23rd May 2015, 13:51 | #13541 | Link |
@Tsusai
I would just use this Code:
video=DirectShowSource("CrankMakeMKV-Segment-006.mkv",audio=false,fps=23.976)
23rd May 2015, 14:09 | #13542 | Link | |
Nevertheless there is bug in encoding client when you activate 25 fps -> 50 fps conversion for sure.
23rd May 2015, 19:11 | #13544 | Link | |
Clip: https://mega.co.nz/#!wp8UnLrY!OBK_0m...16F4OimpP-NyTA |
27th May 2015, 16:19 | #13545 | Link |
I´m using latest Ripbot 1.18.2 BETA. I´m from Germany, so I´m using destination filenames with Umlauts, like ä, ö, ü... When I chose a filename WITHOUT Umlaut (like test.mkv), everything is fine. But if I call the file test_ü.mkv, I get an error (see attachment)
This happens after encoding is done, right before muxing the files. When I close the message, the file will be created and everything is fine. |
27th May 2015, 16:33 | #13546 | Link |
Use external image service.
27th May 2015, 17:06 | #13547 | Link |
http://www.directupload.net/file/d/4...m83f58_jpg.htm
What I found out is, this error only occurs with two audio tracks. Same job, same source, just set second audio to "no audio", and no error message appears. Last edited by stasi; 27th May 2015 at 20:09. |
28th May 2015, 05:24 | #13548 | Link | |
Registered Loser
28th May 2015, 16:09 | #13549 | Link | |
National character was not correctly stored but this is another story...
28th May 2015, 17:11 | #13550 | Link |
Maybe it only happens on german Windows 7. Just kidding. I can reproduce the error by picking any AVI or MKV, set two audio tracks (BTW first audio is OPUS, second is AC3) and after encoding the error message appears.
2nd June 2015, 07:12 | #13551 | Link |
Hello - I picked up American Sniper, but am having some trouble running it through RipBot. When I play the m2ts file in Media Player Classic, it plays normally. It's the same in VideoLAN. VLC lets me pick the audio while MPC does not. When I got to set it up, RipBot for some reason chooses the closed caption audio track, instead of the movie audio no matter which audio I pick. I went to put it through tsMuxeR to take out the closed caption track and it sees both tracks in the Meta File, but if I rip the TRUE-HD audio out, RipBot says there's no audio, and if I take out the AC3 track, it still takes the closed caption track. Anyone seen this before or might offer a suggestion? Thanks for any help.
2nd June 2015, 18:06 | #13552 | Link |
v.1.18.2
Added: support for extra audio stream Added: support for 2 extra servers in encoding client (10 in total) Added: EncodingClient now saves encoding summary in \Chunks\DE_Log_passX.txt file Added: support for HEVC main 10 (x265 16bit) Added: 4K-UHD resize profile Fixed: "RichEdit line insertion error" (hopefully;) Updated: eac3to 3.29, FFmpeg 2015-06-02, MediaInfo 0.7.74, MKVToolnix 7.9.0, x264 r2538, x265 1.7.95
4th June 2015, 02:05 | #13557 | Link | |
Maybe next update, Atak may change things, he's added 2 extra, another 2 should be possible. |
4th June 2015, 10:18 | #13558 | Link |
Guys why do you need more servers?
Regarding layout. Do not forget that some people still work on 768p displays. In this case it is safer to increase form size horizontally than vertically.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 4th June 2015 at 10:24. |
4th June 2015, 12:08 | #13559 | Link | |
Knew you'd have a good explanation for the layout I guess the layout doesn't really matter too much, as once you've set up a batch/queue, and set it in motion, it looks after itself. |
4th June 2015, 16:08 | #13560 | Link |
@pingfr
I'm guessing that you are using 2-pass mode right? Take a look here http://forum.doom9.org/showthread.ph...83#post1722683 2-pass mode is not very well suited for DE. Shorter chunks (let's say 1 min) would only noticeably reduce quality.
