16th June 2015, 20:42 | #13601 | Link |
Atak,
So far it does NOT look promising. It is very, very slow as before on Pass 1. The initial start was fast but as it got further into it it started to slow down. Here is a link to a pdf I put together showing the encoding with the CPU usage of each machine as you requested before. Once the encoding is complete, if it does not crash first, I will post the logs and text files. https://dl.dropboxusercontent.com/u/...20Mohicans.pdf |
16th June 2015, 22:17 | #13602 | Link |
Atak,
The encoding was successful!! Really surprised as it did not start off very well. It took 02h:05m:47s to complete. Pass 1 usually hangs pretty high in the fps range and Pass 2 in the 6-12 fps range. Not sure why it was different but at least it worked. I will try a few other movies later for verification. Here are the log files for you to review just in case https://dl.dropboxusercontent.com/u/...ans2%20Log.zip Thank you so much for your help in getting this working. Your efforts in supporting this program are so appreciated!!!! |
17th June 2015, 10:11 | #13603 | Link |
17th June 2015, 10:41 | #13604 | Link |
viper
first pass is by default much faster than second because it only analyses footage for optimal bitrate distribution. Actual encoding is done in second pass hence much slower encoding speed.
17th June 2015, 15:37 | #13605 | Link | |
Using the above image, this shows PASS 1 as it was almost finished. Notice the RED boxes where the FPS is very low and the GREEN boxes showing the normal FPS range for PASS 1. In the past this would be the normal (GREEN) for PASS 1. Not sure why it would drop to 2 - 3 fps or even 9 fps on a read only. I will do another rip sometime today for additional comparison. I will also try version 1.18.1 just in case... Sorry if I am being a pest. Just trying to pass information... |
17th June 2015, 15:50 | #13606 | Link |
Ah SmartScreen. You got 2 things you can do. It's just like Win 7 when you download any file. It flags it from the Internet and just prompts you to make sure you know this. 1) When it prompts, you can click on More Info. It should give you a Run prompt 2) RT Click->Properties on the EXE. You might see an Unblock Button. Press it. You can do this on zip/7z/rar files as well prior to extraction so the extracted files aren't flagged from the Internet as well. |
17th June 2015, 18:58 | #13608 | Link |
I would like you to do the following things 1) Download process explorer https://technet.microsoft.com/en-us/.../bb896653.aspx 2) Run again encoding but this time show me cpu usage for avs2yuv.exe and x264.exe example I predict that low fps is due to low cpu usage caused by something wrong going with your router. Basically avs2yuv.exe is waiting too long for frames from main pc.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 17th June 2015 at 19:06. |
17th June 2015, 23:51 | #13609 | Link | |
Here is the info you requested... Last of the Mohicans Process Explorer Here is the same information 5 minutes later Hope that helps!!! |
18th June 2015, 12:03 | #13610 | Link |
Something tells me that your network is not working in 1000 Mbps but in slower 100 Mbps mode. Just take a look. According to http://www.blu-ray.com/movies/The-La...Blu-ray/10898/ this movie has average bitrate of 38 Mbps. If we subtract audio stream (DTSMA ~4 Mbps) and all subtitles we should get pure video stream bitrate of ~33 Mbps. Above image shows that your average encoding speed is 73 fps. So If we divide 73 fps by 24 (movie frame rate) we get ~3. 33 Mbps * 3 = 99 Mbps. To verify my theory you should do some simple copy test between PCs with some large file. If your copy speed is limited to ~12 MB/s then you have your answer why first pass is slow.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 18th June 2015 at 12:08. |
18th June 2015, 15:43 | #13611 | Link |
I'm playing around with this interesting tool for the first time.
Got a couple of questions: 1) Why is Sharpen used as default? I tried to remove it from the .ini completely but then I got an error when starting encode saying Sharpen values are incorrect. Changed it to 0.0 on .ini now, but I'm not sure if that disables it completely. 2) Seems like DSS is always the default decoder unless distributed encoding is used in which case the source is indexed by ffms2. Is there a way to choose between DSS and indexing for single pc encode? thanks in advance. Last edited by mini-moose; 18th June 2015 at 16:14. |
18th June 2015, 16:18 | #13612 | Link |
1) 0 = means disabled. (filter has nothing to do) I've added gentle sharpening because downscaled movie looks better (especially on my ancient PSP with screen 480x272)
2) If ain't broke don't fix it. That's my motto. DirectShowSource has been working well for all those years. It is ok if you do not need frame accurate seeking.
18th June 2015, 21:28 | #13614 | Link | |
Then I tried version 1.18.1 and I got 17 - 24 fps range. All was going great up to the end of PASS 1 until Ripbot either crashed of froze. I tried turning off the offending server but would not work. THe abort button did work and it started encoding the last chunk in PASS 1. It is continuing as I type at around 24 FPS. IF I had a network issue wouldn't I still get the same issue even in 1.18.1?? |
19th June 2015, 07:29 | #13615 | Link | |
X-51 PC LTPC PAUL-PC Hope this helps to answer this conundrum!!! |
19th June 2015, 10:30 | #13616 | Link |
My last idea. Copy x264 folder from 1.18.1 version to 1.18.3 (TOOLS/x264)
