Old 28th April 2011, 01:07   #61  |  Link
fairchild
Originally Posted by PelPix View Post
Yet another use for this really amazing script.
(Sorry about the quality. I had to screencap it from a render snapshot because it was currently rendering)
Portal 2! I already beat it in single-player mode, pretty fun puzzler.
MPC-HC/MPC-BE, Lav Filters, MadVR
CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S
fairchild is offline   Reply With Quote
Old 28th April 2011, 03:49   #62  |  Link
SubJunk
Version 1.7 is released which increases the quality of all presets. You can get it from the first post.
SubJunk is offline   Reply With Quote
Old 30th April 2011, 08:52   #63  |  Link
SubJunk
Version 1.7.1 is released which increases the speed by roughly 40%, thanks to the SVP team
Old 30th April 2011, 09:19   #64  |  Link
aegisofrime
Thanks Subjunk! I tried Interframe for one whole DVD yesterday, which annoyingly was not interlaced, thus I couldn't use QTGMC to bob it. Interframe worked very well. I mean, quality and speed, what more could I ask for?
I'm sure the purist will say that framedoubling is flawed, but hey I want 59.94 fps and Interframe is great for that, so why not?
aegisofrime is offline   Reply With Quote
Old 30th April 2011, 09:42   #65  |  Link
SubJunk
Thanks aegis, it's great to know you like it
Old 30th April 2011, 22:22   #66  |  Link
horus14
i have this error u.u
me script
import("C:\Documents and Settings\Administrador\Mis documentos\Encodeo\InterFrame.avsi")
DirectShowSource("G:\[Leopard-Raws] Fairy Tail - 73 RAW (TX 1280x720 x264 AAC).mp4",fps=23.976,audio=true,convertfps=true)
trim(937,3091)
InterFrame(NewNum=48000, NewDen=1001, FlowPath="C:\Documents and Settings\Administrador\Mis documentos\Encodeo\InterFrame.avsi")
Only have this problem with 1.7.1
horus14 is offline   Reply With Quote
Old 30th April 2011, 22:25   #67  |  Link
SubJunk
me script
Hi horus14
It's because your FlowPath should be the path, not including the filename. See the help page in the download, or online here for details on each parameter
Old 1st May 2011, 19:56   #68  |  Link
Mounir
Can someone upload a sample of a 60FPS video processed with interframe, I feel curious today...
Mounir is offline   Reply With Quote
Old 1st May 2011, 22:25   #69  |  Link
Didée
One sample is linked in post#1.
InterFrame is there to be used. So, just use it.
- We´re at the beginning of the end of mankind´s childhood -
My little flickr gallery. (Yes indeed, I do have hobbies other than digital video!)
Didée is offline   Reply With Quote
Old 3rd May 2011, 18:28   #70  |  Link
oddball
Watching the sample clip over and over the cigarette looks really bad. It has a judderyness I find really annoying to watch.
oddball is offline   Reply With Quote
Old 3rd May 2011, 21:52   #71  |  Link
SubJunk
It really shows how juddery regular videos are; it's not the script that makes it juddery, it's just that the rest of the frame is improved while the cigarette remains like the original video
However, you notice things like that much more when the interpolation is still a novelty; when you watch it all the time you get used to it
Old 4th May 2011, 03:12   #72  |  Link
SubJunk
Version 1.8 is released which adds support for 3D content.
Old 8th May 2011, 17:36   #73  |  Link
CruNcher
CruNcher's Avatar
Its not only the cigarette but i have the feeling something is wrong with the background objects that passing by, might be just imagination though but i have the feeling watching the sample something is wrong.
Did someone compared this allready vs other FRCs like Yuvsoft, MSU or Cyberlinks Tzan (CUDA implementation) ?
It is about Time
Old 8th May 2011, 17:52   #74  |  Link
Didée
Doing a non-integer framerate interpolation (like in 24->60) is always visually more problematic than doing an integer conversion (like in plain framerate doubling). When doubling, every second frame is original, and the potentially artificial/or/inconsistent interpolations show up only a short time. When you do 24->60, then you have one original frame, then come 4 (four!) interpolated frames, one original, 4 interpolations, etc. That's *much* more time for (potential) artifacts/inconsistencies to show up and be noticed.
Old 8th May 2011, 18:04   #75  |  Link
CruNcher
CruNcher's Avatar
Very well explained Didée thx if i understand it right this is once again combining needi + mvtools to achieve this so we have now FRC,Deinterlacing,Denoising,Deflicker,AddGrain,Degrain all based on mvtools as the motion estimation engine and needi playing a big part too that's great and for everyone we can partly utilize the GPU as well . And by combining ffdshow with this we can even utilize it in Realtime frameworks and with DSP support (supplying the frames for decoding leaving more CPU for the PostPro)
The SVP guys actually seem to make the first steps into integrating this in a easy to use Realtime package absolutely great
Im really wondering how avisynth and it's framework by these days compares vs high class stuff like thefoundry or greenparrotpictures Research and YuvSoft also isvs like Cyberlink
Surely avisynth didn't reached 10 Bit yet but i wonder how the base algorithms compare and where it stands
Like there FRC http://www.greenparrotpictures.com/slomo.php
or http://www.greenparrotpictures.com/flicker.php
though also mostly impossible to compare i guess with those without having access to them
Of key importance is that we treat the problem at a pixel resolution, and we also pay attention to occlusion and uncovering of objects as they move through the scene.
Maybe that's also what i realize in that sample as it plays in the background
Here is the actual product where their stuff gets into action and what would be comparable to Interframe http://www.thefoundry.co.uk/products/kronos/
http://features.cgsociety.org/story_...?story_id=5776 (the move from C++ to GPU)
here is a moving demo of the scene in the cgsociety article http://www.youtube.com/watch?v=hsFKiLxC4js
Especially the scene is interesting most of their Demo scenes they show Watter (chaotic motion) the canoe paddle shows though some heavy estimation problem, their solution though seems not to apply for interframe in the cigarette case or passing background http://www.youtube.com/watch?v=L0Dl8wyBolQ
Also it seems that their GPU version doesn't show this issue anymore and conquers it now in real time (looking @ the cgsociety demo of the same scene) without needing to apply any alpha matte anymore to fix this
Hey Hey Hey http://thefoundry.s3.amazonaws.com/d...s_Media-v4.zip the assets of that tutorial the Watter scene
http://www.youtube.com/watch?v=tWWGqQImje4 <- Motionblur assets http://thefoundry.s3.amazonaws.com/d...ming_Media.zip <- seems damaged though
http://thefoundry.s3.amazonaws.com/d...Blur_Media.zip <- Motionblur assets in .dpx
http://www.youtube.com/watch?v=YPLj5pQmbV8 <- Grain and Denoise assets http://thefoundry.s3.amazonaws.com/d...rain_Media.zip
The Tutorial Videos are also available as higher quality Quicktime movs not perfect for comparing final results but better then with those youtube videos http://www.thefoundry.co.uk/articles...-nuke-denoise/ http://www.thefoundry.co.uk/articles...r-nuke-kronos/
http://www.thefoundry.co.uk/articles...ke-steadiness/
Also even more assets to play with http://www.thefoundry.co.uk/products...core/training/
The finalcut assets are either in mjpeg 4:2:2 or raw or rle
PS: Can somebody decipher what for a Xeon CPU they compare with http://media.cgnetworks.com/flash/foundry/hawaii.swf Intel Xeon ES5C4 or E55C4 hmm its like Google doesn't know it ?
It is about Time
Old 8th May 2011, 23:35   #76  |  Link
SubJunk
Yes, you're right, and that has always been mentioned in the Description section in the first post
It's probably a combination of errors and that you're not used to seeing such high framerates; people report the same "wrong" feeling when watching native 60FPS content, too.
There are definitely errors in the sample, and in fact that sample hasn't been updated in a while so I should remake it as there have been quality improvements since then. Of course it still won't be perfect
I've compared it to all of the ones I've been able to try.
I emailed the YUVsoft and MSU guys but they said they don't have products for individual people, only for companies. I've also tried a few more products and found them to either be worse or had other problems (for example one of them only works with .avi files so I didn't bother trying it)
I'll read through your big post now and reply later. It's great to have all this feedback in the thread, maybe we can improve the script with all these eyes on it
Old 9th May 2011, 01:01   #77  |  Link
SubJunk
You're right that it's hard to compare them because they will have had a larger clip to work with, but with that in mind I have made comparisons anyway
I should also note that InterFrame is not meant for slow motion and there is a change I would make in the code if it were meant for that. It may seem like framedoubling and slow motion are the same thing, and on paper they are, but our eyes see things differently depending on whether they are moving fast or slow so that is where the difference is.
For example slight blurring and ghosting can look good at fast speed while in slow motion it looks bad, so the technique is similar but not the same.
Samples:
GreenParrot - InterFrame.
P.S. I still have another reply to do, but I'm working so that's why I'm doing separate replies in my breaks
Edit: The Kronos trial installation doesn't work for me so I can't test it.
Old 9th May 2011, 03:58   #78  |  Link
CruNcher
CruNcher's Avatar
looks very good except that speed ramp or artifact @ 0:06 but taking into account you worked with the compressed youtube source it's identical in terms of motion feel, surely this way it can't be nicely compared in other parts like interpolation quality and speed
http://thefoundry.s3.amazonaws.com/p...release-64.zip <- for everyone who wants to give it a compare shoot,dont forget it's an After Effects plugin http://www.thefoundry.co.uk/products...-requirements/
PS: It looks like without the SVP team these speeds wouldn't have been possible @ all amazing work from Russia again a whole OpenCL implementation for the Optical Flow
It is about Time
Old 9th May 2011, 08:40   #79  |  Link
SubJunk
Yes it's great, they are really moving things forward.
The upcoming version increases speed even more
Old 13th May 2011, 09:13   #80  |  Link
madshi
Hey SubJunk,
what kind of motion estimation technique are you currently using? Have you thought about using Optical Flow + Warp, if you're not using that yet? Optical Flow algorithms seem to have improved quite nicely. They're still rather slow (at least the good ones), but I'd guess that they should allow you to improve quality quite a bit. Here are some links to open source Optical Flow algorithms:
http://people.csail.mit.edu/celiu/OpticalFlow/
http://www.onera.fr/dtim-en/gpu-for-image/folkigpu.php
http://sourceforge.net/projects/open...ptical%20Flow/
http://nghiaho.com/?page_id=189
http://plyer.fr/aurelien/?p=124
http://varflow.sourceforge.net/
http://perception.inrialpes.fr/~chari/myweb/Software/
Here's the "official" Optical Flow benchmark site. It seems that there are rather large differences between different Optical Flow algorithms:
http://vision.middlebury.edu/flow/ev...results-i1.php
Interesting approaches would also be to compare motion vectors between consecutive frames and only use those which are comparable. That should nicely sort out erratic motion vectors. Finally, how are you filling the occluded space? If you check motion vectors to the next "future" frame, too, you could eventually fill the occluded space from the future frame. That might help removing many artifacts.
Just shooting from my hip here, haven't really done any motion estimation programming myself yet. Just some brainstorming from what I've read...
48fps, 60fps, framedoubling, interframe, smooth motion
