17th August 2010, 08:28 | #9261 | Link | |
17th August 2010, 10:33 | #9263 | Link |
I think I've found a bug (at least with Up Spanish blu-ray edition) in tsMuxeR, and as it's one of the tools used in BD Rebuilder, maybe it could be interesting posting it here:
http://forum.doom9.org/showpost.php?...postcount=3997 Sorry if this is considered offtopic |
17th August 2010, 16:42 | #9264 | Link |
I'm not sure if this has been discussed anywhere before, but is there a way to have BD-Rebuilder ignore the PS3_UPDATE folder on Sony titles? This folder is generally 150+ MB and I'd much rather have that space free for the video files.
18th August 2010, 04:46 | #9267 | Link | |
Sorry, it's still not clear:
18th August 2010, 12:25 | #9268 | Link | |
cnote
Thank you
18th August 2010, 14:16 | #9269 | Link | |
Aging Video Hobbyist
But this post makes me wonder--regarding possible problems on the INSIDE edge, is there any way to tell a burner (via ImgBurn) to start a burn further-out from the center? |
18th August 2010, 14:57 | #9270 | Link | |
I have never had a failure of the kind noted, and have burned several hundred discs. I have generally kept to 4.26GB to 4.32GB for BD5 and 7.70GB to 7.85GB for BD9. Perhaps those who feel that their backups will look the best if they are 4.37GB BD5 to 7.96GB BD9 will take note. |
18th August 2010, 15:22 | #9272 | Link | |
But I will entertain your original question regarding ImgBurn, since that at least does have some validity. |
18th August 2010, 15:33 | #9273 | Link | |
I had them low originally because of the well-known issue with DVD outer edges. I got a lot of flak for that and finally compromised by raising it a little. Now at least in your case it appears to be a bit too much. |
18th August 2010, 15:55 | #9275 | Link | ||
Many typical sizes have been 8,271,233,024 bytes to 8,451,526,645 bytes.( both of these are recent) Back to page one of this thread: Quote:
18th August 2010, 16:00 | #9276 | Link | |
If you need an ISO, you could then use ImgBurn to create an ISO of the original rip to folders, though this seems redundant. |
18th August 2010, 20:55 | #9277 | Link | |
A DL is burned using "OTP" (opposite track path), meaning the burn starts at the ID & goes to the OD for the first half of the image on "layer 0", then there's the "layer break", then the burn finishes from the OD back to the ID on "layer 1". If it was failing at the edge, he'd be in the ±50% area of the burn, so OD edge quality isn't the reason. The latest Memorex DLs have a LOT of reported problems. Find the "Disc ID" in ImgBurn & then Google that for all the sad stories. They used to be Riteks, now they're some no-name brand coming out of India. I've tried some & had decent luck with them. A few failed verify at the layer break (outer edge), but I never had a burn "failure" with them like Mr cnote reports. I'd guess his failure is caused by "marginal media" not ±100MB on image size. |
18th August 2010, 22:02 | #9278 | Link |
Sync problem
Using the BD version 34.05 I had rebuilded the blu ray movie by reducing the size from 45 gig to 11 gig. Now using the m2ts file I had demuxed the streams into video (.x264) and audio (.dts) streams. I used these streams and muxed into mkv container file. Now while playing this file, initially video and audio matched. But when I fast forwarded the movie and played again at a some point, the video is ahead of audio and never matched.
If used the straight stream (m2ts) file from the blu ray disk and used the program bd-rebuilder and extracted only the movie content as orginal no reduction in size then it is perfect not a problem. Now where is the problem? |
19th August 2010, 00:21 | #9279 | Link | |
