25th March 2009, 01:13 | #2181 | Link | |
PS3 only plays BD25 with no problems at all. |
25th March 2009, 03:29 | #2183 | Link | |
Watch with what... with no problems? What do you see on the PS3 menu for representing the disc? Data Disc, BD ROM, AVCHD? I've got 70-80 full movie backups to BD25 that play perfectly on the PS3. Not a single copy to BD25 has failed to play. What settings are you using in BD Rebuilder? Are you doing any pre-processing or post-processing with another program? Last edited by GaPony; 25th March 2009 at 03:32. |
25th March 2009, 03:38 | #2184 | Link | |
25th March 2009, 07:52 | #2185 | Link | |
When I made a comment about LG BD370, I spoke with reservation, stating clearly that "I wouldn't be surprised if..." |
25th March 2009, 12:47 | #2186 | Link | |
In BD-RB the settings are all default, all i change is the output size and press backup. No pre/post processing with anything. Just create the image in IMGBURN and go. Normally i can play the resulting image in PDVD and fool around with it. Pineapple Express didn't even work. I see people reporting issues about AnyDVDHD being open, so i'm going to try again with that app closed, and running from an iso with no protection. I'll see what happens..
[SLiM] |
25th March 2009, 12:54 | #2187 | Link |
I just make my first attempt with this wonderful software. Quantum of Solace full movie into BD5. When I drop the index.bdmv into AVCHD Patcher ver 1.05 and 1.06 both comes up with error "This file is not correct format". Only after some more reading I know full movie in BD5 is not suppose to work in PS3 so I gave up looking for solution. But the disc plays fine in HTPC with TMT. No luck with PDVD and WinDVD.
Only problem I found is that since I have resize 1080p to 720P and subtitles must be untouched so they becomes really BIG. Hope there is a fix to this. I will try Movie Only next time. Is that with "Stricter AVCHD compliance" checked there is no need to run AVCHD Patcher anymore? |
25th March 2009, 16:11 | #2188 | Link |
vero
[19:50:40] BD Rebuilder v0.20.02 (beta) - Source: HELLBOY2_D1 - Input BD size: 41.72 GB - Approximate total content: [04:29:18.650] - Target BD size: 22.90 GB [19:50:40] PHASE ONE, Encoding - [19:50:40] Extracting audio/subs [VID_00002] - [19:50:42] Reencoding: VID_00002 (1 of 61) - [19:52:02] Extracting audio/subs [VID_00009] - [19:52:03] Reencoding: VID_00009 (2 of 61) - [19:52:47] Extracting audio/subs [VID_00217] - [19:52:50] Reencoding: VID_00217 (3 of 61) - [19:55:41] Extracting audio/subs [VID_00220] - [20:06:59] Reencoding: VID_00220 (4 of 61) - [04:00:26] Extracting audio/subs [VID_00222] - [04:00:37] Reencoding: VID_00222 (5 of 61) - [04:09:16] Extracting audio/subs [VID_00269] - [04:09:16] Reencoding: VID_00269 (6 of 61) - [04:18:30] Extracting audio/subs [VID_00277] - [04:18:33] Reencoding: VID_00277 (7 of 61) - [04:21:01] Extracting audio/subs [VID_00278] - [04:21:06] Reencoding: VID_00278 (8 of 61) - [04:24:20] Extracting audio/subs [VID_00279] - [04:24:22] Reencoding: VID_00279 (9 of 61) - [04:26:30] Extracting audio/subs [VID_00280] - [04:26:38] Reencoding: VID_00280 (10 of 61) - [04:29:45] Extracting audio/subs [VID_00281] - [04:29:49] Reencoding: VID_00281 (11 of 61) - [04:31:46] Extracting audio/subs [VID_00282] - [04:31:48] Reencoding: VID_00282 (12 of 61) - [04:32:46] Extracting audio/subs [VID_00283] - [04:32:47] Reencoding: VID_00283 (13 of 61) - [04:33:18] Extracting audio/subs [VID_00284] - [04:33:19] Reencoding: VID_00284 (14 of 61) - [04:34:02] Extracting audio/subs [VID_00285] - [04:34:04] Reencoding: VID_00285 (15 of 61) - [04:34:28] Extracting audio/subs [VID_00286] - [04:34:29] Reencoding: VID_00286 (16 of 61) - [04:35:05] Extracting audio/subs [VID_00287] - [04:35:06] Reencoding: VID_00287 (17 of 61) - [04:36:11] Extracting audio/subs [VID_00288] - [04:36:12] Reencoding: VID_00288 (18 of 61) - [04:36:40] Extracting audio/subs [VID_00289] - [04:37:09] Reencoding: VID_00289 (19 of 61) - [04:55:38] Extracting audio/subs [VID_00291] - [04:55:41] Reencoding: VID_00291 (20 of 61) - [04:57:48] Extracting audio/subs [VID_00292] - [04:57:56] Reencoding: VID_00292 (21 of 61) - Encode failed. Retrying. - Encode failed. Retrying. x264.exe has encountered a problem and needs to close. We are sorry for the inconvenience. why error?what's wrong with x264? anybody help me anyone can explain to me why is this happened? |
25th March 2009, 16:17 | #2189 | Link | |
If a Movie Only is acceptable for your needs, then check the block for "Stricter compliance..." and it should register as an AVCHD on the PS3 and play. At least for the time being, the PS3 (US Version) only works for full movies if you put them on BD25 discs. Its not a bug in BD-Rebuilder, its the PS3. |
25th March 2009, 17:21 | #2191 | Link |
my uk ps3 will not play full movie backups at all with bd rebuilder burnt onto sony and verbatim bd-res just keeps spinning like its wanting to read it but eventually just stops.
its a release 60 gb ps3 and was working with stuff until recently then wont touch either movie only or backups |
25th March 2009, 18:26 | #2192 | Link | |
Aging Video Hobbyist
25th March 2009, 22:55 | #2194 | Link |
The issue with Hellboy 2 is that some of the extras are in a format that x264 can't handle. There are loads of posts in this thread about it. I got around it by encoding to bd25 and using an minimum encode size which meant the problem extras were copied intact.
25th March 2009, 22:59 | #2195 | Link |
This thread must becoming unusable to jdobbs now as there are so many new posters who are highlighting issues that have come up several times over it's 110 page history. You can't really blame people for not being able to find the information they require givens it's length. Are any of the moderators or helpers with this thread capable of creating a known issues sticky, or problem discs and then starting a new bug reporting thread?
25th March 2009, 23:02 | #2196 | Link |
I have just tried to do Batman Begins Region B, and found the error with the audio encoding. Interestingly the track it has problems with is not the main audio but a 2 channel one designated AC3+. I therefore did the disc to bd9 and only selected the first audio (multichannel AC3), ignoring the True HD one and the AC3+. Disc completed okay but I have the recurring issue on Sony standalones where the audio isn't selectable.
25th March 2009, 23:14 | #2197 | Link | |
There is a rumour that it only affects "Universal" titles, but I call BS on that. I think it's more down to the fact that Universal released nearly all it's new HD DVDs with PIP tracks and then ported them to Bluray. So it's not universal, it's just that there are PIP tracks on all these discs Vs relatively few for studios that were 100% Bluray from the start since the 1st Bluray players didn't even support a PIP track... Just my assumption.... |
26th March 2009, 02:24 | #2198 | Link | |
If I may be so bold as to suggest that those who post questions and/or bug reports follow a set procedure of
When others - both experienced users and newbies - do a search, they would find the original question/report and the resolution. Until and unless the forum software is fully threaded by post (like what you find in blogs) I seriously doubt that the moderators or any other person would be able to keep track of every single post and maintain or make it into an FAQ sticky easily. This is my 2 cents and It is way off topic here. I return you know to your favorite program... BD-ReBuilder. Maybe a ... Maybe not...
Vista SP1 32-bit w/4GB RAM AMD Athlon 64 X2 4400+ @ 2.23GHz nVidia GeForce 8400GS w/512MB RAM |
26th March 2009, 06:08 | #2199 | Link |
You're probably right. In the beginning jdobbs just started us off with considering all issues as bugs. He has probably achieved enough maturity that term "bug" can be more specific.
A known issues thread, locked by the mod, along with a new "Bugs Only" thread is probably a very good idea. I agree that this thread is too long and diverse to be of much use to him. Last edited by GaPony; 26th March 2009 at 06:11. |
26th March 2009, 06:33 | #2200 | Link |
I think if jdobbs put in the first post of this thread this thread would be easier to read:
- current decoding workarounds which a lot of the posts in this thread are and aren't even BD-RB bugs - list of known bugs that he can work on and update the list so hopefully no one else reports - hidden ini settings and what they do To begin with this thread was a discussion piece and it's still kind of that way. I'm guilty of this as well, it was the only BD-RB thread to at first. I've also reported a few bugs here as well and I've also tried helping others out with their bugs and workarounds. Reading through the same discussion over and over again could become annoying but luckily there is 'view last unread' as long as you don't get too far behind. |
