10th November 2013, 20:53 | #18181 | Link | |
Strictly, the conversion factor between kB, MB, GB is 1000 while the conversion factor between kiB, MiB, GiB is 1024. So in fact 23500 MiB = 22.949 GiB which is actually what you get but with the "wrong" (but more familiar) units GB instead of GiB. |
10th November 2013, 22:19 | #18182 | Link | |
10th November 2013, 22:24 | #18183 | Link | |
10th November 2013, 22:26 | #18185 | Link | |
So if you buy 1GB of internal memory you are getting 1,073,741,824 bytes of memory. But if you get a 1GB hard drive it only has 1,000,000,000 bytes. I hate it when the same term means two different things and I refuse to accept it. What good is a standard unit of measure that means two different things or changes definitions with at the drop of a hat? Last edited by jdobbs; 10th November 2013 at 23:24. |
10th November 2013, 23:10 | #18186 | Link |
Aging Video Hobbyist
Ok, well then I have to ask why you would mix these in the program i.e. I put 23500MB into the CUSTOM as I said, and your Settings reports exactly that, but in the log it's stated another way. It seems to me I might not be the only user that's been confused by this.
I do concur with your long-standing arguments about "why risk over-running the 25,025,314,816 bytes total available" but in this case if you remember I had run it before already, and so thought this time I'd up the ante cuz before I'd left fully two gigabytes on the table vs. this time which was still about 1.2GB left over. Just sayin' maybe to let the program report consistently so users don't have to second guess these. Last edited by laserfan; 10th November 2013 at 23:13. |
10th November 2013, 23:22 | #18187 | Link | |
Damn. I sure seem to be in an argumentative mood lately. Maybe I need to switch to decaf. Last edited by jdobbs; 10th November 2013 at 23:47. |
10th November 2013, 23:41 | #18188 | Link |
I see, but wouldn't the 15000 limit nevertheless apply if the .mkv is going to be burnt to a SD disc (single or double layer "DVD") due to limited disk spinning speed? For other media it can be higher of course (40000 IIRC for BD25 or BD50).
10th November 2013, 23:44 | #18189 | Link |
@Darth_Emma
Do a Quick-Play backup of "Monsters University". It can do the backup with only the movie -- and keep the audio in-sync. Quick-Play keeps the original multi-part structure (it also can keep multiple angles or playlists that use the same pieces without increasing required storage). Right after selecting Quick-Play, click on "Edit Quick Play menu". You'll notice that there are three different versions of the film on the disc. I selected only the first one by itself, but you should be able to keep them all if you want with minimal impact. I'm not sure what the differences are -- maybe language or extended cuts, I didn't look. Anyway, I ended up with a movie-only backup where everything is in-sync. In any event, I still need to analyze the source to find why there is something making it different from other multi-part discs in a standard movie-only backup. Last edited by jdobbs; 10th November 2013 at 23:58. |
10th November 2013, 23:50 | #18190 | Link | |
Anyway, I said I was going to do it, and I like to think I always keep my word. Last edited by jdobbs; 10th November 2013 at 23:54. |
11th November 2013, 00:10 | #18192 | Link | |
I wanna make a joke now about "opening a floodgate" of donations for you, but maybe the timing is wrong for that sensitive subject. It's obvious you sure have put a lot of work into the latest updates, and so my nit is ill-timed. Anyway, BTW I think maybe you missed my point, which was simply: if I put 23500MB into CUSTOM, then the log should say 23,500MB (or 23.5GB). That's all I was saying; it looks wrong to the un-initiated. Last edited by laserfan; 11th November 2013 at 00:18. |
11th November 2013, 01:49 | #18194 | Link | |
I'm testing the Quick-Play Menu in the 4 modes with some iPad 2 videos 1080x720. The menus are displaying as they should, and are functioning very well. However, I may have misunderstood something...or..?? I also checked the hidden settings. Is there a switch or setting to set to dis/enable for the menu not to display after each video is played? Excellent for Episode...but perhaps not when you'd like the videos to play sequentially without the menu every time. Like, it's only displayed and interactive if you press the Menu button? I appreciate the Share of your personal menu system.
11th November 2013, 02:34 | #18195 | Link | |
Thanks, I'll try that. I am still not sure what to do with my audio settings under the setting/setup menu. I'm going to try it with all of them unchecked. |
11th November 2013, 09:11 | #18196 | Link |
VIDs to reencode.....
I have just realized that the number of VIDS in the stream list in Full Backup Mode seems to be hanging on the target size choosen, too. According to my last information the only determining factors if a VID is reencoded or not are the "MIN_M2TS_SIZE" command and if the file is determined as a menu item. But due to some reason it seems to be depending on the target size, also. To check this, while looking at the stream list just switch to another target size and the number of VIDS to reencode will change. (At least with Jack The Giant Slayer BD Disk).
Could you please check what did I wrong? |
11th November 2013, 13:56 | #18199 | Link | |
