Old 15th February 2015, 13:08   #12981  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by GCRaistlin View Post
tebasuna51, using libav leads to another issue, doesn't it?
What is the problem?
Of course there are very light differences between decoders but jruggle (ffmpeg developer in AC3 area) minimize the problem.
eac3to uses libav to decode AC3 to 64 bits float (the best resolution), and libav was actualized in eac3to v3.27 (the test was made with 3.24).
I'm trust in the AC3 expert (jruggle) about that.
BTW, if you prefer use a class "A" free decoder liba52 you can use BeHappy with NicAudio to decode AC3.
Old 15th February 2015, 13:33   #12982  |  Link
tebasuna51
tebasuna51's Avatar
Another question about the Arcsoft DTS decoder....is it useful only for the recent 7.1 evolutions?
libav can't decode DTS-HD, only the 'core' is decoded, then can't be used to obtain 7.1 output and lose info from DTS-HR or DTS-MA (lossless).
... Is it better to use it when decoding "regular" 5.1 DTS tracks?... AFAIK, a decoder that is able to decode a specific format (without bugs) should give exactly the same result than another decoder, and therefore there is no advantage to use the slow Arcsoft decoder when decoding a DTS tracks that the libav decoder can also decode properly. Am I right?
Lossy decoders not always output exactly the same result.
There are light differences (like with AC3 in precedents posts).
ArcSoft is a "certified" decoder, libav a free decoder.
It's your choice.
Old 15th February 2015, 16:45   #12983  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
OK, thanks for the information.
r0lZ
Old 18th February 2015, 17:12   #12984  |  Link
Thunderbolt8
got an error message:
X:\file.m2ts>eac3to 1) 2: X:\file.mkv
M2TS, 1 video track, 11 audio tracks, 10 subtitle tracks, 1:48:42, 24p /1.001
1: Chapters, 37 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
v02 Extracting video track number 2...
v02 The h264 muxer doesn't support this stream type yet.
v02 Please send a 20MB sample to dear@madshi.net
v02 Muxing video to Matroska...
Aborted at file position 1048576.
sample can be found here https://www.sendspace.com/file/f7n75i (its a file from 2013)
Laptop Acer Aspire V3-772g: i7-4202MQ, 8GB Ram, NVIDIA GTX 760M (+ Intel HD 4600), Windows 8.1 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64)
Old 25th February 2015, 17:11   #12985  |  Link
bmcelvan
I am having a problem trying trying to decode a TrueHD to anything, wavs, w64, wav or flac. I get the following log:
bitstream parsing for track 2 failed
demuxing this track may still produce correct results - or not.
This audio conversion is not supported.
The eac3to info says:
2: TrueHD, English, 7.1 channels, 48KHz
The mediainfo says:
Audio #1
Format : TrueHD
Codec ID : A_TRUEHD
Duration : 2h 2mn
Bit rate mode : Variable
Maximum bit rate : 7 719 Kbps
Channel(s) : 8 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossless
Language : English
Default : Yes
Forced : No
I have demuxed using mkvtoolnix and changed the extension to .ac3, .thd+ac3 and .truehd and when I try to look at it with eac3to it just says The format of the source file could not be detected.
tsmuxer won't recognize it and vidcoder (handbrake) doesn't even acknowledge it is there.
Could this be some new form of protection from Dolby. Do I need to update a codec or something.
Could it by Dolby atmos - is there a decoder for that?
bmcelvan is offline   Reply With Quote
Old 25th February 2015, 18:09   #12986  |  Link
bmcelvan
*Edit: My apologies, due to bad searching I didn't find the posts about using ffmpeg.
Is there a way to determine if the above track I was talking about is Dolby Atmos. Is that what the A in A_TrueHD stands for? If Yes, then:
I just want to be certain. If I have an .mkv file or a Bluray folder with a 5.1 or 7.1 TrueHD (atmos) track and use the following command, it will output the lossless TrueHD extracted audio in a flac file with proper channel mapping?
ffmpeg -i "my file or folder" -map 0:1 "extracted_audio.flac"
Old 25th February 2015, 18:29   #12987  |  Link
ndjamena
(The "A" is for audio)
ndjamena is offline   Reply With Quote
Old 26th February 2015, 03:16   #12988  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
The case of the movie should tell you if it has Dolby Atmos.
Win10 (x64) build 18362| GPU Caps Viewer 1.42.4.0
NTSC | DVD: R1 | BD: A
Intel Xeon X5660 @2.80GHz
Sparktank is offline   Reply With Quote
Old 26th February 2015, 10:08   #12989  |  Link
tebasuna51
tebasuna51's Avatar
That must work for the second track of a input file (tested .m2ts or .mkv).
I don't know what happens with a folder input.
For questions about ffmpeg syntax please use this thread:
ffmpeg syntax
Old 27th February 2015, 01:26   #12990  |  Link
eddman
I tried replacing the avcodec-54.dll and avutil-52.dll files with newer versions from the latest version of Zeranoe FFmpeg, but eac3to gives me an error that the dll is missing.
What am I doing wrong?
As a side question; is there any other tool/method for converting DTS or dolby audio besides eac3to?
eddman is offline   Reply With Quote
Old 27th February 2015, 09:05   #12991  |  Link
You can certainly convert DVD Video compatible dts or Dolby Digital audio with other tools, like BeHappy or MeGUI, maybe TEncoder. HD audio from Blu-rays is probably not widely supported though.
Old 27th February 2015, 12:00   #12992  |  Link
tebasuna51
tebasuna51's Avatar
The dll's for eac3to aren't the standard dll's, must be compiled for eac3to by madshi.
The answer is in your first question: ffmpeg
Try TAudioConverter (ffmpeg)
Or AviSynth based BeHappy/MeGUI like LigH say.
Old 27th February 2015, 14:02   #12993  |  Link
shh
Bug? DTS-MA 1.0ch (mono!) -> WAV/FLAC broken
Hello!
Config:
C:\TMP>C:\eac3to\eac3to.exe -test
eac3to (v3.27) is up to date
Nero Audio Decoder (Nero 6 or older) doesn't seem to be installed
ArcSoft DTS Decoder (1.1.0.8) works fine
Sonic Audio Decoder (3.27.0.0) doesn't seem to be installed
I got some problems with a DTS-HD MA Mono file:
10MB snippet: http://www.file-upload.net/download-...est.dtsma.html
C:\TMP>C:\eac3to\eac3to.exe test.dtsma
DTS Master Audio, 1.0 channels, 24 bits, 48kHz
(core: DTS, 1.0 channels, 24 bits, 768kbps, 48kHz)
Transcoding to WAV / FLAC / ... results in a sped up audio file.
Only way to handle this is extracting the DTS-core and convert the DTS afterwords.
However, MPC-HC is able to play the original .dtsma file. So the ArcSoft DTS Decoder does work for this file?
Any hints on what to do?
shh
shh is offline   Reply With Quote
Old 27th February 2015, 15:18   #12994  |  Link
Music Fan
You should maybe try ArcSoft DTS Decoder v1.1.0.0 instead of 1.1.0.8 for this file.
Music Fan is offline   Reply With Quote
Old 27th February 2015, 22:43   #12995  |  Link
shh
v1.1.0.0 workend.
Thanks a lot!
shh
Old 28th February 2015, 20:59   #12996  |  Link
73ChargerFan
73ChargerFan's Avatar
Originally Posted by dade49 View Post
This is much simpler. Extract the TrueHD Atmos stream to a multi-channel wav via ffmpeg, and then run that wav through eac3to to dts or whatever.
ffmpeg -i 00000.m2ts -map 0:1 extract.wav
eac3to extract.wav extract.dts
Madshi, any ETA when you'll be able update to discard the Atmos extensions? I'm finding it in more and more BDs.
73ChargerFan is offline   Reply With Quote
Old 1st March 2015, 16:18   #12997  |  Link
Batman007
Guys
I'm trying to slow down an audio from 25.000 FPS to 23.976 FPS through ea3to
I put this code into cmd
C:\eac3to\ea3to.exe "D:\MeGUI 2418\MeGUI output\AVSEQ02 Tc0 L2 2ch 48 224 DELAY 0ms.mp3" "101 D.mp3" -changeTo23.976
But I'm getting this error :
Please tell me what mistake I'm making or what I'm missing
Thank you ......
Batman007 is offline   Reply With Quote
Old 1st March 2015, 16:24   #12998  |  Link
ea>c<3to.exe
Old 1st March 2015, 16:25   #12999  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Try:
eac3to.exe "D:\MeGUI 2418\MeGUI output\AVSEQ02 Tc0 L2 2ch 48 224 DELAY 0ms.mp3" "101 D.mp3" -slowdown
Originally Posted by eac3to v3.27 doc
-slowdown convert 25.000 and 24.000 content to 23.976 fps
r0lZ
Old 1st March 2015, 16:55   #13000  |  Link
xxx666yyy777
Originally Posted by Batman007 View Post
Guys
Thank you ......
BTW - you can usually use the "Tab" button to auto-complete directories and filenames in the MS-DOS window...
xxx666yyy777 is offline   Reply With Quote
eac3to
