1st January 2014, 11:29 | #3741 | Link | |
It just said the folder tools\avs was not found and MeGui couldn't continue. Really weird stuff. I have UAC off and use portable Megui on other disk.
Actually, why didn't I just post the log? Quote:
1st January 2014, 12:52 | #3742 | Link |
And I also have small feature request: in HD streams extractor, can you make the window resizeable "inside"? I can't find proper words to describe it, but the Feature part of the window is extremely small, only showing three lines, which is a bit annoying.
1st January 2014, 14:57 | #3745 | Link |
I pre-make AVS files with crop/resize and then load them in One Click Encoder. OCE is configured to "Keep Input Resolution (disable crop and resize)" and "Auto Crop" + "Anamorphic Output" disabled.
The import AVS created by OCE still adds global "MeGUI_darx/y" values. Any reason that's necessary ? Another thing I noticed in OCE: If the audio is set to be encoded, the video encode is written to .264, but if audio is set to mux only the output will be to .mkv. Again, wondering why. Last edited by mini-moose; 1st January 2014 at 15:19. |
1st January 2014, 20:55 | #3746 | Link |
I seem to be getting a lot of crashes with latest MeGUI build (2444).
--[Error] [1/01/2014 10:50:24 a.m.] An error occurred ---[Error] [1/01/2014 10:50:24 a.m.] Exception message: Attempted to read or write protected memory. This is often an indication that other memory is corrupt. ---[Error] [1/01/2014 10:50:24 a.m.] Stacktrace ----[NoImage] at MeGUI.AviSynthClip.dimzon_avs_getvframe(IntPtr avs, IntPtr buf, Int32 stride, Int32 frm) ----[NoImage] at MeGUI.AviSynthClip.ReadFrame(IntPtr addr, Int32 stride, Int32 frame) ----[NoImage] at MeGUI.AvsFile.AvsVideoReader.ReadFrameBitmap(Int32 position) ----[NoImage] at MeGUI.core.util.Autocrop.autocrop(IVideoReader reader) ----[NoImage] at MeGUI.core.util.Autocrop.autocrop(CropValues& cropValues, IVideoReader reader, Boolean signalAR, mod16Method cropMethod, modValue mValue) ----[NoImage] at MeGUI.OneClickPostProcessing.createAVSFile(String indexFile, String inputFile, Nullable`1 AR, Int32 desiredOutputWidth, Boolean signalAR, LogItem _log, AviSynthSettings avsSettings, Boolean autoDeint, VideoCodecSettings settings, Nullable`1& dar, Boolean autoCrop, Boolean keepInputResolution, Boolean useChaptersMarks) ----[NoImage] at MeGUI.OneClickPostProcessing.StartPostProcessing() Code:
---[Error] [2/01/2014 4:30:32 a.m.] Error parsing media file J:\TMP\5bjlsbut.j3k\FRINGE_SEASON_4_DISC_2_t03_Video.264 ----[NoImage] Index was out of range. Must be non-negative and less than the size of the collection. ----[NoImage] Parameter name: index Code:
--[Error] [2/01/2014 4:33:06 a.m.] Exception message ----[NoImage] GetFrameBuffer: Returned a VFB with a 0 data pointer! ----[NoImage] size=6220864, max=536870912, used=15552192 ----[NoImage] I think we have run out of memory folks! ---[Error] [2/01/2014 4:33:06 a.m.] Stacktrace ----[NoImage] at MeGUI.AviSynthClip.ReadFrame(IntPtr addr, Int32 stride, Int32 frame) ----[NoImage] at MeGUI.AvsFile.AvsVideoReader.ReadFrameBitmap(Int32 position) ----[NoImage] at MeGUI.core.util.Autocrop.autocrop(IVideoReader reader) ----[NoImage] at MeGUI.core.util.Autocrop.autocrop(CropValues& cropValues, IVideoReader reader, Boolean signalAR, mod16Method cropMethod, modValue mValue) ----[NoImage] at MeGUI.OneClickPostProcessing.createAVSFile(String indexFile, String inputFile, Nullable`1 AR, Int32 desiredOutputWidth, Boolean signalAR, LogItem _log, AviSynthSettings avsSettings, Boolean autoDeint, VideoCodecSettings settings, Nullable`1& dar, Boolean autoCrop, Boolean keepInputResolution, Boolean useChaptersMarks) ----[NoImage] at MeGUI.OneClickPostProcessing.StartPostProcessing() ---[Error] [2/01/2014 4:33:06 a.m.] Inner exception: null looks like FFMS2.dll is causing the crash Code:
Faulting application name: MeGUI.exe, version: 1.0.2444.0, time stamp: 0x52c2cd79 Faulting module name: ffms2.dll, version: 2.19.0.0, time stamp: 0x52b520a2 Exception code: 0x40000015 Fault offset: 0x00646438 Faulting process id: 0x13c4 Faulting application start time: 0x01cf067162c16ca2 Faulting application path: D:\MEGUI\MeGUI.exe Faulting module path: D:\MEGUI\tools\ffms\ffms2.dll Report Id: 50eb2342-731e-11e3-8269-bc5ff43694e1 Faulting package full name: Faulting package-relative application ID: EDIT: I have switched FFMS2.dll with the 2.18 RC1 build on the ffmpegsource website and first error doesn't occur any more.
A Man Eating Duck Last edited by AMED; 1st January 2014 at 21:19. |
2nd January 2014, 01:12 | #3748 | Link | |
2nd January 2014, 04:00 | #3749 | Link |
Hi Zathor,
I'm running through the encodes again but using FFMS2 2.18 RC1. This error hasn't been triggered as of yet with this build of FFMS2. EDIT I forgot to mention what version of FFMS2 caused the crashes, r809+35.
A Man Eating Duck Last edited by AMED; 2nd January 2014 at 04:43. |
2nd January 2014, 11:25 | #3751 | Link |
There was just a discussion about a differently named init routine, maybe that's related?
2nd January 2014, 12:39 | #3752 | Link | |
Aspect ratio: Custom pixel shape (34104:34105 = 0.999971). with --sar 1:1 it would be Square Pixels. and mediainfo reports: Display aspect ratio : 16:9 Original display aspect ratio : 16:9 the mediainfo double DAR report also happens with --sar 1:1 sometimes. I think it might have something to do with mod2. For example I get it with if I use 718x404 but not with 716x404. I guess this isn't much of a concern but the custom pixel shape is somewhat. Last edited by mini-moose; 2nd January 2014 at 13:06. |
2nd January 2014, 20:04 | #3757 | Link |
2 logs attached (renamed the extension to .txt cause .log wasn't getting accepted).
one with sar in x264, one without. added the relevant parts from avinaptic/mediainfo at the end of the logs. Last edited by mini-moose; 2nd January 2014 at 20:11. |
2nd January 2014, 21:36 | #3758 | Link |
kalehrl: no x264 profiles are beeing pushed out. Maybe you had those profiles still cached in your update_cache folder? You should avoid to use them.
mini-moose: thanks for the logs. no time yet to check them, because Code:
2449 [Update] show the lsmash package in the updater 2448 [LSMASH Indexer] added LSMASHVideoSource/LWLibavVideoSource support as no indexer is available no progress during "indexing" is available also the cache file must be created in the same directory as the source file [Audio Encoder] added LSMASHAudioSource/LWLibavAudioSource support 2447 [Update] fixed a regression in 2446 2446 [Update] removed "Platform" column added "Last Used" column sort based on first column internal optimizations Last edited by Zathor; 2nd January 2014 at 21:47. |
