8th March 2009, 23:09 | #4461 | Link |
Hey Now!
how do you calculate bitrate filesize in ripbot? I see where it lets you put in locksize but where does it tell you the bitrate?
n/m It's in the dropdown next to the 2 pass mode (have to change to 2 pass from CQ). no help for me as it does not calculate for True-hd only ac3 640 bit...also when i import truehd tracks it gives me a floating point error. Last edited by jamos; 9th March 2009 at 00:15. |
9th March 2009, 00:01 | #4463 | Link | |
9th March 2009, 01:39 | #4464 | Link |
I decided to try RB Builder for the first (was 20.2). I used The Dark Knight that has caused me so much problems with ripbot. The end results are perfect doing movie only with AC3 5.1 and subtitles. I can rewind and fast forward and best of all the audio is in sync. I never got that with ripbot 1.13.0 -1.13.3. Also, it was considerably faster -
BD-B 1st pass - 14 hours 2nd pass - 44 hours Ripbot 1st pass - 24 hours 2nd pass - 70 hours |
9th March 2009, 02:46 | #4465 | Link | |
iam Q6600 (2.4Ghz)/Vista 32bit/4gigs DRAM2 PC8500 i get encodes RipBot: 8-12hrs for 8.5gig BD9 14-20hrs for 25gig BD-R when i did RockNrolla -> BD9 w/ BD-Rebuilder v20.02 at High Quality (default) = 7.33hrs Quality setting is probably lower than RipBot |
9th March 2009, 12:37 | #4467 | Link |
I'm going to repost my original question as I got no answer from anyone.....if there is something wrong with this question, please tell me what's wrong with it, or direct me to the correct place for this question. I appreciate it.
Hello. I'm new to the forum here and new to ripbot. I've been using ripbot to make some BD5s for ps3 and bluray standalones using the bluray option in ripbot. I take a 720p mkv file, load it in, set lock size to 4450, use two-pass, level 4.0, try always to keep the video bitrate over 4,000 for 720 BD5s. The question I have is, is there a Dummy's Guide for optimum settings for ripbot while making BD5 and BD9 movies? I've searched the forum here and can't seem to find any newbie guide to using ripbot. Here are the settings I currently use that a friend told me to use, but could I tweak these settings even more? I'm not sure what each setting does. Again, I'm a newbie to x264 encoding, treat me gentle... |
9th March 2009, 13:24 | #4468 | Link |
@TRONDROM
This provides perfect Quality and is fully Compliant for "Standalone AVCHD" . Use it with CRF(CQ) 18-21 ,or 2pass VBR = 720p Bitrate 4.5-7Mbps ,1080p 8-12Mbps --level 4.1 --keyint 24 --min-keyint 2 --aud --nal-hrd --vbv-bufsize 16500 --vbv-maxrate 16500 --filter -1,-1 --ref 4 --mixed-refs --bframes 3 --b-adapt 2 --weightb --direct auto --subme 8 --trellis 1 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --ipratio 1.1 --pbratio 1.1 --me umh --threads auto --thread-input --mvrange 511 --sar 1:1 --progress --no-psnr --no-ssim This is for Bluray Disc Encoding : --level 4.1 --keyint 24 --min-keyint 2 --aud --nal-hrd --vbv-bufsize 40000 --vbv-maxrate 40000 --filter -3,-3 --ref 4 --mixed-refs --bframes 3 --b-adapt 2 --weightb --direct auto --subme 8 --trellis 1 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --ipratio 1.1 --pbratio 1.1 --me umh --threads auto --thread-input --mvrange 511 --sar 1:1 --progress --no-psnr --no-ssim You can create a Ripbot Profile (Folder C:\Ripbot/Profiles) when you save it into a .txt File. One more question : Why does Ripbot open Mpeg2/AVC TS /M2TS Files not with DGIndex/DGAVC ? Ripbot always opens TS/M2TS with a Directshow Decoder ? Or is the indexing the next Step after the File is open in Ripbot? Last edited by ACrowley; 9th March 2009 at 13:33. |
9th March 2009, 19:09 | #4470 | Link | |
Indexing in general is useful only when you need frame accurate access.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 9th March 2009 at 19:11. |
10th March 2009, 03:31 | #4471 | Link |
hello i have a feature request/suggestion for the author of ripbot
would it be possible for you to add an option that allows us to name the audio and video streams currently it only says GPAC ISO Audio Handler when you could name it something like English 5.1 AAC 320Kbps thanks Last edited by Sem; 10th March 2009 at 03:39. |
10th March 2009, 06:18 | #4472 | Link | |
10th March 2009, 13:06 | #4473 | Link | |
Which one would I chose to encode a BR to MKV (m2ts -> ts -> mkv) with autocrop enabled? I'd love to have a good quality using an average bitrate of 10000 kbis/s for the video. What would I check or uncheck on settings screen? I am a bit confused with all the possibilities there. File will be played on a popcorn hour or western digital hd tv media player. And any idea how long a job would take with this config: Q6600 @ Stock 5GB RAM Windows Server 2008 Enterprise 64Bit 1TB Samsung HDD and 250GB Samsung HDD. Another question: Does selecting CQ result in a singlepass encoding or is it 2 pass aswell? Last edited by ayfa; 10th March 2009 at 13:13. |
10th March 2009, 14:16 | #4474 | Link |
The last few encodes I've tried have froze up right at about 97% on the 2nd pass...I get an error message that states:
avs2yuv.exe has stopped working I've installed v1.13.3 & trying to encode a h.264 .ts file (to Blu-ray, BD9 size) ripped from my cable box using the Hauppage HD PVR...I'm using Windows 7 64-bit on a i7 Quad Core w/6GB of RAM...I've never had this problem before & was unsure what to do...has anyone seen this? |
10th March 2009, 18:43 | #4475 | Link | |
10th March 2009, 21:45 | #4476 | Link |
I've encoded about 200 movies to 1080p using RipBot (generally, as soon as a new version has come out I'll update it) & have well over a 90% success rate...occasionally, I have had a few issues...I have seen some problems w/rips from my cable box using version 1.13.0 & 1.13.2...for those, I usually use 1.12.0 & they come out fine...figured I would try the newer version w/those rips & see what happened...today, I actually got one to finish (even though I got the avs2yuv.exe has stopped working message at around 97% completion of pass 2) it started muxing & then finished...I briefly checked it before going to work & it looked good...very strange...I am unsure about the avs2yuv.exe utility or what exactly it does
11th March 2009, 21:56 | #4479 | Link | |
go back to scratch and remove hali, ffdshow, and avisynth . then reinstall avisynth and ffdshow, latest versions. see how that goes. I had this before when x264 would crash yet ripbot didnt realise and just thought it had finished... |
11th March 2009, 22:19 | #4480 | Link |
Hi
I don't have any codec pack's installed at all, so I will try to reinstall the one you mentioned. I just find it odd that this happend. By the way, the x264 app that is in the tools folder of the RipBot folder, is it OK to replace them with a newer version or will that cause any problems? |
