Old 1st September 2015, 10:00   #32701  |  Link
chros
chros's Avatar
Originally Posted by phate89 View Post
Hi. I'm looking to madvr profiling. Does exist a switch that allow to enable a profile if the laptop is running with ac plugged or battery? I'd like to set a lighter profile when I'm running on battery only.
Not in an automated way, as far as I know, but you can switch between them manually.
Old 1st September 2015, 10:09   #32702  |  Link
Akeno
Originally Posted by nghiabeo20 View Post
I tried this method, but it didn't work. Nothing like "Geforce GTX 960M" showed up. How do I make madvr use the 960M instead of HD4600?
(W10 64, newest driver for both GPU, Jinc3 & xbr).
Thanks in advance!
Two ways of doing this:
  1. Use the Nvidia inspector and change the MPC-HC profile settings to utilize the GPU
  2. or make a copy of the MPC-HC exe and rename it to something like MPC-HC graphics card and set that to use the GPU and as your default player.
Akeno is offline   Reply With Quote
Old 1st September 2015, 14:04   #32703  |  Link
x7007
Following this guide
http://forum.doom9.org/showpost.php?...ostcount=31986
Does it mean I need to select
Chroma Upscaling : super-xbr - Sharpness 100 - AR - SuperRes Filter / Default
image downscaling : Lanczos 3 Taps - AR
image doubling : not sure what to choose here
image upscaling : Jinc - AR
upscaling refinement : SuperRes / Default - 1 , 0.66 Rfine the image after every ~2x upscaling step
Is that correct / same as what madvr selected , is that how you enable SuperRes or there is other way ? Do I need to select upscaling refinement after selecting it in chroma upscaling ?
x7007 is offline   Reply With Quote
Old 1st September 2015, 14:23   #32704  |  Link
superres should be used only once so select "refine the image only once after upscaling is complete"
Old 1st September 2015, 15:54   #32705  |  Link
x7007
So I only select SuperRes from Chroma Upscaling and not touching the upscaling refinement ? what it is for ?
Old 1st September 2015, 17:15   #32706  |  Link
chroma is for chroma and image is for image so you can use both if you see the difference.
but upscale refinement and superres shouldn't be used with every 2x.
Old 1st September 2015, 17:47   #32707  |  Link
Akeno
You can also use this chart as a sort of guide. As for what you need to select, that depends on both your hardware's abilities and your eyes. Image doubling doubles the image size using whatever algorithm you select there. As a rule of thumb, people are much more sensitive to the luma channel than the chroma channel so the majority of madVR users put their processing power into image scaling.
Old 2nd September 2015, 03:19   #32708  |  Link
nghiabeo20
does it force 960M to decode and render the film? or just decode? thanks!
nghiabeo20 is offline   Reply With Quote
Old 2nd September 2015, 04:25   #32709  |  Link
Akeno
Decoding is done by whatever you have designated. MPC-HC will automatically use its internal LAV Filters if you haven't specified another one. madVR has no decoding capabilities as it is purely a video renderer.
Old 2nd September 2015, 06:57   #32710  |  Link
x7007
So selecting Refine the image only once after upscaling is complete would be preferred ?
The question is can I select Chroma Upscaling SuperRes and Select Upscaling refinement SuperRes .
from the post I read super-xbr + SuperRes has better quality than Jinc tap 3. that what Madshi said at least
Old 2nd September 2015, 08:57   #32711  |  Link
Akeno
You can select both if you prefer and if your GPU can handle running both. Development of SuperRes is being concentrated on upscaling refinement at the moment as that produces the most visible differences. This means that the SuperRes filter in Chroma and Upscaling Refinement are similar but not the same due to more tweaks made towards the latter.
Old 2nd September 2015, 10:36   #32712  |  Link
chros
chros's Avatar
As Akeno said, for me both decoding and rendering is done by nvidia in this way.
Old 2nd September 2015, 13:47   #32713  |  Link
amayra
Quality Checker
amayra's Avatar
did i missed the reason you can't use 353.49 needi3 work with these driver under win10
upgrade to windows 10 worst decision ever
I love Doom9
Old 2nd September 2015, 14:39   #32714  |  Link
this is an nvidia issue not windows 10. keep on track plz not everyone is ignoring new features.
Old 2nd September 2015, 15:31   #32715  |  Link
XMonarchY
Is madshi resting/on vacation with red pandas or coding for new madVR? I don't have a problem with either!
BTW, NVidia stated that it was simply the first company to remove D3D9 - OpenCL support from their drivers due to its age and rare cases when it is used, especially in Windows 10. Supposedly both AMD and Intel will drop support for this interop sooner or later. Then again, NVidia hasn't made the best decision in recent past - lack of Async shader support in DirectX 12, overall poor/glitchy drivers (aside from D3D9 - OpenCL interop), and of course lack of the needed OpenCL interop is drivers past 353.49 Hotfix release... AMD may become the next Home Theater and gaming ruler!
Old 2nd September 2015, 20:31   #32716  |  Link
Akeno
People need to stop assuming that Nvidia is purposely gimping their drivers. They're doing what's best for business and what's best is reflected in what the market needs or wants. D3D9 <-> OpenCL interop fits neither of those criteria outside of specific cases like with madVR. If you want to complain about Windows 10 and Nvidia, do so in a different thread instead of clogging up a madVR discussion and testing thread.
Old 2nd September 2015, 21:07   #32717  |  Link
Kranium
I'm Confused
Kranium's Avatar
I was playing around with my MadVR settings last night and a few questions have popped up.
When I play any 29-30fps video in FSE I get something like 10+ repeated frames per second. I lowered upscaling settings a lot with these files and it didn't change anything. I just realized I didn't play with Smooth Motion settings though. Any other ideas why this would be? When I run the same files windowed at the desktop's 60Hz setting I do not get these repeated frames.
Second question. I reached a "desired" upscaling setting that has 39-41ms rendering times on fairly high bitrate 720p -> 1080p conversions. I had read that you want to keep these a bit lower, but if I'm not getting any reports of dropped or repeated frames should it be ok? Or is there another downside I am not thinking of.
Thanks for the help in advance
*Edit: This is Win10 with 353.49 drivers.
HTPC/NAS: i7-4770 - GTX970 - 16GB RAM - 512GB SSD RAID 0 - 16TB HDD - mITX
Kranium is offline   Reply With Quote
Old 2nd September 2015, 21:17   #32718  |  Link
zvans18
zvans18's Avatar
Originally Posted by iinversion View Post
When I close Precision X everything works fine. Other overclocking programs like MSI Afterburner or Asus GPU Tweak do not have this issue.
FWIW precision made a bunch of games stop working correctly for me, something is definitely wrong with some part of it
Windows 10 // i7-8700k + GTX 1080 SLI // MPC-BE x64 + LAV + XySubFilter
zvans18 is offline   Reply With Quote
Old 2nd September 2015, 22:06   #32719  |  Link
a screen from the OSD could help.
that fine as it is.
Old 2nd September 2015, 23:39   #32720  |  Link
I share the same sentiment. Like I've said before, downgrade your driver and wait for madshi to fix it.
