Old 24th October 2023, 08:15   #81  |  Link
anton_foy
Thanks I tried both of your suggestions but it is impossibly slow and I tried Vapoursynth vs-scunet on the same clip and 30 frames would take over 1 hour. So I guess this processing UHD with these models is out of the question for now.
anton_foy is offline   Reply With Quote
Old 24th October 2023, 08:58   #82  |  Link
kedautinh12
Waiting for cuda ver
https://github.com/Asd-g/avs-mlrt/is...ent-1771187328
Old 25th October 2023, 08:56   #83  |  Link
anton_foy
@kedautinh12
Thanks for the info good news.
Something I am wondering about is the num_streams param. Where to find the specification about this for my GPU? May this speed up if I put this to max for my card?
Old 25th October 2023, 18:51   #84  |  Link
Selur
Selur's Avatar
The number of stream depends on the resolution of your input and the VRAM that is used with model X and 1 stream.
If you use a model with one stream and only a fraction of your VRAM is used, you can run multiple streams in parallel to speed things up.
=> increasing the streams will cost VRAM, but can speed things up
So if either the input resolution or the used model changes, the VRAM usage and thus the amount of streams your card can handle can change.
Hybrid here in the forum, homepage, its own forum
Old 26th October 2023, 07:46   #85  |  Link
anton_foy
Thanks I will play around with this.
Old 22nd November 2023, 01:49   #86  |  Link
kedautinh12
Would like to see SwinIR models:
https://github.com/JingyunLiang/SwinIR/releases
https://openmodeldb.info/?q=SwinIR
Old 22nd November 2023, 02:43   #87  |  Link
Dogway
Yes, me too. I tried in vapoursynth and SwinIR didn't work for me there either. Looking for a solid photo upscaler.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 22nd November 2023, 03:08   #88  |  Link
kedautinh12
For Vapoursynth, why you don't ask HolyWu?
https://github.com/HolyWu/vs-swinir/...pen+is%3Aissue
Old 22nd November 2023, 05:42   #89  |  Link
Selur
Selur's Avatar
https://github.com/HolyWu/vs-swinir works fine here,...
Old 22nd November 2023, 20:06   #90  |  Link
Dogway
Ok, I thought the SwinIR models in pth format were supposed to work. Thanks both.
Old 1st December 2023, 14:51   #91  |  Link
kedautinh12
Would like to see CodeFormer models
https://github.com/sczhou/CodeFormer/releases
Old 2nd December 2023, 09:44   #92  |  Link
Selur
Selur's Avatar
Assuming some folks here use those models on normal content, how do you deal with temporal inconsistencies?
(like this: https://forum.videohelp.com/attachme...73592/Face.mp4)
Personally, I use QTGMC with input type 3 to lessen this, but I was wondering what others do.
Cu Selur
Old 3rd December 2023, 03:16   #93  |  Link
kedautinh12
Would like to see UniScale models
https://openmodeldb.info/?q=Uniscale
Old 3rd December 2023, 08:21   #94  |  Link
Selur
Selur's Avatar
You can convert those with chaiNNer (https://github.com/chaiNNer-org/chaiNNer),... (these are also included in the Hybrid onnx models collection)
Old 20th December 2023, 04:27   #95  |  Link
kedautinh12
Would like to see SRFormer models
https://openmodeldb.info/?q=SRFormer
Old 20th December 2023, 08:05   #96  |  Link
Selur
Selur's Avatar
Those seem to work fine here with vs-mlrt. (they are rather slow)
Best post such request over in the github issue tracker.
Cu Selur
Old 20th December 2023, 10:07   #97  |  Link
kedautinh12
I can see it in other model. They use srformer to base for trained on
https://github.com/Phhofm/models
Old 21st December 2023, 04:52   #98  |  Link
kedautinh12
Would like to see Cutie models
https://github.com/hkchengrex/Cutie?tab=readme-ov-file
Old 19th February 2024, 10:38   #99  |  Link
takla
Actually it runs "ok" as long as you're not using any of the broken models from the dropbox link (I haven't tested them all, but 4 of 4 gave an error)
Should be fine if converted manually with "opset 17"
takla is offline   Reply With Quote
Old 10th March 2024, 16:42   #100  |  Link
takla
Here are some models which I've converted to onnx (Mostly for Cartoons/Anime)
I can vouche for all of them working (tested on AMD GPU)
Original sources can be found here
2x_AniScale2S_Compact_i8_60K
Very good with BluRay sources
2x-LD-Anime-Compact
Amazing with high quality DVDs
2x_Garfieldjr_span48
Very Good for mediocre DVD quality
Example script:
LWLibavVideoSource("INPUT.mkv")
ConvertBits(32).ConvertToPlanarRGB()
mlrt_ort(network_path="C:\Program Files (x86)\AviSynth+\plugins64+\models2\2x-LD-Anime-Compact.onnx", builtin=false, provider="dml")
