20th February 2022, 00:49 | #31181 | Link |
Hi everyone,
Sorry to have bothered you with my posts, it wasn’t my intention. I’m no video engineer as you guys; just an “end user” who found out jdobbs’ tool and used it only one time and didn’t work as expected; hence my posting here trying to find out whats going on. As I said, I’m not a video engineer (I’m a software engineer, though); I don’t understand (nor do I have a personal or professional interest) in all the video advanced terms, technicalities and codecs understanding. I just wanted to shrink one Blu-Ray to be able to back it up in a smaller disc as a “n00b”. From my experience here, you have years of knowdledge and learnings, but that didn't translate (nor the community didn't seem) to be very open or friendly to newcomers or people interested in just using the tool and get on with their life. But that’s OK, you are free to foster whatever community you like! Thanks again for the original tool and, hopefully, some expert; community-approved user will stumble into the same issue some time in the future years and benefit the whole community while troubleshooting. |
20th February 2022, 21:26 | #31182 | Link |
Autocrop()
Hi jdobbs,
out of interest. Would it be possible for you to make parameter "threshold" for Avisynth function "Autocrop ()" available through hidden opts? I sometimes encounter too much cropping with default value. Changing AVS and re-running Last command isn't very handy... http://avisynth.nl/index.php/AutoCrop Thank you, ggtop |
22nd February 2022, 22:49 | #31185 | Link |
I second that. But, this would apply to importing of single files as well. Many a time TV show episode titles won't fit in the allocated space. When the menu only contains one column, there is lots of space for lengthy titles.
23rd February 2022, 12:46 | #31187 | Link |
You can do so, but keep in mind that jdobbs tests any and all new releases to make sure that it doesn't break anything. Therefore, if you do, you can't complain when something goes wrong and it is related to the encoder.
For example, I've installed the 1/24/22 version of tsmuxer, as I need its ability to work with DD+ audio. TsMuxer has changed a bunch of naming schemes, which jdobbs has discovered. That means he can't use the new tsMuxer until he has sorted out all of the changes. I've run across one of the naming schemes and I have to deal with it manually when I use BDRB for a certain operation. In other words, do so at your own risk. |
24th February 2022, 07:35 | #31188 | Link |
I've learned some more about the use of titles.inf. Say you have a directory with 10 titles. Not all of them will fit on a BD. So you uncheck the ones that you'll watch later. In the meantime, there are some more titles that you will want to add. After watching some of the titles on the BD, you go back to the directory and removed the viewed titles. You then add the new titles and restart BDRB and import that directory. The list of titles is totally fubar.
There are only two ways to fix it. 1) you remove the titles.inf and start over 2) you manually edit the titles.inf file. With #1 you have to remove the numbers and length text, again (hence the above request). With the #2 option, you won't have the issue with the number and length text. But, you still have to do something, because BDRB loses its marbles when a titles.inf file is used again and the content of the directory has changed. |
24th February 2022, 11:51 | #31189 | Link | |
I do it quite often. |
24th February 2022, 23:46 | #31190 | Link | |
Only when I manually edit the titles.inf file is the list now correct. There's more: I then added a new title and ended up with: Code:
Title-1 Title-2 Title-3 04. Title-3 [0:44:00] Based upon my experience, BDRB was not designed to re-import a directory with changes. The content needs to be the same, or you have to manually edit the titles.inf file. Update: I just edited the titles.inf file to add the new title. I placed it in the 4th position and when I restarted BDRB, I ended up with the same title list as shown above. When I edited the titles.inf file to place the new title alphabetically in the correct position and restarted BDRB, the new title showed up, but had "01. " in front of the title and the "[length]" at the end of the title, even though the title.inf file has no such text in it. That tells me that BDRB has a hidden file of some sort so that it knows that the newly added title was not there before. That would explain the issue I had with a title that kept returning, as noted in previous posts.
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 25th February 2022 at 06:58. |
26th February 2022, 00:14 | #31191 | Link |
You have the original output (created structure from import)
Load this into BD_RB Edit the menu Save and continue EXAMPLE DISC>disc 1, disc 2, etc [folder structure] import Edit menu etc output>NEW DISC Next time NEW DISC Add DISC > (BD/NEW DISC + DISC) structure import Edit menu etc output>NEW DISC 2 Do not touch the inf file directly Just uncheck the movies you don't want and add the ones you do Last edited by gonca; 26th February 2022 at 13:42. |
26th February 2022, 04:20 | #31192 | Link |
Please re-red what I posted. I think you have totally missed what I'm doing. What you are suggesting would be great if the directory had ALL of the titles I would be dealing with. Because the content of the directory would not be changing.
The issue is when the content of the directory changes. After viewing some of the content on the disc. I remove that content from the directory. At that point the titles.inf file no longer matches what is in the directory. When I remove content, most of the time I add new content to the directory. That makes the directory more out-of-step with the titles.inf file. BDRB can't seem to deal with directory content changes. |
26th February 2022, 13:43 | #31193 | Link | |
It has been edited |
26th February 2022, 18:30 | #31194 | Link |
As pointed out in my post, that doesn't work. It might if you start with a single disc and then add a single disc, for a total of two. When working with multiple titles, it tends to fail, as pointed out in post 31189.
26th February 2022, 18:41 | #31195 | Link |
I start with multiple discs and a create a disc structure with menu
Later on I add a new disc to that collection, or replace a disc with an upgraded version of one of the movies, or both. IT WORKS, I do it on a regular basis But you just don't want to get it, fine, there is no issue with the menu creation so good luck! |
2nd March 2022, 10:31 | #31198 | Link |
I've run into an issue with backing up a UHD disc. This has happened before, so it didn't come as a surprise. That said, this is more informational than anything else.
I'm on my third try to try and get it to fit on a BD25. The original M2TS file is about 60GB. 8.1GB of which is the TrueHD and AC3 audio streams. Using the default settings, the re-encoded video was about 30GB. Certainly missed the mark. Then tried 21000 as a custom setting. Still missed. I then tried 19000. Still larger than the target by about 3GB. I'm now trying 18000. But what I've noticed in the config file is that when a job is started, the target size is equal to the previous setting. For a custom size of 19000, the target was 21000. For the current custom setting of 18000, the target is 19000. I have no idea why the current target setting is set to the previous custom setting. UPDATE: I have to yet another attempt. It would probably have been easier if I could have selected a bitrate instead of a target size. The original file is a 29.7 Mbps. I figure that using 15 Mbps would have fit. The last run BDRB set the bitrate to 16 Mbps. Frankly, I'm not sure that 15 Mbps will cut it. I noticed that the target rate stayed at 19000, even though I've now set 17000. Nope, cancelled the 17000, as the bitrate is a fraction about 15 Mbps, which I don't think it is going to make it. So, I'm trying 16000, yielding a bitrate just over 14 Mbps. If this doesn't do it, I'm heading to bed, as I've already spent over 4 hours on this single project. UPDATE #2: It took a target size of 15000. That is about 64% of the default 23500. That is a big math error.
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 2nd March 2022 at 13:11. |
6th March 2022, 11:42 | #31199 | Link |
Strange ... the target size in my inf file matches the set target exactly ...
Are you doing Full disk backup? Movie Only? I also had the targed size missed on rare occasions, but that was only about one or two GB ... |
