4th August 2010, 03:55 | #9021 | Link |
Wow! Thx 4 the prompt reply. And sorry about the attachment. I tried to attach the ini. file and it wouldn't take, so i copied it 2 a word document. I will try 2 use the "code" method should I need 2 attach a file in the future. Anyways to answer ur question... I used AnyDVD HD 6.6.8 and used the "Rip Video DVD to harddisk" option.
4th August 2010, 04:30 | #9022 | Link |
@jdobbs
(Not significant, but...) From what I've been able to determine, the "HD_COMPLIANT" hidden function no longer works properly in conjunction with "multiAVCHD" (Which is, as far as I know, the only tool that makes use of such modified BD-RB-created files). As has been discussed in the past, this apparently has to do with changes made to x264.exe over the past several months. Although I've personally enjoyed its use - and am likely one of a very few who have done so - I'd suggest that you remove it as an option, "hidden" or otherwise, because after processing with BD-RB and multiAVCHD with no apparent flaws, the resultant files are unusable "slide shows" - unless, of course, you and "deank" choose to once again make your two wonderful tools compatible in this regard... |
4th August 2010, 10:04 | #9024 | Link |
Subs resizing code for 1080p -> 720p output
Hi jdobbs,
Any news on if you have found anytime to write the code to resize the subs when resizing at 1080p -> 720p for movie only projects (DVD-5). As the subs are a little on the big size and a little off centre in the final resized 720p project? Many thanks |
4th August 2010, 14:00 | #9025 | Link |
Programmer (or just 教务长)
Few months ago clr2007 stumbled upon a blu-ray title in re-author mode with my tool. It turned out that one of the original mpls files in PLAYLIST folder was not a playlist file, but a xml or bdmv (but named 00xxx.mpls)... I can't remember exactly, but probably in very rear cases one may find files in places where they don't belong. I always check if mpls files start with "MPLS" and contain at least one playitem before processing.
4th August 2010, 14:06 | #9026 | Link | |
4th August 2010, 15:54 | #9027 | Link | |
----------------------- [20:27:52] BD Rebuilder v0.34.06 (beta) *- Source: *HOT_TUB_TIME_MACHINE *- Input BD size: 34.48 GB *- Approximate total content: [02:16:48.116] *- Target BD size: 22.66 GB *- Windows Version: 6.1 [7600] *- Quality: Good (Very Fast), Two Pass *- Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [20:27:52] PHASE ONE, Encoding - [20:27:52] Extracting A/V streams [VID_00990] - [20:27:53] Reencoding: VID_00990 (1 of 40) - [20:27:53] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 120 frames - [20:27:53] Reencoding: VID_00990, Pass 1 of 1 - [20:27:56] Video Encode complete - [20:27:56] Reencoding audio tracks (if req'd) - [20:27:56] Multiplexing M2TS - [20:27:56] Extracting A/V streams [VID_00918] - [20:27:58] Reencoding: VID_00918 (2 of 40) - [20:27:58] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 672 frames - [20:27:58] Reencoding: VID_00918, Pass 1 of 1 - [20:28:12] Video Encode complete - [20:28:12] Reencoding audio tracks (if req'd) - [20:28:12] Multiplexing M2TS - [20:28:13] Extracting A/V streams [VID_00914] - [20:28:15] Reencoding: VID_00914 (3 of 40) - [20:28:15] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 1,007 frames - [20:28:15] Reencoding: VID_00914, Pass 1 of 1 - [20:28:36] Video Encode complete - [20:28:36] Reencoding audio tracks (if req'd) - [20:28:36] Multiplexing M2TS - [20:28:37] Extracting A/V streams [VID_00926] - [20:28:38] Reencoding: VID_00926 (4 of 40) - [20:28:38] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 1,168 frames - [20:28:38] Reencoding: VID_00926, Pass 1 of 1 - [20:29:04] Video Encode complete - [20:29:04] Reencoding audio tracks (if req'd) - [20:29:04] Multiplexing M2TS - [20:29:05] Extracting A/V streams [VID_00913] - [20:29:07] Reencoding: VID_00913 (5 of 40) - [20:29:07] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 1,245 frames - [20:29:07] Reencoding: VID_00913, Pass 1 of 1 - [20:29:37] Video Encode complete - [20:29:37] Reencoding audio tracks (if req'd) - [20:29:37] Multiplexing M2TS - [20:29:38] Extracting A/V streams [VID_00916] - [20:29:41] Reencoding: VID_00916 (6 of 40) - [20:29:41] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 1,800 frames - [20:29:41] Reencoding: VID_00916, Pass 1 of 1 - [20:30:21] Video Encode complete - [20:30:21] Reencoding audio tracks (if req'd) - [20:30:21] Multiplexing M2TS - [20:30:22] Extracting A/V streams [VID_00919] - [20:30:25] Reencoding: VID_00919 (7 of 40) - [20:30:25] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 1,867 frames - [20:30:25] Reencoding: VID_00919, Pass 1 of 1 - [20:31:04] Video Encode complete - [20:31:04] Reencoding audio tracks (if req'd) - [20:31:04] Multiplexing M2TS - [20:31:06] Extracting A/V streams [VID_00920] - [20:31:08] Reencoding: VID_00920 (8 of 40) - [20:31:08] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 1,969 frames - [20:31:08] Reencoding: VID_00920, Pass 1 of 1 - [20:31:49] Video Encode complete - [20:31:49] Reencoding audio tracks (if req'd) - [20:31:49] Multiplexing M2TS - [20:31:51] Extracting A/V streams [VID_00915] - [20:31:54] Reencoding: VID_00915 (9 of 40) - [20:31:54] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 2,126 frames - [20:31:54] Reencoding: VID_00915, Pass 1 of 1 - [20:32:42] Video Encode complete - [20:32:42] Reencoding audio tracks (if req'd) - [20:32:42] Multiplexing M2TS - [20:32:44] Extracting A/V streams [VID_00924] - [20:32:47] Reencoding: VID_00924 (10 of 40) - [20:32:47] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 2,224 frames - [20:32:47] Reencoding: VID_00924, Pass 1 of 1 - [20:33:35] Video Encode complete - [20:33:35] Reencoding audio tracks (if req'd) - [20:33:35] Multiplexing M2TS - [20:33:38] Extracting A/V streams [VID_00923] - [20:33:40] Reencoding: VID_00923 (11 of 40) - [20:33:40] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 2,267 frames - [20:33:40] Reencoding: VID_00923, Pass 1 of 1 - [20:34:31] Video Encode complete - [20:34:31] Reencoding audio tracks (if req'd) - [20:34:31] Multiplexing M2TS - [20:34:34] Extracting A/V streams [VID_00921] - [20:34:37] Reencoding: VID_00921 (12 of 40) - [20:34:37] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 2,310 frames - [20:34:37] Reencoding: VID_00921, Pass 1 of 1 - [20:35:30] Video Encode complete - [20:35:30] Reencoding audio tracks (if req'd) - [20:35:30] Multiplexing M2TS - [20:35:32] Extracting A/V streams [VID_00932] - [20:35:36] Reencoding: VID_00932 (13 of 40) - [20:35:36] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 1,149 frames **- Bitrate: 19,896 Kbs - [20:35:36] Reencoding: VID_00932, Pass 1 of 2 - [20:36:17] Reencoding: VID_00932, Pass 2 of 2 - [20:37:02] Video Encode complete - [20:37:02] Reencoding audio tracks (if req'd) - [20:37:02] Multiplexing M2TS - [20:37:05] Extracting A/V streams [VID_00922] - [20:37:08] Reencoding: VID_00922 (14 of 40) - [20:37:08] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 2,532 frames - [20:37:08] Reencoding: VID_00922, Pass 1 of 1 - [20:38:06] Video Encode complete - [20:38:06] Reencoding audio tracks (if req'd) - [20:38:06] Multiplexing M2TS - [20:38:08] Extracting A/V streams [VID_00912] - [20:38:12] Reencoding: VID_00912 (15 of 40) - [20:38:12] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 2,622 frames - [20:38:12] Reencoding: VID_00912, Pass 1 of 1 - [20:39:11] Video Encode complete - [20:39:11] Reencoding audio tracks (if req'd) - [20:39:11] Multiplexing M2TS - [20:39:14] Extracting A/V streams [VID_00892] - [20:39:17] Reencoding: VID_00892 (16 of 40) - [20:39:17] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 1,287 frames **- Bitrate: 20,017 Kbs - [20:39:17] Reencoding: VID_00892, Pass 1 of 2 - [20:40:04] Reencoding: VID_00892, Pass 2 of 2 - [20:40:55] Video Encode complete - [20:40:55] Reencoding audio tracks (if req'd) - [20:40:55] Multiplexing M2TS - [20:40:58] Extracting A/V streams [VID_00942] - [20:41:02] Reencoding: VID_00942 (17 of 40) - [20:41:02] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 1,393 frames **- Bitrate: 19,783 Kbs - [20:41:02] Reencoding: VID_00942, Pass 1 of 2 - [20:41:52] Reencoding: VID_00942, Pass 2 of 2 - [20:42:47] Video Encode complete - [20:42:47] Reencoding audio tracks (if req'd) - [20:42:47] Multiplexing M2TS - [20:42:51] Extracting A/V streams [VID_00934] - [20:42:55] Reencoding: VID_00934 (18 of 40) - [20:42:55] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 1,507 frames - [20:42:55] Reencoding: VID_00934, Pass 1 of 1 - [20:43:45] Video Encode complete - [20:43:45] Reencoding audio tracks (if req'd) - [20:43:45] Multiplexing M2TS - [20:43:48] Extracting A/V streams [VID_00938] - [20:43:52] Reencoding: VID_00938 (19 of 40) - [20:43:52] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 1,640 frames **- Bitrate: 20,067 Kbs - [20:43:52] Reencoding: VID_00938, Pass 1 of 2 - [20:44:51] Reencoding: VID_00938, Pass 2 of 2 - [20:45:57] Video Encode complete - [20:45:57] Reencoding audio tracks (if req'd) - [20:45:57] Multiplexing M2TS - [20:46:01] Extracting A/V streams [VID_00928] - [20:46:05] Reencoding: VID_00928 (20 of 40) - [20:46:05] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 1,656 frames - [20:46:05] Reencoding: VID_00928, Pass 1 of 1 - [20:47:01] Video Encode complete - [20:47:02] Reencoding audio tracks (if req'd) - [20:47:02] Multiplexing M2TS - [20:47:04] Extracting A/V streams [VID_00112] - [20:47:10] Reencoding: VID_00112 (21 of 40) - [20:47:10] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 3,462 frames - [20:47:10] Reencoding: VID_00112, Pass 1 of 1 - [20:48:24] Video Encode complete - [20:48:24] Reencoding audio tracks (if req'd) - [20:48:24] Multiplexing M2TS - [20:48:27] Extracting A/V streams [VID_00925] - [20:48:32] Reencoding: VID_00925 (22 of 40) - [20:48:32] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 3,501 frames - [20:48:32] Reencoding: VID_00925, Pass 1 of 1 - [20:49:46] Video Encode complete - [20:49:46] Reencoding audio tracks (if req'd) - [20:49:46] Multiplexing M2TS - [20:49:49] Extracting A/V streams [VID_00927] - [20:49:53] Reencoding: VID_00927 (23 of 40) - [20:49:53] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 3,505 frames - [20:49:53] Reencoding: VID_00927, Pass 1 of 1 - [20:51:13] Video Encode complete - [20:51:13] Reencoding audio tracks (if req'd) - [20:51:13] Multiplexing M2TS - [20:51:17] Extracting A/V streams [VID_00936] - [20:51:22] Reencoding: VID_00936 (24 of 40) - [20:51:22] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 1,830 frames - [20:51:22] Reencoding: VID_00936, Pass 1 of 1 - [20:52:25] Video Encode complete - [20:52:25] Reencoding audio tracks (if req'd) - [20:52:25] Multiplexing M2TS - [20:52:28] Extracting A/V streams [VID_00917] - [20:52:33] Reencoding: VID_00917 (25 of 40) - [20:52:33] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 3,787 frames - [20:52:33] Reencoding: VID_00917, Pass 1 of 1 - [20:53:52] Video Encode complete - [20:53:52] Reencoding audio tracks (if req'd) - [20:53:52] Multiplexing M2TS - [20:53:54] Extracting A/V streams [VID_00895] - [20:54:00] Reencoding: VID_00895 (26 of 40) - [20:54:00] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 1,870 frames **- Bitrate: 20,392 Kbs - [20:54:00] Reencoding: VID_00895, Pass 1 of 2 - [20:55:07] Reencoding: VID_00895, Pass 2 of 2 - [20:56:24] Video Encode complete - [20:56:24] Reencoding audio tracks (if req'd) - [20:56:24] Multiplexing M2TS - [20:56:28] Extracting A/V streams [VID_00930] - [20:56:33] Reencoding: VID_00930 (27 of 40) - [20:56:33] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 2,013 frames - [20:56:33] Reencoding: VID_00930, Pass 1 of 1 - [20:57:41] Video Encode complete - [20:57:41] Reencoding audio tracks (if req'd) - [20:57:41] Multiplexing M2TS - [20:57:45] Extracting A/V streams [VID_00944] - [20:57:50] Reencoding: VID_00944 (28 of 40) - [20:57:50] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 2,034 frames - [20:57:50] Reencoding: VID_00944, Pass 1 of 1 - [20:58:59] Video Encode complete - [20:58:59] Reencoding audio tracks (if req'd) - [20:58:59] Multiplexing M2TS - [20:59:02] Extracting A/V streams [VID_00941] - [20:59:11] Reencoding: VID_00941 (29 of 40) - [20:59:11] Collecting video information **- Source Video: MPEG-4 (AVC), 1920x1080 **- Rate/Length: 23.976fps, 2,565 frames **- Bitrate: 20,624 Kbs - [20:59:11] Reencoding: VID_00941, Pass 1 of 2 - [21:00:42] Reencoding: VID_00941, Pass 2 of 2 - [21:02:24] Video Encode complete |
4th August 2010, 16:02 | #9028 | Link | |
By the way, I just did that movie as movie-only -- I'll rerun it as a full BD-25 backup and see what I get. Last edited by jdobbs; 4th August 2010 at 16:21. |
4th August 2010, 17:25 | #9029 | Link | |
This is the first and only disc that I have had a problem with. I do appreciate you taking the time to look into it. I do keep HD audio but that wouldn't have anything to do with it, would it? |
4th August 2010, 20:35 | #9032 | Link | |
4th August 2010, 21:34 | #9033 | Link | |
4th August 2010, 22:10 | #9034 | Link | |
Just to confirm, at the 7:04-7:20 mark of the movie there was no stutter or hanging? Also, would using open GOPs have anything to do with this? Thanks again for your time and effort. A donation will definitely be forthcoming. |
4th August 2010, 23:03 | #9035 | Link | |
[Edit] Yes, I checked that one... that would be the M2TS change with the Doctor in the lobby, followed shortly by another change where the man in bed "high-grabs" someone (within about a minute of the other change). Both work correctly. Last edited by jdobbs; 4th August 2010 at 23:10. |
5th August 2010, 00:35 | #9037 | Link |
I've got a problem for ya jdobbs. Check this one out. Problem also occurs with auto quality settings
[01:29:30] BD Rebuilder v0.34.06 (beta) - Source: TWILIGHT - Input BD size: 44,78 GB - Approximate total content: [04:37:04.081] - Target BD size: 22,66 GB - Windows Version: 6.0 [6002] - Quality: High Quality (Default), Two Pass - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [01:29:31] PHASE ONE, Encoding - [01:29:31] Extracting A/V streams [VID_00000] - Error in attempt to extract audio/subs. - AV frame too large (34560 bytes). Increase AV buffer. [01:31:30] - Failed to retrieve audio, aborted Code:
[Options] MODE=0 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=0 AUDIO_TO_KEEP=dut;eng;nld; SUBS_TO_KEEP=dut;eng;nld; SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DEINTERLACE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=1 FULL_AVCHD=0 REMOVE_OUTPUT=1 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23450 PRIORITY_CLASS=1 TARGET_SIZE=23200 AUTO_BURN=2 IMGBURN_TARGET_DEVICE=e: QUICK_EXTRAS=0 MINIMIZE_TO_TRAY=1 Last edited by Ch3vr0n; 5th August 2010 at 00:49. |
5th August 2010, 01:20 | #9038 | Link | |
I thought for sure that I had tried out the PS3 previously on the first couple of attempts, but maybe my memory is playing tricks on me. Anyway, problem solved (well not solved but source determined and its not BD Rebuilder). Thanks again jdobbs!! |
