12th August 2010, 18:21 | #9181 | Link | |
thanx |
12th August 2010, 20:18 | #9182 | Link | |
12th August 2010, 21:32 | #9184 | Link |
I've tested the fix of the issue "2nd audio DD+ will be flagged as DTS express". Now it gets correct flagged as DD+ in rebuild too.
Playback problem with TMT still there. But there is a different to before: With old version, I got only sound, when I've selected German. The sound was a mix of the german and the 2nd audiotrack, changing frame by frame (I think). When I selected other language, there was no sound at all. In the new version, when I select german, I get the same as above. But when I select other language, I get now the comment stream clearly. Something is also interesting. The comment is detected by BD-RB as 2nd audio, but in TMT it is listendened as regular audio and 2nd audio. More interesting is, when used, it is not selected unter 2nd audio. It is selected in list of regular audio. To show, what I mean a screenshot of the menu. First of the original disc. Second of the rebuild. In both time I've selected audio comment by using the pop-up menu of the BD itself: Original: Rebuild: Maybe it helps to find a fix for playback. Alternatively it would be nice, to be able to uncheck 2nd audio at all. |
12th August 2010, 21:32 | #9185 | Link | |
Since you want movie-only try this: - use MakeMKV with the material and create an MKV form the main title - next use tsMuxeR to re-create a BD structure from this MKV - finally try BD RB again |
12th August 2010, 21:39 | #9186 | Link | |
cf this post of mine and the one I posted before it for some mor background information the problem sounds similar but I wasnt dealing with a software player |
12th August 2010, 23:46 | #9187 | Link | |
When the 2nd audio is dropped out (for that I used a bug in the last version as an exploit to do this), it plays fine. Last edited by KarstenS; 12th August 2010 at 23:49. |
13th August 2010, 08:07 | #9191 | Link | |
Sorry. Can't test that. I've got a BD-ROM drive only. No BD burner. And for DVD9 it is a little bit to big (I rebuild with targetsize of 14,5GB). Had no need for this as I can use the original disk in standalone player. Rebuild is for use in driveless HTPC with WMC.
EDIT: Forgot some little thing. It is not only that strage sound. Also the english subtitle for audio comment is active in the rebuilt version. That is also not by using the original disc. Last edited by KarstenS; 13th August 2010 at 08:12. |
13th August 2010, 15:12 | #9192 | Link | |
However, that same backup plays fine with PowerDVD, unfortunately for most people that want to play the backup from folders, PowerDVD does not support this option. Thus, an image must be created to be played back by a virtual drive. For some reason, many people object to this. Even more important, this same backup works perfectly fine if burned to BD-R/RE for playback on a standalone, which I believe was the intent for BD-RB. Now if the standalone did not play it back correctly, jdobbs would be all over it!! But software players are not the same, hence updates happen all the time to correct issues. |
13th August 2010, 15:35 | #9194 | Link | |
I do not have a PS3, nor Corel WinDvd 10, so for this statement I will assume you are . I am sure jdobbs would like to have BD-RB work perfectly for all playback options, but I think that would be a tall task even for him! |
13th August 2010, 15:50 | #9195 | Link | |
hope this is the info you need? Code:
[18:17:17] BD Rebuilder v0.34.07 (beta) - Source: DOCTOR_PARNASSUS - Input BD size: 42.09 GB - Approximate total content: [03:00:51.680] - Target BD size: 22.90 GB - Windows Version: 6.1 [7600] - Resize SD to HD 720p enabled - SHUTDOWN at completion enabled - Quality: High-Speed Option (BD-25), Two Pass - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [18:17:20] PHASE ONE, Encoding - [18:17:20] Extracting A/V streams [VID_00000] - [18:17:26] Reencoding: VID_00000 (1 of 16) - [18:17:26] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 725 frames - Bitrate: 9,483 Kbs - [18:17:26] Reencoding: VID_00000, Pass 1 of 2 - [18:17:27] Reencoding: VID_00000, Pass 2 of 2 - [18:18:28] Video Encode complete - [18:18:28] Reencoding audio tracks (if req'd) - [18:18:28] Multiplexing M2TS - [18:18:30] Extracting A/V streams [VID_00001] - [18:36:45] Reencoding: VID_00001 (2 of 16) - [18:36:45] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 176,280 frames - Bitrate: 12,857 Kbs - [18:36:45] Reencoding: VID_00001, Pass 1 of 2 - [18:36:47] Reencoding: VID_00001, Pass 2 of 2 - [23:07:38] Video Encode complete - [23:07:38] Reencoding audio tracks (if req'd) - [23:07:39] Multiplexing M2TS - [23:17:45] Extracting A/V streams [VID_00014] - [23:18:12] Reencoding: VID_00014 (3 of 16) - [23:18:12] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 6,343 frames - Bitrate: 12,761 Kbs - [23:18:12] Reencoding: VID_00014, Pass 1 of 2 - [23:18:13] Reencoding: VID_00014, Pass 2 of 2 - [23:28:37] Video Encode complete - [23:28:37] Reencoding audio tracks (if req'd) - [23:28:37] Multiplexing M2TS - [23:28:51] Extracting A/V streams [VID_00015] - [23:29:03] Reencoding: VID_00015 (4 of 16) - [23:29:03] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,939 frames - Bitrate: 12,751 Kbs - [23:29:03] Reencoding: VID_00015, Pass 1 of 2 - [23:29:04] Reencoding: VID_00015, Pass 2 of 2 - [23:33:42] Video Encode complete - [23:33:42] Reencoding audio tracks (if req'd) - [23:33:42] Multiplexing M2TS - [23:33:46] Extracting A/V streams [VID_00016] - [23:34:27] Reencoding: VID_00016 (5 of 16) - [23:34:27] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 10,449 frames - Bitrate: 12,847 Kbs - [23:34:27] Reencoding: VID_00016, Pass 1 of 2 - [23:34:28] Reencoding: VID_00016, Pass 2 of 2 - [23:56:12] Video Encode complete - [23:56:12] Reencoding audio tracks (if req'd) - [23:56:12] Multiplexing M2TS - [23:56:38] Extracting A/V streams [VID_00017] - [23:56:57] Reencoding: VID_00017 (6 of 16) - [23:56:57] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,978 frames - Bitrate: 12,849 Kbs - [23:56:57] Reencoding: VID_00017, Pass 1 of 2 - [23:56:58] Reencoding: VID_00017, Pass 2 of 2 - [00:09:50] Video Encode complete - [00:09:50] Reencoding audio tracks (if req'd) - [00:09:50] Multiplexing M2TS - [00:10:00] Extracting A/V streams [VID_00018] - [00:10:19] Reencoding: VID_00018 (7 of 16) - [00:10:19] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,243 frames - Bitrate: 12,846 Kbs - [00:10:19] Reencoding: VID_00018, Pass 1 of 2 - [00:10:20] Reencoding: VID_00018, Pass 2 of 2 - [00:20:09] Video Encode complete - [00:20:09] Reencoding audio tracks (if req'd) - [00:20:09] Multiplexing M2TS - [00:20:19] Extracting A/V streams [VID_00019] - [00:20:56] Reencoding: VID_00019 (8 of 16) - [00:20:56] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 8,294 frames - Bitrate: 12,853 Kbs - [00:20:56] Reencoding: VID_00019, Pass 1 of 2 - [00:20:57] Reencoding: VID_00019, Pass 2 of 2 - [00:42:10] Video Encode complete - [00:42:10] Reencoding audio tracks (if req'd) - [00:42:10] Multiplexing M2TS - [00:42:29] Extracting A/V streams [VID_00020] - [00:42:47] Reencoding: VID_00020 (9 of 16) - [00:42:47] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,525 frames - Bitrate: 12,850 Kbs - [00:42:47] Reencoding: VID_00020, Pass 1 of 2 - [00:42:49] Reencoding: VID_00020, Pass 2 of 2 - [00:54:12] Video Encode complete - [00:54:12] Reencoding audio tracks (if req'd) - [00:54:12] Multiplexing M2TS - [00:54:21] Extracting A/V streams [VID_00021] - [00:55:02] Reencoding: VID_00021 (10 of 16) - [00:55:02] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 9,408 frames - Bitrate: 12,853 Kbs - [00:55:02] Reencoding: VID_00021, Pass 1 of 2 - [00:55:03] Reencoding: VID_00021, Pass 2 of 2 - [01:15:48] Video Encode complete - [01:15:48] Reencoding audio tracks (if req'd) - [01:15:48] Multiplexing M2TS - [01:16:20] Extracting A/V streams [VID_00022] - Error in attempt to extract audio/subs. - Not enought buffer for parse video stream. Current frame num 0 [01:16:21] - Failed to retrieve audio, aborted Code:
hidden ops [Options] THREADS=n n represents the number of threads to use in X264, default is "auto" FREE_PROCESSOR=n subtract n from the processor count (leaves n processors free for other tasks) FIXED_CRF=n n = 10..50 - force CRF encoding to use this CRF value (output size control disappears) FIX_CLPI=n n = 0/1 - if set to 1, BD-RB fixes CLPI file, only useful on old TSMUXER versions MIN_M2TS_SIZE=n n = minimum size required for BD-RB processing on BD-25 in MB, default is 100 SHOW_ENCODER=n n = 0/1 - Default 0. If set to 1, BD-RB will show the X264 window during encoding QUICK_CRF=n n = 10..50 -- CRF value for "Quick Extras" encoding, defaults are BD5=26,BD9=22,BD25=20 QUICK_USE_QUALITY=n n = 0/1 - if set to 1, BD-RB will use the current quality selection for CRF encodes SECONDARY_CRF=n n = 10..50 - force BD-RB to use the specified CRF value for secondary encodings SECONDARY_USE_QUALITY=n n = 0/1 - 0=OFF (default) - if set to "0" ultrafast is used, "1" uses standard quality FORCE_ENCODE=n n = 0/1 - if set to 1, BD-RB will never check to see if original video will fi FORCE_NOENCODE=n n = 0/1 - if set to 1, BD-RB will always use original video (sizing will not be checked) NO_MBTREE=n n = 0/1 - if set to 1, BD-RB will disable MBTREE in encodes GROUP_SIZE=n n = Number of frames in each sample group for CRF estimation SAMPLE_SIZE=n n = Number of frames in each sample for CRF estimation (size/group = sample percentage) HDDVD_COMPLIANT=n n = 0/1 - if set to 1, the output will be compliant with HD-DVD standards AUDIO_AMPLIFY=n n = 0-x - Increase volume of reencoded audio. Example "1.2" = 20% increase, "2.0" = 2X KEEP_MBTREE=n n = 0/1 - 0=Off (default), 1=Keep the stats.mbtree file after encode is complete TWEAK_PASS_ONE=s s = X264 pass 1 command line tweak(s)(warning -- for experts only, bugs not supported) TWEAK_PASS_TWO=s s = X264 pass 2 command line tweak(s)(warning -- for experts only, bugs not supported) WEIGHTP=n n = 0/1 - If set to 1, BD-RB will allow X264 "--weightp", default is "0" (off) USE_NAL_HRD=n n = 0/1 - 1=ON (default) 1 = Use "--nal-hrd" in the X264 command line, 0 = Don't use it. FIX_MOVIEONLY=n n = 0/1 - 1=ON (default) - If set to "0", BD-RB will not add ExtensionData() to CLPI/MPLS PASS_TWO_STATS_UPDATE=n n = 0/1 - 0=OFF (default) - if set to "1", BD-RB uses "--pass 3" for second pass REMOVE_WORKING=n n = 0/1 - 0=OFF (default) - if set to "1", the WORKFILES folder is removed after rebuild REMOVE_OUTPUT=n n = 0/1 - 0=OFF (default) - if set to "1", the OUTPUT folder is removed after burning MKV_INTERMEDIATE=n n = 0/1 - 0=OFF (default) - if set to "1", .MKV files are used instead of .264 B_PYRAMID=n n = 0/1 - 1=On (default) - if set to "0", " --b-pyramid none" is used, else "strict" ALTCRF=n n = 0-50 - CRF value to use for Alternate Movie-Only encodes (default=20) AUTO_BIAS=n n = 0/1/2 - Default= 1, Auto Quality bias, 0=higher speed, 1=normal, 2=higher quality IMGBURN_TARGET_DEVICE=s s = Drive to use for burning with ImgBurn (ex: e:, f:, etc) SHUTDOWN_SLEEP=n n = 0/1 - Default=0, Setting to "1" changes "SHUTDOWN after Rebuild" option to "SLEEP..." DISABLE_FFMS=n n = 0/1 - Default=0, Set to "1" to use AVISYNTH for seamless-branched titles RESET_PERMISSION = n n = 0/1 - Default=1, When set to "1", tells ImgBurn to reset permission flag during burn COLOR_BOOST=n n = 0/1 - Default=0, When set to "1" BD-RB will boost color levels by 10% (slow) KEEP_HD_LPCM=n n = 0/1 - Default=1, When set to "0", BD-RB reencodes LPCM even for "Keep HD Audio" [Paths] NICAUDIO= Change the path for NICAUDIO.DLL TSMUXER= Change the path for TSMUXER.EXE WAVI= Change the path for WAVI.EXE AFTEN= Change the path for AFTEN.EXE DECOMB= Change the path for DECOMB521.DLL MKVMERGE= Change the path for MKVMERGE.EXE last command was Code:
"D:\RTER\WORKFILES\VID_00021.AVS" --preset ultrafast --cabac --bframes 3 --b-pyramid strict --weightp 0 --open-gop bluray --qpmin=0 --bitrate 12853 --level 4.1 --qpfile "D:\RTER\WORKFILES\VID_00021.CHP" --sar 1:1 --aud --nal-hrd vbr --pic-struct --vbv-bufsize 30000 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 35000 --threads auto --slices 4 --thread-input --output "D:\RTER\WORKFILES\VID_00021.AVS.264" Code:
[Options] MODE=0 ENCODE_QUALITY=5 ONEPASS_ENCODING=0 AUTO_QUALITY=0 TARGET_SIZE=23450 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP= SD_CONVERT=1 OPEN_GOP=1 RESIZE_1080=0 DEINTERLACE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=1 MOVIE_ONLY_LOOP=0 REMOVE_OUTPUT=0 USE_FILTERS=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23450 QUICK_EXTRAS=0 VERBOSE_STATUS=1 [Paths] SOURCE_PATH=D:\DOCTOR PARNASSUS\ WORKING_PATH=D:\RTER\ LABEL=DOCTOR_PARNASSUS VERSION=v0.34.07 (beta) SOURCE_SIZE=45194686690 SOURCE_VIDEO_SIZE=44071815168 TARGET_SIZE=24589107200 REDUCTION=.532454485674067 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP= BACKUP_MODE=0 MOVIEONLY_TYPE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=10 [00000] AUDIO=111 PGS=0 M2TS_TARGET=56415299 RATE=9483 NSIZE=52058112 FLINK=0 MLINK=0 [00001] AUDIO=111 PGS=0 M2TS_TARGET=17597114434 RATE=12857 NSIZE=16827635712 FLINK=0 MLINK=0 [00014] AUDIO=11 PGS= M2TS_TARGET=468778586 RATE=12761 NSIZE=460210176 FLINK=0 MLINK=0 [00015] AUDIO=11 PGS= M2TS_TARGET=217037785 RATE=12751 NSIZE=207974400 FLINK=0 MLINK=0 [00016] AUDIO=1 PGS= M2TS_TARGET=765059502 RATE=12847 NSIZE=738729984 FLINK=0 MLINK=0 [00017] AUDIO=1 PGS= M2TS_TARGET=364522328 RATE=12849 NSIZE=350490624 FLINK=0 MLINK=0 [00018] AUDIO=1 PGS= M2TS_TARGET=310632550 RATE=12846 NSIZE=302813184 FLINK=0 MLINK=0 [00019] AUDIO=1 PGS= M2TS_TARGET=607531761 RATE=12853 NSIZE=586266624 FLINK=0 MLINK=0 [00020] AUDIO=1 PGS= M2TS_TARGET=331376499 RATE=12850 NSIZE=318720000 FLINK=0 MLINK=0 [00021] AUDIO=1 PGS= M2TS_TARGET=689159743 RATE=12853 NSIZE=667502592 FLINK=0 MLINK=0 [00022] AUDIO=1 PGS= Last edited by jdobbs; 13th August 2010 at 16:10. |
13th August 2010, 16:05 | #9196 | Link | |
13th August 2010, 16:14 | #9197 | Link |
@By-Tor;
I made a full disc backup to BD-R of this movie, region A, and it is perfect, no problems. Sorry, I know that does not help you though. Perhaps try to delete the BD-RB .ini, or unzip a fresh downloaded one, and run it from there, letting BD-RB create a new .ini. Then use only the defaults, no resizing at all. Keep all subs, HD audio if you like, and try again. What is the specs of your VID_00022, the one yours is crashing on? EDIT: Mine is: 00:00:05, 645,120 bytes, MPEG-2 Video, 1080P/23.976fps/16:9 - per BDInfo.( no audio present ) Last edited by Capsbackup; 13th August 2010 at 16:28. |
13th August 2010, 18:53 | #9198 | Link | ||
By the way. May it be possible, that you allow to disable 2nd audio for rebuilding please? As I already tested, it is a working workaround. EDIT: Were my logs of cars helpful to explain why I got this oversize? As I didn't checked any HD audio, it should not be the reason, or? Last edited by KarstenS; 13th August 2010 at 18:57. |
13th August 2010, 20:00 | #9199 | Link | |
[04:09:07] BD Rebuilder v0.34.04 (beta) - Source: THE_WARLORDS - Input BD size: 40.03 GB - Approximate total content: [04:39:47.445] - Target BD size: 23.24 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=1 DTS=0 HD=1 Kbs=640 [04:09:07] PHASE ONE, Encoding - [04:09:07] Extracting A/V streams [VID_00021] - [04:09:11] Reencoding: VID_00021 (1 of 38) - [04:09:11] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 417 frames - [04:09:11] Reencoding: VID_00021, Pass 1 of 1 - [04:09:24] Video Encode complete - [04:09:24] Reencoding audio tracks (if req'd) - [04:09:24] Multiplexing M2TS - [04:09:31] Extracting A/V streams [VID_00031] - [04:09:33] Reencoding: VID_00031 (2 of 38) - [04:09:33] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 562 frames - [04:09:33] Reencoding: VID_00031, Pass 1 of 1 - [04:09:50] Video Encode complete - [04:09:50] Reencoding audio tracks (if req'd) - [04:09:50] Multiplexing M2TS - [04:09:51] Extracting A/V streams [VID_00011] - [04:09:53] Reencoding: VID_00011 (3 of 38) - [04:09:53] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 2,529 frames - [04:09:53] Reencoding: VID_00011, Pass 1 of 1 - [04:09:59] Video Encode complete - [04:09:59] Reencoding audio tracks (if req'd) - [04:09:59] Multiplexing M2TS - [04:10:00] Extracting A/V streams [VID_00009] - [04:10:03] Reencoding: VID_00009 (4 of 38) - [04:10:03] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 2,559 frames - [04:10:03] Reencoding: VID_00009, Pass 1 of 1 - [04:10:08] Video Encode complete - [04:10:08] Reencoding audio tracks (if req'd) - [04:10:08] Multiplexing M2TS - [04:10:09] Extracting A/V streams [VID_00010] - [04:10:14] Reencoding: VID_00010 (5 of 38) - [04:10:14] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 2,970 frames - [04:10:14] Reencoding: VID_00010, Pass 1 of 1 - [04:10:19] Video Encode complete - [04:10:19] Reencoding audio tracks (if req'd) - [04:10:19] Multiplexing M2TS - [04:10:20] Extracting A/V streams [VID_00006] - [04:10:23] Reencoding: VID_00006 (6 of 38) - [04:10:23] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 3,040 frames - [04:10:23] Reencoding: VID_00006, Pass 1 of 1 - [04:10:29] Video Encode complete - [04:10:29] Reencoding audio tracks (if req'd) - [04:10:29] Multiplexing M2TS - [04:10:31] Extracting A/V streams [VID_00013] - [04:10:34] Reencoding: VID_00013 (7 of 38) - [04:10:34] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 3,127 frames - [04:10:34] Reencoding: VID_00013, Pass 1 of 1 - [04:10:40] Video Encode complete - [04:10:40] Reencoding audio tracks (if req'd) - [04:10:40] Multiplexing M2TS - [04:10:41] Extracting A/V streams [VID_00007] - [04:10:46] Reencoding: VID_00007 (8 of 38) - [04:10:46] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 3,257 frames - [04:10:46] Reencoding: VID_00007, Pass 1 of 1 - [04:10:52] Video Encode complete - [04:10:52] Reencoding audio tracks (if req'd) - [04:10:52] Multiplexing M2TS - [04:10:54] Extracting A/V streams [VID_00012] - [04:10:59] Reencoding: VID_00012 (9 of 38) - [04:10:59] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 3,355 frames - [04:10:59] Reencoding: VID_00012, Pass 1 of 1 - [04:11:05] Video Encode complete - [04:11:05] Reencoding audio tracks (if req'd) - [04:11:05] Multiplexing M2TS - [04:11:07] Extracting A/V streams [VID_00008] - [04:11:12] Reencoding: VID_00008 (10 of 38) - [04:11:12] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 3,450 frames - [04:11:12] Reencoding: VID_00008, Pass 1 of 1 - [04:11:18] Video Encode complete - [04:11:18] Reencoding audio tracks (if req'd) - [04:11:18] Multiplexing M2TS - [04:11:20] Extracting A/V streams [VID_00030] - [04:11:24] Reencoding: VID_00030 (11 of 38) - [04:11:24] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 930 frames - [04:11:24] Reencoding: VID_00030, Pass 1 of 1 - [04:11:52] Video Encode complete - [04:11:52] Reencoding audio tracks (if req'd) - [04:11:52] Multiplexing M2TS - [04:11:53] Extracting A/V streams [VID_00016] - [04:11:58] Reencoding: VID_00016 (12 of 38) - [04:11:58] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 4,341 frames - [04:11:58] Reencoding: VID_00016, Pass 1 of 1 - [04:12:05] Video Encode complete - [04:12:05] Reencoding audio tracks (if req'd) - [04:12:05] Multiplexing M2TS - [04:12:07] Extracting A/V streams [VID_00005] - [04:12:10] Reencoding: VID_00005 (13 of 38) - [04:12:10] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 6,605 frames - [04:12:10] Reencoding: VID_00005, Pass 1 of 1 - [04:12:22] Video Encode complete - [04:12:22] Reencoding audio tracks (if req'd) - [04:12:22] Multiplexing M2TS - [04:12:25] Extracting A/V streams [VID_00018] - [04:12:30] Reencoding: VID_00018 (14 of 38) - [04:12:30] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 4,560 frames - [04:12:30] Reencoding: VID_00018, Pass 1 of 1 - [04:12:37] Video Encode complete - [04:12:37] Reencoding audio tracks (if req'd) - [04:12:37] Multiplexing M2TS - [04:12:39] Extracting A/V streams [VID_00015] - [04:12:44] Reencoding: VID_00015 (15 of 38) - [04:12:44] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 4,590 frames - [04:12:44] Reencoding: VID_00015, Pass 1 of 1 - [04:12:53] Video Encode complete - [04:12:53] Reencoding audio tracks (if req'd) - [04:12:53] Multiplexing M2TS - [04:12:55] Extracting A/V streams [VID_00023] - [04:13:00] Reencoding: VID_00023 (16 of 38) - [04:13:00] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,246 frames - [04:13:00] Reencoding: VID_00023, Pass 1 of 1 - [04:13:37] Video Encode complete - [04:13:37] Reencoding audio tracks (if req'd) - [04:13:37] Multiplexing M2TS - [04:13:39] Extracting A/V streams [VID_00029] - [04:13:45] Reencoding: VID_00029 (17 of 38) - [04:13:45] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,402 frames - [04:13:45] Reencoding: VID_00029, Pass 1 of 1 - [04:14:26] Video Encode complete - [04:14:26] Reencoding audio tracks (if req'd) - [04:14:26] Multiplexing M2TS - [04:14:27] Extracting A/V streams [VID_00017] - [04:14:34] Reencoding: VID_00017 (18 of 38) - [04:14:34] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 5,510 frames - [04:14:34] Reencoding: VID_00017, Pass 1 of 1 - [04:14:43] Video Encode complete - [04:14:43] Reencoding audio tracks (if req'd) - [04:14:43] Multiplexing M2TS - [04:14:45] Extracting A/V streams [VID_00027] - [04:14:52] Reencoding: VID_00027 (19 of 38) - [04:14:52] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,508 frames - [04:14:52] Reencoding: VID_00027, Pass 1 of 1 - [04:15:37] Video Encode complete - [04:15:37] Reencoding audio tracks (if req'd) - [04:15:37] Multiplexing M2TS - [04:15:38] Extracting A/V streams [VID_00508] - [04:15:45] Reencoding: VID_00508 (20 of 38) - [04:15:45] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 1,859 frames - [04:15:45] Reencoding: VID_00508, Pass 1 of 1 - [04:16:39] Video Encode complete - [04:16:39] Reencoding audio tracks (if req'd) - [04:16:39] Multiplexing M2TS - [04:16:41] Extracting A/V streams [VID_00014] - [04:16:49] Reencoding: VID_00014 (21 of 38) - [04:16:49] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 6,705 frames - [04:16:49] Reencoding: VID_00014, Pass 1 of 1 - [04:17:02] Video Encode complete - [04:17:02] Reencoding audio tracks (if req'd) - [04:17:02] Multiplexing M2TS - [04:17:04] Extracting A/V streams [VID_00020] - [04:17:14] Reencoding: VID_00020 (22 of 38) - [04:17:14] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 9,272 frames - [04:17:14] Reencoding: VID_00020, Pass 1 of 1 - [04:17:31] Video Encode complete - [04:17:31] Reencoding audio tracks (if req'd) - [04:17:31] Multiplexing M2TS - [04:17:34] Extracting A/V streams [VID_00032] - [04:17:44] Reencoding: VID_00032 (23 of 38) - [04:17:44] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,538 frames - [04:17:44] Reencoding: VID_00032, Pass 1 of 1 - [04:18:54] Video Encode complete - [04:18:54] Reencoding audio tracks (if req'd) - [04:18:54] Multiplexing M2TS - [04:18:56] Extracting A/V streams [VID_00019] - [04:19:06] Reencoding: VID_00019 (24 of 38) - [04:19:06] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 10,470 frames - [04:19:06] Reencoding: VID_00019, Pass 1 of 1 - [04:19:25] Video Encode complete - [04:19:25] Reencoding audio tracks (if req'd) - [04:19:25] Multiplexing M2TS - [04:19:29] Extracting A/V streams [VID_00024] - [04:19:42] Reencoding: VID_00024 (25 of 38) - [04:19:42] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,863 frames - [04:19:42] Reencoding: VID_00024, Pass 1 of 1 - [04:21:09] Video Encode complete - [04:21:09] Reencoding audio tracks (if req'd) - [04:21:09] Multiplexing M2TS - [04:21:13] Extracting A/V streams [VID_00521] - [04:21:26] Reencoding: VID_00521 (26 of 38) - [04:21:26] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,939 frames - [04:21:26] Reencoding: VID_00521, Pass 1 of 1 - [04:22:31] Video Encode complete - [04:22:31] Reencoding audio tracks (if req'd) - [04:22:31] Multiplexing M2TS - [04:22:35] Extracting A/V streams [VID_00522] - [04:22:50] Reencoding: VID_00522 (27 of 38) - [04:22:50] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,117 frames - [04:22:50] Reencoding: VID_00522, Pass 1 of 1 - [04:24:08] Video Encode complete - [04:24:08] Reencoding audio tracks (if req'd) - [04:24:08] Multiplexing M2TS - [04:24:11] Extracting A/V streams [VID_00028] - [04:24:26] Reencoding: VID_00028 (28 of 38) - [04:24:26] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,601 frames - [04:24:26] Reencoding: VID_00028, Pass 1 of 1 - [04:26:11] Video Encode complete - [04:26:11] Reencoding audio tracks (if req'd) - [04:26:11] Multiplexing M2TS - [04:26:14] Extracting A/V streams [VID_00523] - [04:26:30] Reencoding: VID_00523 (29 of 38) - [04:26:30] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,105 frames - [04:26:30] Reencoding: VID_00523, Pass 1 of 1 - [04:27:54] Video Encode complete - [04:27:54] Reencoding audio tracks (if req'd) - [04:27:54] Multiplexing M2TS - [04:27:59] Extracting A/V streams [VID_00520] - [04:28:14] Reencoding: VID_00520 (30 of 38) - [04:28:14] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,020 frames - [04:28:14] Reencoding: VID_00520, Pass 1 of 1 - [04:29:31] Video Encode complete - [04:29:31] Reencoding audio tracks (if req'd) - [04:29:31] Multiplexing M2TS - [04:29:35] Extracting A/V streams [VID_00026] - [04:29:56] Reencoding: VID_00026 (31 of 38) - [04:29:56] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,703 frames - [04:29:56] Reencoding: VID_00026, Pass 1 of 1 - [04:31:54] Video Encode complete - [04:31:55] Reencoding audio tracks (if req'd) - [04:31:55] Multiplexing M2TS - [04:31:58] Extracting A/V streams [VID_00003] - [04:32:22] Reencoding: VID_00003 (32 of 38) - [04:32:22] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 31,963 frames - [04:32:22] Reencoding: VID_00003, Pass 1 of 1 - [04:33:21] Video Encode complete - [04:33:21] Reencoding audio tracks (if req'd) - [04:33:21] Multiplexing M2TS - [04:33:29] Extracting A/V streams [VID_00004] - [04:34:01] Reencoding: VID_00004 (33 of 38) - [04:34:02] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 8,346 frames - [04:34:02] Reencoding: VID_00004, Pass 1 of 1 - [04:38:06] Video Encode complete - [04:38:06] Reencoding audio tracks (if req'd) - [04:38:06] Multiplexing M2TS - [04:38:16] Extracting A/V streams [VID_00001] - [04:38:58] Reencoding: VID_00001 (34 of 38) - [04:38:58] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 49,040 frames - [04:38:58] Reencoding: VID_00001, Pass 1 of 1 - [04:40:19] Video Encode complete - [04:40:19] Reencoding audio tracks (if req'd) - [04:40:19] Multiplexing M2TS - [04:40:31] Extracting A/V streams [VID_00025] - [04:41:17] Reencoding: VID_00025 (35 of 38) - [04:41:17] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 7,962 frames - [04:41:17] Reencoding: VID_00025, Pass 1 of 1 - [04:45:20] Video Encode complete - [04:45:20] Reencoding audio tracks (if req'd) - [04:45:21] Multiplexing M2TS - [04:45:30] Extracting A/V streams [VID_00002] - [04:46:30] Reencoding: VID_00002 (36 of 38) - [04:46:31] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 63,636 frames - [04:46:31] Reencoding: VID_00002, Pass 1 of 1 - [04:48:26] Video Encode complete - [04:48:26] Reencoding audio tracks (if req'd) - [04:48:26] Multiplexing M2TS - [04:48:40] Extracting A/V streams [VID_00022] - [04:50:02] Reencoding: VID_00022 (37 of 38) - [04:50:02] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 15,628 frames - [04:50:03] Reencoding: VID_00022, Pass 1 of 1 - [04:58:00] Video Encode complete - [04:58:00] Reencoding audio tracks (if req'd) - [04:58:00] Multiplexing M2TS - [04:58:37] Extracting A/V streams [VID_00000] - [05:13:11] Reencoding: VID_00000 (38 of 38) - [05:13:11] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 163,008 frames - Bitrate: 16,370 Kbs - [05:13:11] Reencoding: VID_00000, Pass 1 of 2 - [05:13:11] Reencoding: VID_00000, Pass 2 of 2 - [06:34:41] Video Encode complete - [06:34:41] Reencoding audio tracks (if req'd) - [06:34:41] Multiplexing M2TS [06:42:55]PHASE ONE complete [06:42:55]PHASE TWO - Rebuild Started - [06:42:55] Rebuilding BD file Structure [06:43:14] - Encode and Rebuild complete - WORKFILES folder removed. [06:43:16]JOB: THE_WARLORDS finished. |
13th August 2010, 23:54 | #9200 | Link | |
@ebjones
Please note this quote from the first post of this thread: Quote:
