Old 16th April 2010, 14:23   #7721  |  Link
Originally Posted by Moviewatcher666 View Post
Hey jdobbs,
I have made a BD25 Region A full backup of Monsters Vs Aliens. The audio on the PIP Secondary video is terribly out of sync. Is there anyway to fix this? Otherwise the rest of the disc plays perfectly.
I ran Inspect.exe and I have all the right versions of the encoding software and I am using BD Rebuilder .33.04.
Is this a bug in the program? Any help is greatly appreciated.
Thanks!
Moviewatcher666
I'll have to get it and run a test. If I can repeat it I can fix it.
Old 16th April 2010, 14:27   #7722  |  Link
Originally Posted by 8ternity View Post
I've try to put MIN_M2TS_SIZE=100 and it freezed in the same file.
I've try to put MIN_M2TS_SIZE=500 and it freeze at another file VID_00026....
Thank you!
What happens if you try to playback the AVS file with Media Player Classic or Windows Media Player?
Old 16th April 2010, 16:02   #7723  |  Link
8ternity
8ternity's Avatar
It play well with mpc the latest avs file, the one who not work for converting. It work if i set "play with ffdshow" use ffdshow for this time.
Properties of video played:
video: YV12 1920x1080 23.98fps [Avisynth video #1]
Old 16th April 2010, 20:18   #7724  |  Link
woodman
Just done a full backup of Tropic Thunder (BD25) and some of the extras files are not getting compressed enough, 3.5GB original to 3.3GB encoded approx, and also the 1GB files. The very small files get to about half their size, it’s happened on the Incredible Hulk to. The film is fine, apart from the file being smaller, just thought I’d report it; it leaves less room for the main film
- Windows Version: 5.1 [2600]
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter: Ok
- FFDSHOW: 3326, Ok
- FFDSHOW VC-1 set "disabled", WMP11, Ok
- BD Rebuilder v0.33.0.4, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
woodman is offline   Reply With Quote
Old 16th April 2010, 20:18   #7725  |  Link
Ch3vr0n
As for the 23.976 source... check and see if the original used pulldown. If BD-RB shows a "*" in the stream listing, that is an indicator that the source was actually 29.97 as a result of pulldown.
What if there's 2 *'s next to the stream ? I've got a VC-1 disc where multiple streams are
1080i, 29.97fps**
just a question though.
Old 16th April 2010, 20:53   #7726  |  Link
Zot
problems encoding "Motherhood"
I'm using BD Rebuilder 0.33.04. Inspect.exe shows all OK. Source is "Motherhood" which shows up as MPEG-4 (AVC), 1080i, 29.97fps.
I've tried to encode with and without forcing deinterlace, but the output seems jerky whenever they pan across a scene. Images seem like they are ghosting or doubling during motion. Static scenes play OK, just scenes that pan across the screen seem off. THis is true if output is played on my PC or my LG370 BD Player. When playing original BD I don't have this problem.
Any ideas?
Much thanks,
Z
Here's the INF file:
[Status]
LABEL=MOTHERHOOD
VERSION=v0.33.04 (beta)
SOURCE_SIZE=17816524800
SOURCE_VIDEO_SIZE=17816524800
TARGET_SIZE=4581228544
REDUCTION=.257133677606982
RESIZE_1080=0
AUDIO_TO_KEEP=eng;hun;
SUBS_TO_KEEP=eng;hun;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00005]
AUDIO=100
PGS=10
M2TS_TARGET=4581228544
RATE=5812
NSIZE=4091873280
FLINK=0
MLINK=0
Zot is offline   Reply With Quote
Old 16th April 2010, 22:50   #7727  |  Link
Capsbackup
Originally Posted by Zot View Post
I experienced this too. You might check to see if BD-RB chose the correct field order. Open the .avs script created by BD-RB for the .m2ts file of the main movie with notepad.)
ex:
AssumeFieldBased().AssumeTFF() or it may say AssumeBFF().
Then open the .m2ts file with dgavcdec, select preview, and see what it says the field order is.
Old 16th April 2010, 23:14   #7728  |  Link
DK
DK's Avatar
me too with for example "A Frozen Flower/Blood & Flowers"
Old 16th April 2010, 23:23   #7729  |  Link
setarip_old
setarip_old's Avatar
@jdobbs
Does the conversation in the following post (37722) mean that you solved the DTS Express (or is it Express DTS) quandary?
http://forum.doom9.org/showpost.php?...postcount=7722
Old 17th April 2010, 00:06   #7730  |  Link
Ch3vr0n
That would definately be nice if DTS-E was able to be decoded. I'd be able to backup my Fast & Furious BD boxset then. They all contain DTS-E
Old 17th April 2010, 00:16   #7731  |  Link
Zot
ex:
OK - Here's what I got. the MBAFF is throwing me?
Thank you for your help, BTW!
Inspect:
- Windows Version: 6.1 [7600]
- FFDSHOW: 3326, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
AVS File:
#Created by BD Rebuilder - v0.33.04 (beta)
DirectshowSource("Y:\BLURAY\MOTHERHOOD\BDMV\STREAM\00005.m2ts", fps=29.97, framecount=160542, audio=false)
ConvertToYV12()
LoadPlugin("F:\Installed ABITP35 WIN7\bd rebuilder\BD_Rebuilder\tools\decomb521.dll")
FieldDeinterlace()
ConvertToYV12().AssumeFPS(30000,1001)
DGAVCDEC:
Stream Type: Transport [192]
Profile: High
Level: 4.1
Frame Size: 1920x1080
SAR: 1:1
Display Size: 1920x1080
Frame Rate: 29.970030 fps
Colorimetry: BT.709 [1]
Frame Structure: MBAFF
Frame Type: not yet
Coded Number: 371
Playback Number: 371
Frame Repeats: 0
Field Repeats: 0
Bitrate: 18.748
Bitrate (Avg): 19.100
Bitrate (Max): 23.099
Audio Stream: 1100: DTS HDMA C+L+R+SL+SR 48 1536
Audio Stream: 1101: AC3 3/2 48 448
Audio Stream: 1102: AC3 2/0 48 192
Elapsed: 0:00:23
Remain: 3:04:43
FPS: 16.24
Info:
Old 17th April 2010, 00:52   #7732  |  Link
1080i, 29.97fps**
That means it is a field based interlaced source.
Old 17th April 2010, 00:54   #7733  |  Link
@jdobbs
Does the conversation in the following post (37722) mean that you solved the DTS Express (or is it Express DTS) quanndary?
No. I just assume his source is DD. I'm going to start working on the DTS Express issue next week. Not sure if I can fix it without support from TSMUXER -- but I'll give it a shot.
Old 17th April 2010, 00:57   #7734  |  Link
- FFDSHOW: 3326, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
I assume you have "Quick Code for Extras" selected. Since it uses a fixed CRF for different output sizes, it can randomly happen that way... the only alternative is to deselect it.
Old 17th April 2010, 01:37   #7735  |  Link
8ternity
8ternity's Avatar
About my issue jdobbs?
Old 17th April 2010, 01:50   #7736  |  Link
setarip_old
@jdobbs
Sorry, my mistake. I thought ALL PIP audio was DTS Express...
Old 17th April 2010, 02:48   #7737  |  Link
Moviewatcher666
@jdobbs
setarip_old
Monsters Vs Aliens uses AC3 for the secondary audio not DTS Express. I think that this movie is one for the few the does use AC3 for secondary audio on PIP video.
Jdobbs
Your assumption is correct. Sorry...should have mentioned that it was DD (AC3)
Moviewatcher666 is offline   Reply With Quote
Old 17th April 2010, 03:15   #7738  |  Link
setarip_old
Menu audio not looping on standalone
Hopefully someone already has an answer for this, because I failed to save he logs:
I recently made full disc BD-RB backups on DVD-9s of "Indiana Jones and the Kingdom of the Crystal Skull" and "Sleeping Beauty - 50th Anniversary".
Both burned discs play perfectly under Power DVD v.7.3, with menu background music looping until selections are made.
However, with each of the two, when played on a SONY BDP-S360, the menu background music ceases after approximately halfway through the first loop.
Somewhat surprisingly, everything else about these two discs continues to play perfectly - main movie, extras, options, etc. with all controls totally functional.
Your ideas will be appreciated.
Old 17th April 2010, 04:10   #7739  |  Link
Capsbackup
@setarip_old;
I believe this is due to DVD media and AVCHD, it's apparently not very consistent. If you burned that very same creation onto a BD-RE, I am quite sure you would find it works perfectly.
I have had this happen to me randomly, some work perfectly and some don't. Most always the movie plays fine though, with the occasional audio not heard on the main movie but works for all the trailesrs and extras.
Old 17th April 2010, 04:25   #7740  |  Link
Capsbackup
I checked my region A version of this disc, and I receive the same log.
You could try changing the field order to BFF, run it manually to BD5 size and burn to DVD+RW and test to see if it's OK.
Found this post, but I'm not sure what to make of it.
http://forum.doom9.org/showthread.php?t=142427
EDIT:
Zot, you could try and run ReStream on the file to change the field order without reencoding. It does work with .ts files, but I am not sure about .m2ts or .264 files, but tsMuxeR can convert it for you, and this would be quicker than reencoding. If you burn to RW media and test on your standalone, you can confirm if this was the problem.
