24th January 2015, 17:14 | #22161 | Link | |
I first ran BD-RB version 50.01 to test the pre-fix version: Part 1 of 3 re-encoded, but part 2 of 3 did not. So I aborted and started up BD-RB 50.03 and re-ran with the exact same settings: all 3 parts re-encoded (I didn't wait for completion because I was doing these tests on my slow computer). I posted the log below, just in case it is of interest. I didn't re-test 'Trance', the other title where I saw this problem, because I recall you said you had purchased that title for testing, so I presume that you've already confirmed the results on that title yourself. Anyways, looks like you've squashed that one. Kudos, and a job well done Code:
[01/24/15] BD Rebuilder v0.50.01 [09:31:13] Source: THE_COUNSELOR_00800 - Input BD size: 33.50 GB - Approximate total content: [01:57:14.026] - Target BD size: 23.63 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: Good (Very Fast), Two Pass - Decoding/Frame serving: DirectShow - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [09:31:15] PHASE ONE, Encoding - [09:31:15] Processing: VID_00500 (1 of 3) - [09:31:15] Extracting A/V streams [VID_00500] - [09:43:56] Reencoding video [VID_00500] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 6,753 frames - Bitrate: 26,245 Kbs - [09:43:56] Reencoding: VID_00500, Pass 1 of 2 - [09:45:54] Reencoding: VID_00500, Pass 2 of 2 - [09:47:53] Video Encode complete - [09:47:53] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [09:51:25] Processing: VID_00501 (2 of 3) - [09:51:25] Extracting A/V streams [VID_00501] - [09:51:36] Reencoding video [VID_00501] - [09:51:36] Keeping original video (no reencode) - [09:51:36] Processing: VID_00502 (3 of 3) - [09:51:36] Extracting A/V streams [VID_00502] [09:53:19]PHASE ONE aborted by user request ---------------------- [01/24/15] BD Rebuilder v0.50.03 [09:55:04] Source: THE_COUNSELOR_00800 - Input BD size: 33.50 GB - Approximate total content: [01:57:14.026] - Target BD size: 23.63 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: Good (Very Fast), Two Pass - Decoding/Frame serving: DirectShow - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [09:55:08] PHASE ONE, Encoding - [09:55:08] Processing: VID_00500 (1 of 3) - [09:55:08] Extracting A/V streams [VID_00500] - [10:07:37] Reencoding video [VID_00500] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 6,753 frames - Bitrate: 26,245 Kbs - [10:07:37] Reencoding: VID_00500, Pass 1 of 2 - [10:09:41] Reencoding: VID_00500, Pass 2 of 2 - [10:12:13] Video Encode complete - [10:12:13] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [10:15:15] Processing: VID_00501 (2 of 3) - [10:15:15] Extracting A/V streams [VID_00501] - [10:15:24] Reencoding video [VID_00501] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 788 frames - Bitrate: 18,615 Kbs - [10:15:24] Reencoding: VID_00501, Pass 1 of 2 - [10:15:30] Reencoding: VID_00501, Pass 2 of 2 - [10:15:34] Video Encode complete - [10:15:34] Processing: VID_00502 (3 of 3) - [10:15:34] Extracting A/V streams [VID_00502] - [10:36:10] Reencoding video [VID_00502] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 161,107 frames - Bitrate: 25,628 Kbs - [10:36:10] Reencoding: VID_00502, Pass 1 of 2 [10:41:25]PHASE ONE aborted by user request |
25th January 2015, 22:58 | #22165 | Link |
I respectfully ask jdobbs, if a particular version is working fine, why make it unusable by forcing an update? I'm all in for the app to implement new features and improvements, but forcing an update does not make sense to me? Wouldn't a popup indicating there is a new version available, be a better alternative? This would give the person the option to do so.
25th January 2015, 23:33 | #22166 | Link |
There hasn't been a forced update or timeout in several versions now (since v0.49.07).
The purpose of the timeout was never to implement new features -- but to prevent me from having to answer bug reports that had already been fixed. I think that was fair as it's me who had to respond to outdated reports. But I think it's stable enough now that I don't get the volume of bug reports that I used to, so I disabled the timeout. The only reason I keep it in beta is so I can still make significant changes without having to apologize every time I cause a new bug. Last edited by jdobbs; 25th January 2015 at 23:41. |
26th January 2015, 05:10 | #22168 | Link |
I may have missed this, but how does BDRB handle Atmos audio? I saw a ways back where a fellow was trying to reencode 'TRANSFORMERS 4' which has an Atmos soundtrack, and he commented that it looked like it was keeping like a 7 Gig audio track (he wanted intact audio) and I looked for a few pages after that and I didn't see any further replies to that. I think he mentioned that he would like to keep just the normal HD audio WITHOUT all the Atmos information.
Would someone mind refreshing me about how BDRB handles this kind of audio? Thanks! |
26th January 2015, 06:00 | #22170 | Link | |
So if you keep the track intact, the Atmos extension data stays. If you reencode, the output is Dolby 5.1 reencoded from the data that is present in compliance with the BD standard. Last edited by jdobbs; 26th January 2015 at 06:03. |
26th January 2015, 06:09 | #22171 | Link | |
I suppose that if the Atmos stuff adds THAT much size to the audio track, there may be ways to transcode it using UsEAC3to or TSMuxer or something in the future. Seems like I was reading a thread about that somewhere... |
26th January 2015, 06:11 | #22172 | Link |
Did you notice, as the guy was saying, that like with 'TRANSFORMERS 4' the full intact audio came out to about 7 Gigs? Wouldn't you think that that would kind of cramp a person's style a bit with re-encoding, taking up that much space...?
26th January 2015, 06:17 | #22173 | Link |
7gig is nothing on a 25gb disc. (Exact space is 23.5) which still leaves 16.5gb for the movie, with the power of x264 that's plenty. Even more when English is the only audio you keep. I didn't notice any pixellation issues on my 42" TV.
Verstuurd vanaf mijn Nexus 7 met Tapatalk |
26th January 2015, 06:55 | #22174 | Link | |
26th January 2015, 14:03 | #22175 | Link |
@ Lathe RE: Just seemed like a lot to me, although I always keep intact audio in English.
I always want to keep the HD audio too. If you process Transformer 4 with BD_Rebuilder you will find in the work folder the following audio files for the 00800.mpls * 00800.4352.ac3 = 5.79gb * 00800.4353.ac3 = 755mb * 00800.4358.ac3 = 755mb which adds up to 7.26gb, which is a LOT of audio. I am tempted to think that the "ATMOS" sound info is just in the two =755mb ac3's but maybe jdobbs would be able to tell us more about how that works. He is after all the master of all things bluray, lol. I wish there was a checkmark to keep only the DTS-HD 7.1 audio and discard the ATMOS but I guess it would mean a lot more of a headache than just deleting the two 755mb ac3 files. How many people will have 128 different speakers in their home anyway, I myself only have a 5.1 setup but want to keep the 7.1 in case I decide to upgrade the rear channels some time. Hope to see some more discussion about ATMOS cause it looks like this will become the norm on blu ray especially with the upcoming 4K ultra blu rays. |
26th January 2015, 16:30 | #22176 | Link |
Dolby Atmos to DTS-HD is not possible without reencoding the track. But there is no Freeware that can do this. You can only extract the HD track to a normal 5.1 track by loosing the core infos. On Transformers 4 BD is only the english track an Atmos track and thats not my language I watch movies.
27th January 2015, 02:30 | #22177 | Link | |
29th January 2015, 00:52 | #22180 | Link | |
@JD I bought Ghostbusters and Ghostbusters 2 in a pack, and have noticed if first movie is processed (without any rerendering) to just have warning and stuff removed and not keeping any 480i which has mixed Telecine and Interlaced, it completes well. However, if I switch to BD-25 output and enable rerendering the final mux fails. It does have a secondary video.. Long list of tests...so attached instead of posted; including config.
