9th May 2010, 17:31 | #8141 | Link |
Ch3vr0n : Wrong, The Dark Knight is all in HD except for the PiP content that is not concerned by this setting. Batman Begins is an older release with most of his bonuses coming from the DVD release. Transforming an old 29,97fps SD content to 59.94fps 720p is not a neutral process. It can give good result, and it can fail! Beyond that, you shouldn't compare 2 different releases, even if it's the same bat guy who plays on it! About the Audio, you should try, to see if it comes from the HD track.
9th May 2010, 19:30 | #8145 | Link |
Hi jdobbs,
First I would like to say "thank you" for this excellent program! I've already made many successfully re-encoding, but this failed: 8.48.43] BD Rebuilder v0.33.06 (beta) - Source: SHERLOCK_HOLMES - Input BD size: 26,26 GB - Approximate total content: [02:08:24.738] - Target BD size: 7,72 GB - Windows Version: 5.1 [2600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [18.48.46] PHASE ONE, Encoding - [18.48.46] Extracting A/V streams [VID_00155] - [19.08.22] Reencoding: VID_00155 (1 of 23) - [19.08.22] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 1.645 frames - Bitrate: 7.076 Kbs - [19.08.22] Reencoding: VID_00155, Pass 1 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.33.06 (beta) - Windows Version: 5.1 [2600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok [19.08.34] - Failed video encode, aborted May be you already knew the issue. Ciao |
9th May 2010, 21:54 | #8146 | Link |
@JohnnyB.Good
As you are probably aware, you don't have something set up properly to get this error, or another codec pack has priority over ffdshow. You should try to uninstall ffdshow, haali and avisynth. Make sure you also delete the Haali folder found in C:\Program Files\. Uninstall any other codec packs too. Reboot. Reinstall the ones from where you download BD-RB. Run ffdshow video decoder and encoder and set per jdobbs recommendation. |
10th May 2010, 05:39 | #8147 | Link |
Thank you for your reply. I've something set up umproperly. But, just before Sherlock, I made OK encoding of Up in the air. Is the set up sensitive to movie?
Here the Up in the air log: [20.08.36] BD Rebuilder v0.33.06 (beta) - Source: UP_IN_THE_AIR - Input BD size: 32,02 GB - Approximate total content: [01:49:20.554] - Target BD size: 7,72 GB - Windows Version: 5.1 [2600] - MOVIE-ONLY mode enabled - SHUTDOWN at completion enabled - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [20.08.40] PHASE ONE, Encoding - [20.08.40] Extracting A/V streams [VID_00001] - [20.59.00] Reencoding: VID_00001 (1 of 1) - [20.59.00] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 157.296 frames - Bitrate: 8.647 Kbs - [20.59.00] Reencoding: VID_00001, Pass 1 of 2 - [00.17.07] Reencoding: VID_00001, Pass 2 of 2 - [03.41.08] Video Encode complete - [03.41.08] Reencoding audio tracks (if req'd) - [03.47.15] Multiplexing M2TS [03.59.17]PHASE ONE complete [03.59.17]PHASE TWO - Rebuild Started - [03.59.17] Rebuilding AVCHD file Structure [04.15.36] - Encode and Rebuild complete - Computer SHUTDOWN initiated. |
10th May 2010, 20:51 | #8151 | Link | |
11th May 2010, 01:40 | #8152 | Link | |
[17:29:47] Reencoding: VID_00027 (9 of 17) - [17:29:47] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29,970fps, 25.595 frames - Convert: 1280x720, 59,940fps, 51.190 frames ... Now, I repeat, each release are different even if it's another Batman with the same format. I will not teach you anything in saying that not only Batman BD are encoded in VC-1. I already gave you a few differences between these two releases, I will give you another : The Dark Knight has no PiP. So if your movie don't launch somewhere, try to remove the PiP from the process in adding in the config file : PROCESS_SECONDARY=0 . You didn't have the PiP sound already? Let remove the image! However, in doing this, you should retrieve the main movie and have a stutter free playback on other players. My two cents it's a slight PiP compatibility issue!... Maybe... Maybe not... Who knows!... If it works, as IlPorcospino, I will make you a 1 cent rebate! Last edited by SoniG; 11th May 2010 at 01:45. |
11th May 2010, 01:46 | #8153 | Link |
K i'll try that and burn it to a blank bd-re. Don't want a coaster ^^ can be a couple days till i know if it works. Aint got a bd-player at home, only at my mom's where i visit every week. Ill keep you posted If you think so it may be related to the pip yes, cause its weird. In PDVD 10 i can display it fine but without audio (main movie audio plays) and in TMT3 its the exact opposite. The movie plays but with VERY jittery audio and not the main audio so i assume its the pip audio. Maybe thats the issue. I've backed up VC-1 discs before so that can't be the problem. I'll get back to you
11th May 2010, 18:58 | #8157 | Link |
Sorry to come here with a probably easy to answer question, but due to a lack of time for reading 408 pages I decided to post here the following:
What do I have to do (or set up program) when I just want to keep DTS Sound (not DTS-HD) without automatically get it recoded to AC3 ? This does not seem to work when the BD is already ripped completely to HDD and THEN using BDrebuilder to do a movie only backup. (??) I always get AC3 then... |
11th May 2010, 19:51 | #8159 | Link |
Yes, thank you, iSeries, this time I got DTS with the settings you described (since I needed complete output I used a custom size of 47.500) . I just was confused by the info-screen of BDrebuilder, which showed AC3=1 DTS=0 HD=1 . That looks like DTS is disabled or something...
Thanks agaín... btw. it could be helpful to have a BD50 option for output... |
11th May 2010, 20:14 | #8160 | Link |
Yes, sure, the original AC3 is 640kbps and the reencoded one has also 640kbps... As it's a movie only, I've just remuxed the BD-Rebuilder result changing the reencoded AC3 with the original track, it's easy, but quite annoying.
