25th June 2015, 16:27 | #4541 | Link | |
MeGUI avs ffmpeg x264 x264_10b x265 xvid_encraw Along with copies of DeviL.dll. So I told MeGUI to switch to the "installed" Avisynth and restarted it. That gets MeGUI to delete all the avisynth.dll and DeviL.dll copies. Then I replaced all the files in the avs folder, told MeGUI to use the portable Avisynth and restarted it again. When it restarted it copied the new files back to the appropriate locations. I don't know if switching between Avisynth versions was necessary. Chances are MeGUI would replace the copies with the newer files when it starts anyway, but it might be worth checking they're all the same. So far so good (not that I've done much testing yet). |
25th June 2015, 18:54 | #4542 | Link |
I have never enabled the option to always use the included Avisynth (nor installed the stand alone version) but when i did enable it so did avisynth.dll and DeviL.dll copies pop up here and there. So it seems like if u dont have AviSynth installed so do MeGUI use the portable one that comes with it, without any questions.......
26th June 2015, 13:55 | #4544 | Link |
Report in the German doom9/Gleitz board:
When MeGUI creates an Xvid AVI "immediately" (e.g. in the Main window, loading an AVS, selecting Xvid as encoder, and queuing a job), it is now split into 2 jobs, so that xvid_encraw creates a raw ASP stream (*.m4v), and ffmpeg multiplexes it to an AVI. This multiplex uses the FourCCs "FMP4" as VfW and DShow flags, instead of "xvid" (VfW, right after "vids" chunk) and "XVID" (DShow). Especially consumer players supporting Xvid may not recognize the FourCC "FMP4". I hope it will be possible to enforce the Xvid FourCCs during the ffmpeg multiplex. |
27th June 2015, 19:08 | #4548 | Link |
@ Kurtnoise:
MeGUI executes xvid_encraw to encode raw MPEG4-ASP first (*.m4v), then calls ffmpeg only to multiplex it: Code:
"ProgramFiles\MeGUI\tools\ffmpeg\ffmpeg.exe" -y -i "*.m4v" -vcodec copy -vtag XVID -r fps "*.avi" __ People in ffmpeg related IRC channels recommend filing an issue on trac. Last edited by LigH; 27th June 2015 at 19:31. |
27th June 2015, 19:12 | #4549 | Link |
As written in the german forum this is a bug of FFmpeg 2.7+
FFmpeg 2.5.2 wrote the tag correctly. 2.7 and above seems to ignore the vtag option for AVI containers (not for MKV). If anyone has the time to report this bug (feature?) in the FFmpeg ticket tool please feel free to do so. |
29th June 2015, 09:39 | #4552 | Link |
After Avisynth+ was upgraded to r1825 my encodings wont end because of lack of RAM error message after some hours.
There is nothing special in my script, just some deinterlacing: Code:
global MeGUI_darx = 93 global MeGUI_dary = 68 AVISource("x.avi") QTGMC(Denoiser="dfttest", Preset="Placebo", EdiMode="NNEDI3", EdiThreads=8, Sharpness=1.0) Reverting back to r1576 solves the problem for me. |
29th June 2015, 09:50 | #4553 | Link |
This may be because r1825 is an MT build which possibly does memory management in a different way, even if you did not explicitly enable multithreading for the whole filter sequence. Some issues are already known, the high complexity of QTGMC provokes failures easily.
Try some more conservative options. Espoecially EdiThreads=8 appears way too much to me. And the preset "placebo" has this name for a good reason, I bet: You only believe it does good... At least this is definitely not caused by MeGUI as a user interface for calling a conversion script. |
29th June 2015, 10:01 | #4554 | Link |
I already made some tests in past, because r1825 is already out for some days and my encoding also broke with "tempgaussmc_beta2(edimode="nnedi3")".
I just wonder when issues are known why it was published by MeGUI. My placebo encodings looks great (and the other settings also will) |
29th June 2015, 10:30 | #4556 | Link |
And you are absolutly right (Grüße übrigens auch aus Deutschland).
I read about the settings which preset for which source will make sense. But I don't want sit with a magnifier next to my monitor to count pixels just to see, that there is no difference... or maybe there is? No... yes, um... so I made an easy choice and just take the "best" setting and don't risk some quality disadvantages. For encoding I can spend time and placebo is not that insane slow on SD sources. It makes sense for decoding when performance is important. (Just my OT thoughts.) |
30th June 2015, 22:08 | #4557 | Link |
I'm seeing a filename issue with MeGUI 2561 and OCE. The file is called Mukōzuke.mkv and when ever it's processed by the oneclick step it errors. If I rename it to Mukozuke.mkv, OCE works fine.
To reproduce this error just name any working mkv to Mukōzuke.mkv and then run through OCE. Code:
[Error] [1/07/2015 9:06:05 a.m.] An error occurred -[Error] [1/07/2015 9:06:05 a.m.] Exception message: FFVideoSource: Can't open 'D:\MeGUI Test\Mukozuke.mkv' -[Error] [1/07/2015 9:06:05 a.m.] Stacktrace --[NoImage] at MeGUI.AviSynthClip..ctor(String func, String arg, AviSynthColorspace forceColorspace) --[NoImage] at MeGUI.AvsFile..ctor(String script, Boolean parse) --[NoImage] at MeGUI.ffmsFile..ctor(String fileName, String indexFile) --[NoImage] at MeGUI.OneClickPostProcessing.createAVSFile(String indexFile, String inputFile, Nullable`1 AR, Int32 desiredOutputWidth, Boolean signalAR, LogItem _log, AviSynthSettings avsSettings, Boolean autoDeint, VideoCodecSettings settings, Nullable`1& dar, Boolean autoCrop, Boolean keepInputResolution, Boolean useChaptersMarks) --[NoImage] at MeGUI.OneClickPostProcessing.StartPostProcessing() -[Error] [1/07/2015 9:06:05 a.m.] Inner exception: null Code:
[Information] Versions -[Information] [1/07/2015 9:01:18 a.m.] MeGUI: 2561 -[Information] [1/07/2015 9:01:18 a.m.] Operating System: Windows 8.1 Professional Edition x64 (6.3.0.9600) -[Information] [1/07/2015 9:01:18 a.m.] .NET Framework: 4.0 (4.0.0.0) -[Information] [1/07/2015 9:01:18 a.m.] .NET Framework: 4.5.1 (4.5.51641) -[Information] [1/07/2015 9:01:18 a.m.] AviSynth: 2.6.0.2 (25-05-2011) (inactive) -[Information] [1/07/2015 9:01:18 a.m.] AviSynth+ portable: 0.1 (23-03-2015) (active) -[Information] [1/07/2015 9:01:18 a.m.] AvisynthWrapper: (02-01-2009) -[Information] [1/07/2015 9:01:18 a.m.] Haali Matroska Splitter: 1.11.96.14 (03-03-2011) -[Information] [1/07/2015 9:01:18 a.m.] Haali DSS2: (03-03-2011) -[Information] [1/07/2015 9:01:18 a.m.] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008) -[Information] [1/07/2015 9:01:18 a.m.] MediaInfo: 0.7.74.0 (26-05-2015) -[Information] [1/07/2015 9:01:18 a.m.] MediaInfoWrapper: 0.7.61.0 (06-01-2013) -[Information] [1/07/2015 9:01:18 a.m.] MessageBoxExLib: 1.0.2218.28317 (19-12-2008) -[Information] [1/07/2015 9:01:18 a.m.] SevenZipSharp: 0.64.3890.29348 (02-01-2011) -[Information] [1/07/2015 9:01:18 a.m.] 7z: 9.20 (18-11-2010)
A Man Eating Duck Last edited by AMED; 30th June 2015 at 22:11. |
30th June 2015, 23:10 | #4558 | Link | |
So, in order to make this work you would have to save the script with CP1257 encoding and change your system locale to Baltic (Latvian or Lithuanian, for example). Not sure if it's worth the trouble...
Groucho's Avisynth Stuff |
1st July 2015, 07:06 | #4560 | Link | |
ffmpeg trac ticket #4682
