3rd September 2009, 17:20 | #2261 | Link |
x264 r1247M x86
Built by rack04 on September 3, 2009, 9:05:49 AM CST
4th September 2009, 12:29 | #2262 | Link |
Strictly Rhythm
x264_x64_r1247_unpatched | MD5
GCC 4.4.1 20090803 (x64.core2.Komisar), unpatched, generic, fprofiled ________________________________________________________________________________ x264_x86_r1247_techouse | INFO GCC 4.4.1 20090803 (x86.core2.Komisar), fprofiled, -march=core2 x264_x64_r1247_techouse | INFO GCC 4.4.1 20090803 (x86_64.core2.Komisar), fprofiled, -march=core2 Patches used: x264_win_zone_parse_fix_06.diff
5th September 2009, 06:59 | #2264 | Link | |
Will try making new BD's for my BD30 now. See if slicing (plus nal-hrd) makes a noticeable difference (suspect not, but at least they are "compliant") Last edited by G_M_C; 5th September 2009 at 07:04. |
5th September 2009, 14:37 | #2265 | Link |
Wewkiee
Oh and the other patch probably should have been fine (I didn't look at the code.) Slices dont have an impact on dpb_output_delay and cpb_removal_delay calculation. Slices add some overhead, but x264 already accounts for that so that information is passed to the patch.
...yeah...but...why on earth would I compare apples with apples? |
5th September 2009, 21:56 | #2266 | Link |
Has anybody compiled r1247 with x264_hrd_pd_interlace.17 patch and encode something? It gives me an output video which has very low bitrate, like 75Kbps. If I compile x264 without v17 of the x264_hrd_pd_interlace, then the output video is fine.
6th September 2009, 00:03 | #2267 | Link | |
Compiling Encoder
clean git: x264 [info]: frame I:2 Avg QP:15.75 size: 2118 PSNR Mean Y:74.50 U:78.31 V:76.37 Avg:75.08 Global:53.17 x264 [info]: frame P:126 Avg QP:27.38 size: 4091 PSNR Mean Y:42.89 U:47.43 V:46.95 Avg:43.81 Global:42.82 x264 [info]: frame B:172 Avg QP:31.00 size: 434 PSNR Mean Y:41.85 U:45.69 V:45.32 Avg:42.68 Global:42.27 w/ hrd pd: x264 [info]: frame I:2 Avg QP:15.75 size: 15710 PSNR Mean Y:74.50 U:78.31 V:76.37 Avg:75.08 Global:53.17 x264 [info]: frame P:126 Avg QP:27.38 size: 46819 PSNR Mean Y:42.89 U:47.43 V:46.95 Avg:43.81 Global:42.82 x264 [info]: frame B:172 Avg QP:31.00 size: 47128 PSNR Mean Y:41.85 U:45.69 V:45.32 Avg:42.68 Global:42.27 patch also broke vbv as on my sample which has 0 underflows with on clean git, reports an underflow for ~92% of the frames with the patch. the final output rate with the patch is also about 25% of what it is with clean git when using vbv. so yeah, the patch is highly broken, don't use it. Last edited by kemuri-_9; 6th September 2009 at 00:07. |
6th September 2009, 18:25 | #2270 | Link |
Wewkiee
I initiated the variable that tracks the size of the current frame in the AUD if statement. so using anyone using --aud would have be fine. w/out it, the variable got exponantially bigger so ratecontrol would think it was getting humungous frames and eventially wasnt able to compensate. i tested with --aud so never caught it. anywho... its fixed. feel free to scrutinize this one before using.
6th September 2009, 20:10 | #2272 | Link |
x264 r1251M x86
Built by rack04 on September 6, 2009, 2:06:54 PM CST
6th September 2009, 21:32 | #2273 | Link |
もこたんインしたお!
x264 r1251 64bit unpatched:
download ; hash
x264 r1251 32bit download ; release notes
x264 r1251 64bit download ; release notes
patched with:
2009/09/09: Updated the hrd_pd_interlace patch to v1⑨.
[I'm human, no debug]
7th September 2009, 01:05 | #2274 | Link |
|ン、)
r1251M built with ICC.
Windows: x264-r1251M-imk-win.7z win_build_info.txt OS X: x264-r1251M-imk-osx.7z osx_build_info.txt Last edited by imk; 7th September 2009 at 01:53. Reason: Added link to OSX build. |
7th September 2009, 12:49 | #2275 | Link |
Strictly Rhythm
x264_x64_r1251_unpatched | MD5
GCC 4.4.1 20090803 (x64.core2.Komisar), unpatched, generic, fprofiled ________________________________________________________________________________ x264_x86_r1251_techouse | INFO GCC 4.4.1 20090803 (x86.core2.Komisar), fprofiled, -march=core2 x264_x64_r1251_techouse | INFO GCC 4.4.1 20090803 (x86_64.core2.Komisar), fprofiled, -march=core2 Patches used: x264_win_zone_parse_fix_06.diff x264_hrd_pd_interlace.19.diff
Last edited by techouse; 10th September 2009 at 09:09. Reason: Trahald's new revision of the patch x264_hrd_pd_interlace.19.diff. I rather edited this post than make a new one. |
7th September 2009, 13:15 | #2276 | Link |
Spinner of yarns
Hi Trahald.
I found the streams encoded with x264_hrd_pd_interlace.18.diff make avinaptic display the error. Is this safe? Edit: I heard that PSP cannot play that streams.
僕と契約して、L-SMASH developerになってよ! L-SMASH | L-SMASH Works | Opus-in-ISOBMFF specification and reference software Last edited by VFR maniac; 7th September 2009 at 18:27. |
7th September 2009, 14:56 | #2277 | Link | |
Hi Trahald.
I get the error: Assertion failed: dpb_output_delay < pow( 2, sps->vui.nal_hrd_parameters.i_dpb_output_delay_length ), file encoder/set.c, line 652 It is the same error as here (you fixed it): http://forum.doom9.org/showthread.ph...62#post1316462 Quote:
8th September 2009, 01:56 | #2279 | Link |
Angel of Night
Has anyone made a build with Trahald's b-pyramid/open gop patches? The latest one is on the mailing list, I was interested in trying it but don't have a build environment set up where I am.
8th September 2009, 03:16 | #2280 | Link |
This question has probably been answered, but please forgive me for not having the time/patience to read 100+ pages
Why aren't the patches incorporated into x264 permanently? Is there some sort of problem? Does compiling a patch break anything in x264? Otherwise I don't see a reason (unless someone point it out) to bother a few people here to compile a build every time x264 updates, and x264 updates quite often. |
h.264, x264, x264 builds, x264 patches, x264 unofficial builds |
