Old 10th November 2020, 03:47   #30181  |  Link
LowDead
Elit Amans
Originally Posted by cartman0208 View Post
I also use a GTX1660 Ti with a pretty much default BRDREBUILDER.INI, no hiddenopts added.
Graphics driver might not be the most current, I'm on 451.48
I haven't done many 1080p disks yet, but on the finished ones (nvencc, Highest quality) I didn't notice any pixelation, at least not in the main movie.
So, what do CraigWally and I have in common with our setups? It seems no one else but us experience this.
Operating System: Windows 10 Pro 64-bit (10.0, Build 19042) (19041.vb_release.191206-1406)
Language: Swedish (Regional Setting: Swedish)
CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz (12 Cores)
RAM: 32768MB
GFX0: Intel UHD Graphics 630 128MB
GFX1: NVIDIA GeForce RTX 2070 8GB
BD Writer: PIONEER BD-RW BDR-S09 (Primary)
BD Writer: ASUS BW-16D1HT (LibreDrive)
TV: Samsung F9005 (with SEK-3005 addon)
UHD Bluray: Samsung UBD-K8500
HD Bluray/Console: Playstation 3
//LD
Old 10th November 2020, 09:20   #30182  |  Link
Sharc
According to Table 1 NVIDIA dropped 'H.264 field encoding' for Turing and Ampere GPUs.
https://docs.nvidia.com/video-techno...nc-performance
Blu-ray compliance requests 'interlaced' for 25 and 29.97 fps for any resolution. Fake-interlaced is not always possible.
Confused ........
Old 10th November 2020, 10:32   #30183  |  Link
cartman0208
Confused ........
So... if that could be the issue:
Is 'field encoding' support set in hardware or software? Meaning my 'old' driver might still support that feature?
@LowDead: What's your graphics driver version?
Old 10th November 2020, 15:27   #30184  |  Link
LowDead
Elit Amans
Game driver Version 457.30 dated 11/09/2020
I also noted that one could switch to a "studio" driver from within the Geforce experience.. anyone have tried that driver?
//LD
Windows 11 Pro 64-bit, AMD Ryzen 9 5950X@3.40GHz, 32GB, NVIDIA RTX 2070 8GB, PIONEER BDR-S09XLT, ASUS BW-16D1HT, LG CX 65", Panasonic DP-UB820EB-K, Sony PS3 & PS5
Old 11th November 2020, 01:02   #30185  |  Link
Confused ........
Interesting. I hadn't noticed that before. I'm interested to know how it handles interlaced content with a Turing GPU. I'll run a couple tests on some interlaced content and see what happens.
Old 12th November 2020, 15:56   #30186  |  Link
Mark_Venture
Not so much a bug, but more of a question... I'm re-ripping all my movies (as Alt-Movie Only) due to a drive crash Because I have a mix of 4K TV's and 1080p's, I usually rip both discs of a movie. I ran into a Bluray that wont rip (looks like there is a scratch on the bottom). The 4k/UHD disc does rip. I'm just wondering if UHD Disc -> 1080p MKV would result in any quality difference compared to Bluray Disc -> 1080p MKV? (I'm just thinking about those "fake 4K" discs that are from a 2K source)... I mean I do get it will be better than not having the 1080p copy on my server, just curious if it might suffer.
Old 12th November 2020, 23:13   #30187  |  Link
It should be fine. But, if you do, you may want to consider performing some type of HDR->SDR conversion (assuming HDR on the original). I've seen reports that sometimes it can look "washed out" without it. I saw this AVISYNTH plugin, but haven't tried it myself.
But you may want to just try it without first -- as sometimes these reports are less than accurate (people sometimes have magic eyes and ears that see things that aren't really there).
Old 13th November 2020, 00:01   #30188  |  Link
gonca
You can always try DGTonemap, DGHDRtoSDR and DGPQtoHLG
http://rationalqm.us/mine.html
I believe they can run in software mode
Old 13th November 2020, 00:08   #30189  |  Link
I think they all require AVISYNTH+ (or at least the Wiki says so). But, again, I haven't tried them.
Old 13th November 2020, 01:00   #30190  |  Link
gonca
They do have a 32 bit version, but I'll check
Old 13th November 2020, 02:33   #30191  |  Link
videoh
Useful n00b
DG tools use YUV420P16 for HBD. I don't know if Avisynth 2.6 can swallow that. If needed we could have an option for delivering a different format. Let me know what you need.
Old 13th November 2020, 12:05   #30192  |  Link
gonca
AVS 2.6 can't handle the higher bit depth, and it has no internal filters equivalent to ConvertBits()
Old 13th November 2020, 13:26   #30193  |  Link
videoh
Useful n00b
There is a hack called Stack16, but why bother when Avisynth+ handles HBD natively?
Old 13th November 2020, 20:27   #30194  |  Link
CraigWally
Just as a test, you might want to try replacing the version of NVENCC with the newest one (v05.19) and see if it has an impact.
No difference
CraigWally is offline   Reply With Quote
Old 14th November 2020, 00:26   #30195  |  Link
Originally Posted by CraigWally View Post
No difference
Old 14th November 2020, 15:54   #30196  |  Link
stonesfan129
Hi all, my apologies if there is a better place to request this. I was wondering if an Alternate Output could be added for "MKV Container, HEVC, NO_RESIZE, Auto-AC3." Currently there is one that does Auto-AAC but it would be nice to have one that does AC3 so I can play these files over my surround sound system. Currently I have just been converting audio through Staxrip and then converting that output through BDRB with "MKV Container, HEVC, NO_RESIZE, Intact Audio" and it's just very time-consuming. Thank you.
stonesfan129 is offline   Reply With Quote
Old 14th November 2020, 16:03   #30197  |  Link
You can open up the ALTERNATE.TXT file in the MISC folder of the installation and add it. The top of the file tells you what all the parameters mean, and then the existing presets are listed below. Just add another preset with the settings you want. Here's what you'd add (to the default ALTERNATE.TXT) to get the preset you want:
[00041]
caption=MKV Container, HEVC, NO_RESIZE, Auto-Ac3
vEncoder=1
vBitrate=1500
vKeyint=Auto
aBitrate=*
aType=0
vFormat=7
cType=1
Old 14th November 2020, 16:50   #30198  |  Link
stonesfan129
[00041]
vEncoder=1
vBitrate=1500
vKeyint=Auto
aBitrate=*
aType=0
vFormat=7
cType=1
This is exactly what I was looking for. Thank you sir for this great program.
Old 15th November 2020, 00:54   #30199  |  Link
Good to hear.
Old 15th November 2020, 11:45   #30200  |  Link
Eriz0
@jdobbs
thank you very much for your software, itīs amazing, but I have a question...
is it possible to disable the --uhd-bd option in 4k encoding to gain a bit more speed?
Eriz0 is offline   Reply With Quote
