29th January 2015, 12:52 | #22181 | Link |
Jdobbs, importing mkv files BDRB returns with the following error. Some hint of what might be happening?
[09:33:46] Importing MKV: GUARDIOES_DA_GALAXIA - Collecting audio/video streams from source... [09:33:48]ERROR: Gathering source file information. Aborted. [01/29/15] Checking System Settings - BD-Rebuilder v0.50.03 - Windows Version: 6.1 [7601] - Working Path Free Space: 369,07GB - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 4515, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [01/29/15] Systems Settings Check complete |
29th January 2015, 21:42 | #22186 | Link | |
Speaking of the type pgs subtitles, the BDRB in import mode does not accept this type of subtitles, correct? Last edited by soneca; 29th January 2015 at 22:40. |
30th January 2015, 01:31 | #22187 | Link |
Yes, it supports import of PGS streams from MKV. If you look at the MKV with MEDIAINFO the codec id should say "S_HDMV/PGS"
BD-RB will also import subtitles of the type SRT. [Edit] As a test I just imported an MKV which has PGS subtitles. No problem. Last edited by jdobbs; 30th January 2015 at 01:38. |
30th January 2015, 04:53 | #22188 | Link |
I do not know what's going on....
This support mkv with pgs subtitles also applies to generate dvd's? I've done many AVCHD discs and DVD's from the mkv files with srt subtitles embedded type, no problem, all right. But tried a few times to generate a dvd from mkv files with embedded pgs subtitles but the result is always DVD without subtitles. I will do more tests to a better definition of what is happening... Thanks! |
30th January 2015, 05:28 | #22189 | Link | |
I generally don't complain about MKV input problems though, because the program is mostly aimed at BD → (name your format). I guess I probably should have posted though. It technically was a bug... :S
Only one rooster, need be in the hen house... Last edited by omegaman7; 30th January 2015 at 05:30. |
30th January 2015, 06:08 | #22190 | Link | |
There really shouldn't be any problem outputting the PGS subtitles to DVD -- as they would be no different than regular BD subtitles after they're imported, but I'll test that tomorrow. Last edited by jdobbs; 30th January 2015 at 06:11. |
30th January 2015, 06:39 | #22191 | Link | |
Update: Using internal LAVF, single and 2-pass the test process completes without error, unless I don't delete the previous Output directory. Then this error is produced: "CopyDirStructure() 00075 1200". Otherwise, if deleted after starting process..all goes well.
30th January 2015, 06:45 | #22192 | Link |
Shame to you and your family name! Joking. I haven't imported any DVDs and made MKV's from them in a while, but that does remind me to revisit a bug when MKVs ARE involved, but not meaning they're causing it. I'll check that soon.
30th January 2015, 13:59 | #22193 | Link | |
I tried to import 11 mkv files and 4 of them gave me that error message that I reported. The files are similar, so do not know what is causing this error. But the conversion to DVD from mkv with subtitles pgs the error comes after they are properly converted to idx/sub, at the time of integration to vob container. [10:03:47]PHASE TWO - Rebuild Started - [10:03:47] Building ALTERNATE OUTPUT Structure - [10:03:47] Converting 1 subtitles to DVD format. - [10:03:54] Starting MPLEX. - [10:04:00] Multiplexing 1 subtitles into stream. - WARNING: Failed to integrate Subtitle_01 - [10:04:00] Building DVD File Structure. [10:04:13] - Encode and Rebuild complete |
30th January 2015, 17:02 | #22194 | Link | |
As of right now, though, I'm still leaning toward corrupt sources. Do you know what muxing software was used to create the MKV files? There's not much I can do for a source that has issues before hitting BD-RB. The MKV sources I'm using for testing are all created by BD-RB. That way I know they are properly formatted. Just as a test, you might try remuxing one of the sources that failed to import with MKVMERGE before attempting import. Last edited by jdobbs; 30th January 2015 at 17:10. |
30th January 2015, 17:18 | #22195 | Link | |
I used to label which drive ripped a BD. But It's quite possible that I missed a few...
30th January 2015, 18:02 | #22196 | Link | |
Clarification: I can still import from the MKV with no issues. But I can repeat the issue encountered when converting to DVD. Last edited by jdobbs; 30th January 2015 at 18:10. |
30th January 2015, 20:34 | #22197 | Link | |
You should see it fixed in the next release. |
30th January 2015, 22:01 | #22199 | Link | |
- [10:52:24] ScanDirectory() 00006 2603 - [10:52:26] SourceCheck() 00009 2503 - [10:53:08] SourceCheck() 00055 2501 Illegal Source. Selected source is not a BD format. Any help/suggestions appreciated. TIA!!! |
31st January 2015, 05:55 | #22200 | Link | |
