Reencoding: VID_00002, Pass 1 of 2
 - [23:58:10] Reencoding: VID_00002, Pass 2 of 2
 - [23:59:50] Video Encode complete
 - [23:59:50] Processing audio tracks
 - [23:59:50] Multiplexing M2TS
 - [23:59:56] Processing: VID_00023 (16 of 28)
 - [23:59:56] Extracting A/V streams [VID_00023]
 - [00:00:05] Reencoding video [VID_00023]
   - Rate/Length: 23,976fps, 2.716 frames
   - Bitrate: 18.763 Kbs
 - [00:00:05] Reencoding: VID_00023, Pass 1 of 2
 - [00:00:38] Reencoding: VID_00023, Pass 2 of 2
 - [00:02:41] Video Encode complete
 - [00:02:41] Processing audio tracks
 - [00:02:41] Multiplexing M2TS
 - [00:02:48] Processing: VID_00005 (17 of 28)
 - [00:02:48] Extracting A/V streams [VID_00005]
 - [00:02:57] Reencoding video [VID_00005]
   - Rate/Length: 23,976fps, 2.626 frames
   - Bitrate: 19.059 Kbs
 - [00:02:57] Reencoding: VID_00005, Pass 1 of 2
 - [00:03:30] Reencoding: VID_00005, Pass 2 of 2
 - [00:05:23] Video Encode complete
 - [00:05:23] Processing audio tracks
 - [00:05:23] Multiplexing M2TS
 - [00:05:30] Processing: VID_00000 (18 of 28)
 - [00:05:30] Extracting A/V streams [VID_00000]
 - [00:05:39] Reencoding video [VID_00000]
   - Rate/Length: 23,976fps, 3.407 frames
   - Bitrate: 14.330 Kbs
 - [00:05:39] Reencoding: VID_00000, Pass 1 of 2
 - [00:06:19] Reencoding: VID_00000, Pass 2 of 2
 - [00:08:18] Video Encode complete
 - [00:08:18] Processing audio tracks
 - [00:08:18] Multiplexing M2TS
 - [00:08:26] Processing: VID_00016 (19 of 28)
 - [00:08:26] Extracting A/V streams [VID_00016]
 - [00:08:35] Reencoding video [VID_00016]
   - Rate/Length: 23,976fps, 2.999 frames
   - Bitrate: 18.338 Kbs
 - [00:08:35] Reencoding: VID_00016, Pass 1 of 2
 - [00:09:13] Reencoding: VID_00016, Pass 2 of 2
 - [00:11:32] Video Encode complete
 - [00:11:32] Processing audio tracks
 - [00:11:32] Multiplexing M2TS
 - [00:11:40] Processing: VID_00031 (20 of 28)
 - [00:11:40] Extracting A/V streams [VID_00031]
 - [00:11:50] Reencoding video [VID_00031]
   - Bitrate: 20.057 Kbs
 - [00:11:50] Reencoding: VID_00031, Pass 1 of 2
 - [00:12:35] Reencoding: VID_00031, Pass 2 of 2
 - [00:15:25] Video Encode complete
 - [00:15:25] Processing audio tracks
 - [00:15:25] Multiplexing M2TS
 - [00:15:33] Processing: VID_00022 (21 of 28)
 - [00:15:33] Extracting A/V streams [VID_00022]
 - [00:15:43] Reencoding video [VID_00022]
   - Rate/Length: 23,976fps, 3.266 frames
   - Bitrate: 21.213 Kbs
 - [00:15:43] Reencoding: VID_00022, Pass 1 of 2
 - [00:16:29] Reencoding: VID_00022, Pass 2 of 2
 - [00:19:19] Video Encode complete
 - [00:19:19] Processing audio tracks
 - [00:19:19] Multiplexing M2TS
 - [00:19:27] Processing: VID_00013 (22 of 28)
 - [00:19:27] Extracting A/V streams [VID_00013]
 - [00:19:37] Reencoding video [VID_00013]
   - Rate/Length: 23,976fps, 3.753 frames
   - Bitrate: 19.941 Kbs
 - [00:19:37] Reencoding: VID_00013, Pass 1 of 2
 - [00:20:28] Reencoding: VID_00013, Pass 2 of 2
 - [00:23:34] Video Encode complete
 - [00:23:34] Processing audio tracks
 - [00:23:34] Multiplexing M2TS
 - [00:23:42] Processing: VID_00025 (23 of 28)
 - [00:23:42] Extracting A/V streams [VID_00025]
 - [00:23:55] Reencoding video [VID_00025]
   - Rate/Length: 23,976fps, 5.121 frames
   - Bitrate: 19.896 Kbs
 - [00:23:55] Reencoding: VID_00025, Pass 1 of 2
 - [00:25:03] Reencoding: VID_00025, Pass 2 of 2
 - [00:29:17] Video Encode complete
 - [00:29:17] Processing audio tracks
 - [00:29:17] Multiplexing M2TS
 - [00:29:27] Processing: VID_00028 (24 of 28)
 - [00:29:27] Extracting A/V streams [VID_00028]
 - [00:29:42] Reencoding video [VID_00028]
   - Rate/Length: 23,976fps, 6.364 frames
   - Bitrate: 20.582 Kbs
 - [00:29:42] Reencoding: VID_00028, Pass 1 of 2
 - [00:31:06] Reencoding: VID_00028, Pass 2 of 2
 - [00:36:19] Video Encode complete
 - [00:36:19] Processing audio tracks
 - [00:36:19] Multiplexing M2TS
 - [00:36:31] Processing: VID_00019 (25 of 28)
 - [00:36:31] Extracting A/V streams [VID_00019]
 - [00:36:50] Reencoding video [VID_00019]
   - Rate/Length: 23,976fps, 10.770 frames
   - Bitrate: 19.905 Kbs
 - [00:36:50] Reencoding: VID_00019, Pass 1 of 2
 - [00:39:09] Reencoding: VID_00019, Pass 2 of 2
 - [00:47:57] Video Encode complete
 - [00:47:57] Processing audio tracks
 - [00:47:57] Multiplexing M2TS
 - [00:48:13] Processing: VID_00034 (26 of 28)
 - [00:48:13] Extracting A/V streams [VID_00034]
 - [00:48:38] Reencoding video [VID_00034]
   - Rate/Length: 23,976fps, 15.114 frames
   - Bitrate: 20.233 Kbs
 - [00:48:38] Reencoding: VID_00034, Pass 1 of 2
 - [00:51:58] Reencoding: VID_00034, Pass 2 of 2
 - [01:04:21] Video Encode complete
 - [01:04:21] Processing audio tracks
 - [01:04:21] Multiplexing M2TS
 - [01:04:44] Processing: VID_00008 (27 of 28)
 - [01:04:44] Extracting A/V streams [VID_00008]
 - [01:05:32] Reencoding video [VID_00008]
   - Rate/Length: 23,976fps, 34.491 frames
   - Bitrate: 20.269 Kbs
 - [01:05:32] Reencoding: VID_00008, Pass 1 of 2
 - [01:12:55] Reencoding: VID_00008, Pass 2 of 2
 - [01:40:54] Video Encode complete
 - [01:40:55] Processing audio tracks
 - [01:40:55] Multiplexing M2TS
 - [01:41:39] Processing: VID_00038 (28 of 28)
 - [01:41:39] Extracting A/V streams [VID_00038]
 - [01:42:33] Reencoding video [VID_00038]
   - Rate/Length: 23,976fps, 40.363 frames
   - Bitrate: 19.410 Kbs
 - [01:42:33] Reencoding: VID_00038, Pass 1 of 2
 - [01:50:29] Reencoding: VID_00038, Pass 2 of 2
 - [02:15:51] Video Encode complete
 - [02:15:51] Processing audio tracks
 - [02:15:51] Multiplexing M2TS
[02:16:43]PHASE ONE complete
[02:16:43]PHASE TWO - Rebuild Started
 - [02:16:43] Rebuilding BD file Structure
[02:17:15] - Encode and Rebuild complete
 - WORKFILES folder removed.
 - Computer SHUTDOWN initiated.
Old 27th May 2014, 21:52   #20355  |  Link
worknstiff
@ kabster; RE Decoding/Frame serving: FRIMSource
Alien Vs. Predator isn't a 3D movie, why are you using FRIMSource to encode. Perhaps you would have a better outcome if you just use the regular encoder instead. I thought jdobbs had disabled FRIM except for 3D MVC encodes. hope this helps, worknstiff
Old 27th May 2014, 21:59   #20356  |  Link
Ch3vr0n
He's not, he's using it as a frame server. Kabster, go to the he'll menu and select inspect. Post the results
Verstuurd vanaf mijn Nexus 7 met Tapatalk
Old 27th May 2014, 22:28   #20357  |  Link
kabster
kabster's Avatar
First i want to say, that i have used different settings for decoding. i.e: default, x264 → (fyi, using x264 as frame server helped allot to fix A/V lip sync), and lastly Frimsource .. its no use this time to get arround this latest issue !!
@chevron,
as i have wrote earlier, every tool, codec, decoder etc is marked OK during the test ..
Old 27th May 2014, 22:42   #20358  |  Link
Ch3vr0n
@kabster: that may exactly be the problem. You not supposed to use the latest versions out there! Only the ones specified in the first post. How are we and jdobbs supposed to help you if you refuse to most the required info?
Old 28th May 2014, 00:29   #20359  |  Link
gonca
@jdobbs
Do these entries from kabsters' INF look right. I'm referring to the negative signs.
KEEP_HD_AUDIO=-1
FRIMSOURCE=-1
Old 28th May 2014, 07:51   #20360  |  Link
Diego
I use rewritable to test if the decrypting was fine. But burn a 50gb for a movie that has 27 gb it's a shame.
