11th August 2007, 18:14 | #44 | Link |
Options -> Playback -> output -> "use texture surfaces and render video in 3D"
MPC-HC 2.2.1 |
13th August 2007, 00:16 | #47 | Link |
Software Developer
clsid, I have mirrored your latest build at this location:
http://mulder.dummwiedeutsch.de/pub/...2007-08-10.zip Just in case you want to put the direct download link in your initial post...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 13th August 2007 at 00:22. |
13th August 2007, 04:19 | #48 | Link | |
war59312.com
Crashes on HD 1080 version:
http://pixelcorps.tv/node/250 Quote:
Update: Official MPC 6.4.9.0 crashes too. Any ideas? Update2: Uninstalled quicktime and problem solved. Quicktime sucks big time!!!!! Last edited by war59312; 13th August 2007 at 04:33. |
13th August 2007, 08:58 | #50 | Link |
Interestingly enough that file works perfectly on CelticDruids late 2006 build
http://tirnanog.fate.jp/mirror/Media...yer%20Classic/
| Meeow! |
13th August 2007, 14:22 | #52 | Link |
Instead of uninstalling QuickTime, you could also rename the file to .mp4 or .hdmov or .whatever. Then MPC will use DirectShow for playing it.
You can also set QuickTime file formats to DirectShow in MPC options. But I recommend renaming instead, since some .mov files can only be played properly with QuickTime.
MPC-HC 2.2.1 |
15th August 2007, 15:06 | #53 | Link | |
Problem with an .MP3. It plays fine with WMP, but not with MPC:
Mystérieuse Amour |
15th August 2007, 15:11 | #54 | Link |
Here is the file for which I get the problem of my previous message:
http://rapidshare.com/files/49144820/test.mp3.html
Mystérieuse Amour |
15th August 2007, 16:27 | #55 | Link |
WMP uses its own DMO decoder.
Your file plays fine in MPC if you enable the internal MPEG audio decoder or if you install a DirectShow decoder for MP3 audio.
MPC-HC 2.2.1 |
16th August 2007, 13:09 | #57 | Link |
The last change to Guliverkli SVN was on May 11th 2006.
MPC-HC 2.2.1 |
media player classic, mpc, vsfilter |
