Old 15th January 2011, 19:13   #10981  |  Link
superdawg59
avid fan
Hello,
Maybe someone can help? I have done over 60 backups and have not encountered this before. I usually can find an answer on this site from you gentlemen who are much more tech savvy than I. I am getting the following when trying to rebuild kill bill vol 1 us. it says:
Error in attempt to extract audio/subs.
AV frame too large (65164 bytes) increase buff
Failed to retrieve audio.
this happens in movie only as well as full back up. I have all the correct versions of ffdshow and avisynth and haali and they are all correctly set by the inspect button on bd rebuilder. if I can reset the buffer can some one tell my dumb ass how. thank you in advance for any and all help.
tom c
superdawg59 is offline   Reply With Quote
Old 15th January 2011, 20:23   #10982  |  Link
colinhunt
Ok, I found it. Apparently 24fps is rare -- because based on the code it looks like it has never worked in movie-only mode. It always get set to either 23.976 or 29.97. I'll have it fixed for the next release.
Good to know. Of the past 10 titles I've done 5 were 24fps exactly.
Old 15th January 2011, 20:33   #10983  |  Link
Originally Posted by Voyeurism View Post
I don't think it is 24fps, given the above. I guess I will await the next build and see whether it makes any difference. I've attached the .INF and .LOG files in case you want to take a look.
EDIT: I've also just noticed that the audio is out of sync on my backup of "New Moon" (2nd movie in the Twighlight tilogy). The frame rate for the video stream on the original disk is shown as 23.976023fps in both VLC and BD Rebuilder, but VLC shows the stream in the rebuilt BD5 as 47.952047fps.
That's similar to Capsbackup's report. I'm still looking, but right now I have to believe there is something different between your setup and mine. I've been testing it to death and I can't get it to happen for me. It sounds like pulldown was applied -- but pulldown is never applied to an HD (1920x1080) source.
Old 15th January 2011, 20:42   #10984  |  Link
colinhunt
By the by, how does BD-RB process 1080i25 sources?
Some statistics: of the 79 titles I have waiting for encoding, 20 are something else than 1080p23.976. Of them, 13 are 24.00fps, 3 are 1080i25 and the rest are 1080i29.97.
Old 15th January 2011, 20:52   #10985  |  Link
24fps is probably not as rare as you think. I have a couple of these ....
http://forum.doom9.org/showthread.ph...75#post1469375
I traced it down to a change made in v0.36.1 as a part of the DVD Output routines.
Old 15th January 2011, 20:52   #10986  |  Link
Not sure I know what you're asking? It processes them like any other stream...
Old 15th January 2011, 21:10   #10987  |  Link
colinhunt
It's output as 1080i25? Since BD has no support for 1080p25 and some movies are shot in 25fps here in Europe, authoring shops tend to encode progressive frames but flag them as 1080i25 to get round the limitation.
Old 15th January 2011, 22:29   #10988  |  Link
Crocluvr92
Haali Spliiter And FFDshow
Cant seem to encode Inception, heres the log:
[13:52:01] BD Rebuilder v0.37.01 (beta)
- Source: INCEPTION
- Input BD size: 40.54 GB
- Approximate total content: [03:27:06.580]
- Target BD size: 22.95 GB
- Windows Version: 6.1 [7600]
- Resuming from previously started job.
[13:52:02] PHASE ONE, Encoding
- [13:52:02] Reencoding: VID_00053 (4 of 46)
- [13:52:02] Collecting video information
- Rate/Length: 23.976fps, 1,256 frames
- [13:52:02] Reencoding: VID_00053, Pass 1 of 1
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- BD-Rebuilder v0.37.01 (beta)
- HAALI Splitter: Isn't recommended version
- FFDSHOW: 2527, not recommended version
- FFDSHOW VC-1 set incorrectly: [0]
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[13:55:05] - Failed video encode, aborted
What is the Recommended version of Haali Splitter and FFDShow for this version of BD Rebuilder?
Crocluvr92 is offline   Reply With Quote
Old 15th January 2011, 22:33   #10989  |  Link
omegaman7
omegaman7's Avatar
  - Source:  INCEPTION
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
Probably the ones that Jdobbs linked in his very first post on this thread
Old 15th January 2011, 22:37   #10990  |  Link
Crocluvr92
And what Page would that be on ? Being that there is over 500 pages.
Old 15th January 2011, 22:41   #10991  |  Link
omegaman7
omegaman7's Avatar
He started the thread, and designed the application. The very first post on this thread. Page 1
Old 15th January 2011, 23:10   #10992  |  Link
L4a-Thompson
hello,
@jdobbs
did you found any problem witch i have with the asynchronouse streams, at the movie only dvd output with the 23,976 sources?
L4a-Thompson is offline   Reply With Quote
Old 15th January 2011, 23:27   #10993  |  Link
Originally Posted by L4a-Thompson View Post
hello,
@jdobbs
No, and I do those every day -- sometimes 2-3 each day -- totaling over around 2000 backups, and I have never had one that was out of sync.
However your issue was related to PAL conversion during DVD backup and that is new code and might need some tweaking -- but I've done quite a bit of testing and can't repeat any sync issues. Quite a few others have tried it too with no problems.
Old 16th January 2011, 00:56   #10994  |  Link
1Bullet
Overall I am not having any major issues, however I am seeing one small bug that may have been in other versions but I did not notice it
I am doing a backup of a movie, the closer the movie to 24 gb or smaller before processing it, BD rebuilder seems to miss target by about 1 gb.
I backed a 23878 mb and final movie end up at 21013 mb. I was hoping for reduction of 900mb and it was more than double.
In the past when more encoding is required (larger file) usually it is closer to 22700 to 23000 mb
1Bullet is offline   Reply With Quote
Old 16th January 2011, 03:49   #10995  |  Link
Originally Posted by Capsbackup View Post
I was using the Playall button, and starting from the first clip, Let Her Sleep, the audio was out.
I am running a fast backup now, and will post the files again.
I usually know better than to delete them until things are resolved, but I guess I had a senior moment again.
When I unselected IVTC sources with 3:2 pulldown, these same deleted scenes were in sync.
I loaded up your INI and was able to repeat the goofiness. I don't know what caused it yet, but I think I should be able to find it quick enough.
Old 16th January 2011, 04:10   #10996  |  Link
Ok, I found it. It was only happening when the source was pulldown, and IVTC was set at the same time as DEINTERLACE.
Old 16th January 2011, 05:19   #10997  |  Link
Capsbackup
Excellent!
So should those two settings not be used together?
Old 16th January 2011, 05:31   #10998  |  Link
dpa34
I am looking online and Deciding Between a I7 2600 and a I5 2500k I don't play many Games But I would x.264 or Bd re-builder Does the Fact the I5 2500 not have Hyper threading and does not have the extra 4 threads really affect the speed compared to a I7 9500 or I7 2600 ?
dpa34 is offline   Reply With Quote
Old 16th January 2011, 07:23   #10999  |  Link
Excellent!
It should be okay to have them both selected... so they will work when needed. The bug was in the order I considered them. Now that I've fixed the bug it for the next release you shouldn't have to worry about it. But in practice they are never active (while encoding) at the same time even when selected -- because a source with telecining is progressive, so it needs no deinterlacing.
Old 16th January 2011, 08:51   #11000  |  Link
Crocluvr92
@omegaman7
" He started the thread, and designed the application. The very first post on this thread. Page 1 "
The instructions tell me what programs to Download, but NOT the proper versions for BD Rebuilder v0.37.01 (beta)
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Can someone please tell me what the proper versions of Haali Splitter and FFDSHOW to get for this version of BD Rebuilder?
