30th July 2009, 19:05 | #2081 | Link |
Ehm, basically... yes ;-). OK... I will redo the tracing. I closed the terminal this morning, but the information were as I mentioned. I started another encode with imk's build using DirectShowSource of the same source this morning and up to now there have not been any errors. Do you definitely expect more information than I posted, so that I missed something? In that case I do the tracing again.
Edit: Actually, the DirectShowSource encode failed too, but for other, unknown reasons... I've just started the backtrace again. Edit: OK, an error occurred again. I now paste exactly what is shown in the terminal: Code:
This application has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information. warning: Process detach: hModule = 0x10000000, gRefCnt = 2 Program exited with code 03. (gdb) bt No stack. Edit: The issue might have been caused by using SetMTMode(2) at the very beginning of the avs-script, especially before AVCSource/DirectShowSource. When I put it after source loading, the encodes seem to be stable. I have already encoded about 33000 frames and the crashes were always at a few 1000 frames. Last edited by moviefan; 1st August 2009 at 21:22. |
1st August 2009, 21:07 | #2082 | Link | |||||
I want to modify x264.c to make a custom profile
cmd now : Quote:
1st August 2009, 23:41 | #2083 | Link |
You can discover the variable names by looking at common/common.c and the function x264_param_parse then add them to your preset. You don't have to add your preset name to the help if it is for your use.
x264 log explained || x264 deblocking how-to preset -> tune -> user set options -> fast first pass -> profile -> level Doom10 - Of course it's better, it's one more. |
2nd August 2009, 00:15 | #2084 | Link |
Software Developer
juGGaKNot, try this:
else if( !strcasecmp( optarg, "juggaknot" ) ) { param->analyse.i_me_method = X264_ME_TESA; param->analyse.i_subpel_refine = 10; param->analyse.i_me_range = 24; param->i_frame_reference = 16; param->i_bframe_adaptive = X264_B_ADAPT_TRELLIS; param->analyse.i_direct_mv_pred = X264_DIRECT_PRED_AUTO; param->analyse.inter |= X264_ANALYSE_PSUB8x8; param->analyse.b_fast_pskip = 0; // --no-fast-pskip param->analyse.i_trellis = 2; param->i_bframe = 16; // --bframes 4 param->rc.f_qcompress = 1.0f // --qcomp 1.0 param->rc.i_vbv_max_bitrate = 20000; // --vbv-maxrate 20000 param->rc.i_vbv_buffer_size = 20000; // --vbv-bufsize 20000 param->rc.b_aud = 1; // --aud param->b_dct_decimate = 0; // --no-dct-decimate param->vui.b_fullrange = 1; // --fullrange on param->analyse.f_psy_rd = 1.0f; // --psy-rd 1.0:00 param->analyse.f_psy_trellis = 0.0f; // --psy-rd 1.0:00 param->rc.i_aq_mode = X264_AQ_AUTOVARIANCE; // --aq-mode 2 param->rc.f_aq_strength = 1.0f; // --aq-strength 1.0 param->rc.f_ip_factor = 1.1f; // --ipratio 1.1 param->rc.f_pb_factor = 1.1f; // --pbratio 1.1 param->vui.i_sar_height = 1; //--sar 1:1 param->vui.i_sar_width = 1; //--sar 1:1 param->b_nal_hrd = 1; // --nal-hrd } Note that some lines are superfluous, as they simply represent the default. But I included them anyway, just for completeness
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 2nd August 2009 at 00:20. |
2nd August 2009, 09:29 | #2085 | Link | ||
thnx. LE error on the diff Code:
*************** *** 593,598 **** param->analyse.i_trellis = 2; param->i_bframe = 16; } else { fprintf( stderr, "x264 [error]: invalid preset: %s\n", optarg ); --- 593,626 ---- param->analyse.i_trellis = 2; param->i_bframe = 16; } + else if( !strcasecmp( optarg, "juggaknot" ) ) + { + param->analyse.i_me_method = X264_ME_TESA; + param->analyse.i_subpel_refine = 10; + param->analyse.i_me_range = 24; + param->i_frame_reference = 16; + param->i_bframe_adaptive = X264_B_ADAPT_TRELLIS; + param->analyse.i_direct_mv_pred = X264_DIRECT_PRED_AUTO; + param->analyse.inter |= X264_ANALYSE_PSUB8x8; + param->analyse.b_fast_pskip = 0; // --no-fast-pskip + param->analyse.i_trellis = 2; + param->i_bframe = 16; // --bframes 4 + param->rc.f_qcompress = 1.0f // --qcomp 1.0 + param->rc.i_vbv_max_bitrate = 20000; // --vbv-maxrate 20000 + param->rc.i_vbv_buffer_size = 20000; // --vbv-bufsize 20000 + param->rc.b_aud = 1; // --aud + param->b_dct_decimate = 0; // --no-dct-decimate + param->vui.b_fullrange = 1; // --fullrange on + param->analyse.f_psy_rd = 1.0f; // --psy-rd 1.0:00 + param->analyse.f_psy_trellis = 0.0f; // --psy-rd 1.0:00 + param->rc.i_aq_mode = X264_AQ_AUTOVARIANCE; // --aq-mode 2 + param->rc.f_aq_strength = 1.0f; // --aq-strength 1.0 + param->rc.f_ip_factor = 1.1f; // --ipratio 1.1 + param->rc.f_pb_factor = 1.1f; // --pbratio 1.1 + param->vui.i_sar_height = 1; //--sar 1:1 + param->vui.i_sar_width = 1; //--sar 1:1 + param->b_nal_hrd = 1; // --nal-hrd + } else { fprintf( stderr, "x264 [error]: invalid preset: %s\n", optarg ); Quote:
if i copy the code in x264.c ( replace placebo with juggaknot ) i get errors on aud Last edited by juGGaKNot; 2nd August 2009 at 12:05. |
2nd August 2009, 10:45 | #2086 | Link |
Hello.
I'm totaly new in h264. I've try to encode videos in h264, and import them in scenarist. After faillure and research, it seems that standard x264 built lack some "4-slice" support in produced stream to be BD compliant, at least in scenarist (v4.3.0) aspect. I've found that maybe it exist some patched version wich add these "slice". I hope i'm in the right place to ask this. If these versions exist, where can i find them, and what specific command line option do i have to add in MeGUI ? Thanks. |
2nd August 2009, 11:32 | #2087 | Link |
You can try to compile x264 with this patch and then add the appropriate custom command line options in megui.
2nd August 2009, 11:44 | #2088 | Link | |
2nd August 2009, 12:20 | #2090 | Link | |
x264 developer
Technically, BD does require slicing, but I have yet to receive a report of a player not taking an unsliced stream. Some authoring software checks it anyways though. |
2nd August 2009, 12:25 | #2091 | Link |
OK, if the patch is used, is x264 in its current development stage capable of 100% BD compliance (official requirements)? (speaking of encoding 1080p material, using Level 4.1 and the correct settings to be within BD specs)
2nd August 2009, 13:09 | #2093 | Link | |
2nd August 2009, 13:13 | #2094 | Link |
Software Developer
2nd August 2009, 13:19 | #2096 | Link |
Software Developer
Let me google that for you:
http://lmgtfy.com/?q=x264_win_zone_p...iletype%3Adiff
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 2nd August 2009 at 13:25. |
2nd August 2009, 13:29 | #2097 | Link |
filetype:xxx, good tip
i get one error hrd also got errors, 13 modified, 14 and 15 : Code:
$ patch -p1 < /d/x264_win_zone_parse_fix_05.diff patching file encoder/ratecontrol.c Hunk #1 FAILED at 638. Hunk #2 FAILED at 649. 2 out of 2 hunks FAILED -- saving rejects to file encoder/ratecontrol.c.rej $ patch -p1 < /d/x264_hrd_pulldown.13_interlace.diff patching file common/bs.h Hunk #1 FAILED at 169. 1 out of 1 hunk FAILED -- saving rejects to file common/bs.h.rej patching file common/common.c Hunk #1 FAILED at 141. Hunk #2 FAILED at 370. Hunk #3 FAILED at 585. 3 out of 3 hunks FAILED -- saving rejects to file common/common.c.rej patching file common/common.h Hunk #1 FAILED at 279. 1 out of 1 hunk FAILED -- saving rejects to file common/common.h.rej patching file common/frame.c Hunk #1 FAILED at 109. 1 out of 1 hunk FAILED -- saving rejects to file common/frame.c.rej patching file common/frame.h Hunk #1 FAILED at 34. 1 out of 1 hunk FAILED -- saving rejects to file common/frame.h.rej patching file common/set.h Hunk #1 FAILED at 125. 1 out of 1 hunk FAILED -- saving rejects to file common/set.h.rej patching file encoder/encoder.c Hunk #1 FAILED at 383. Hunk #2 FAILED at 702. Hunk #3 FAILED at 908. Hunk #4 FAILED at 1309. Hunk #5 FAILED at 1358. Hunk #6 FAILED at 1368. Hunk #7 FAILED at 1390. Hunk #8 FAILED at 1514. Hunk #9 FAILED at 1547. Hunk #10 FAILED at 1608. Hunk #11 FAILED at 1699. Hunk #12 FAILED at 1749. Hunk #13 FAILED at 1763. 13 out of 13 hunks FAILED -- saving rejects to file encoder/encoder.c.rej patching file encoder/ratecontrol.c Hunk #1 FAILED at 70. Hunk #2 FAILED at 91. Hunk #3 FAILED at 143. Hunk #4 FAILED at 287. Hunk #5 FAILED at 1088. Hunk #6 FAILED at 1170. Hunk #7 FAILED at 1292. Hunk #8 FAILED at 1305. 8 out of 8 hunks FAILED -- saving rejects to file encoder/ratecontrol.c.rej patching file encoder/ratecontrol.h Hunk #1 FAILED at 34. 1 out of 1 hunk FAILED -- saving rejects to file encoder/ratecontrol.h.rej patching file encoder/set.c Hunk #1 FAILED at 208. Hunk #2 FAILED at 391. Hunk #3 FAILED at 580. 3 out of 3 hunks FAILED -- saving rejects to file encoder/set.c.rej patching file encoder/set.h Hunk #1 FAILED at 29. 1 out of 1 hunk FAILED -- saving rejects to file encoder/set.h.rej patching file x264.c Hunk #1 FAILED at 196. Hunk #2 FAILED at 354. Hunk #3 FAILED at 399. Hunk #4 FAILED at 467. Hunk #5 FAILED at 1107. 5 out of 5 hunks FAILED -- saving rejects to file x264.c.rej patching file x264.h Hunk #1 FAILED at 201. Hunk #2 FAILED at 267. Hunk #3 FAILED at 293. 3 out of 3 hunks FAILED -- saving rejects to file x264.h.rej $ patch -p1 < /d/x264_hrd_pulldown.14_interlace.diff patching file common/bs.h Hunk #1 FAILED at 169. 1 out of 1 hunk FAILED -- saving rejects to file common/bs.h.rej patching file common/common.c Hunk #1 FAILED at 145. Hunk #2 FAILED at 374. Hunk #3 FAILED at 589. 3 out of 3 hunks FAILED -- saving rejects to file common/common.c.rej patching file common/common.h Hunk #1 FAILED at 288. 1 out of 1 hunk FAILED -- saving rejects to file common/common.h.rej patching file common/frame.c Hunk #1 FAILED at 109. 1 out of 1 hunk FAILED -- saving rejects to file common/frame.c.rej patching file common/frame.h Hunk #1 FAILED at 34. 1 out of 1 hunk FAILED -- saving rejects to file common/frame.h.rej patching file common/set.h Hunk #1 FAILED at 125. 1 out of 1 hunk FAILED -- saving rejects to file common/set.h.rej patching file encoder/encoder.c Hunk #1 FAILED at 403. Hunk #2 FAILED at 725. Hunk #3 FAILED at 931. Hunk #4 FAILED at 940. Hunk #5 FAILED at 1386. Hunk #6 FAILED at 1396. Hunk #7 FAILED at 1418. Hunk #8 FAILED at 1571. Hunk #9 FAILED at 1633. Hunk #10 FAILED at 1729. Hunk #11 FAILED at 1779. Hunk #12 FAILED at 1793. 12 out of 12 hunks FAILED -- saving rejects to file encoder/encoder.c.rej patching file encoder/ratecontrol.c Hunk #1 FAILED at 68. Hunk #2 FAILED at 89. Hunk #3 FAILED at 140. Hunk #4 FAILED at 286. Hunk #5 FAILED at 1089. Hunk #6 FAILED at 1171. Hunk #7 FAILED at 1293. Hunk #8 FAILED at 1305. 8 out of 8 hunks FAILED -- saving rejects to file encoder/ratecontrol.c.rej patching file encoder/ratecontrol.h Hunk #1 FAILED at 34. 1 out of 1 hunk FAILED -- saving rejects to file encoder/ratecontrol.h.rej patching file encoder/set.c Hunk #1 FAILED at 208. Hunk #2 FAILED at 383. Hunk #3 FAILED at 572. 3 out of 3 hunks FAILED -- saving rejects to file encoder/set.c.rej patching file encoder/set.h Hunk #1 FAILED at 29. 1 out of 1 hunk FAILED -- saving rejects to file encoder/set.h.rej patching file x264.c Hunk #1 FAILED at 196. Hunk #2 FAILED at 354. Hunk #3 FAILED at 399. Hunk #4 FAILED at 467. 4 out of 4 hunks FAILED -- saving rejects to file x264.c.rej patching file x264.h Hunk #1 FAILED at 200. Hunk #2 FAILED at 266. Hunk #3 FAILED at 292. 3 out of 3 hunks FAILED -- saving rejects to file x264.h.rej $ patch -p1 < /d/x264_hrd_pulldown.15_interlace.diff patching file common/bs.h Hunk #1 FAILED at 169. 1 out of 1 hunk FAILED -- saving rejects to file common/bs.h.rej patching file common/common.c Hunk #1 FAILED at 145. Hunk #2 FAILED at 374. Hunk #3 FAILED at 589. 3 out of 3 hunks FAILED -- saving rejects to file common/common.c.rej patching file common/common.h Hunk #1 FAILED at 288. 1 out of 1 hunk FAILED -- saving rejects to file common/common.h.rej patching file common/frame.c Hunk #1 FAILED at 109. 1 out of 1 hunk FAILED -- saving rejects to file common/frame.c.rej patching file common/frame.h Hunk #1 FAILED at 34. 1 out of 1 hunk FAILED -- saving rejects to file common/frame.h.rej patching file common/set.h Hunk #1 FAILED at 125. 1 out of 1 hunk FAILED -- saving rejects to file common/set.h.rej patching file encoder/encoder.c Hunk #1 FAILED at 403. Hunk #2 FAILED at 725. Hunk #3 FAILED at 931. Hunk #4 FAILED at 940. Hunk #5 FAILED at 1386. Hunk #6 FAILED at 1396. Hunk #7 FAILED at 1418. Hunk #8 FAILED at 1571. Hunk #9 FAILED at 1633. Hunk #10 FAILED at 1729. Hunk #11 FAILED at 1779. Hunk #12 FAILED at 1793. 12 out of 12 hunks FAILED -- saving rejects to file encoder/encoder.c.rej patching file encoder/ratecontrol.c Hunk #1 FAILED at 68. Hunk #2 FAILED at 89. Hunk #3 FAILED at 140. Hunk #4 FAILED at 286. Hunk #5 FAILED at 1089. Hunk #6 FAILED at 1171. Hunk #7 FAILED at 1293. Hunk #8 FAILED at 1305. 8 out of 8 hunks FAILED -- saving rejects to file encoder/ratecontrol.c.rej patching file encoder/ratecontrol.h Hunk #1 FAILED at 34. 1 out of 1 hunk FAILED -- saving rejects to file encoder/ratecontrol.h.rej patching file encoder/set.c Hunk #1 FAILED at 208. Hunk #2 FAILED at 384. Hunk #3 FAILED at 573. 3 out of 3 hunks FAILED -- saving rejects to file encoder/set.c.rej patching file encoder/set.h Hunk #1 FAILED at 29. 1 out of 1 hunk FAILED -- saving rejects to file encoder/set.h.rej patching file x264.c Hunk #1 FAILED at 196. Hunk #2 FAILED at 354. Hunk #3 FAILED at 399. Hunk #4 FAILED at 467. 4 out of 4 hunks FAILED -- saving rejects to file x264.c.rej patching file x264.h Hunk #1 FAILED at 200. Hunk #2 FAILED at 266. Hunk #3 FAILED at 292. 3 out of 3 hunks FAILED -- saving rejects to file x264.h.rej Last edited by juGGaKNot; 2nd August 2009 at 13:44. |
2nd August 2009, 15:33 | #2099 | Link | |
Using windows xp.
2nd August 2009, 15:55 | #2100 | Link |
Wewkiee
When you installed git it asks what type of line endings you want, IIRC it defaults to windows (CR/LF) when installed on windows. You should select linux(LF) . When it happened to me, I just reinstalled GIT and changed the setting. I assume there is another quicker way to do it, but i didnt bother looking.
My own question... When i diff, the vcproj/sln files always end up in there. A few times Ive googled til i get tired of googling a way (well.. a simple way) to avoid that, but never can find one. i usually do git diff -ignore-space-at-eol > blah.diff . (the ignore arg ive found keeps the diff file from quoting the entire vcproj file but a header still shows up. ) you can see that at the beginning of my diffs
...yeah...but...why on earth would I compare apples with apples? |
h.264, x264, x264 builds, x264 patches, x264 unofficial builds |
